[geos-commits] r3497 - in trunk: capi include/geos/algorithm include/geos/geom include/geos/geom/prep include/geos/geomgraph include/geos/geomgraph/index include/geos/index/chain include/geos/index/strtree include/geos/io include/geos/noding include/geos/operation/relate include/geos/operation/valid include/geos/planargraph include/geos/util src/precision
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Oct 4 16:46:04 EDT 2011
Author: hobu
Date: 2011-10-04 13:46:04 -0700 (Tue, 04 Oct 2011)
New Revision: 3497
   trunk/capi/geos_ts_c.cpp
   trunk/include/geos/algorithm/CGAlgorithms.h
   trunk/include/geos/algorithm/PointInRing.h
   trunk/include/geos/geom/MultiPoint.h
   trunk/include/geos/geom/prep/PreparedGeometry.h
   trunk/include/geos/geomgraph/EdgeEndStar.h
   trunk/include/geos/geomgraph/Node.h
   trunk/include/geos/geomgraph/NodeFactory.h
   trunk/include/geos/geomgraph/index/EdgeSetIntersector.h
   trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h
   trunk/include/geos/geomgraph/index/SweepLineEventObj.h
   trunk/include/geos/index/chain/MonotoneChainOverlapAction.h
   trunk/include/geos/index/strtree/Boundable.h
   trunk/include/geos/index/strtree/SIRtree.h
   trunk/include/geos/index/strtree/STRtree.h
   trunk/include/geos/io/ParseException.h
   trunk/include/geos/io/StringTokenizer.h
   trunk/include/geos/io/WKBReader.h
   trunk/include/geos/noding/Noder.h
   trunk/include/geos/noding/SimpleNoder.h
   trunk/include/geos/operation/relate/RelateNodeFactory.h
   trunk/include/geos/operation/valid/RepeatedPointTester.h
   trunk/include/geos/planargraph/GraphComponent.h
   trunk/include/geos/util/IllegalArgumentException.h
   trunk/include/geos/util/IllegalStateException.h
   trunk/include/geos/util/UnsupportedOperationException.h
   trunk/src/precision/CommonBitsRemover.cpp
remove extra ;'s to satisfy pedantic warning
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/capi/geos_ts_c.cpp	2011-10-04 20:46:04 UTC (rev 3497)
@@ -145,8 +145,8 @@
     void *userdata;
   public:
     CAPI_ItemVisitor (GEOSQueryCallback cb, void *ud)
-        : ItemVisitor(), callback(cb), userdata(ud) {};
-    void visitItem (void *item) { callback(item, userdata); };
+        : ItemVisitor(), callback(cb), userdata(ud) {}
+    void visitItem (void *item) { callback(item, userdata); }
Modified: trunk/include/geos/algorithm/CGAlgorithms.h
--- trunk/include/geos/algorithm/CGAlgorithms.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/algorithm/CGAlgorithms.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -60,7 +60,7 @@
 		STRAIGHT
-	CGAlgorithms(){};
+	CGAlgorithms(){}
 	/** \brief
 	 * Tests whether a point lies inside a ring.
Modified: trunk/include/geos/algorithm/PointInRing.h
--- trunk/include/geos/algorithm/PointInRing.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/algorithm/PointInRing.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -30,7 +30,7 @@
 class GEOS_DLL PointInRing{
 public:
-	virtual ~PointInRing(){};
+	virtual ~PointInRing(){}
 	virtual bool isInside(const geom::Coordinate& pt)=0;
Modified: trunk/include/geos/geom/MultiPoint.h
--- trunk/include/geos/geom/MultiPoint.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geom/MultiPoint.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -84,7 +84,7 @@
 	bool equalsExact(const Geometry *other, double tolerance=0) const;
-	Geometry *clone() const { return new MultiPoint(*this); };
+	Geometry *clone() const { return new MultiPoint(*this); }
 protected:
Modified: trunk/include/geos/geom/prep/PreparedGeometry.h
--- trunk/include/geos/geom/prep/PreparedGeometry.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geom/prep/PreparedGeometry.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -52,7 +52,7 @@
 class GEOS_DLL PreparedGeometry {
 public:
-	virtual ~PreparedGeometry() {};
+	virtual ~PreparedGeometry() {}
 	 * Gets the original {@link Geometry} which has been prepared.
Modified: trunk/include/geos/geomgraph/EdgeEndStar.h
--- trunk/include/geos/geomgraph/EdgeEndStar.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geomgraph/EdgeEndStar.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -70,7 +70,7 @@
 	EdgeEndStar();
-	virtual ~EdgeEndStar() {};
+	virtual ~EdgeEndStar() {}
 	/** \brief
 	 * Insert a EdgeEnd into this EdgeEndStar
Modified: trunk/include/geos/geomgraph/Node.h
--- trunk/include/geos/geomgraph/Node.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geomgraph/Node.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -140,7 +140,7 @@
 	/** \brief
 	 * Basic nodes do not compute IMs
-	virtual void computeIM(geom::IntersectionMatrix& /*im*/) {};
+	virtual void computeIM(geom::IntersectionMatrix& /*im*/) {}
 private:
Modified: trunk/include/geos/geomgraph/NodeFactory.h
--- trunk/include/geos/geomgraph/NodeFactory.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geomgraph/NodeFactory.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -43,7 +43,7 @@
 	static const NodeFactory &instance();
 	virtual ~NodeFactory() {}
 protected:
-	NodeFactory() {};
+	NodeFactory() {}
Modified: trunk/include/geos/geomgraph/index/EdgeSetIntersector.h
--- trunk/include/geos/geomgraph/index/EdgeSetIntersector.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geomgraph/index/EdgeSetIntersector.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -56,7 +56,7 @@
 			std::vector<Edge*> *edges1,
 			SegmentIntersector *si)=0;
-	virtual ~EdgeSetIntersector(){};
+	virtual ~EdgeSetIntersector(){}
Modified: trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h
--- trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geomgraph/index/MonotoneChainIndexer.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -35,7 +35,7 @@
 public:
-	MonotoneChainIndexer(){};
+	MonotoneChainIndexer(){}
 	void getChainStartIndices(const geom::CoordinateSequence*, std::vector<int>&);
Modified: trunk/include/geos/geomgraph/index/SweepLineEventObj.h
--- trunk/include/geos/geomgraph/index/SweepLineEventObj.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/geomgraph/index/SweepLineEventObj.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -28,7 +28,7 @@
 // inherit from it.
 class GEOS_DLL SweepLineEventOBJ {
 public:
-	virtual ~SweepLineEventOBJ(){};
+	virtual ~SweepLineEventOBJ(){}
Modified: trunk/include/geos/index/chain/MonotoneChainOverlapAction.h
--- trunk/include/geos/index/chain/MonotoneChainOverlapAction.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/index/chain/MonotoneChainOverlapAction.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -51,9 +51,9 @@
 public:
-	MonotoneChainOverlapAction() {};
+	MonotoneChainOverlapAction() {}
-	virtual ~MonotoneChainOverlapAction() {};
+	virtual ~MonotoneChainOverlapAction() {}
 	 * This function can be overridden if the original chains are needed
Modified: trunk/include/geos/index/strtree/Boundable.h
--- trunk/include/geos/index/strtree/Boundable.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/index/strtree/Boundable.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -38,7 +38,7 @@
 	 * @see AbstractSTRtree::IntersectsOp
 	virtual const void* getBounds() const=0;
-	virtual ~Boundable() {};
+	virtual ~Boundable() {}
Modified: trunk/include/geos/index/strtree/SIRtree.h
--- trunk/include/geos/index/strtree/SIRtree.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/index/strtree/SIRtree.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -93,7 +93,7 @@
 	AbstractNode* createNode(int level);
-	IntersectsOp* getIntersectsOp() {return intersectsOp;};
+	IntersectsOp* getIntersectsOp() {return intersectsOp;}
 	std::auto_ptr<BoundableList> sortBoundables(const BoundableList* input);
Modified: trunk/include/geos/index/strtree/STRtree.h
--- trunk/include/geos/index/strtree/STRtree.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/index/strtree/STRtree.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -105,7 +105,7 @@
 		return &intersectsOp;
 public:
Modified: trunk/include/geos/io/ParseException.h
--- trunk/include/geos/io/ParseException.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/io/ParseException.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -44,7 +44,7 @@
 	ParseException(const std::string& msg, double num);
-	~ParseException() throw() {};
+	~ParseException() throw() {}
 private:
 	static std::string stringify(double num);
Modified: trunk/include/geos/io/StringTokenizer.h
--- trunk/include/geos/io/StringTokenizer.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/io/StringTokenizer.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -42,7 +42,7 @@
 	//StringTokenizer();
 	StringTokenizer(const std::string& txt);
-	~StringTokenizer() {};
+	~StringTokenizer() {}
 	int nextToken();
 	int peekNextToken();
 	double getNVal();
Modified: trunk/include/geos/io/WKBReader.h
--- trunk/include/geos/io/WKBReader.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/io/WKBReader.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -80,7 +80,7 @@
 public:
-	WKBReader(geom::GeometryFactory const& f): factory(f) {};
+	WKBReader(geom::GeometryFactory const& f): factory(f) {}
 	/// Inizialize parser with default GeometryFactory.
 	WKBReader();
Modified: trunk/include/geos/noding/Noder.h
--- trunk/include/geos/noding/Noder.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/noding/Noder.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -70,7 +70,7 @@
 	virtual ~Noder() {}
 protected:
-	Noder(){};
+	Noder(){}
 } // namespace geos.noding
Modified: trunk/include/geos/noding/SimpleNoder.h
--- trunk/include/geos/noding/SimpleNoder.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/noding/SimpleNoder.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -57,7 +57,7 @@
 	SimpleNoder(SegmentIntersector* nSegInt=NULL)
 		SinglePassNoder(nSegInt)
 	void computeNodes(std::vector<SegmentString*>* inputSegmentStrings);
Modified: trunk/include/geos/operation/relate/RelateNodeFactory.h
--- trunk/include/geos/operation/relate/RelateNodeFactory.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/operation/relate/RelateNodeFactory.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -46,7 +46,7 @@
 	geomgraph::Node* createNode(const geom::Coordinate &coord) const;
 	static const geomgraph::NodeFactory &instance();
 private:
-	RelateNodeFactory() {};
+	RelateNodeFactory() {}
Modified: trunk/include/geos/operation/valid/RepeatedPointTester.h
--- trunk/include/geos/operation/valid/RepeatedPointTester.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/operation/valid/RepeatedPointTester.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -48,7 +48,7 @@
 class GEOS_DLL RepeatedPointTester {
 public:
-	RepeatedPointTester() {};
+	RepeatedPointTester() {}
 	geom::Coordinate& getCoordinate();
 	bool hasRepeatedPoint(const geom::Geometry *g);
 	bool hasRepeatedPoint(const geom::CoordinateSequence *coord);
Modified: trunk/include/geos/planargraph/GraphComponent.h
--- trunk/include/geos/planargraph/GraphComponent.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/planargraph/GraphComponent.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -61,7 +61,7 @@
 		isVisitedVar(false)
-	virtual ~GraphComponent() {};
+	virtual ~GraphComponent() {}
 	/** \brief
 	 * Tests if a component has been visited during the course
Modified: trunk/include/geos/util/IllegalArgumentException.h
--- trunk/include/geos/util/IllegalArgumentException.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/util/IllegalArgumentException.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -43,7 +43,7 @@
 		GEOSException("IllegalArgumentException", msg)
-	~IllegalArgumentException() throw() {};
+	~IllegalArgumentException() throw() {}
 } // namespace geos::util
Modified: trunk/include/geos/util/IllegalStateException.h
--- trunk/include/geos/util/IllegalStateException.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/util/IllegalStateException.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -36,7 +36,7 @@
 		GEOSException("IllegalStateException", msg)
-	~IllegalStateException() throw() {};
+	~IllegalStateException() throw() {}
Modified: trunk/include/geos/util/UnsupportedOperationException.h
--- trunk/include/geos/util/UnsupportedOperationException.h	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/include/geos/util/UnsupportedOperationException.h	2011-10-04 20:46:04 UTC (rev 3497)
@@ -45,7 +45,7 @@
 		GEOSException("UnsupportedOperationException", msg)
-	~UnsupportedOperationException() throw() {};
+	~UnsupportedOperationException() throw() {}
Modified: trunk/src/precision/CommonBitsRemover.cpp
--- trunk/src/precision/CommonBitsRemover.cpp	2011-10-04 16:18:04 UTC (rev 3496)
+++ trunk/src/precision/CommonBitsRemover.cpp	2011-10-04 20:46:04 UTC (rev 3497)
@@ -53,7 +53,7 @@
         ::geos::ignore_unused_variable_warning(coord);
         assert(0);
 	void filter_rw(geom::Coordinate *coord) const
More information about the geos-commits mailing list
