[geos-commits] r3493 - in trunk: capi src
svn_geos at osgeo.org
Tue Oct 4 11:42:49 EDT 2011
Author: hobu
Date: 2011-10-04 08:42:49 -0700 (Tue, 04 Oct 2011)
New Revision: 3493
trunk/capi/CMakeLists.txt
trunk/src/CMakeLists.txt
fix up non-framework CMake builds on APPLE
Modified: trunk/capi/CMakeLists.txt
--- trunk/capi/CMakeLists.txt 2011-10-04 15:32:23 UTC (rev 3492)
+++ trunk/capi/CMakeLists.txt 2011-10-04 15:42:49 UTC (rev 3493)
@@ -21,7 +21,7 @@
file(GLOB geos_capi_HEADERS ${CMAKE_BINARY_DIR}/capi/*.h) # fix source_group issue
-if(NOT APPLE AND NOT GEOS_ENABLE_MACOSX_FRAMEWORK)
+if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK)
# if building OS X framework, CAPI built into C++ library
add_library(geos_c SHARED ${geos_c_SOURCES})
@@ -34,12 +34,6 @@
CLEAN_DIRECT_OUTPUT 1)
endif()
-if(APPLE)
- set_target_properties(geos PROPERTIES
- BUILD_WITH_INSTALL_RPATH TRUE
- INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}")
-endif()
# Installation
@@ -53,7 +47,7 @@
DESTINATION include)
endif()
install(TARGETS geos_c
RUNTIME DESTINATION bin
LIBRARY DESTINATION lib
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt 2011-10-04 15:32:23 UTC (rev 3492)
+++ trunk/src/CMakeLists.txt 2011-10-04 15:42:49 UTC (rev 3493)
@@ -14,7 +14,7 @@
file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
-if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
+if(GEOS_ENABLE_MACOSX_FRAMEWORK)
# OS X frameworks don't have static libs
# also 1 binary, so include CAPI here
# and, make name all caps
@@ -79,18 +79,18 @@
endif()
-if(APPLE)
- PROPERTIES
-endif()
+# if(APPLE)
+# set_target_properties(geos
+# PROPERTIES
+# BUILD_WITH_INSTALL_RPATH TRUE
+# INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}")
+# endif()
# Installation
install(TARGETS geos geos-static
More information about the geos-commits
