[geos-commits] r3272 - in trunk: capi include src
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Mar 24 13:54:38 EDT 2011
Author: mloskot
Date: 2011-03-24 10:54:38 -0700 (Thu, 24 Mar 2011)
New Revision: 3272
   trunk/capi/CMakeLists.txt
   trunk/include/CMakeLists.txt
   trunk/src/CMakeLists.txt
Added source_group properties to support source browsers in various IDEs
Modified: trunk/capi/CMakeLists.txt
--- trunk/capi/CMakeLists.txt	2011-03-16 22:29:35 UTC (rev 3271)
+++ trunk/capi/CMakeLists.txt	2011-03-24 17:54:38 UTC (rev 3272)
@@ -20,8 +20,10 @@
   geos_c.cpp
   geos_ts_c.cpp)
-add_library(geos_c SHARED ${geos_c_SOURCES})
+file(GLOB geos_capi_HEADERS ${CMAKE_BINARY_DIR}/capi/*.h) # fix source_group issue
+add_library(geos_c SHARED ${geos_c_SOURCES} ${geos_capi_HEADERS})
 target_link_libraries(geos_c geos)
 # TODO: Enable SOVERSION property
@@ -30,6 +32,10 @@
   VERSION ${CAPI_VERSION}
   CLEAN_DIRECT_OUTPUT 1)
+# Installation
 install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos_c.h
   DESTINATION include)
@@ -37,3 +43,9 @@
   RUNTIME DESTINATION bin
   LIBRARY DESTINATION lib
   ARCHIVE DESTINATION lib)
+# Group source files for IDE source explorers (e.g. Visual Studio)
+source_group("Header Files" FILES ${geos_capi_HEADERS})
\ No newline at end of file
Modified: trunk/include/CMakeLists.txt
--- trunk/include/CMakeLists.txt	2011-03-16 22:29:35 UTC (rev 3271)
+++ trunk/include/CMakeLists.txt	2011-03-24 17:54:38 UTC (rev 3272)
@@ -12,6 +12,12 @@
+#add_subdirectory(geos)
+# Install/Uninstall
 install(FILES geos.h
   DESTINATION include/geos)
@@ -26,4 +32,4 @@
   FILES_MATCHING
   PATTERN "*.h"
   PATTERN "*.inl"
-  PATTERN ".svn" EXCLUDE)
+  PATTERN ".svn" EXCLUDE)
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt	2011-03-16 22:29:35 UTC (rev 3271)
+++ trunk/src/CMakeLists.txt	2011-03-24 17:54:38 UTC (rev 3272)
@@ -13,9 +13,10 @@
 file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
+file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
-add_library(geos SHARED ${geos_SOURCES})
-add_library(geos-static STATIC ${geos_SOURCES})
+add_library(geos SHARED ${geos_SOURCES} ${geos_ALL_HEADERS})
+add_library(geos-static STATIC ${geos_SOURCES} ${geos_ALL_HEADERS})
 set_target_properties(geos
@@ -30,7 +31,110 @@
   PREFIX "lib"
+# Installation
 install(TARGETS geos geos-static
+file(GLOB top_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h)
+source_group("Header Files" FILES ${top_HEADERS})
+file(GLOB geos_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/*.h)
+source_group("Header Files\\geos" FILES ${geos_HEADERS})
+### geos/algorithm
+file(GLOB geos_algorithm_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/algorithm/*.h)
+source_group("Header Files\\geos\\algorithm" FILES ${geos_algorithm_HEADERS})
+file(GLOB geos_algorithm_distance_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/algorithm/distance/*.h)
+source_group("Header Files\\geos\\algorithm\\distance" FILES ${geos_algorithm_distance_HEADERS})
+file(GLOB geos_algorithm_locate_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/algorithm/locate/*.h)
+source_group("Header Files\\geos\\algorithm\\locate" FILES ${geos_algorithm_locate_HEADERS})
+### geos/geom
+file(GLOB geos_geom_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/geom/*.h)
+source_group("Header Files\\geos\\geom" FILES ${geos_geom_HEADERS})
+file(GLOB geos_geom_prep_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/geom/prep/*.h)
+source_group("Header Files\\geos\\geom\\prep" FILES ${geos_geom_prep_HEADERS})
+file(GLOB geos_geom_util_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/geom/util/*.h)
+source_group("Header Files\\geos\\geom\\util" FILES ${geos_geom_util_HEADERS})
+### geos/geomgraph
+file(GLOB geos_geomgraph_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/geomgraph/*.h)
+source_group("Header Files\\geos\\geomgraph" FILES ${geos_geomgraph_HEADERS})
+file(GLOB geos_geomgraph_index_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/geomgraph/index/*.h)
+source_group("Header Files\\geos\\geomgraph\\index" FILES ${geos_geomgraph_index_HEADERS})
+### geos/index
+file(GLOB geos_index_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/*.h)
+source_group("Header Files\\geos\\index" FILES ${geos_index_HEADERS})
+file(GLOB geos_index_bintree_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/bintree/*.h)
+source_group("Header Files\\geos\\index\\bintree" FILES ${geos_index_bintree_HEADERS})
+file(GLOB geos_index_chain_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/chain/*.h)
+source_group("Header Files\\geos\\index\\chain" FILES ${geos_index_chain_HEADERS})
+file(GLOB geos_index_intervalrtree_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/intervalrtree/*.h)
+source_group("Header Files\\geos\\index\\intervalrtree" FILES ${geos_index_intervalrtree_HEADERS})
+file(GLOB geos_index_quadtree_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/quadtree/*.h)
+source_group("Header Files\\geos\\index\\quadtree" FILES ${geos_index_quadtree_HEADERS})
+file(GLOB geos_index_strtree_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/strtree/*.h)
+source_group("Header Files\\geos\\index\\strtree" FILES ${geos_index_strtree_HEADERS})
+file(GLOB geos_index_sweepline_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/index/sweepline/*.h)
+source_group("Header Files\\geos\\index\\sweepline" FILES ${geos_index_sweepline_HEADERS})
+### geos/io
+file(GLOB geos_io_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/io/*.h)
+source_group("Header Files\\geos\\io" FILES ${geos_io_HEADERS})
+### geos/linearref
+file(GLOB geos_linearref_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/linearref/*.h)
+source_group("Header Files\\geos\\linearref" FILES ${geos_linearref_HEADERS})
+### geos/noding
+file(GLOB geos_noding_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/noding/*.h)
+source_group("Header Files\\geos\\noding" FILES ${geos_noding_HEADERS})
+file(GLOB geos_noding_snapround_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/noding/snapround/*.h)
+source_group("Header Files\\geos\\noding\\snapround" FILES ${geos_noding_snapround_HEADERS})
+### geos/operation
+file(GLOB geos_operation_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/*.h)
+source_group("Header Files\\geos\\operation" FILES ${geos_operation_HEADERS})
+file(GLOB geos_operation_buffer_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/buffer/*.h)
+source_group("Header Files\\geos\\operation\\buffer" FILES ${geos_operation_buffer_HEADERS})
+file(GLOB geos_operation_distance_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/distance/*.h)
+source_group("Header Files\\geos\\operation\\distance" FILES ${geos_operation_distance_HEADERS})
+file(GLOB geos_operation_linemerge_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/linemerge/*.h)
+source_group("Header Files\\geos\\operation\\linemerge" FILES ${geos_operation_linemerge_HEADERS})
+file(GLOB geos_operation_overlay_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/overlay/*.h)
+source_group("Header Files\\geos\\operation\\overlay" FILES ${geos_operation_overlay_HEADERS})
+file(GLOB geos_operation_overlay_snap_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/overlay/snap/*.h)
+source_group("Header Files\\geos\\operation\\overlay\\snap" FILES ${geos_operation_overlay_snap_HEADERS})
+file(GLOB geos_operation_overlay_validate_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/overlay/validate/*.h)
+source_group("Header Files\\geos\\operation\\overlay\\validate" FILES ${geos_operation_overlay_validate_HEADERS})
+file(GLOB geos_operation_polygonize_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/polygonize/*.h)
+source_group("Header Files\\geos\\operation\\polygonize" FILES ${geos_operation_polygonize_HEADERS})
+file(GLOB geos_operation_predicate_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/predicate/*.h)
+source_group("Header Files\\geos\\operation\\predicate" FILES ${geos_operation_predicate_HEADERS})
+file(GLOB geos_operation_relate_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/relate/*.h)
+source_group("Header Files\\geos\\operation\\relate" FILES ${geos_operation_relate_HEADERS})
+file(GLOB geos_operation_sharedpaths_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/sharedpaths/*.h)
+source_group("Header Files\\geos\\operation\\sharedpaths" FILES ${geos_operation_sharedpaths_HEADERS})
+file(GLOB geos_operation_union_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/union/*.h)
+source_group("Header Files\\geos\\operation\\union" FILES ${geos_operation_union_HEADERS})
+file(GLOB geos_operation_valid_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/operation/valid/*.h)
+source_group("Header Files\\geos\\operation\\valid" FILES ${geos_operation_valid_HEADERS})
+### geos/planargraph
+file(GLOB geos_planargraph_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/planargraph/*.h)
+source_group("Header Files\\geos\\planargraph" FILES ${geos_planargraph_HEADERS})
+file(GLOB geos_planargraph_algorithm_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/planargraph/algorithm/*.h)
+source_group("Header Files\\geos\\planargraph\\algorithm" FILES ${geos_planargraph_algorithm_HEADERS})
+### geso/precision
+file(GLOB geos_precision_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/precision/*.h)
+source_group("Header Files\\geos\\precision" FILES ${geos_precision_HEADERS})
+### geso/simplify
+file(GLOB geos_simplify_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/simplify/*.h)
+source_group("Header Files\\geos\\simplify" FILES ${geos_simplify_HEADERS})
+### geso/util
+file(GLOB geos_util_HEADERS ${CMAKE_SOURCE_DIR}/include/geos/util/*.h)
+source_group("Header Files\\geos\\util" FILES ${geos_util_HEADERS})
More information about the geos-commits mailing list
