[geos-commits] r3375 - in trunk: . capi include src tools
svn_geos at osgeo.org
Sun May 22 19:34:04 EDT 2011
Author: mloskot
Date: 2011-05-22 16:34:04 -0700 (Sun, 22 May 2011)
New Revision: 3375
trunk/CMakeLists.txt
trunk/capi/CMakeLists.txt
trunk/include/CMakeLists.txt
trunk/src/CMakeLists.txt
trunk/tools/CMakeLists.txt
Added OS X framework build option to CMake configuration (Ticket #385)
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2011-05-20 08:02:17 UTC (rev 3374)
+++ trunk/CMakeLists.txt 2011-05-22 23:34:04 UTC (rev 3375)
@@ -68,6 +68,13 @@
"Set to OFF|ON (default) to control IEEE754 conformance and remove extra precision" ON)
endif()
+if(APPLE)
+ option(GEOS_ENABLE_MACOSX_FRAMEWORK
+ "Set to OFF|ON (default) to build GEOS as a Mac OS X framework" ON)
+ option(GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT
+ "Set to ON|OFF (default) to add Unix compatibility to the Mac OS X framework" OFF)
+endif()
# Setup C/C++ compiler options
Modified: trunk/capi/CMakeLists.txt
--- trunk/capi/CMakeLists.txt 2011-05-20 08:02:17 UTC (rev 3374)
+++ trunk/capi/CMakeLists.txt 2011-05-22 23:34:04 UTC (rev 3375)
@@ -22,30 +22,41 @@
file(GLOB geos_capi_HEADERS ${CMAKE_BINARY_DIR}/capi/*.h) # fix source_group issue
-add_library(geos_c SHARED ${geos_c_SOURCES} ${geos_capi_HEADERS})
+if(NOT APPLE AND NOT GEOS_ENABLE_MACOSX_FRAMEWORK)
+ # if building OS X framework, CAPI built into C++ library
+ add_library(geos_c SHARED ${geos_c_SOURCES})
-target_link_libraries(geos_c geos-static)
+ target_link_libraries(geos_c geos-static)
-# TODO: Enable SOVERSION property
-set_target_properties(geos_c
- PROPERTIES
- VERSION ${CAPI_VERSION}
- CLEAN_DIRECT_OUTPUT 1)
+ # TODO: Enable SOVERSION property
+ set_target_properties(geos_c
+ PROPERTIES
+ VERSION ${CAPI_VERSION}
+ CLEAN_DIRECT_OUTPUT 1)
+endif()
# Installation
-install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos_c.h
- DESTINATION include)
+if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
+ install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos_c.h
+ DESTINATION GEOS.framework/Versions/${VERSION_MAJOR}/Headers)
+ install(CODE "execute_process(COMMAND sed -E -i \"\" \"s,# *include[[:space:]]+<geos/,#include <GEOS/,g\" \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework/Versions/${VERSION_MAJOR}/Headers/geos_c.h\")")
+else()
+ DESTINATION include)
+endif()
-install(TARGETS geos_c
- RUNTIME DESTINATION bin
- LIBRARY DESTINATION lib
- ARCHIVE DESTINATION lib)
+ install(TARGETS geos_c
+ RUNTIME DESTINATION bin
+ LIBRARY DESTINATION lib
+ ARCHIVE DESTINATION lib)
+endif()
# Group source files for IDE source explorers (e.g. Visual Studio)
-source_group("Header Files" FILES ${geos_capi_HEADERS})
\ No newline at end of file
+source_group("Header Files" FILES ${geos_capi_HEADERS})
Modified: trunk/include/CMakeLists.txt
--- trunk/include/CMakeLists.txt 2011-05-20 08:02:17 UTC (rev 3374)
+++ trunk/include/CMakeLists.txt 2011-05-22 23:34:04 UTC (rev 3375)
@@ -12,24 +12,42 @@
-#add_subdirectory(geos)
# Install/Uninstall
+# There is a builtin cmake way to get headers in the right location
+# for OS X framework, but it's not practical this complex tree
+ set(installdest GEOS.framework/Versions/${VERSION_MAJOR}/Headers)
+else()
+ set(installdest include/geos)
+endif()
install(FILES geos.h
- DESTINATION include/geos)
+ DESTINATION ${installdest})
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos/platform.h
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos/version.h
install(DIRECTORY geos/
FILES_MATCHING
PATTERN "*.h"
PATTERN "*.inl"
- PATTERN ".svn" EXCLUDE)
+ PATTERN ".svn" EXCLUDE)
+# Some post-processing for the framework
+# luckily GEOS uses header subdir already, just need to change case
+ install(CODE
+ "execute_process(COMMAND find \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/${installdest}\" -name *.* -print0
+ COMMAND xargs -0 sed -E -i \"\" \"s,# *include[[:space:]]+<geos/,#include <GEOS/,g\")")
+ install(CODE
+ "execute_process(COMMAND ln -sfh Versions/Current/Headers \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework/Headers\")")
+endif()
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt 2011-05-20 08:02:17 UTC (rev 3374)
+++ trunk/src/CMakeLists.txt 2011-05-22 23:34:04 UTC (rev 3375)
@@ -15,6 +15,46 @@
file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
+ # OS X frameworks don't have static libs
+ # also 1 binary, so include CAPI here
+ # and, make name all caps
+ set(geos_c_SOURCES
+ ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_c.cpp
+ ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
+ add_library(GEOS SHARED ${geos_SOURCES} ${geos_c_SOURCES})
+ set_target_properties(GEOS
+ PROPERTIES
+ FRAMEWORK 1
+ FRAMEWORK_VERSION ${VERSION_MAJOR}
+ MACOSX_FRAMEWORK_INFO_PLIST "${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.in"
+ MACOSX_FRAMEWORK_BUNDLE_VERSION "GEOS ${VERSION}"
+ MACOSX_FRAMEWORK_SHORT_VERSION_STRING ${VERSION}
+ MACOSX_FRAMEWORK_IDENTIFIER org.osgeo.geos)
+ install(TARGETS GEOS FRAMEWORK DESTINATION .)
+ if(GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT)
+ # Unix compatibility option, provides typical bin/lib/include folder
+ # structure for framework-challenged projects
+ set(GEOS_FWDIR "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework")
+ set(GEOS_FWDIR_VER "${GEOS_FWDIR}/Versions/${VERSION_MAJOR}")
+ install(CODE "execute_process(COMMAND mkdir -p \"${GEOS_FWDIR_VER}/unix/bin\")")
+ install(CODE "execute_process(COMMAND mkdir -p \"${GEOS_FWDIR_VER}/unix/include\")")
+ install(CODE "execute_process(COMMAND mkdir -p \"${GEOS_FWDIR_VER}/unix/lib\")")
+ install(CODE "execute_process(COMMAND ln -sfh ../../Headers \"${GEOS_FWDIR_VER}/unix/include/geos\")")
+ install(CODE "execute_process(COMMAND ln -sf ../../Headers/geos_c.h \"${GEOS_FWDIR_VER}/unix/include/geos_c.h\")")
+ install(CODE "execute_process(COMMAND ln -sf ../../GEOS \"${GEOS_FWDIR_VER}/unix/lib/libgeos.dylib\")")
+ install(CODE "execute_process(COMMAND ln -sf ../../GEOS \"${GEOS_FWDIR_VER}/unix/lib/libgeos_c.dylib\")")
+ install(CODE "execute_process(COMMAND ln -sfh Versions/Current/unix \"${GEOS_FWDIR}/unix\")")
+ endif()
+else()
add_library(geos SHARED ${geos_SOURCES} ${geos_ALL_HEADERS})
add_library(geos-static STATIC ${geos_SOURCES} ${geos_ALL_HEADERS})
@@ -31,14 +71,18 @@
PREFIX "lib"
+endif()
# Installation
-install(TARGETS geos geos-static
+ install(TARGETS geos geos-static
+endif()
Modified: trunk/tools/CMakeLists.txt
--- trunk/tools/CMakeLists.txt 2011-05-20 08:02:17 UTC (rev 3374)
+++ trunk/tools/CMakeLists.txt 2011-05-22 23:34:04 UTC (rev 3375)
@@ -14,17 +14,28 @@
if(UNIX)
- # Autoconf compatibility variables to use the same script source.
- set(prefix ${CMAKE_INSTALL_PREFIX})
- set(exec_prefix ${CMAKE_INSTALL_PREFIX}/bin)
- set(libdir ${CMAKE_INSTALL_PREFIX}/lib)
+ if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT)
+ set(installdest GEOS.framework/Versions/${VERSION_MAJOR}/unix/bin)
+ set(prefix ${CMAKE_INSTALL_PREFIX}/GEOS.framework/Versions/${VERSION_MAJOR}/unix)
+ elseif(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
+ # just a dummy so installdest not set
+ # want geos-config only for Mac unix build or framework+unixcompat
+ else()
+ set(installdest bin)
+ set(prefix ${CMAKE_INSTALL_PREFIX})
+ endif()
- configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
- ${CMAKE_CURRENT_BINARY_DIR}/geos-config @ONLY)
+ set(exec_prefix ${prefix}/bin)
+ set(libdir ${prefix}/lib)
+ if(installdest)
+ configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
+ ${CMAKE_CURRENT_BINARY_DIR}/geos-config @ONLY)
+ install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos-config
+ PERMISSIONS
+ OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE)
+endif()
- install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos-config
- DESTINATION bin/
- PERMISSIONS
- OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE)
endif()
More information about the geos-commits
