[geos-commits] r3341 - in trunk/tests/unit: . capi
svn_geos at osgeo.org
Tue May 10 07:11:54 EDT 2011
Author: strk
Date: 2011-05-10 04:11:54 -0700 (Tue, 10 May 2011)
New Revision: 3341
Added:
trunk/tests/unit/capi/GEOSIntersectsTest.cpp
trunk/tests/unit/Makefile.am
Add test for 357 (doesn't succeed at failing)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2011-05-10 09:51:31 UTC (rev 3340)
+++ trunk/tests/unit/Makefile.am 2011-05-10 11:11:54 UTC (rev 3341)
@@ -98,6 +98,7 @@
capi/GEOSGeomFromWKBTest.cpp \
capi/GEOSGeomToWKTTest.cpp \
capi/GEOSContainsTest.cpp \
+ capi/GEOSIntersectsTest.cpp \
capi/GEOSWithinTest.cpp \
capi/GEOSSimplifyTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
Added: trunk/tests/unit/capi/GEOSIntersectsTest.cpp
--- trunk/tests/unit/capi/GEOSIntersectsTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSIntersectsTest.cpp 2011-05-10 11:11:54 UTC (rev 3341)
@@ -0,0 +1,146 @@
+// $Id$
+// Test Suite for C-API GEOSIntersects
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeosintersects_data
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosintersects_data()
+ : geom1_(0), geom2_(0)
+ initGEOS(notice, notice);
+ ~test_capigeosintersects_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ geom1_ = 0;
+ geom2_ = 0;
+ finishGEOS();
+ typedef test_group<test_capigeosintersects_data> group;
+ typedef group::object object;
+ group test_capigeosintersects_group("capi::GEOSIntersects");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ ensure( 0 != geom1_ );
+ ensure( 0 != geom2_ );
+ char const r1 = GEOSIntersects(geom1_, geom2_);
+ ensure_equals(r1, 0);
+ char const r2 = GEOSIntersects(geom2_, geom1_);
+ ensure_equals(r2, 0);
+ template<>
+ template<>
+ void object::test<2>()
+ geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
+ geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+ ensure_equals(int(r1), 1);
+ ensure_equals(int(r2), 1);
+ template<>
+ template<>
+ void object::test<3>()
+ geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
+ geom2_ = GEOSGeomFromWKT("POLYGON((1 1,1 2,2 2,2 1,1 1))");
+ // This is a tef for bug #357
+ template<>
+ template<>
+ void object::test<4>()
+ GEOSCoordSequence* cs = GEOSCoordSeq_create(5, 2);
+ double nan = -0.0/0;
+ GEOSCoordSeq_setX(cs, 0, 1); GEOSCoordSeq_setY(cs, 0, 1);
+ for (unsigned int i=1; i<4; ++i) {
+ GEOSCoordSeq_setX(cs, i, nan);
+ GEOSCoordSeq_setY(cs, i, nan);
+ GEOSCoordSeq_setX(cs, 4, 1); GEOSCoordSeq_setY(cs, 4, 1);
+ geom1_ = GEOSGeom_createPolygon(
+ GEOSGeom_createLinearRing(cs),
+ NULL, 0);
+ char const r1 = GEOSIntersects(geom1_, geom1_);
+} // namespace tut
More information about the geos-commits
