[geos-commits] r3362 - trunk/src/algorithm
svn_geos at osgeo.org
Fri May 13 11:53:16 EDT 2011
Author: mloskot
Date: 2011-05-13 08:53:16 -0700 (Fri, 13 May 2011)
New Revision: 3362
trunk/src/algorithm/RobustDeterminant.cpp
Removed std::isfinite as possibly non-existing on some platforms - rather fix platform.h if needed.
Modified: trunk/src/algorithm/RobustDeterminant.cpp
--- trunk/src/algorithm/RobustDeterminant.cpp 2011-05-12 10:11:13 UTC (rev 3361)
+++ trunk/src/algorithm/RobustDeterminant.cpp 2011-05-13 15:53:16 UTC (rev 3362)
@@ -43,8 +43,6 @@
double k;
long count=0;
- using std::isfinite;
// Protect against non-finite numbers
if ( ISNAN(x1) || ISNAN(y1) || ISNAN(x2) || ISNAN(y2) ||
!FINITE(x1) || !FINITE(y1) || !FINITE(x2) || !FINITE(y2) )
More information about the geos-commits
