[geos-commits] r3485 - in branches/3.3: . capi src
svn_geos at osgeo.org
Fri Sep 23 11:59:12 EDT 2011
Author: strk
Date: 2011-09-23 08:59:11 -0700 (Fri, 23 Sep 2011)
New Revision: 3485
branches/3.3/NEWS
branches/3.3/capi/CMakeLists.txt
branches/3.3/src/CMakeLists.txt
Fix OS X framework cmake build (#385) -- thanks kyngchaos
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2011-09-23 12:14:53 UTC (rev 3484)
+++ branches/3.3/NEWS 2011-09-23 15:59:11 UTC (rev 3485)
@@ -12,6 +12,7 @@
- Fix Geometry::clone to copy SRID (#464)
- Fix for clang builds (#463)
- Fix out-of-place build for python binding (#332)
+ - Fix OS X framework cmake build (#385)
Changes in 3.3.0
2011-05-30
Modified: branches/3.3/capi/CMakeLists.txt
--- branches/3.3/capi/CMakeLists.txt 2011-09-23 12:14:53 UTC (rev 3484)
+++ branches/3.3/capi/CMakeLists.txt 2011-09-23 15:59:11 UTC (rev 3485)
@@ -33,13 +33,13 @@
PROPERTIES
VERSION ${CAPI_VERSION}
CLEAN_DIRECT_OUTPUT 1)
-endif()
if(APPLE)
set_target_properties(geos PROPERTIES
BUILD_WITH_INSTALL_RPATH TRUE
INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}")
endif()
+endif()
# Installation
Modified: branches/3.3/src/CMakeLists.txt
--- branches/3.3/src/CMakeLists.txt 2011-09-23 12:14:53 UTC (rev 3484)
+++ branches/3.3/src/CMakeLists.txt 2011-09-23 15:59:11 UTC (rev 3485)
@@ -78,14 +78,14 @@
PREFIX "lib"
-endif()
if(APPLE)
PROPERTIES
endif()
+endif()
# Installation
More information about the geos-commits
