[geos-commits] r3333 - in trunk: include/geos/geomgraph
src/geomgraph
svn_geos at osgeo.org
Fri May 6 14:51:56 EDT 2011
Author: strk
Date: 2011-05-06 11:51:56 -0700 (Fri, 06 May 2011)
New Revision: 3333
Removed:
trunk/src/geomgraph/EdgeIntersection.cpp
trunk/include/geos/geomgraph/EdgeIntersection.h
trunk/src/geomgraph/Makefile.am
Turn EdgeIntersection into a concrete, fully-inlined, C++ class.
Modified: trunk/include/geos/geomgraph/EdgeIntersection.h
--- trunk/include/geos/geomgraph/EdgeIntersection.h 2011-05-06 18:51:46 UTC (rev 3332)
+++ trunk/include/geos/geomgraph/EdgeIntersection.h 2011-05-06 18:51:56 UTC (rev 3333)
@@ -1,10 +1,9 @@
- * $Id$
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2009-2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005-2006 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -24,19 +23,19 @@
#define GEOS_GEOMGRAPH_EDGEINTERSECTION_H
#include <geos/export.h>
-#include <string>
-#include <geos/geom/Coordinate.h> // for CoordinateLessThen
+#include <geos/geom/Coordinate.h> // for composition and inlines
#include <geos/inline.h>
+#include <ostream>
namespace geos {
namespace geomgraph { // geos.geomgraph
- * Represents a point on an
- * edge which intersects with another edge.
+ * Represents a point on an edge which intersects with another edge.
* The intersection may either be a single point, or a line segment
* (in which case this point is the start of the line segment)
@@ -49,62 +48,72 @@
// the point of intersection
geom::Coordinate coord;
+ // the edge distance of this point along the containing line segment
+ double dist;
// the index of the containing line segment in the parent edge
int segmentIndex;
- // the edge distance of this point along the containing line segment
- double dist;
EdgeIntersection(const geom::Coordinate& newCoord,
- int newSegmentIndex, double newDist);
+ int newSegmentIndex, double newDist)
+ coord(newCoord),
+ dist(newDist),
+ segmentIndex(newSegmentIndex)
- virtual ~EdgeIntersection();
+ bool isEndPoint(int maxSegmentIndex) const {
+ if (segmentIndex==0 && dist==0.0) return true;
+ if (segmentIndex==maxSegmentIndex) return true;
+ return false;
- * @return -1 this EdgeIntersection is located before the
- * argument location
- * @return 0 this EdgeIntersection is at the argument location
- * @return 1 this EdgeIntersection is located after the argument
- * location
- int compare(int newSegmentIndex, double newDist) const;
- bool isEndPoint(int maxSegmentIndex);
- std::string print() const;
- int compareTo(const EdgeIntersection *) const;
const geom::Coordinate& getCoordinate() const {
return coord;
int getSegmentIndex() const { return segmentIndex; }
- double getDistance() { return dist; }
+ double getDistance() const { return dist; }
+/// Strict weak ordering operator for EdgeIntersection
+/// This is the C++ equivalent of JTS's compareTo
+inline bool operator< (const EdgeIntersection& ei1, const EdgeIntersection& ei2)
+ if ( ei1.segmentIndex < ei2.segmentIndex ) return true;
+ if ( ei1.segmentIndex == ei2.segmentIndex )
+ if ( ei1.dist < ei2.dist ) return true;
+ // TODO: check if the Coordinate matches, or this will
+ // be a robustness issue in computin distance
+ // See http://trac.osgeo.org/geos/ticket/350
+ return false;
+// @deprecated, use strict weak ordering operator
struct GEOS_DLL EdgeIntersectionLessThen {
bool operator()(const EdgeIntersection *ei1,
const EdgeIntersection *ei2) const
- if ( ei1->segmentIndex<ei2->segmentIndex ||
- ( ei1->segmentIndex==ei2->segmentIndex &&
- ei1->dist<ei2->dist ) ) return true;
- return false;
+ return *ei1 < *ei2;
-std::ostream& operator<< (std::ostream&, const EdgeIntersection&);
+/// Output operator
+inline std::ostream& operator<< (std::ostream& os, const EdgeIntersection& e)
+ os << e.coord << " seg # = " << e.segmentIndex << " dist = " << e.dist;
+ return os;
} // namespace geos.geomgraph
} // namespace geos
-//#ifdef GEOS_INLINE
-//# include "geos/geomgraph/EdgeIntersection.inl"
-//#endif
#endif // ifndef GEOS_GEOMGRAPH_EDGEINTERSECTION_H
Deleted: trunk/src/geomgraph/EdgeIntersection.cpp
--- trunk/src/geomgraph/EdgeIntersection.cpp 2011-05-06 18:51:46 UTC (rev 3332)
+++ trunk/src/geomgraph/EdgeIntersection.cpp 2011-05-06 18:51:56 UTC (rev 3333)
@@ -1,89 +0,0 @@
- * $Id$
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: geomgraph/EdgeIntersection.java rev. 1.5 (JTS-1.10)
-#include <sstream>
-#include <string>
-#include <geos/geomgraph/EdgeIntersection.h>
-using namespace std;
-using namespace geos::geom;
-namespace geos {
-namespace geomgraph { // geos.geomgraph
-EdgeIntersection::EdgeIntersection(const Coordinate& newCoord,
- coord(newCoord),
- segmentIndex(newSegmentIndex),
- dist(newDist)
-EdgeIntersection::~EdgeIntersection()
-int
-EdgeIntersection::compare(int newSegmentIndex, double newDist) const
- if (segmentIndex<newSegmentIndex) return -1;
- if (segmentIndex>newSegmentIndex) return 1;
- if (dist<newDist) return -1;
- if (dist>newDist) return 1;
- return 0;
-bool
-EdgeIntersection::isEndPoint(int maxSegmentIndex)
- if (segmentIndex==0 && dist==0.0) return true;
- if (segmentIndex==maxSegmentIndex) return true;
- return false;
-string
-EdgeIntersection::print() const
- ostringstream s;
- s << *this;
- return s.str();
-std::ostream&
-operator<< (std::ostream&os, const EdgeIntersection& e)
- os << e.coord << " seg # = " << e.segmentIndex << " dist = " << e.dist;
- return os;
-int
-EdgeIntersection::compareTo(const EdgeIntersection *other) const
- return compare(other->segmentIndex, other->dist);
-} // namespace geos.geomgraph
Modified: trunk/src/geomgraph/Makefile.am
--- trunk/src/geomgraph/Makefile.am 2011-05-06 18:51:46 UTC (rev 3332)
+++ trunk/src/geomgraph/Makefile.am 2011-05-06 18:51:56 UTC (rev 3333)
@@ -15,7 +15,6 @@
Edge.cpp \
EdgeEnd.cpp \
EdgeEndStar.cpp \
- EdgeIntersection.cpp \
EdgeIntersectionList.cpp \
EdgeNodingValidator.cpp \
EdgeList.cpp \
More information about the geos-commits
