[geos-commits] r3514 - in trunk: src/operation/union
tests/unit/operation/union tests/xmltester/tests/general
svn_geos at osgeo.org
Fri Nov 4 13:59:22 EDT 2011
Author: strk
Date: 2011-11-04 10:59:22 -0700 (Fri, 04 Nov 2011)
New Revision: 3514
trunk/src/operation/union/UnaryUnionOp.cpp
trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp
trunk/tests/xmltester/tests/general/TestUnaryUnion.xml
Fix noding of self-intersecting lines through UnaryUnion (#482)
Includes updated tests from JTS
Modified: trunk/src/operation/union/UnaryUnionOp.cpp
--- trunk/src/operation/union/UnaryUnionOp.cpp 2011-11-04 17:45:43 UTC (rev 3513)
+++ trunk/src/operation/union/UnaryUnionOp.cpp 2011-11-04 17:59:22 UTC (rev 3514)
@@ -82,13 +82,18 @@
GeomAutoPtr unionLines;
if (!lines.empty()) {
-#if 0
- GeomAutoPtr lineGeom = geomFact->buildGeometry( lines.begin(),
- lines.end() );
- unionLines = unionNoOpt(*lineGeom);
-#endif
+ /* JTS compatibility NOTE:
+ * we use cascaded here for robustness [1]
+ * but also add a final unionNoOpt step to deal with
+ * self-intersecting lines [2]
+ * [1](http://trac.osgeo.org/geos/ticket/392
+ * [2](http://trac.osgeo.org/geos/ticket/482
unionLines.reset( CascadedUnion::Union( lines.begin(),
lines.end() ) );
+ unionLines = unionNoOpt(*unionLines);
GeomAutoPtr unionPolygons;
Modified: trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp
--- trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp 2011-11-04 17:45:43 UTC (rev 3513)
+++ trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp 2011-11-04 17:59:22 UTC (rev 3514)
@@ -1,5 +1,5 @@
-// Test Suite for geos::operation::geounion::CascadedPolygonUnion class.
+// Test Suite for geos::operation::geounion::UnaryUnionOp class.
// tut
#include <tut.hpp>
@@ -166,5 +166,17 @@
doTest(geoms, "GEOMETRYCOLLECTION (POINT (80 50), POINT (100 70), LINESTRING (40 60, 120 110))");
+ template<>
+ template<>
+ void object::test<6>()
+ static char const* const geoms[] =
+ "LINESTRING (0 0, 10 0, 5 -5, 5 5)",
+ NULL
+ doTest(geoms, "MULTILINESTRING ((0 0, 5 0), (5 0, 10 0, 5 -5, 5 0), (5 0, 5 5))");
} // namespace tut
Modified: trunk/tests/xmltester/tests/general/TestUnaryUnion.xml
--- trunk/tests/xmltester/tests/general/TestUnaryUnion.xml 2011-11-04 17:45:43 UTC (rev 3513)
+++ trunk/tests/xmltester/tests/general/TestUnaryUnion.xml 2011-11-04 17:59:22 UTC (rev 3514)
@@ -27,6 +27,18 @@
</case>
<case>
+ <desc>L - LineString (showing noding)</desc>
+ <a>
+ LINESTRING (0 0, 10 0, 5 -5, 5 5)
+ </a>
+<test>
+ <op name="union" arg1="A">
+ MULTILINESTRING ((0 0, 5 0), (5 0, 10 0, 5 -5, 5 0), (5 0, 5 5))
+ </op>
+</test>
+</case>
+<case>
<desc>mL - multiLineString (showing noding)</desc>
<a>
MULTILINESTRING((0 0, 10 10), (0 10, 10 0))
More information about the geos-commits
