[geos-commits] r3360 - in trunk: src/algorithm tests/unit/capi
svn_geos at osgeo.org
Thu May 12 05:56:04 EDT 2011
Author: strk
Date: 2011-05-12 02:56:04 -0700 (Thu, 12 May 2011)
New Revision: 3360
trunk/src/algorithm/RobustDeterminant.cpp
trunk/tests/unit/capi/GEOSIntersectsTest.cpp
Have RobustDeterminant throw an IllegalArgument if passed any infinite or nan value. Fixes bug #357. Includes regress test.
Modified: trunk/src/algorithm/RobustDeterminant.cpp
--- trunk/src/algorithm/RobustDeterminant.cpp 2011-05-12 07:39:23 UTC (rev 3359)
+++ trunk/src/algorithm/RobustDeterminant.cpp 2011-05-12 09:56:04 UTC (rev 3360)
@@ -20,9 +20,12 @@
#include <geos/algorithm/RobustDeterminant.h>
+#include <geos/util/IllegalArgumentException.h>
#include <cmath>
+#include <geos/platform.h> // for ISNAN, FINITE
#ifdef _MSC_VER
#pragma warning(disable : 4127)
#endif
@@ -40,6 +43,15 @@
double k;
long count=0;
+ using std::isfinite;
+ // Protect against non-finite numbers
+ if ( ISNAN(x1) || ISNAN(y1) || ISNAN(x2) || ISNAN(y2) ||
+ !FINITE(x1) || !FINITE(y1) || !FINITE(x2) || !FINITE(y2) )
+ throw util::IllegalArgumentException("RobustDeterminant encountered non-finite numbers ");
* testing null entries
Modified: trunk/tests/unit/capi/GEOSIntersectsTest.cpp
--- trunk/tests/unit/capi/GEOSIntersectsTest.cpp 2011-05-12 07:39:23 UTC (rev 3359)
+++ trunk/tests/unit/capi/GEOSIntersectsTest.cpp 2011-05-12 09:56:04 UTC (rev 3360)
@@ -9,6 +9,7 @@
#include <cstdarg>
#include <cstdio>
#include <cstdlib>
+#include <cstring>
namespace tut
@@ -117,7 +118,7 @@
ensure_equals(int(r2), 1);
- // This is a tef for bug #357
+ // This is a test for bug #357 (GEOSIntersects with nan coords)
template<>
template<>
void object::test<4>()
@@ -132,15 +133,31 @@
GEOSCoordSeq_setX(cs, 4, 1); GEOSCoordSeq_setY(cs, 4, 1);
- geom1_ = GEOSGeom_createPolygon(
- GEOSGeom_createLinearRing(cs),
- NULL, 0);
+ geom1_ = GEOSGeom_createPolygon(GEOSGeom_createLinearRing(cs),
+ NULL, 0);
char const r1 = GEOSIntersects(geom1_, geom1_);
- ensure_equals(int(r1), 1);
+ ensure_equals(int(r1), 2);
+ // This is a test for bug #357 (GEOSIntersects with inf coords)
+ template<>
+ template<>
+ void object::test<5>()
+ const char *hex = "0103000020E61000000100000005000000737979F3DDCC2CC0F92154F9E7534540000000000000F07F000000000000F07F8F806E993F7E55C0304B29FFEA8554400634E8D1DD424540B5FEE6A37FCD4540737979F3DDCC2CC0F92154F9E7534540";
+ geom1_ = GEOSGeomFromHEX_buf((unsigned char*)hex, std::strlen(hex));
+ ensure( 0 != geom1_ );
+ char const r1 = GEOSIntersects(geom1_, geom1_);
} // namespace tut
More information about the geos-commits
