[geos-commits] r3353 - in trunk: include/geos/geom/prep
src/geom/prep
svn_geos at osgeo.org
Thu May 12 02:13:39 EDT 2011
Author: strk
Date: 2011-05-11 23:13:39 -0700 (Wed, 11 May 2011)
New Revision: 3353
trunk/include/geos/geom/prep/PreparedLineStringIntersects.h
trunk/src/geom/prep/PreparedLineStringIntersects.cpp
Port info for PreparedLineStringIntersects, and avoid polluting the global namespace
Modified: trunk/include/geos/geom/prep/PreparedLineStringIntersects.h
--- trunk/include/geos/geom/prep/PreparedLineStringIntersects.h 2011-05-12 06:10:20 UTC (rev 3352)
+++ trunk/include/geos/geom/prep/PreparedLineStringIntersects.h 2011-05-12 06:13:39 UTC (rev 3353)
@@ -1,5 +1,4 @@
- * $Id$
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
@@ -14,7 +13,7 @@
- * Last port: geom/prep/PreparedLineStringIntersects.java rev 1.2 (JTS-1.10)
+ * Last port: geom/prep/PreparedLineStringIntersects.java r338 (JTS-1.12)
@@ -27,9 +26,6 @@
#include <geos/geom/Coordinate.h>
#include <geos/noding/SegmentStringUtil.h>
-using namespace geos::algorithm;
-using namespace geos::geom::util;
namespace geos {
namespace geom { // geos::geom
namespace prep { // geos::geom::prep
@@ -80,7 +76,6 @@
protected:
PreparedLineString & prepLine;
- //PreparedLineString * prepLine;
* Tests whether any representative point of the test Geometry intersects
@@ -91,25 +86,7 @@
* @return true if any point of the argument intersects the prepared geometry
bool isAnyTestPointInTarget(const geom::Geometry * testGeom) const;
- // * This could be optimized by using the segment index on the lineal target.
- // * However, it seems like the L/P case would be pretty rare in practice.
- // PointLocator * locator = new PointLocator();
- // geom::Coordinate::ConstVect coords;
- // ComponentCoordinateExtracter::getCoordinates( *testGeom, coords);
- // for (std::size_t i=0, n=coords.size(); i<n; i++)
- // geom::Coordinate c = *(coords[i]);
- // if ( locator->intersects( c, &(prepLine->getGeometry()) ))
- // return true;
- // return false;
// Declare type as noncopyable
PreparedLineStringIntersects(const PreparedLineStringIntersects& other);
PreparedLineStringIntersects& operator=(const PreparedLineStringIntersects& rhs);
@@ -120,7 +97,4 @@
} // namespace geos
#endif // GEOS_GEOM_PREP_PREPAREDLINESTRINGINTERSECTS_H
- * $Log$
Modified: trunk/src/geom/prep/PreparedLineStringIntersects.cpp
--- trunk/src/geom/prep/PreparedLineStringIntersects.cpp 2011-05-12 06:10:20 UTC (rev 3352)
+++ trunk/src/geom/prep/PreparedLineStringIntersects.cpp 2011-05-12 06:13:39 UTC (rev 3353)
@@ -1,5 +1,4 @@
- * $Id$
@@ -13,7 +12,7 @@
@@ -26,6 +25,9 @@
#include <geos/noding/FastSegmentSetIntersectionFinder.h>
+using namespace geos::algorithm;
+using namespace geos::geom::util;
namespace geos {
namespace geom { // geos.geom
namespace prep { // geos.geom.prep
@@ -91,7 +93,3 @@
} // namespace geos.geom
} // namespace geos
- * $Log$
More information about the geos-commits
