[geos-commits] r3367 - in trunk: include/geos/geom src/geom
svn_geos at osgeo.org
Tue May 17 12:50:03 EDT 2011
Author: strk
Date: 2011-05-17 09:50:03 -0700 (Tue, 17 May 2011)
New Revision: 3367
trunk/include/geos/geom/Coordinate.h
trunk/include/geos/geom/Coordinate.inl
trunk/src/geom/Coordinate.cpp
Remove disabled code and old logs. No functional change.
Modified: trunk/include/geos/geom/Coordinate.h
--- trunk/include/geos/geom/Coordinate.h 2011-05-16 14:17:32 UTC (rev 3366)
+++ trunk/include/geos/geom/Coordinate.h 2011-05-17 16:50:03 UTC (rev 3367)
@@ -96,13 +96,6 @@
Coordinate(double xNew=0.0, double yNew=0.0, double zNew=DoubleNotANumber);
-// Letting the compiler synthetize these gives us more numerical stability
-#if 0
- Coordinate(const Coordinate& c);
- Coordinate &operator=(const Coordinate &c);
-#endif
bool equals2D(const Coordinate& other) const;
/// 2D only
@@ -170,24 +163,3 @@
#endif // ndef GEOS_GEOM_COORDINATE_H
- * $Log$
- * Revision 1.6 2006/06/14 19:27:02 strk
- * Let the compiler synthetize copy ctor and assignment op for Coordinate class to obtain better numerical stability.
- * Revision 1.5 2006/05/23 15:06:07 strk
- * * source/headers/geos/geom/Coordinate.h: added missing <string> include.
- * Revision 1.4 2006/03/27 15:57:39 strk
- * Commented need for platform.h include
- * Revision 1.3 2006/03/24 09:52:41 strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.2 2006/03/20 10:12:45 strk
- * Bug #70 - Small fix in fwd decl. of CoordinateLessThen
- * Revision 1.1 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
Modified: trunk/include/geos/geom/Coordinate.inl
--- trunk/include/geos/geom/Coordinate.inl 2011-05-16 14:17:32 UTC (rev 3366)
+++ trunk/include/geos/geom/Coordinate.inl 2011-05-17 16:50:03 UTC (rev 3367)
@@ -17,7 +17,6 @@
#define GEOS_GEOM_COORDINATE_INL
#include <geos/geom/Coordinate.h>
-//#include <geos/geom/PrecisionModel.h> // we need it for makePrecise, possibly to be obsoleted
#include <geos/platform.h> // for DoubleNotANumber
#include <cassert>
@@ -53,27 +52,6 @@
z(zNew)
-#if 0
-INLINE
-Coordinate::Coordinate(const Coordinate& c)
- x(c.x),
- y(c.y),
- z(c.z)
-INLINE Coordinate&
-Coordinate::operator=(const Coordinate &c)
- if ( this == &c ) return *this;
- x=c.x;
- y=c.y;
- z=c.z;
- return *this;
-#endif
INLINE bool
Coordinate::equals2D(const Coordinate& other) const
@@ -105,15 +83,6 @@
((z == other.z)||(ISNAN(z) && ISNAN(other.z)));
-#if 0
-INLINE void
-Coordinate::makePrecise(const PrecisionModel *pm)
- x = pm->makePrecise(x);
- y = pm->makePrecise(y);
-#endif
INLINE double
Coordinate::distance(const Coordinate& p) const
Modified: trunk/src/geom/Coordinate.cpp
--- trunk/src/geom/Coordinate.cpp 2011-05-16 14:17:32 UTC (rev 3366)
+++ trunk/src/geom/Coordinate.cpp 2011-05-17 16:50:03 UTC (rev 3367)
@@ -55,178 +55,6 @@
return os;
-#if 0
- x(c.x),
- y(c.y),
- z(c.z)
-Coordinate&
- x=c.x;
- y=c.y;
- z=c.z;
- return *this;
-#endif
} // namespace geos::geom
} // namespace geos
- * $Log$
- * Revision 1.35 2006/06/14 19:27:02 strk
- * Revision 1.34 2006/03/27 15:56:21 strk
- * Added missing platform.h include (for ISNAN macro)
- * Revision 1.33 2006/03/24 09:52:41 strk
- * Revision 1.32 2006/03/23 15:10:28 strk
- * Dropped by-pointer TopologyException constructor, various small cleanups
- * Revision 1.31 2006/03/14 15:32:24 strk
- * Cleaned up toString funx (more WKT friendly)
- * Revision 1.30 2006/03/13 21:54:56 strk
- * Streamlined headers inclusion.
- * Revision 1.29 2006/03/09 16:46:47 strk
- * Revision 1.28 2006/03/03 10:46:21 strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.27 2006/02/28 17:44:26 strk
- * Added a check in SegmentNode::addSplitEdge to prevent attempts
- * to build SegmentString with less then 2 points.
- * This is a temporary fix for the buffer.xml assertion failure, temporary
- * as Martin Davis review would really be needed there.
- * Revision 1.26 2006/02/28 14:34:03 strk
- * Added many assertions and debugging output hunting for a bug in BufferOp
- * Revision 1.25 2006/02/24 15:39:06 strk
- * - operator>> for Coordinate, planarNode and planarEdge
- * - Fixed bug in planarGraphComponent::setMarked
- * - Added linemerge.xml test (single test, should grow a bit)
- * Revision 1.24 2006/02/23 23:17:52 strk
- * - Coordinate::nullCoordinate made private
- * - Simplified Coordinate inline definitions
- * - LMGeometryComponentFilter definition moved to LineMerger.cpp file
- * - Misc cleanups
- * Revision 1.23 2006/02/19 19:46:49 strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.22 2006/01/31 19:07:33 strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- * from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- * then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- * Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- * memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
- * Revision 1.21 2005/11/21 16:03:20 strk
- * Coordinate interface change:
- * Removed setCoordinate call, use assignment operator
- * instead. Provided a compile-time switch to
- * make copy ctor and assignment operators non-inline
- * to allow for more accurate profiling.
- * Coordinate copies removal:
- * NodeFactory::createNode() takes now a Coordinate reference
- * rather then real value. This brings coordinate copies
- * in the testLeaksBig.xml test from 654818 to 645991
- * (tested in 2.1 branch). In the head branch Coordinate
- * copies are 222198.
- * Removed useless coordinate copies in ConvexHull
- * operations
- * STL containers heap allocations reduction:
- * Converted many containers element from
- * pointers to real objects.
- * Made some use of .reserve() or size
- * initialization when final container size is known
- * in advance.
- * Stateless classes allocations reduction:
- * Provided ::instance() function for
- * NodeFactories, to avoid allocating
- * more then one (they are all
- * stateless).
- * HCoordinate improvements:
- * Changed HCoordinate constructor by HCoordinates
- * take reference rather then real objects.
- * Changed HCoordinate::intersection to avoid
- * a new allocation but rather return into a provided
- * storage. LineIntersector changed to reflect
- * the above change.
- * Revision 1.20 2005/01/28 08:47:06 strk
- * Removed sprintf usage, replaced with sstream
- * Revision 1.19 2004/11/29 16:05:33 strk
- * Fixed a bug in LineIntersector::interpolateZ causing NaN values
- * to come out.
- * Handled dimensional collapses in ElevationMatrix.
- * Added ISNAN macro and changed ISNAN/FINITE macros to avoid
- * dispendious isnan() and finite() calls.
- * Revision 1.18 2004/11/01 16:43:04 strk
- * Added Profiler code.
- * Temporarly patched a bug in DoubleBits (must check drawbacks).
- * Various cleanups and speedups.
- * Revision 1.17 2004/10/21 22:29:54 strk
- * Indentation changes and some more COMPUTE_Z rules
- * Revision 1.16 2004/07/22 07:04:49 strk
- * Documented missing geometry functions.
- * Revision 1.15 2004/07/21 09:55:24 strk
- * CoordinateSequence::atLeastNCoordinatesOrNothing definition fix.
- * Documentation fixes.
- * Revision 1.14 2004/07/14 21:17:10 strk
- * added inequality operator for Coordinate
- * Revision 1.13 2004/07/02 13:28:26 strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.12 2004/03/18 10:42:44 ybychkov
- * "IO" and "Util" upgraded to JTS 1.4
- * "Geometry" partially upgraded.
- * Revision 1.11 2003/11/07 01:23:42 pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
More information about the geos-commits
