[geos-commits] r3331 - trunk/src/geomgraph
svn_geos at osgeo.org
Fri May 6 14:51:38 EDT 2011
Author: strk
Date: 2011-05-06 11:51:37 -0700 (Fri, 06 May 2011)
New Revision: 3331
trunk/src/geomgraph/Edge.cpp
trunk/src/geomgraph/EdgeIntersection.cpp
trunk/src/geomgraph/EdgeIntersectionList.cpp
Make output operators for Edge, EdgeIntersection and EdgeIntersectionList closer to JTS, for easier comparison
Modified: trunk/src/geomgraph/Edge.cpp
--- trunk/src/geomgraph/Edge.cpp 2011-05-06 18:51:30 UTC (rev 3330)
+++ trunk/src/geomgraph/Edge.cpp 2011-05-06 18:51:37 UTC (rev 3331)
@@ -296,15 +296,15 @@
std::ostream&
operator<< (std::ostream&os, const Edge& e)
- os << "EDGE";
- if ( e.name != "" ) os << " name:" << e.name;
+ os << "edge";
+ if ( e.name != "" ) os << " " << e.name;
- os << " label:" << e.label->toString()
- << " depthDelta:" << e.depthDelta
- << ":" << std::endl
+ os
<< " LINESTRING"
- //<< *(e.pts);
- << e.pts->toString();
+ << *(e.pts)
+ << " " << e.label->toString()
+ << " " << e.depthDelta
return os;
Modified: trunk/src/geomgraph/EdgeIntersection.cpp
--- trunk/src/geomgraph/EdgeIntersection.cpp 2011-05-06 18:51:30 UTC (rev 3330)
+++ trunk/src/geomgraph/EdgeIntersection.cpp 2011-05-06 18:51:37 UTC (rev 3331)
@@ -73,7 +73,7 @@
std::ostream&
operator<< (std::ostream&os, const EdgeIntersection& e)
- os << e.coord << " seg#=" << e.segmentIndex << " dist=" << e.dist;
+ os << e.coord << " seg # = " << e.segmentIndex << " dist = " << e.dist;
return os;
Modified: trunk/src/geomgraph/EdgeIntersectionList.cpp
--- trunk/src/geomgraph/EdgeIntersectionList.cpp 2011-05-06 18:51:30 UTC (rev 3330)
+++ trunk/src/geomgraph/EdgeIntersectionList.cpp 2011-05-06 18:51:37 UTC (rev 3331)
@@ -188,7 +188,7 @@
std::ostream&
operator<< (std::ostream&os, const EdgeIntersectionList& e)
- os << "Intersections: ";
+ os << "Intersections:" << std::endl;
EdgeIntersectionList::const_iterator it=e.begin(), endIt=e.end();
for (; it!=endIt; ++it) {
EdgeIntersection *ei=*it;
More information about the geos-commits
