[geos-commits] r3600 - branches/3.3/swig/python
svn_geos at osgeo.org
Thu Apr 5 12:49:22 EDT 2012
Author: strk
Date: 2012-04-05 09:49:22 -0700 (Thu, 05 Apr 2012)
New Revision: 3600
branches/3.3/swig/python/geos.py
branches/3.3/swig/python/geos_wrap.cxx
Regenerate swig wrappers with SWIG 1.3.40
Modified: branches/3.3/swig/python/geos.py
--- branches/3.3/swig/python/geos.py 2012-04-05 16:47:56 UTC (rev 3599)
+++ branches/3.3/swig/python/geos.py 2012-04-05 16:49:22 UTC (rev 3600)
@@ -1,281 +1,397 @@
-# This file was automatically generated by SWIG (http://www.swig.org).
-# Version 1.3.31
-# Don't modify this file, modify the SWIG interface instead.
-import _geos
-import new
-new_instancemethod = new.instancemethod
-try:
- _swig_property = property
-except NameError:
- pass # Python < 2.2 doesn't have 'property'.
-def _swig_setattr_nondynamic(self,class_type,name,value,static=1):
- if (name == "thisown"): return self.this.own(value)
- if (name == "this"):
- if type(value).__name__ == 'PySwigObject':
- self.__dict__[name] = value
- return
- method = class_type.__swig_setmethods__.get(name,None)
- if method: return method(self,value)
- if (not static) or hasattr(self,name):
- else:
- raise AttributeError("You cannot add attributes to %s" % self)
-def _swig_setattr(self,class_type,name,value):
- return _swig_setattr_nondynamic(self,class_type,name,value,0)
-def _swig_getattr(self,class_type,name):
- if (name == "thisown"): return self.this.own()
- method = class_type.__swig_getmethods__.get(name,None)
- if method: return method(self)
- raise AttributeError,name
-def _swig_repr(self):
- try: strthis = "proxy of " + self.this.__repr__()
- except: strthis = ""
- return "<%s.%s; %s >" % (self.__class__.__module__, self.__class__.__name__, strthis,)
-import types
-try:
- _object = types.ObjectType
- _newclass = 1
-except AttributeError:
- class _object : pass
- _newclass = 0
-del types
-def _swig_setattr_nondynamic_method(set):
- def set_attr(self,name,value):
- if hasattr(self,name) or (name == "this"):
- set(self,name,value)
- else:
- return set_attr
-class PySwigIterator(object):
- thisown = _swig_property(lambda x: x.this.own(), lambda x, v: x.this.own(v), doc='The membership flag')
- def __init__(self): raise AttributeError, "No constructor defined"
- __repr__ = _swig_repr
- __swig_destroy__ = _geos.delete_PySwigIterator
- __del__ = lambda self : None;
- def value(*args): return _geos.PySwigIterator_value(*args)
- def incr(*args): return _geos.PySwigIterator_incr(*args)
- def decr(*args): return _geos.PySwigIterator_decr(*args)
- def distance(*args): return _geos.PySwigIterator_distance(*args)
- def equal(*args): return _geos.PySwigIterator_equal(*args)
- def copy(*args): return _geos.PySwigIterator_copy(*args)
- def next(*args): return _geos.PySwigIterator_next(*args)
- def previous(*args): return _geos.PySwigIterator_previous(*args)
- def advance(*args): return _geos.PySwigIterator_advance(*args)
- def __eq__(*args): return _geos.PySwigIterator___eq__(*args)
- def __ne__(*args): return _geos.PySwigIterator___ne__(*args)
- def __iadd__(*args): return _geos.PySwigIterator___iadd__(*args)
- def __isub__(*args): return _geos.PySwigIterator___isub__(*args)
- def __add__(*args): return _geos.PySwigIterator___add__(*args)
- def __sub__(*args): return _geos.PySwigIterator___sub__(*args)
- def __iter__(self): return self
-PySwigIterator_swigregister = _geos.PySwigIterator_swigregister
-PySwigIterator_swigregister(PySwigIterator)
-GEOS_VERSION_MAJOR = _geos.GEOS_VERSION_MAJOR
-GEOS_VERSION_MINOR = _geos.GEOS_VERSION_MINOR
-GEOS_VERSION = _geos.GEOS_VERSION
-GEOS_JTS_PORT = _geos.GEOS_JTS_PORT
-GEOS_CAPI_VERSION_MAJOR = _geos.GEOS_CAPI_VERSION_MAJOR
-GEOS_CAPI_VERSION_MINOR = _geos.GEOS_CAPI_VERSION_MINOR
-GEOS_CAPI_VERSION_PATCH = _geos.GEOS_CAPI_VERSION_PATCH
-GEOS_CAPI_FIRST_INTERFACE = _geos.GEOS_CAPI_FIRST_INTERFACE
-GEOS_CAPI_LAST_INTERFACE = _geos.GEOS_CAPI_LAST_INTERFACE
-GEOS_CAPI_VERSION = _geos.GEOS_CAPI_VERSION
-GEOS_POINT = _geos.GEOS_POINT
-GEOS_LINESTRING = _geos.GEOS_LINESTRING
-GEOS_LINEARRING = _geos.GEOS_LINEARRING
-GEOS_POLYGON = _geos.GEOS_POLYGON
-GEOS_MULTIPOINT = _geos.GEOS_MULTIPOINT
-GEOS_MULTILINESTRING = _geos.GEOS_MULTILINESTRING
-GEOS_MULTIPOLYGON = _geos.GEOS_MULTIPOLYGON
-GEOS_GEOMETRYCOLLECTION = _geos.GEOS_GEOMETRYCOLLECTION
-GEOS_WKB_XDR = _geos.GEOS_WKB_XDR
-GEOS_WKB_NDR = _geos.GEOS_WKB_NDR
-version = _geos.version
-class CoordinateSequence(object):
- def __init__(self, *args):
- this = _geos.new_CoordinateSequence(*args)
- try: self.this.append(this)
- except: self.this = this
- __swig_destroy__ = _geos.delete_CoordinateSequence
- def clone(*args): return _geos.CoordinateSequence_clone(*args)
- def setX(*args): return _geos.CoordinateSequence_setX(*args)
- def setY(*args): return _geos.CoordinateSequence_setY(*args)
- def setZ(*args): return _geos.CoordinateSequence_setZ(*args)
- def setOrdinate(*args): return _geos.CoordinateSequence_setOrdinate(*args)
- def getX(*args): return _geos.CoordinateSequence_getX(*args)
- def getY(*args): return _geos.CoordinateSequence_getY(*args)
- def getZ(*args): return _geos.CoordinateSequence_getZ(*args)
- def getOrdinate(*args): return _geos.CoordinateSequence_getOrdinate(*args)
- def getSize(*args): return _geos.CoordinateSequence_getSize(*args)
- def getDimensions(*args): return _geos.CoordinateSequence_getDimensions(*args)
-CoordinateSequence_swigregister = _geos.CoordinateSequence_swigregister
-CoordinateSequence_swigregister(CoordinateSequence)
-class Geometry(object):
- __swig_destroy__ = _geos.delete_Geometry
- def clone(*args): return _geos.Geometry_clone(*args)
- def geomType(*args): return _geos.Geometry_geomType(*args)
- def typeId(*args): return _geos.Geometry_typeId(*args)
- def normalize(*args): return _geos.Geometry_normalize(*args)
- def getSRID(*args): return _geos.Geometry_getSRID(*args)
- def setSRID(*args): return _geos.Geometry_setSRID(*args)
- def getDimensions(*args): return _geos.Geometry_getDimensions(*args)
- def getNumGeometries(*args): return _geos.Geometry_getNumGeometries(*args)
- def intersection(*args): return _geos.Geometry_intersection(*args)
- def buffer(*args): return _geos.Geometry_buffer(*args)
- def convexHull(*args): return _geos.Geometry_convexHull(*args)
- def difference(*args): return _geos.Geometry_difference(*args)
- def symDifference(*args): return _geos.Geometry_symDifference(*args)
- def boundary(*args): return _geos.Geometry_boundary(*args)
- def union(*args): return _geos.Geometry_union(*args)
- def pointOnSurface(*args): return _geos.Geometry_pointOnSurface(*args)
- def getCentroid(*args): return _geos.Geometry_getCentroid(*args)
- def getEnvelope(*args): return _geos.Geometry_getEnvelope(*args)
- def relate(*args): return _geos.Geometry_relate(*args)
- def lineMerge(*args): return _geos.Geometry_lineMerge(*args)
- def simplify(*args): return _geos.Geometry_simplify(*args)
- def topologyPreserveSimplify(*args): return _geos.Geometry_topologyPreserveSimplify(*args)
- def relatePattern(*args): return _geos.Geometry_relatePattern(*args)
- def disjoint(*args): return _geos.Geometry_disjoint(*args)
- def touches(*args): return _geos.Geometry_touches(*args)
- def intersects(*args): return _geos.Geometry_intersects(*args)
- def crosses(*args): return _geos.Geometry_crosses(*args)
- def within(*args): return _geos.Geometry_within(*args)
- def contains(*args): return _geos.Geometry_contains(*args)
- def overlaps(*args): return _geos.Geometry_overlaps(*args)
- def equals(*args): return _geos.Geometry_equals(*args)
- def equalsExact(*args): return _geos.Geometry_equalsExact(*args)
- def isEmpty(*args): return _geos.Geometry_isEmpty(*args)
- def isValid(*args): return _geos.Geometry_isValid(*args)
- def isSimple(*args): return _geos.Geometry_isSimple(*args)
- def isRing(*args): return _geos.Geometry_isRing(*args)
- def hasZ(*args): return _geos.Geometry_hasZ(*args)
- def area(*args): return _geos.Geometry_area(*args)
- def length(*args): return _geos.Geometry_length(*args)
- def distance(*args): return _geos.Geometry_distance(*args)
-Geometry_swigregister = _geos.Geometry_swigregister
-Geometry_swigregister(Geometry)
-class Point(Geometry):
- __swig_destroy__ = _geos.delete_Point
- def getCoordSeq(*args): return _geos.Point_getCoordSeq(*args)
-Point_swigregister = _geos.Point_swigregister
-Point_swigregister(Point)
-class LineString(Geometry):
- __swig_destroy__ = _geos.delete_LineString
- def getCoordSeq(*args): return _geos.LineString_getCoordSeq(*args)
-LineString_swigregister = _geos.LineString_swigregister
-LineString_swigregister(LineString)
-class LinearRing(Geometry):
- __swig_destroy__ = _geos.delete_LinearRing
- def getCoordSeq(*args): return _geos.LinearRing_getCoordSeq(*args)
-LinearRing_swigregister = _geos.LinearRing_swigregister
-LinearRing_swigregister(LinearRing)
-class Polygon(Geometry):
- __swig_destroy__ = _geos.delete_Polygon
- def getExteriorRing(*args): return _geos.Polygon_getExteriorRing(*args)
- def getNumInteriorRings(*args): return _geos.Polygon_getNumInteriorRings(*args)
- def getInteriorRingN(*args): return _geos.Polygon_getInteriorRingN(*args)
-Polygon_swigregister = _geos.Polygon_swigregister
-Polygon_swigregister(Polygon)
-class GeometryCollection(Geometry):
- __swig_destroy__ = _geos.delete_GeometryCollection
- def getGeometryN(*args): return _geos.GeometryCollection_getGeometryN(*args)
-GeometryCollection_swigregister = _geos.GeometryCollection_swigregister
-GeometryCollection_swigregister(GeometryCollection)
-class MultiPoint(GeometryCollection):
- __swig_destroy__ = _geos.delete_MultiPoint
-MultiPoint_swigregister = _geos.MultiPoint_swigregister
-MultiPoint_swigregister(MultiPoint)
-class MultiLineString(GeometryCollection):
- __swig_destroy__ = _geos.delete_MultiLineString
-MultiLineString_swigregister = _geos.MultiLineString_swigregister
-MultiLineString_swigregister(MultiLineString)
-class MultiLinearRing(GeometryCollection):
- __swig_destroy__ = _geos.delete_MultiLinearRing
-MultiLinearRing_swigregister = _geos.MultiLinearRing_swigregister
-MultiLinearRing_swigregister(MultiLinearRing)
-class MultiPolygon(GeometryCollection):
- __swig_destroy__ = _geos.delete_MultiPolygon
-MultiPolygon_swigregister = _geos.MultiPolygon_swigregister
-MultiPolygon_swigregister(MultiPolygon)
-createPoint = _geos.createPoint
-createLineString = _geos.createLineString
-createLinearRing = _geos.createLinearRing
-createPolygon = _geos.createPolygon
-geomFromWKT = _geos.geomFromWKT
-geomToWKT = _geos.geomToWKT
-getWKBOutputDims = _geos.getWKBOutputDims
-setWKBOutputDims = _geos.setWKBOutputDims
-getWKBByteOrder = _geos.getWKBByteOrder
-setWKBByteOrder = _geos.setWKBByteOrder
-geomFromWKB = _geos.geomFromWKB
-geomToWKB = _geos.geomToWKB
-geomFromHEX = _geos.geomFromHEX
-geomToHEX = _geos.geomToHEX
+# This file was automatically generated by SWIG (http://www.swig.org).
+# Version 1.3.40
+# Do not make changes to this file unless you know what you are doing--modify
+# the SWIG interface file instead.
+from sys import version_info
+if version_info >= (2,6,0):
+ def swig_import_helper():
+ from os.path import dirname
+ import imp
+ fp = None
+ try:
+ fp, pathname, description = imp.find_module('_geos', [dirname(__file__)])
+ except ImportError:
+ import _geos
+ return _geos
+ if fp is not None:
+ try:
+ _mod = imp.load_module('_geos', fp, pathname, description)
+ finally:
+ fp.close()
+ return _mod
+ _geos = swig_import_helper()
+ del swig_import_helper
+else:
+ import _geos
+del version_info
+try:
+ _swig_property = property
+except NameError:
+ pass # Python < 2.2 doesn't have 'property'.
+def _swig_setattr_nondynamic(self,class_type,name,value,static=1):
+ if (name == "thisown"): return self.this.own(value)
+ if (name == "this"):
+ if type(value).__name__ == 'SwigPyObject':
+ self.__dict__[name] = value
+ return
+ method = class_type.__swig_setmethods__.get(name,None)
+ if method: return method(self,value)
+ if (not static) or hasattr(self,name):
+ else:
+ raise AttributeError("You cannot add attributes to %s" % self)
+def _swig_setattr(self,class_type,name,value):
+ return _swig_setattr_nondynamic(self,class_type,name,value,0)
+def _swig_getattr(self,class_type,name):
+ if (name == "thisown"): return self.this.own()
+ method = class_type.__swig_getmethods__.get(name,None)
+ if method: return method(self)
+ raise AttributeError(name)
+def _swig_repr(self):
+ try: strthis = "proxy of " + self.this.__repr__()
+ except: strthis = ""
+ return "<%s.%s; %s >" % (self.__class__.__module__, self.__class__.__name__, strthis,)
+try:
+ _object = object
+ _newclass = 1
+except AttributeError:
+ class _object : pass
+ _newclass = 0
+def _swig_setattr_nondynamic_method(set):
+ def set_attr(self,name,value):
+ if hasattr(self,name) or (name == "this"):
+ set(self,name,value)
+ else:
+ return set_attr
+class SwigPyIterator(object):
+ thisown = _swig_property(lambda x: x.this.own(), lambda x, v: x.this.own(v), doc='The membership flag')
+ def __init__(self, *args, **kwargs): raise AttributeError("No constructor defined - class is abstract")
+ __repr__ = _swig_repr
+ __swig_destroy__ = _geos.delete_SwigPyIterator
+ __del__ = lambda self : None;
+ def value(self): return _geos.SwigPyIterator_value(self)
+ def incr(self, n = 1): return _geos.SwigPyIterator_incr(self, n)
+ def decr(self, n = 1): return _geos.SwigPyIterator_decr(self, n)
+ def distance(self, *args): return _geos.SwigPyIterator_distance(self, *args)
+ def equal(self, *args): return _geos.SwigPyIterator_equal(self, *args)
+ def copy(self): return _geos.SwigPyIterator_copy(self)
+ def next(self): return _geos.SwigPyIterator_next(self)
+ def __next__(self): return _geos.SwigPyIterator___next__(self)
+ def previous(self): return _geos.SwigPyIterator_previous(self)
+ def advance(self, *args): return _geos.SwigPyIterator_advance(self, *args)
+ def __eq__(self, *args): return _geos.SwigPyIterator___eq__(self, *args)
+ def __ne__(self, *args): return _geos.SwigPyIterator___ne__(self, *args)
+ def __iadd__(self, *args): return _geos.SwigPyIterator___iadd__(self, *args)
+ def __isub__(self, *args): return _geos.SwigPyIterator___isub__(self, *args)
+ def __add__(self, *args): return _geos.SwigPyIterator___add__(self, *args)
+ def __sub__(self, *args): return _geos.SwigPyIterator___sub__(self, *args)
+ def __iter__(self): return self
+SwigPyIterator_swigregister = _geos.SwigPyIterator_swigregister
+SwigPyIterator_swigregister(SwigPyIterator)
+GEOS_VERSION_MAJOR = _geos.GEOS_VERSION_MAJOR
+GEOS_VERSION_MINOR = _geos.GEOS_VERSION_MINOR
+GEOS_VERSION = _geos.GEOS_VERSION
+GEOS_JTS_PORT = _geos.GEOS_JTS_PORT
+GEOS_CAPI_VERSION_MAJOR = _geos.GEOS_CAPI_VERSION_MAJOR
+GEOS_CAPI_VERSION_MINOR = _geos.GEOS_CAPI_VERSION_MINOR
+GEOS_CAPI_VERSION_PATCH = _geos.GEOS_CAPI_VERSION_PATCH
+GEOS_CAPI_FIRST_INTERFACE = _geos.GEOS_CAPI_FIRST_INTERFACE
+GEOS_CAPI_LAST_INTERFACE = _geos.GEOS_CAPI_LAST_INTERFACE
+GEOS_CAPI_VERSION = _geos.GEOS_CAPI_VERSION
+GEOS_POINT = _geos.GEOS_POINT
+GEOS_LINESTRING = _geos.GEOS_LINESTRING
+GEOS_LINEARRING = _geos.GEOS_LINEARRING
+GEOS_POLYGON = _geos.GEOS_POLYGON
+GEOS_MULTIPOINT = _geos.GEOS_MULTIPOINT
+GEOS_MULTILINESTRING = _geos.GEOS_MULTILINESTRING
+GEOS_MULTIPOLYGON = _geos.GEOS_MULTIPOLYGON
+GEOS_GEOMETRYCOLLECTION = _geos.GEOS_GEOMETRYCOLLECTION
+GEOS_WKB_XDR = _geos.GEOS_WKB_XDR
+GEOS_WKB_NDR = _geos.GEOS_WKB_NDR
+def version():
+ return _geos.version()
+version = _geos.version
+class CoordinateSequence(object):
+ def __init__(self, *args):
+ this = _geos.new_CoordinateSequence(*args)
+ try: self.this.append(this)
+ except: self.this = this
+ __swig_destroy__ = _geos.delete_CoordinateSequence
+ def clone(self): return _geos.CoordinateSequence_clone(self)
+ def setX(self, *args): return _geos.CoordinateSequence_setX(self, *args)
+ def setY(self, *args): return _geos.CoordinateSequence_setY(self, *args)
+ def setZ(self, *args): return _geos.CoordinateSequence_setZ(self, *args)
+ def setOrdinate(self, *args): return _geos.CoordinateSequence_setOrdinate(self, *args)
+ def getX(self, *args): return _geos.CoordinateSequence_getX(self, *args)
+ def getY(self, *args): return _geos.CoordinateSequence_getY(self, *args)
+ def getZ(self, *args): return _geos.CoordinateSequence_getZ(self, *args)
+ def getOrdinate(self, *args): return _geos.CoordinateSequence_getOrdinate(self, *args)
+ def getSize(self): return _geos.CoordinateSequence_getSize(self)
+ def getDimensions(self): return _geos.CoordinateSequence_getDimensions(self)
+CoordinateSequence_swigregister = _geos.CoordinateSequence_swigregister
+CoordinateSequence_swigregister(CoordinateSequence)
+class Geometry(object):
+ def __init__(self, *args, **kwargs): raise AttributeError("No constructor defined")
+ __swig_destroy__ = _geos.delete_Geometry
+ def clone(self): return _geos.Geometry_clone(self)
+ def geomType(self): return _geos.Geometry_geomType(self)
+ def typeId(self): return _geos.Geometry_typeId(self)
+ def normalize(self): return _geos.Geometry_normalize(self)
+ def getSRID(self): return _geos.Geometry_getSRID(self)
+ def setSRID(self, *args): return _geos.Geometry_setSRID(self, *args)
+ def getDimensions(self): return _geos.Geometry_getDimensions(self)
+ def getNumGeometries(self): return _geos.Geometry_getNumGeometries(self)
+ def intersection(self, *args): return _geos.Geometry_intersection(self, *args)
+ def buffer(self, *args): return _geos.Geometry_buffer(self, *args)
+ def convexHull(self): return _geos.Geometry_convexHull(self)
+ def difference(self, *args): return _geos.Geometry_difference(self, *args)
+ def symDifference(self, *args): return _geos.Geometry_symDifference(self, *args)
+ def boundary(self): return _geos.Geometry_boundary(self)
+ def union(self, *args): return _geos.Geometry_union(self, *args)
+ def pointOnSurface(self): return _geos.Geometry_pointOnSurface(self)
+ def getCentroid(self): return _geos.Geometry_getCentroid(self)
+ def getEnvelope(self): return _geos.Geometry_getEnvelope(self)
+ def relate(self, *args): return _geos.Geometry_relate(self, *args)
+ def lineMerge(self): return _geos.Geometry_lineMerge(self)
+ def simplify(self, *args): return _geos.Geometry_simplify(self, *args)
+ def topologyPreserveSimplify(self, *args): return _geos.Geometry_topologyPreserveSimplify(self, *args)
+ def relatePattern(self, *args): return _geos.Geometry_relatePattern(self, *args)
+ def disjoint(self, *args): return _geos.Geometry_disjoint(self, *args)
+ def touches(self, *args): return _geos.Geometry_touches(self, *args)
+ def intersects(self, *args): return _geos.Geometry_intersects(self, *args)
+ def crosses(self, *args): return _geos.Geometry_crosses(self, *args)
+ def within(self, *args): return _geos.Geometry_within(self, *args)
+ def contains(self, *args): return _geos.Geometry_contains(self, *args)
+ def overlaps(self, *args): return _geos.Geometry_overlaps(self, *args)
+ def equals(self, *args): return _geos.Geometry_equals(self, *args)
+ def equalsExact(self, *args): return _geos.Geometry_equalsExact(self, *args)
+ def isEmpty(self): return _geos.Geometry_isEmpty(self)
+ def isValid(self): return _geos.Geometry_isValid(self)
+ def isSimple(self): return _geos.Geometry_isSimple(self)
+ def isRing(self): return _geos.Geometry_isRing(self)
+ def hasZ(self): return _geos.Geometry_hasZ(self)
+ def area(self): return _geos.Geometry_area(self)
+ def length(self): return _geos.Geometry_length(self)
+ def distance(self, *args): return _geos.Geometry_distance(self, *args)
+Geometry_swigregister = _geos.Geometry_swigregister
+Geometry_swigregister(Geometry)
+class Point(Geometry):
+ __swig_destroy__ = _geos.delete_Point
+ def getCoordSeq(self): return _geos.Point_getCoordSeq(self)
+Point_swigregister = _geos.Point_swigregister
+Point_swigregister(Point)
+class LineString(Geometry):
+ __swig_destroy__ = _geos.delete_LineString
+ def getCoordSeq(self): return _geos.LineString_getCoordSeq(self)
+LineString_swigregister = _geos.LineString_swigregister
+LineString_swigregister(LineString)
+class LinearRing(Geometry):
+ __swig_destroy__ = _geos.delete_LinearRing
+ def getCoordSeq(self): return _geos.LinearRing_getCoordSeq(self)
+LinearRing_swigregister = _geos.LinearRing_swigregister
+LinearRing_swigregister(LinearRing)
+class Polygon(Geometry):
+ __swig_destroy__ = _geos.delete_Polygon
+ def getExteriorRing(self): return _geos.Polygon_getExteriorRing(self)
+ def getNumInteriorRings(self): return _geos.Polygon_getNumInteriorRings(self)
+ def getInteriorRingN(self, *args): return _geos.Polygon_getInteriorRingN(self, *args)
+Polygon_swigregister = _geos.Polygon_swigregister
+Polygon_swigregister(Polygon)
+class GeometryCollection(Geometry):
+ __swig_destroy__ = _geos.delete_GeometryCollection
+ def getGeometryN(self, *args): return _geos.GeometryCollection_getGeometryN(self, *args)
+GeometryCollection_swigregister = _geos.GeometryCollection_swigregister
+GeometryCollection_swigregister(GeometryCollection)
+class MultiPoint(GeometryCollection):
+ __swig_destroy__ = _geos.delete_MultiPoint
+MultiPoint_swigregister = _geos.MultiPoint_swigregister
+MultiPoint_swigregister(MultiPoint)
+class MultiLineString(GeometryCollection):
+ __swig_destroy__ = _geos.delete_MultiLineString
+MultiLineString_swigregister = _geos.MultiLineString_swigregister
+MultiLineString_swigregister(MultiLineString)
+class MultiLinearRing(GeometryCollection):
+ __swig_destroy__ = _geos.delete_MultiLinearRing
+MultiLinearRing_swigregister = _geos.MultiLinearRing_swigregister
+MultiLinearRing_swigregister(MultiLinearRing)
+class MultiPolygon(GeometryCollection):
+ __swig_destroy__ = _geos.delete_MultiPolygon
+MultiPolygon_swigregister = _geos.MultiPolygon_swigregister
+MultiPolygon_swigregister(MultiPolygon)
+def createPoint(*args):
+ return _geos.createPoint(*args)
+createPoint = _geos.createPoint
+def createLineString(*args):
+ return _geos.createLineString(*args)
+createLineString = _geos.createLineString
+def createLinearRing(*args):
+ return _geos.createLinearRing(*args)
+createLinearRing = _geos.createLinearRing
+def createPolygon(*args):
+ return _geos.createPolygon(*args)
+createPolygon = _geos.createPolygon
+class Prepared(object):
+ this = _geos.new_Prepared(*args)
+ __swig_destroy__ = _geos.delete_Prepared
+ def contains(self, *args): return _geos.Prepared_contains(self, *args)
+ def containsProperly(self, *args): return _geos.Prepared_containsProperly(self, *args)
+ def covers(self, *args): return _geos.Prepared_covers(self, *args)
+ def intersects(self, *args): return _geos.Prepared_intersects(self, *args)
+Prepared_swigregister = _geos.Prepared_swigregister
+Prepared_swigregister(Prepared)
+class STRtree(object):
+ this = _geos.new_STRtree(*args)
+ __swig_destroy__ = _geos.delete_STRtree
+ def insert(self, *args): return _geos.STRtree_insert(self, *args)
+ def remove(self, *args): return _geos.STRtree_remove(self, *args)
+ def query(self, *args): return _geos.STRtree_query(self, *args)
+ def iterate(self, *args): return _geos.STRtree_iterate(self, *args)
+STRtree_swigregister = _geos.STRtree_swigregister
+STRtree_swigregister(STRtree)
+class WktReader(object):
+ def __init__(self):
+ this = _geos.new_WktReader()
+ __swig_destroy__ = _geos.delete_WktReader
+ def read(self, *args): return _geos.WktReader_read(self, *args)
+WktReader_swigregister = _geos.WktReader_swigregister
+WktReader_swigregister(WktReader)
+class WktWriter(object):
+ this = _geos.new_WktWriter()
+ __swig_destroy__ = _geos.delete_WktWriter
+ def write(self, *args): return _geos.WktWriter_write(self, *args)
+WktWriter_swigregister = _geos.WktWriter_swigregister
+WktWriter_swigregister(WktWriter)
+class WkbReader(object):
+ this = _geos.new_WkbReader()
+ __swig_destroy__ = _geos.delete_WkbReader
+ def read(self, *args): return _geos.WkbReader_read(self, *args)
+ def readHEX(self, *args): return _geos.WkbReader_readHEX(self, *args)
+WkbReader_swigregister = _geos.WkbReader_swigregister
+WkbReader_swigregister(WkbReader)
+class WkbWriter(object):
+ this = _geos.new_WkbWriter()
+ __swig_destroy__ = _geos.delete_WkbWriter
+ def getOutputDimension(self): return _geos.WkbWriter_getOutputDimension(self)
+ def setOutputDimension(self, *args): return _geos.WkbWriter_setOutputDimension(self, *args)
+ def getByteOrder(self): return _geos.WkbWriter_getByteOrder(self)
+ def setByteOrder(self, *args): return _geos.WkbWriter_setByteOrder(self, *args)
+ def getIncludeSRID(self): return _geos.WkbWriter_getIncludeSRID(self)
+ def setIncludeSRID(self, *args): return _geos.WkbWriter_setIncludeSRID(self, *args)
+ def write(self, *args): return _geos.WkbWriter_write(self, *args)
+ def writeHEX(self, *args): return _geos.WkbWriter_writeHEX(self, *args)
+WkbWriter_swigregister = _geos.WkbWriter_swigregister
+WkbWriter_swigregister(WkbWriter)
Modified: branches/3.3/swig/python/geos_wrap.cxx
--- branches/3.3/swig/python/geos_wrap.cxx 2012-04-05 16:47:56 UTC (rev 3599)
+++ branches/3.3/swig/python/geos_wrap.cxx 2012-04-05 16:49:22 UTC (rev 3600)
@@ -1,9253 +1,10726 @@
- * This file was automatically generated by SWIG (http://www.swig.org).
- * Version 1.3.31
- * This file is not intended to be easily readable and contains a number of
- * coding conventions designed to improve portability and efficiency. Do not make
- * changes to this file unless you know what you are doing--modify the SWIG
- * interface file instead.
-#define SWIGPYTHON
-#define SWIG_PYTHON_DIRECTOR_NO_VTABLE
-#ifdef __cplusplus
-template<class T> class SwigValueWrapper {
- T *tt;
-public:
- SwigValueWrapper() : tt(0) { }
- SwigValueWrapper(const SwigValueWrapper<T>& rhs) : tt(new T(*rhs.tt)) { }
- SwigValueWrapper(const T& t) : tt(new T(t)) { }
- ~SwigValueWrapper() { delete tt; }
- SwigValueWrapper& operator=(const T& t) { delete tt; tt = new T(t); return *this; }
- operator T&() const { return *tt; }
- T *operator&() { return tt; }
-private:
- SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
-#endif
- * This section contains generic SWIG labels for method/variable
- * declarations/attributes, and other compiler dependent labels.
-/* template workaround for compilers that cannot correctly implement the C++ standard */
-#ifndef SWIGTEMPLATEDISAMBIGUATOR
-# if defined(__SUNPRO_CC)
-# if (__SUNPRO_CC <= 0x560)
-# define SWIGTEMPLATEDISAMBIGUATOR template
-# else
-# endif
-# else
-# endif
-#endif
-/* inline attribute */
-#ifndef SWIGINLINE
-# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
-# define SWIGINLINE inline
-# else
-# endif
-#endif
-/* attribute recognised by some compilers to avoid 'unused' warnings */
-#ifndef SWIGUNUSED
-# if defined(__GNUC__)
-# if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
-# define SWIGUNUSED __attribute__ ((__unused__))
-# else
-# endif
-# elif defined(__ICC)
-# else
-# endif
-#endif
-#ifndef SWIGUNUSEDPARM
-# ifdef __cplusplus
-# define SWIGUNUSEDPARM(p)
-# else
-# define SWIGUNUSEDPARM(p) p SWIGUNUSED
-# endif
-#endif
-/* internal SWIG method */
-#ifndef SWIGINTERN
-# define SWIGINTERN static SWIGUNUSED
-#endif
-/* internal inline SWIG method */
-#ifndef SWIGINTERNINLINE
-# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
-#endif
-/* exporting methods */
-#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
-# ifndef GCC_HASCLASSVISIBILITY
-# define GCC_HASCLASSVISIBILITY
-# endif
-#endif
-#ifndef SWIGEXPORT
-# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-# if defined(STATIC_LINKED)
-# define SWIGEXPORT
-# else
-# define SWIGEXPORT __declspec(dllexport)
-# endif
-# else
-# if defined(__GNUC__) && defined(GCC_HASCLASSVISIBILITY)
-# define SWIGEXPORT __attribute__ ((visibility("default")))
-# else
-# endif
-# endif
-#endif
-/* calling conventions for Windows */
-#ifndef SWIGSTDCALL
-# define SWIGSTDCALL __stdcall
-# else
-# endif
-#endif
-/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
-#if !defined(SWIG_NO_CRT_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
-# define _CRT_SECURE_NO_DEPRECATE
-#endif
-/* Python.h has to appear first */
-#ifdef _DEBUG
-#undef _DEBUG
-#include <Python.h>
-#define _DEBUG
-#undef _CRT_MANIFEST_RETAIL
-#else
-#endif
- * swigrun.swg
- * This file contains generic CAPI SWIG runtime support for pointer
- * type checking.
-/* This should only be incremented when either the layout of swig_type_info changes,
- or for whatever reason, the runtime changes incompatibly */
-#define SWIG_RUNTIME_VERSION "3"
-/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
-#ifdef SWIG_TYPE_TABLE
-# define SWIG_QUOTE_STRING(x) #x
-# define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
-# define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
-#else
-#endif
- You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
- creating a static or dynamic library from the swig runtime code.
- In 99.9% of the cases, swig just needs to declare them as 'static'.
- But only do this if is strictly necessary, ie, if you have problems
- with your compiler or so.
-#ifndef SWIGRUNTIME
-# define SWIGRUNTIME SWIGINTERN
-#endif
-#ifndef SWIGRUNTIMEINLINE
-# define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
-#endif
-/* Generic buffer size */
-#ifndef SWIG_BUFFER_SIZE
-# define SWIG_BUFFER_SIZE 1024
-#endif
-/* Flags for pointer conversions */
-#define SWIG_POINTER_DISOWN 0x1
-/* Flags for new pointer objects */
-#define SWIG_POINTER_OWN 0x1
- Flags/methods for returning states.
- The swig conversion methods, as ConvertPtr, return and integer
- that tells if the conversion was successful or not. And if not,
- an error code can be returned (see swigerrors.swg for the codes).
- Use the following macros/flags to set or process the returning
- states.
- In old swig versions, you usually write code as:
- if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
- // success code
- } else {
- //fail code
- Now you can be more explicit as:
- int res = SWIG_ConvertPtr(obj,vptr,ty.flags);
- if (SWIG_IsOK(res)) {
- // success code
- } else {
- // fail code
- that seems to be the same, but now you can also do
- Type *ptr;
- int res = SWIG_ConvertPtr(obj,(void **)(&ptr),ty.flags);
- // success code
- if (SWIG_IsNewObj(res) {
- delete *ptr;
- } else {
- } else {
- // fail code
- I.e., now SWIG_ConvertPtr can return new objects and you can
- identify the case and take care of the deallocation. Of course that
- requires also to SWIG_ConvertPtr to return new result values, as
- int SWIG_ConvertPtr(obj, ptr,...) {
- if (<obj is ok>) {
- if (<need new object>) {
- *ptr = <ptr to new allocated object>;
- return SWIG_NEWOBJ;
- } else {
- *ptr = <ptr to old object>;
- return SWIG_OLDOBJ;
- } else {
- return SWIG_BADOBJ;
- Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
- more explicit by returning SWIG_BADOBJ, SWIG_ERROR or any of the
- swig errors code.
- Finally, if the SWIG_CASTRANK_MODE is enabled, the result code
- allows to return the 'cast rank', for example, if you have this
- int food(double)
- int fooi(int);
- and you call
- food(1) // cast rank '1' (1 -> 1.0)
- fooi(1) // cast rank '0'
- just use the SWIG_AddCast()/SWIG_CheckState()
-#define SWIG_OK (0)
-#define SWIG_ERROR (-1)
-#define SWIG_IsOK(r) (r >= 0)
-#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
-/* The CastRankLimit says how many bits are used for the cast rank */
-#define SWIG_CASTRANKLIMIT (1 << 8)
-/* The NewMask denotes the object was created (using new/malloc) */
-#define SWIG_NEWOBJMASK (SWIG_CASTRANKLIMIT << 1)
-/* The TmpMask is for in/out typemaps that use temporal objects */
-#define SWIG_TMPOBJMASK (SWIG_NEWOBJMASK << 1)
-/* Simple returning values */
-#define SWIG_BADOBJ (SWIG_ERROR)
-#define SWIG_OLDOBJ (SWIG_OK)
-#define SWIG_NEWOBJ (SWIG_OK | SWIG_NEWOBJMASK)
-#define SWIG_TMPOBJ (SWIG_OK | SWIG_TMPOBJMASK)
-/* Check, add and del mask methods */
-#define SWIG_AddNewMask(r) (SWIG_IsOK(r) ? (r | SWIG_NEWOBJMASK) : r)
-#define SWIG_DelNewMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_NEWOBJMASK) : r)
-#define SWIG_IsNewObj(r) (SWIG_IsOK(r) && (r & SWIG_NEWOBJMASK))
-#define SWIG_AddTmpMask(r) (SWIG_IsOK(r) ? (r | SWIG_TMPOBJMASK) : r)
-#define SWIG_DelTmpMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_TMPOBJMASK) : r)
-#define SWIG_IsTmpObj(r) (SWIG_IsOK(r) && (r & SWIG_TMPOBJMASK))
-/* Cast-Rank Mode */
-#if defined(SWIG_CASTRANK_MODE)
-# ifndef SWIG_TypeRank
-# define SWIG_TypeRank unsigned long
-# endif
-# ifndef SWIG_MAXCASTRANK /* Default cast allowed */
-# define SWIG_MAXCASTRANK (2)
-# endif
-# define SWIG_CASTRANKMASK ((SWIG_CASTRANKLIMIT) -1)
-# define SWIG_CastRank(r) (r & SWIG_CASTRANKMASK)
-SWIGINTERNINLINE int SWIG_AddCast(int r) {
- return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
-SWIGINTERNINLINE int SWIG_CheckState(int r) {
- return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
-#else /* no cast-rank mode */
-# define SWIG_AddCast
-# define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
-#endif
-#include <string.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef void *(*swig_converter_func)(void *);
-typedef struct swig_type_info *(*swig_dycast_func)(void **);
-/* Structure to store inforomation on one type */
-typedef struct swig_type_info {
- const char *name; /* mangled name of this type */
- const char *str; /* human readable name of this type */
- swig_dycast_func dcast; /* dynamic cast function down a hierarchy */
- struct swig_cast_info *cast; /* linked list of types that can cast into this type */
- void *clientdata; /* language specific type data */
- int owndata; /* flag if the structure owns the clientdata */
-} swig_type_info;
-/* Structure to store a type and conversion function used for casting */
-typedef struct swig_cast_info {
- swig_type_info *type; /* pointer to type that is equivalent to this type */
- swig_converter_func converter; /* function to cast the void pointers */
- struct swig_cast_info *next; /* pointer to next cast in linked list */
- struct swig_cast_info *prev; /* pointer to the previous cast */
-} swig_cast_info;
-/* Structure used to store module information
- * Each module generates one structure like this, and the runtime collects
- * all of these structures and stores them in a circularly linked list.*/
-typedef struct swig_module_info {
- swig_type_info **types; /* Array of pointers to swig_type_info structures that are in this module */
- size_t size; /* Number of types in this module */
- struct swig_module_info *next; /* Pointer to next element in circularly linked list */
- swig_type_info **type_initial; /* Array of initially generated type structures */
- swig_cast_info **cast_initial; /* Array of initially generated casting structures */
- void *clientdata; /* Language specific module data */
-} swig_module_info;
- Compare two type names skipping the space characters, therefore
- "char*" == "char *" and "Class<int>" == "Class<int >", etc.
- Return 0 when the two name types are equivalent, as in
- strncmp, but skipping ' '.
-SWIGRUNTIME int
-SWIG_TypeNameComp(const char *f1, const char *l1,
- const char *f2, const char *l2) {
- for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
- while ((*f1 == ' ') && (f1 != l1)) ++f1;
- while ((*f2 == ' ') && (f2 != l2)) ++f2;
- if (*f1 != *f2) return (*f1 > *f2) ? 1 : -1;
- return (l1 - f1) - (l2 - f2);
- Check type equivalence in a name list like <name1>|<name2>|...
- Return 0 if not equal, 1 if equal
-SWIGRUNTIME int
-SWIG_TypeEquiv(const char *nb, const char *tb) {
- int equiv = 0;
- const char* te = tb + strlen(tb);
- const char* ne = nb;
- while (!equiv && *ne) {
- for (nb = ne; *ne; ++ne) {
- if (*ne == '|') break;
- equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
- if (*ne) ++ne;
- return equiv;
- Return 0 if equal, -1 if nb < tb, 1 if nb > tb
-SWIGRUNTIME int
-SWIG_TypeCompare(const char *nb, const char *tb) {
- int equiv = 0;
- if (*ne) ++ne;
- return equiv;
-/* think of this as a c++ template<> or a scheme macro */
-#define SWIG_TypeCheck_Template(comparison, ty) \
- if (ty) { \
- swig_cast_info *iter = ty->cast; \
- while (iter) { \
- if (comparison) { \
- if (iter == ty->cast) return iter; \
- /* Move iter to the top of the linked list */ \
- iter->prev->next = iter->next; \
- if (iter->next) \
- iter->next->prev = iter->prev; \
- iter->next = ty->cast; \
- iter->prev = 0; \
- if (ty->cast) ty->cast->prev = iter; \
- ty->cast = iter; \
- return iter; \
- iter = iter->next; \
- return 0
- Check the typename
-SWIGRUNTIME swig_cast_info *
-SWIG_TypeCheck(const char *c, swig_type_info *ty) {
- SWIG_TypeCheck_Template(strcmp(iter->type->name, c) == 0, ty);
-/* Same as previous function, except strcmp is replaced with a pointer comparison */
-SWIG_TypeCheckStruct(swig_type_info *from, swig_type_info *into) {
- SWIG_TypeCheck_Template(iter->type == from, into);
- Cast a pointer up an inheritance hierarchy
-SWIGRUNTIMEINLINE void *
-SWIG_TypeCast(swig_cast_info *ty, void *ptr) {
- return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr);
- Dynamic pointer casting. Down an inheritance hierarchy
-SWIGRUNTIME swig_type_info *
-SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
- swig_type_info *lastty = ty;
- if (!ty || !ty->dcast) return ty;
- while (ty && (ty->dcast)) {
- ty = (*ty->dcast)(ptr);
- if (ty) lastty = ty;
- return lastty;
- Return the name associated with this type
-SWIGRUNTIMEINLINE const char *
-SWIG_TypeName(const swig_type_info *ty) {
- return ty->name;
- Return the pretty name associated with this type,
- that is an unmangled type name in a form presentable to the user.
-SWIGRUNTIME const char *
-SWIG_TypePrettyName(const swig_type_info *type) {
- /* The "str" field contains the equivalent pretty names of the
- type, separated by vertical-bar characters. We choose
- to print the last name, as it is often (?) the most
- specific. */
- if (!type) return NULL;
- if (type->str != NULL) {
- const char *last_name = type->str;
- const char *s;
- for (s = type->str; *s; s++)
- if (*s == '|') last_name = s+1;
- return last_name;
- else
- return type->name;
- Set the clientdata field for a type
-SWIGRUNTIME void
-SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
- swig_cast_info *cast = ti->cast;
- /* if (ti->clientdata == clientdata) return; */
- ti->clientdata = clientdata;
- while (cast) {
- if (!cast->converter) {
- swig_type_info *tc = cast->type;
- if (!tc->clientdata) {
- SWIG_TypeClientData(tc, clientdata);
- cast = cast->next;
-SWIGRUNTIME void
-SWIG_TypeNewClientData(swig_type_info *ti, void *clientdata) {
- SWIG_TypeClientData(ti, clientdata);
- ti->owndata = 1;
- Search for a swig_type_info structure only by mangled name
- Search is a O(log #types)
- We start searching at module start, and finish searching when start == end.
- Note: if start == end at the beginning of the function, we go all the way around
- the circular list.
-SWIG_MangledTypeQueryModule(swig_module_info *start,
- swig_module_info *end,
- const char *name) {
- swig_module_info *iter = start;
- do {
- if (iter->size) {
- register size_t l = 0;
- register size_t r = iter->size - 1;
- do {
- /* since l+r >= 0, we can (>> 1) instead (/ 2) */
- register size_t i = (l + r) >> 1;
- const char *iname = iter->types[i]->name;
- if (iname) {
- register int compare = strcmp(name, iname);
- if (compare == 0) {
- return iter->types[i];
- } else if (compare < 0) {
- if (i) {
- r = i - 1;
- } else {
- break;
- } else if (compare > 0) {
- l = i + 1;
- } else {
- break; /* should never happen */
- } while (l <= r);
- } while (iter != end);
- return 0;
- Search for a swig_type_info structure for either a mangled name or a human readable name.
- It first searches the mangled names of the types, which is a O(log #types)
- If a type is not found it then searches the human readable names, which is O(#types).
-SWIG_TypeQueryModule(swig_module_info *start,
- /* STEP 1: Search the name field using binary search */
- swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
- if (ret) {
- return ret;
- } else {
- /* STEP 2: If the type hasn't been found, do a complete search
- of the str field (the human readable name) */
- do {
- register size_t i = 0;
- for (; i < iter->size; ++i) {
- if (iter->types[i]->str && (SWIG_TypeEquiv(iter->types[i]->str, name)))
- /* neither found a match */
- return 0;
- Pack binary data into a string
-SWIGRUNTIME char *
-SWIG_PackData(char *c, void *ptr, size_t sz) {
- static const char hex[17] = "0123456789abcdef";
- register const unsigned char *u = (unsigned char *) ptr;
- register const unsigned char *eu = u + sz;
- for (; u != eu; ++u) {
- register unsigned char uu = *u;
- *(c++) = hex[(uu & 0xf0) >> 4];
- *(c++) = hex[uu & 0xf];
- return c;
- Unpack binary data from a string
-SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
- register unsigned char *u = (unsigned char *) ptr;
- register char d = *(c++);
- register unsigned char uu;
- if ((d >= '0') && (d <= '9'))
- uu = ((d - '0') << 4);
- else if ((d >= 'a') && (d <= 'f'))
- uu = ((d - ('a'-10)) << 4);
- else
- return (char *) 0;
- d = *(c++);
- uu |= (d - '0');
- uu |= (d - ('a'-10));
- else
- *u = uu;
- return c;
- Pack 'void *' into a string buffer.
-SWIGRUNTIME char *
-SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
- char *r = buff;
- if ((2*sizeof(void *) + 2) > bsz) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,&ptr,sizeof(void *));
- if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
- strcpy(r,name);
- return buff;
-SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
- if (*c != '_') {
- if (strcmp(c,"NULL") == 0) {
- *ptr = (void *) 0;
- return name;
- } else {
- return 0;
- return SWIG_UnpackData(++c,ptr,sizeof(void *));
-SWIGRUNTIME char *
-SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
- char *r = buff;
- size_t lname = (name ? strlen(name) : 0);
- if ((2*sz + 2 + lname) > bsz) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,ptr,sz);
- if (lname) {
- strncpy(r,name,lname+1);
- } else {
- *r = 0;
- return buff;
-SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
- if (*c != '_') {
- memset(ptr,0,sz);
- return name;
- } else {
- return 0;
- return SWIG_UnpackData(++c,ptr,sz);
-#ifdef __cplusplus
-#endif
-/* Errors in SWIG */
-#define SWIG_UnknownError -1
-#define SWIG_IOError -2
-#define SWIG_RuntimeError -3
-#define SWIG_IndexError -4
-#define SWIG_TypeError -5
-#define SWIG_DivisionByZero -6
-#define SWIG_OverflowError -7
-#define SWIG_SyntaxError -8
-#define SWIG_ValueError -9
-#define SWIG_SystemError -10
-#define SWIG_AttributeError -11
-#define SWIG_MemoryError -12
-#define SWIG_NullReferenceError -13
-/* Add PyOS_snprintf for old Pythons */
-#if PY_VERSION_HEX < 0x02020000
-# if defined(_MSC_VER) || defined(__BORLANDC__) || defined(_WATCOM)
-# define PyOS_snprintf _snprintf
-# else
-# define PyOS_snprintf snprintf
-# endif
-#endif
-/* A crude PyString_FromFormat implementation for old Pythons */
-#ifndef SWIG_PYBUFFER_SIZE
-# define SWIG_PYBUFFER_SIZE 1024
-#endif
-static PyObject *
-PyString_FromFormat(const char *fmt, ...) {
- va_list ap;
- char buf[SWIG_PYBUFFER_SIZE * 2];
- int res;
- va_start(ap, fmt);
- res = vsnprintf(buf, sizeof(buf), fmt, ap);
- va_end(ap);
- return (res < 0 || res >= (int)sizeof(buf)) ? 0 : PyString_FromString(buf);
-#endif
-/* Add PyObject_Del for old Pythons */
-#if PY_VERSION_HEX < 0x01060000
-# define PyObject_Del(op) PyMem_DEL((op))
-#endif
-#ifndef PyObject_DEL
-# define PyObject_DEL PyObject_Del
-#endif
-/* A crude PyExc_StopIteration exception for old Pythons */
-# ifndef PyExc_StopIteration
-# define PyExc_StopIteration PyExc_RuntimeError
-# endif
-# ifndef PyObject_GenericGetAttr
-# define PyObject_GenericGetAttr 0
-# endif
-#endif
-/* Py_NotImplemented is defined in 2.1 and up. */
-#if PY_VERSION_HEX < 0x02010000
-# ifndef Py_NotImplemented
-# define Py_NotImplemented PyExc_RuntimeError
-# endif
-#endif
-/* A crude PyString_AsStringAndSize implementation for old Pythons */
-# ifndef PyString_AsStringAndSize
-# define PyString_AsStringAndSize(obj, s, len) {*s = PyString_AsString(obj); *len = *s ? strlen(*s) : 0;}
-# endif
-#endif
-/* PySequence_Size for old Pythons */
-#if PY_VERSION_HEX < 0x02000000
-# ifndef PySequence_Size
-# define PySequence_Size PySequence_Length
-# endif
-#endif
-/* PyBool_FromLong for old Pythons */
-#if PY_VERSION_HEX < 0x02030000
-static
-PyObject *PyBool_FromLong(long ok)
- PyObject *result = ok ? Py_True : Py_False;
- Py_INCREF(result);
- return result;
-#endif
-/* Py_ssize_t for old Pythons */
-/* This code is as recommended by: */
-/* http://www.python.org/dev/peps/pep-0353/#conversion-guidelines */
-#if PY_VERSION_HEX < 0x02050000 && !defined(PY_SSIZE_T_MIN)
-typedef int Py_ssize_t;
-# define PY_SSIZE_T_MAX INT_MAX
-# define PY_SSIZE_T_MIN INT_MIN
-#endif
- * error manipulation
-SWIGRUNTIME PyObject*
-SWIG_Python_ErrorType(int code) {
- PyObject* type = 0;
- switch(code) {
- case SWIG_MemoryError:
- type = PyExc_MemoryError;
- break;
- case SWIG_IOError:
- type = PyExc_IOError;
- break;
- case SWIG_RuntimeError:
- type = PyExc_RuntimeError;
- break;
- case SWIG_IndexError:
- type = PyExc_IndexError;
- break;
- case SWIG_TypeError:
- type = PyExc_TypeError;
- break;
- case SWIG_DivisionByZero:
- type = PyExc_ZeroDivisionError;
- break;
- case SWIG_OverflowError:
- type = PyExc_OverflowError;
- break;
- case SWIG_SyntaxError:
- type = PyExc_SyntaxError;
- break;
- case SWIG_ValueError:
- type = PyExc_ValueError;
- break;
- case SWIG_SystemError:
- type = PyExc_SystemError;
- break;
- case SWIG_AttributeError:
- type = PyExc_AttributeError;
- break;
- default:
- return type;
-SWIGRUNTIME void
-SWIG_Python_AddErrorMsg(const char* mesg)
- PyObject *type = 0;
- PyObject *value = 0;
- PyObject *traceback = 0;
- if (PyErr_Occurred()) PyErr_Fetch(&type, &value, &traceback);
- if (value) {
- PyObject *old_str = PyObject_Str(value);
- PyErr_Clear();
- Py_XINCREF(type);
- PyErr_Format(type, "%s %s", PyString_AsString(old_str), mesg);
- Py_DECREF(old_str);
- Py_DECREF(value);
- } else {
- PyErr_Format(PyExc_RuntimeError, mesg);
-#if defined(SWIG_PYTHON_NO_THREADS)
-# if defined(SWIG_PYTHON_THREADS)
-# undef SWIG_PYTHON_THREADS
-# endif
-#endif
-#if defined(SWIG_PYTHON_THREADS) /* Threading support is enabled */
-# if !defined(SWIG_PYTHON_USE_GIL) && !defined(SWIG_PYTHON_NO_USE_GIL)
-# if (PY_VERSION_HEX >= 0x02030000) /* For 2.3 or later, use the PyGILState calls */
-# define SWIG_PYTHON_USE_GIL
-# endif
-# endif
-# if defined(SWIG_PYTHON_USE_GIL) /* Use PyGILState threads calls */
-# ifndef SWIG_PYTHON_INITIALIZE_THREADS
-# define SWIG_PYTHON_INITIALIZE_THREADS PyEval_InitThreads()
-# endif
-# ifdef __cplusplus /* C++ code */
- class SWIG_Python_Thread_Block {
- bool status;
- PyGILState_STATE state;
- public:
- void end() { if (status) { PyGILState_Release(state); status = false;} }
- SWIG_Python_Thread_Block() : status(true), state(PyGILState_Ensure()) {}
- ~SWIG_Python_Thread_Block() { end(); }
- class SWIG_Python_Thread_Allow {
- bool status;
- PyThreadState *save;
- public:
- void end() { if (status) { PyEval_RestoreThread(save); status = false; }}
- SWIG_Python_Thread_Allow() : status(true), save(PyEval_SaveThread()) {}
- ~SWIG_Python_Thread_Allow() { end(); }
-# define SWIG_PYTHON_THREAD_BEGIN_BLOCK SWIG_Python_Thread_Block _swig_thread_block
-# define SWIG_PYTHON_THREAD_END_BLOCK _swig_thread_block.end()
-# define SWIG_PYTHON_THREAD_BEGIN_ALLOW SWIG_Python_Thread_Allow _swig_thread_allow
-# define SWIG_PYTHON_THREAD_END_ALLOW _swig_thread_allow.end()
-# else /* C code */
-# define SWIG_PYTHON_THREAD_BEGIN_BLOCK PyGILState_STATE _swig_thread_block = PyGILState_Ensure()
-# define SWIG_PYTHON_THREAD_END_BLOCK PyGILState_Release(_swig_thread_block)
-# define SWIG_PYTHON_THREAD_BEGIN_ALLOW PyThreadState *_swig_thread_allow = PyEval_SaveThread()
-# define SWIG_PYTHON_THREAD_END_ALLOW PyEval_RestoreThread(_swig_thread_allow)
-# endif
-# else /* Old thread way, not implemented, user must provide it */
-# if !defined(SWIG_PYTHON_INITIALIZE_THREADS)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_BEGIN_BLOCK)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_END_BLOCK)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_BEGIN_ALLOW)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_END_ALLOW)
-# endif
-# endif
-#else /* No thread support */
-#endif
- * Python API portion that goes into the runtime
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* cc-mode */
-#endif
-#endif
- * Constant declarations
-/* Constant Types */
-#define SWIG_PY_POINTER 4
-#define SWIG_PY_BINARY 5
-/* Constant information structure */
-typedef struct swig_const_info {
- int type;
- char *name;
- long lvalue;
- double dvalue;
- void *pvalue;
- swig_type_info **ptype;
-} swig_const_info;
-#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
-#endif
-#endif
- * See the LICENSE file for information on copyright, usage and redistribution
- * of SWIG, and the README file for authors - http://www.swig.org/release.html.
- * pyrun.swg
- * This file contains the runtime support for Python modules
- * and includes code for managing global variables and pointer
- * type checking.
-/* Common SWIG API */
-/* for raw pointers */
-#define SWIG_Python_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
-#define SWIG_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtr(obj, pptr, type, flags)
-#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, own)
-#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(ptr, type, flags)
-#define SWIG_CheckImplicit(ty) SWIG_Python_CheckImplicit(ty)
-#define SWIG_AcquirePtr(ptr, src) SWIG_Python_AcquirePtr(ptr, src)
-#define swig_owntype int
-/* for raw packed data */
-#define SWIG_ConvertPacked(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
-#define SWIG_NewPackedObj(ptr, sz, type) SWIG_Python_NewPackedObj(ptr, sz, type)
-/* for class or struct pointers */
-#define SWIG_ConvertInstance(obj, pptr, type, flags) SWIG_ConvertPtr(obj, pptr, type, flags)
-#define SWIG_NewInstanceObj(ptr, type, flags) SWIG_NewPointerObj(ptr, type, flags)
-/* for C or C++ function pointers */
-#define SWIG_ConvertFunctionPtr(obj, pptr, type) SWIG_Python_ConvertFunctionPtr(obj, pptr, type)
-#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_Python_NewPointerObj(ptr, type, 0)
-/* for C++ member pointers, ie, member methods */
-#define SWIG_ConvertMember(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
-#define SWIG_NewMemberObj(ptr, sz, type) SWIG_Python_NewPackedObj(ptr, sz, type)
-/* Runtime API */
-#define SWIG_GetModule(clientdata) SWIG_Python_GetModule()
-#define SWIG_SetModule(clientdata, pointer) SWIG_Python_SetModule(pointer)
-#define SWIG_NewClientData(obj) PySwigClientData_New(obj)
-#define SWIG_SetErrorObj SWIG_Python_SetErrorObj
-#define SWIG_SetErrorMsg SWIG_Python_SetErrorMsg
-#define SWIG_ErrorType(code) SWIG_Python_ErrorType(code)
-#define SWIG_Error(code, msg) SWIG_Python_SetErrorMsg(SWIG_ErrorType(code), msg)
-#define SWIG_fail goto fail
-/* Runtime API implementation */
-/* Error manipulation */
-SWIGINTERN void
-SWIG_Python_SetErrorObj(PyObject *errtype, PyObject *obj) {
- SWIG_PYTHON_THREAD_BEGIN_BLOCK;
- PyErr_SetObject(errtype, obj);
- Py_DECREF(obj);
- SWIG_PYTHON_THREAD_END_BLOCK;
-SWIGINTERN void
-SWIG_Python_SetErrorMsg(PyObject *errtype, const char *msg) {
- PyErr_SetString(errtype, (char *) msg);
-#define SWIG_Python_Raise(obj, type, desc) SWIG_Python_SetErrorObj(SWIG_Python_ExceptionType(desc), obj)
-/* Set a constant value */
-SWIGINTERN void
-SWIG_Python_SetConstant(PyObject *d, const char *name, PyObject *obj) {
- PyDict_SetItemString(d, (char*) name, obj);
- Py_DECREF(obj);
-/* Append a value to the result obj */
-SWIGINTERN PyObject*
-SWIG_Python_AppendOutput(PyObject* result, PyObject* obj) {
-#if !defined(SWIG_PYTHON_OUTPUT_TUPLE)
- if (!result) {
- result = obj;
- } else if (result == Py_None) {
- Py_DECREF(result);
- result = obj;
- } else {
- if (!PyList_Check(result)) {
- PyObject *o2 = result;
- result = PyList_New(1);
- PyList_SetItem(result, 0, o2);
- PyList_Append(result,obj);
- Py_DECREF(obj);
- return result;
-#else
- PyObject* o2;
- PyObject* o3;
- if (!result) {
- result = obj;
- result = obj;
- } else {
- if (!PyTuple_Check(result)) {
- o2 = result;
- result = PyTuple_New(1);
- PyTuple_SET_ITEM(result, 0, o2);
- o3 = PyTuple_New(1);
- PyTuple_SET_ITEM(o3, 0, obj);
- o2 = result;
- result = PySequence_Concat(o2, o3);
- Py_DECREF(o2);
- Py_DECREF(o3);
- return result;
-#endif
-/* Unpack the argument tuple */
-SWIGINTERN int
-SWIG_Python_UnpackTuple(PyObject *args, const char *name, int min, int max, PyObject **objs)
- if (!args) {
- if (!min && !max) {
- return 1;
- } else {
- PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got none",
- name, (min == max ? "" : "at least "), min);
- return 0;
- if (!PyTuple_Check(args)) {
- PyErr_SetString(PyExc_SystemError, "UnpackTuple() argument list is not a tuple");
- return 0;
- } else {
- register int l = PyTuple_GET_SIZE(args);
- if (l < min) {
- PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got %d",
- name, (min == max ? "" : "at least "), min, l);
- return 0;
- } else if (l > max) {
- name, (min == max ? "" : "at most "), max, l);
- return 0;
- } else {
- register int i;
- for (i = 0; i < l; ++i) {
- objs[i] = PyTuple_GET_ITEM(args, i);
- for (; l < max; ++l) {
- objs[l] = 0;
- return i + 1;
-/* A functor is a function object with one single object argument */
-#if PY_VERSION_HEX >= 0x02020000
-#define SWIG_Python_CallFunctor(functor, obj) PyObject_CallFunctionObjArgs(functor, obj, NULL);
-#else
-#define SWIG_Python_CallFunctor(functor, obj) PyObject_CallFunction(functor, "O", obj);
-#endif
- Helper for static pointer initialization for both C and C++ code, for example
- static PyObject *SWIG_STATIC_POINTER(MyVar) = NewSomething(...);
-#ifdef __cplusplus
-#define SWIG_STATIC_POINTER(var) var
-#else
-#define SWIG_STATIC_POINTER(var) var = 0; if (!var) var
-#endif
- * Pointer declarations
-#define SWIG_POINTER_NOSHADOW (SWIG_POINTER_OWN << 1)
-#define SWIG_POINTER_NEW (SWIG_POINTER_NOSHADOW | SWIG_POINTER_OWN)
-#define SWIG_POINTER_IMPLICIT_CONV (SWIG_POINTER_DISOWN << 1)
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* cc-mode */
-#endif
-#endif
-/* How to access Py_None */
-#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-# ifndef SWIG_PYTHON_NO_BUILD_NONE
-# ifndef SWIG_PYTHON_BUILD_NONE
-# define SWIG_PYTHON_BUILD_NONE
-# endif
-# endif
-#endif
-#ifdef SWIG_PYTHON_BUILD_NONE
-# ifdef Py_None
-# undef Py_None
-# define Py_None SWIG_Py_None()
-# endif
-SWIGRUNTIMEINLINE PyObject *
-_SWIG_Py_None(void)
- PyObject *none = Py_BuildValue((char*)"");
- Py_DECREF(none);
- return none;
-SWIGRUNTIME PyObject *
-SWIG_Py_None(void)
- static PyObject *SWIG_STATIC_POINTER(none) = _SWIG_Py_None();
- return none;
-#endif
-/* The python void return value */
-SWIG_Py_Void(void)
- PyObject *none = Py_None;
- Py_INCREF(none);
- return none;
-/* PySwigClientData */
-typedef struct {
- PyObject *klass;
- PyObject *newraw;
- PyObject *newargs;
- PyObject *destroy;
- int delargs;
- int implicitconv;
-} PySwigClientData;
-SWIGRUNTIMEINLINE int
-SWIG_Python_CheckImplicit(swig_type_info *ty)
- PySwigClientData *data = (PySwigClientData *)ty->clientdata;
- return data ? data->implicitconv : 0;
-SWIG_Python_ExceptionType(swig_type_info *desc) {
- PySwigClientData *data = desc ? (PySwigClientData *) desc->clientdata : 0;
- PyObject *klass = data ? data->klass : 0;
- return (klass ? klass : PyExc_RuntimeError);
-SWIGRUNTIME PySwigClientData *
-PySwigClientData_New(PyObject* obj)
- if (!obj) {
- return 0;
- } else {
- PySwigClientData *data = (PySwigClientData *)malloc(sizeof(PySwigClientData));
- /* the klass element */
- data->klass = obj;
- Py_INCREF(data->klass);
- /* the newraw method and newargs arguments used to create a new raw instance */
- if (PyClass_Check(obj)) {
- data->newraw = 0;
- data->newargs = obj;
- Py_INCREF(obj);
- } else {
-#if (PY_VERSION_HEX < 0x02020000)
- data->newraw = 0;
-#else
- data->newraw = PyObject_GetAttrString(data->klass, (char *)"__new__");
-#endif
- if (data->newraw) {
- Py_INCREF(data->newraw);
- data->newargs = PyTuple_New(1);
- PyTuple_SetItem(data->newargs, 0, obj);
- } else {
- Py_INCREF(data->newargs);
- /* the destroy method, aka as the C++ delete method */
- data->destroy = PyObject_GetAttrString(data->klass, (char *)"__swig_destroy__");
- if (PyErr_Occurred()) {
- PyErr_Clear();
- data->destroy = 0;
- if (data->destroy) {
- int flags;
- Py_INCREF(data->destroy);
- flags = PyCFunction_GET_FLAGS(data->destroy);
-#ifdef METH_O
- data->delargs = !(flags & (METH_O));
-#else
- data->delargs = 0;
-#endif
- } else {
- data->implicitconv = 0;
- return data;
-SWIGRUNTIME void
-PySwigClientData_Del(PySwigClientData* data)
- Py_XDECREF(data->newraw);
- Py_XDECREF(data->newargs);
- Py_XDECREF(data->destroy);
-/* =============== PySwigObject =====================*/
-typedef struct {
- PyObject_HEAD
- void *ptr;
- swig_type_info *ty;
- int own;
- PyObject *next;
-} PySwigObject;
-PySwigObject_long(PySwigObject *v)
- return PyLong_FromVoidPtr(v->ptr);
-PySwigObject_format(const char* fmt, PySwigObject *v)
- PyObject *res = NULL;
- PyObject *args = PyTuple_New(1);
- if (args) {
- if (PyTuple_SetItem(args, 0, PySwigObject_long(v)) == 0) {
- PyObject *ofmt = PyString_FromString(fmt);
- if (ofmt) {
- res = PyString_Format(ofmt,args);
- Py_DECREF(ofmt);
- Py_DECREF(args);
- return res;
-PySwigObject_oct(PySwigObject *v)
- return PySwigObject_format("%o",v);
-PySwigObject_hex(PySwigObject *v)
- return PySwigObject_format("%x",v);
-#ifdef METH_NOARGS
-PySwigObject_repr(PySwigObject *v)
-#else
-PySwigObject_repr(PySwigObject *v, PyObject *args)
-#endif
- const char *name = SWIG_TypePrettyName(v->ty);
- PyObject *hex = PySwigObject_hex(v);
- PyObject *repr = PyString_FromFormat("<Swig Object of type '%s' at 0x%s>", name, PyString_AsString(hex));
- Py_DECREF(hex);
- if (v->next) {
-#ifdef METH_NOARGS
- PyObject *nrep = PySwigObject_repr((PySwigObject *)v->next);
-#else
- PyObject *nrep = PySwigObject_repr((PySwigObject *)v->next, args);
-#endif
- PyString_ConcatAndDel(&repr,nrep);
- return repr;
-SWIGRUNTIME int
-PySwigObject_print(PySwigObject *v, FILE *fp, int SWIGUNUSEDPARM(flags))
-#ifdef METH_NOARGS
- PyObject *repr = PySwigObject_repr(v);
-#else
- PyObject *repr = PySwigObject_repr(v, NULL);
-#endif
- if (repr) {
- fputs(PyString_AsString(repr), fp);
- Py_DECREF(repr);
- return 0;
- } else {
- return 1;
-PySwigObject_str(PySwigObject *v)
- char result[SWIG_BUFFER_SIZE];
- return SWIG_PackVoidPtr(result, v->ptr, v->ty->name, sizeof(result)) ?
- PyString_FromString(result) : 0;
-SWIGRUNTIME int
-PySwigObject_compare(PySwigObject *v, PySwigObject *w)
- void *i = v->ptr;
- void *j = w->ptr;
- return (i < j) ? -1 : ((i > j) ? 1 : 0);
-SWIGRUNTIME PyTypeObject* _PySwigObject_type(void);
-PySwigObject_type(void) {
- static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigObject_type();
- return type;
-PySwigObject_Check(PyObject *op) {
- return ((op)->ob_type == PySwigObject_type())
- || (strcmp((op)->ob_type->tp_name,"PySwigObject") == 0);
-PySwigObject_New(void *ptr, swig_type_info *ty, int own);
-SWIGRUNTIME void
-PySwigObject_dealloc(PyObject *v)
- PySwigObject *sobj = (PySwigObject *) v;
- PyObject *next = sobj->next;
- if (sobj->own) {
- swig_type_info *ty = sobj->ty;
- PySwigClientData *data = ty ? (PySwigClientData *) ty->clientdata : 0;
- PyObject *destroy = data ? data->destroy : 0;
- if (destroy) {
- /* destroy is always a VARARGS method */
- PyObject *res;
- if (data->delargs) {
- /* we need to create a temporal object to carry the destroy operation */
- PyObject *tmp = PySwigObject_New(sobj->ptr, ty, 0);
- res = SWIG_Python_CallFunctor(destroy, tmp);
- Py_DECREF(tmp);
- } else {
- PyCFunction meth = PyCFunction_GET_FUNCTION(destroy);
- PyObject *mself = PyCFunction_GET_SELF(destroy);
- res = ((*meth)(mself, v));
- Py_XDECREF(res);
- } else {
- const char *name = SWIG_TypePrettyName(ty);
-#if !defined(SWIG_PYTHON_SILENT_MEMLEAK)
- printf("swig/python detected a memory leak of type '%s', no destructor found.\n", name);
-#endif
- Py_XDECREF(next);
- PyObject_DEL(v);
-PySwigObject_append(PyObject* v, PyObject* next)
-#ifndef METH_O
- PyObject *tmp = 0;
- if (!PyArg_ParseTuple(next,(char *)"O:append", &tmp)) return NULL;
- next = tmp;
-#endif
- if (!PySwigObject_Check(next)) {
- return NULL;
- sobj->next = next;
- Py_INCREF(next);
- return SWIG_Py_Void();
-#ifdef METH_NOARGS
-PySwigObject_next(PyObject* v)
-#else
-PySwigObject_next(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
-#endif
- if (sobj->next) {
- Py_INCREF(sobj->next);
- return sobj->next;
- } else {
-#ifdef METH_NOARGS
-PySwigObject_disown(PyObject *v)
-#else
-PySwigObject_disown(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
-#endif
- PySwigObject *sobj = (PySwigObject *)v;
- sobj->own = 0;
-#ifdef METH_NOARGS
-PySwigObject_acquire(PyObject *v)
-#else
-PySwigObject_acquire(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
-#endif
- sobj->own = SWIG_POINTER_OWN;
-PySwigObject_own(PyObject *v, PyObject *args)
- PyObject *val = 0;
- if (!PyArg_ParseTuple(args,(char *)"|O:own",&val))
-#else
- if (!PyArg_UnpackTuple(args, (char *)"own", 0, 1, &val))
-#endif
- return NULL;
- else
- PyObject *obj = PyBool_FromLong(sobj->own);
- if (val) {
-#ifdef METH_NOARGS
- if (PyObject_IsTrue(val)) {
- PySwigObject_acquire(v);
- } else {
- PySwigObject_disown(v);
-#else
- PySwigObject_acquire(v,args);
- } else {
- PySwigObject_disown(v,args);
-#endif
- return obj;
-#ifdef METH_O
-static PyMethodDef
-swigobject_methods[] = {
- {(char *)"disown", (PyCFunction)PySwigObject_disown, METH_NOARGS, (char *)"releases ownership of the pointer"},
- {(char *)"acquire", (PyCFunction)PySwigObject_acquire, METH_NOARGS, (char *)"aquires ownership of the pointer"},
- {(char *)"own", (PyCFunction)PySwigObject_own, METH_VARARGS, (char *)"returns/sets ownership of the pointer"},
- {(char *)"append", (PyCFunction)PySwigObject_append, METH_O, (char *)"appends another 'this' object"},
- {(char *)"next", (PyCFunction)PySwigObject_next, METH_NOARGS, (char *)"returns the next 'this' object"},
- {(char *)"__repr__",(PyCFunction)PySwigObject_repr, METH_NOARGS, (char *)"returns object representation"},
- {0, 0, 0, 0}
-#else
-static PyMethodDef
- {(char *)"disown", (PyCFunction)PySwigObject_disown, METH_VARARGS, (char *)"releases ownership of the pointer"},
- {(char *)"acquire", (PyCFunction)PySwigObject_acquire, METH_VARARGS, (char *)"aquires ownership of the pointer"},
- {(char *)"append", (PyCFunction)PySwigObject_append, METH_VARARGS, (char *)"appends another 'this' object"},
- {(char *)"next", (PyCFunction)PySwigObject_next, METH_VARARGS, (char *)"returns the next 'this' object"},
- {(char *)"__repr__",(PyCFunction)PySwigObject_repr, METH_VARARGS, (char *)"returns object representation"},
- {0, 0, 0, 0}
-#endif
-SWIGINTERN PyObject *
-PySwigObject_getattr(PySwigObject *sobj,char *name)
- return Py_FindMethod(swigobject_methods, (PyObject *)sobj, name);
-#endif
-_PySwigObject_type(void) {
- static char swigobject_doc[] = "Swig object carries a C/C++ instance pointer";
- static PyNumberMethods PySwigObject_as_number = {
- (binaryfunc)0, /*nb_add*/
- (binaryfunc)0, /*nb_subtract*/
- (binaryfunc)0, /*nb_multiply*/
- (binaryfunc)0, /*nb_divide*/
- (binaryfunc)0, /*nb_remainder*/
- (binaryfunc)0, /*nb_divmod*/
- (ternaryfunc)0,/*nb_power*/
- (unaryfunc)0, /*nb_negative*/
- (unaryfunc)0, /*nb_positive*/
- (unaryfunc)0, /*nb_absolute*/
- (inquiry)0, /*nb_nonzero*/
- 0, /*nb_invert*/
- 0, /*nb_lshift*/
- 0, /*nb_rshift*/
- 0, /*nb_and*/
- 0, /*nb_xor*/
- 0, /*nb_or*/
- (coercion)0, /*nb_coerce*/
- (unaryfunc)PySwigObject_long, /*nb_int*/
- (unaryfunc)PySwigObject_long, /*nb_long*/
- (unaryfunc)0, /*nb_float*/
- (unaryfunc)PySwigObject_oct, /*nb_oct*/
- (unaryfunc)PySwigObject_hex, /*nb_hex*/
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_true_divide */
-#elif PY_VERSION_HEX >= 0x02000000
- 0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_or */
-#endif
- static PyTypeObject pyswigobject_type;
- static int type_init = 0;
- if (!type_init) {
- const PyTypeObject tmp
- PyObject_HEAD_INIT(NULL)
- 0, /* ob_size */
- (char *)"PySwigObject", /* tp_name */
- sizeof(PySwigObject), /* tp_basicsize */
- 0, /* tp_itemsize */
- (destructor)PySwigObject_dealloc, /* tp_dealloc */
- (printfunc)PySwigObject_print, /* tp_print */
- (getattrfunc)PySwigObject_getattr, /* tp_getattr */
-#else
- (getattrfunc)0, /* tp_getattr */
-#endif
- (setattrfunc)0, /* tp_setattr */
- (cmpfunc)PySwigObject_compare, /* tp_compare */
- (reprfunc)PySwigObject_repr, /* tp_repr */
- &PySwigObject_as_number, /* tp_as_number */
- 0, /* tp_as_sequence */
- 0, /* tp_as_mapping */
- (hashfunc)0, /* tp_hash */
- (ternaryfunc)0, /* tp_call */
- (reprfunc)PySwigObject_str, /* tp_str */
- PyObject_GenericGetAttr, /* tp_getattro */
- 0, /* tp_setattro */
- 0, /* tp_as_buffer */
- Py_TPFLAGS_DEFAULT, /* tp_flags */
- swigobject_doc, /* tp_doc */
- 0, /* tp_traverse */
- 0, /* tp_clear */
- 0, /* tp_richcompare */
- 0, /* tp_weaklistoffset */
- 0, /* tp_iter */
- 0, /* tp_iternext */
- swigobject_methods, /* tp_methods */
- 0, /* tp_members */
- 0, /* tp_getset */
- 0, /* tp_base */
- 0, /* tp_dict */
- 0, /* tp_descr_get */
- 0, /* tp_descr_set */
- 0, /* tp_dictoffset */
- 0, /* tp_init */
- 0, /* tp_alloc */
- 0, /* tp_new */
- 0, /* tp_free */
- 0, /* tp_is_gc */
- 0, /* tp_bases */
- 0, /* tp_mro */
- 0, /* tp_cache */
- 0, /* tp_subclasses */
- 0, /* tp_weaklist */
-#endif
-#if PY_VERSION_HEX >= 0x02030000
- 0, /* tp_del */
-#endif
-#ifdef COUNT_ALLOCS
- 0,0,0,0 /* tp_alloc -> tp_next */
-#endif
- pyswigobject_type = tmp;
- pyswigobject_type.ob_type = &PyType_Type;
- type_init = 1;
- return &pyswigobject_type;
- PySwigObject *sobj = PyObject_NEW(PySwigObject, PySwigObject_type());
- if (sobj) {
- sobj->ptr = ptr;
- sobj->ty = ty;
- sobj->own = own;
- sobj->next = 0;
- return (PyObject *)sobj;
- * Implements a simple Swig Packed type, and use it instead of string
-typedef struct {
- PyObject_HEAD
- void *pack;
- size_t size;
-} PySwigPacked;
-SWIGRUNTIME int
-PySwigPacked_print(PySwigPacked *v, FILE *fp, int SWIGUNUSEDPARM(flags))
- fputs("<Swig Packed ", fp);
- if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))) {
- fputs("at ", fp);
- fputs(result, fp);
- fputs(v->ty->name,fp);
- fputs(">", fp);
- return 0;
-PySwigPacked_repr(PySwigPacked *v)
- return PyString_FromFormat("<Swig Packed at %s%s>", result, v->ty->name);
- } else {
- return PyString_FromFormat("<Swig Packed %s>", v->ty->name);
-PySwigPacked_str(PySwigPacked *v)
- if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))){
- return PyString_FromFormat("%s%s", result, v->ty->name);
- } else {
- return PyString_FromString(v->ty->name);
-SWIGRUNTIME int
-PySwigPacked_compare(PySwigPacked *v, PySwigPacked *w)
- size_t i = v->size;
- size_t j = w->size;
- int s = (i < j) ? -1 : ((i > j) ? 1 : 0);
- return s ? s : strncmp((char *)v->pack, (char *)w->pack, 2*v->size);
-SWIGRUNTIME PyTypeObject* _PySwigPacked_type(void);
-PySwigPacked_type(void) {
- static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigPacked_type();
- return type;
-PySwigPacked_Check(PyObject *op) {
- return ((op)->ob_type == _PySwigPacked_type())
- || (strcmp((op)->ob_type->tp_name,"PySwigPacked") == 0);
-SWIGRUNTIME void
-PySwigPacked_dealloc(PyObject *v)
- if (PySwigPacked_Check(v)) {
- PySwigPacked *sobj = (PySwigPacked *) v;
- free(sobj->pack);
- PyObject_DEL(v);
-_PySwigPacked_type(void) {
- static char swigpacked_doc[] = "Swig object carries a C/C++ instance pointer";
- static PyTypeObject pyswigpacked_type;
- if (!type_init) {
- 0, /* ob_size */
- (char *)"PySwigPacked", /* tp_name */
- sizeof(PySwigPacked), /* tp_basicsize */
- (destructor)PySwigPacked_dealloc, /* tp_dealloc */
- (printfunc)PySwigPacked_print, /* tp_print */
- (cmpfunc)PySwigPacked_compare, /* tp_compare */
- (reprfunc)PySwigPacked_repr, /* tp_repr */
- 0, /* tp_as_number */
- (reprfunc)PySwigPacked_str, /* tp_str */
- swigpacked_doc, /* tp_doc */
- 0, /* tp_clear */
- 0, /* tp_iter */
- 0, /* tp_methods */
- 0, /* tp_base */
- 0, /* tp_dict */
- 0, /* tp_init */
- 0, /* tp_alloc */
- 0, /* tp_new */
- 0, /* tp_free */
- 0, /* tp_is_gc */
- 0, /* tp_bases */
- 0, /* tp_mro */
- 0, /* tp_cache */
-#endif
- 0, /* tp_del */
-#endif
-#endif
- pyswigpacked_type = tmp;
- pyswigpacked_type.ob_type = &PyType_Type;
- type_init = 1;
- return &pyswigpacked_type;
-PySwigPacked_New(void *ptr, size_t size, swig_type_info *ty)
- PySwigPacked *sobj = PyObject_NEW(PySwigPacked, PySwigPacked_type());
- if (sobj) {
- void *pack = malloc(size);
- if (pack) {
- memcpy(pack, ptr, size);
- sobj->pack = pack;
- sobj->ty = ty;
- sobj->size = size;
- } else {
- PyObject_DEL((PyObject *) sobj);
- sobj = 0;
- return (PyObject *) sobj;
-PySwigPacked_UnpackData(PyObject *obj, void *ptr, size_t size)
- if (PySwigPacked_Check(obj)) {
- PySwigPacked *sobj = (PySwigPacked *)obj;
- if (sobj->size != size) return 0;
- memcpy(ptr, sobj->pack, size);
- return sobj->ty;
- } else {
- return 0;
- * pointers/data manipulation
-_SWIG_This(void)
- return PyString_FromString("this");
-SWIG_This(void)
- static PyObject *SWIG_STATIC_POINTER(swig_this) = _SWIG_This();
- return swig_this;
-/* #define SWIG_PYTHON_SLOW_GETSET_THIS */
-SWIGRUNTIME PySwigObject *
-SWIG_Python_GetSwigThis(PyObject *pyobj)
- if (PySwigObject_Check(pyobj)) {
- return (PySwigObject *) pyobj;
- } else {
- PyObject *obj = 0;
-#if (!defined(SWIG_PYTHON_SLOW_GETSET_THIS) && (PY_VERSION_HEX >= 0x02030000))
- if (PyInstance_Check(pyobj)) {
- obj = _PyInstance_Lookup(pyobj, SWIG_This());
- } else {
- PyObject **dictptr = _PyObject_GetDictPtr(pyobj);
- if (dictptr != NULL) {
- PyObject *dict = *dictptr;
- obj = dict ? PyDict_GetItem(dict, SWIG_This()) : 0;
- } else {
-#ifdef PyWeakref_CheckProxy
- if (PyWeakref_CheckProxy(pyobj)) {
- PyObject *wobj = PyWeakref_GET_OBJECT(pyobj);
- return wobj ? SWIG_Python_GetSwigThis(wobj) : 0;
-#endif
- obj = PyObject_GetAttr(pyobj,SWIG_This());
- if (obj) {
- Py_DECREF(obj);
- } else {
- if (PyErr_Occurred()) PyErr_Clear();
- return 0;
-#else
- if (obj) {
- Py_DECREF(obj);
- } else {
- return 0;
-#endif
- if (obj && !PySwigObject_Check(obj)) {
- /* a PyObject is called 'this', try to get the 'real this'
- PySwigObject from it */
- return SWIG_Python_GetSwigThis(obj);
- return (PySwigObject *)obj;
-/* Acquire a pointer value */
-SWIGRUNTIME int
-SWIG_Python_AcquirePtr(PyObject *obj, int own) {
- if (own) {
- PySwigObject *sobj = SWIG_Python_GetSwigThis(obj);
- if (sobj) {
- int oldown = sobj->own;
- sobj->own = own;
- return oldown;
- return 0;
-/* Convert a pointer value */
-SWIGRUNTIME int
-SWIG_Python_ConvertPtrAndOwn(PyObject *obj, void **ptr, swig_type_info *ty, int flags, int *own) {
- if (!obj) return SWIG_ERROR;
- if (obj == Py_None) {
- if (ptr) *ptr = 0;
- return SWIG_OK;
- } else {
- while (sobj) {
- void *vptr = sobj->ptr;
- if (ty) {
- swig_type_info *to = sobj->ty;
- if (to == ty) {
- /* no type cast needed */
- if (ptr) *ptr = vptr;
- break;
- } else {
- swig_cast_info *tc = SWIG_TypeCheck(to->name,ty);
- if (!tc) {
- sobj = (PySwigObject *)sobj->next;
- } else {
- if (ptr) *ptr = SWIG_TypeCast(tc,vptr);
- break;
- } else {
- break;
- if (sobj) {
- if (own) *own = sobj->own;
- if (flags & SWIG_POINTER_DISOWN) {
- sobj->own = 0;
- return SWIG_OK;
- } else {
- int res = SWIG_ERROR;
- if (flags & SWIG_POINTER_IMPLICIT_CONV) {
- if (data && !data->implicitconv) {
- PyObject *klass = data->klass;
- if (klass) {
- PyObject *impconv;
- data->implicitconv = 1; /* avoid recursion and call 'explicit' constructors*/
- impconv = SWIG_Python_CallFunctor(klass, obj);
- PyErr_Clear();
- impconv = 0;
- if (impconv) {
- PySwigObject *iobj = SWIG_Python_GetSwigThis(impconv);
- if (iobj) {
- void *vptr;
- res = SWIG_Python_ConvertPtrAndOwn((PyObject*)iobj, &vptr, ty, 0, 0);
- if (ptr) {
- *ptr = vptr;
- /* transfer the ownership to 'ptr' */
- iobj->own = 0;
- res = SWIG_AddCast(res);
- res = SWIG_AddNewMask(res);
- } else {
- Py_DECREF(impconv);
- return res;
-/* Convert a function ptr value */
-SWIGRUNTIME int
-SWIG_Python_ConvertFunctionPtr(PyObject *obj, void **ptr, swig_type_info *ty) {
- if (!PyCFunction_Check(obj)) {
- return SWIG_ConvertPtr(obj, ptr, ty, 0);
- } else {
- void *vptr = 0;
- /* here we get the method pointer for callbacks */
- const char *doc = (((PyCFunctionObject *)obj) -> m_ml -> ml_doc);
- const char *desc = doc ? strstr(doc, "swig_ptr: ") : 0;
- if (desc) {
- desc = ty ? SWIG_UnpackVoidPtr(desc + 10, &vptr, ty->name) : 0;
- if (!desc) return SWIG_ERROR;
- if (ty) {
- swig_cast_info *tc = SWIG_TypeCheck(desc,ty);
- if (!tc) return SWIG_ERROR;
- *ptr = SWIG_TypeCast(tc,vptr);
- } else {
- *ptr = vptr;
- return SWIG_OK;
-/* Convert a packed value value */
-SWIGRUNTIME int
-SWIG_Python_ConvertPacked(PyObject *obj, void *ptr, size_t sz, swig_type_info *ty) {
- swig_type_info *to = PySwigPacked_UnpackData(obj, ptr, sz);
- if (!to) return SWIG_ERROR;
- if (ty) {
- if (to != ty) {
- /* check type cast? */
- return SWIG_OK;
- * Create a new pointer object
- Create a new instance object, whitout calling __init__, and set the
- 'this' attribute.
-SWIG_Python_NewShadowInstance(PySwigClientData *data, PyObject *swig_this)
-#if (PY_VERSION_HEX >= 0x02020000)
- PyObject *inst = 0;
- PyObject *newraw = data->newraw;
- if (newraw) {
- inst = PyObject_Call(newraw, data->newargs, NULL);
- if (inst) {
-#if !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
- PyObject **dictptr = _PyObject_GetDictPtr(inst);
- if (dict == NULL) {
- dict = PyDict_New();
- *dictptr = dict;
- PyDict_SetItem(dict, SWIG_This(), swig_this);
-#else
- PyObject *key = SWIG_This();
- PyObject_SetAttr(inst, key, swig_this);
-#endif
- } else {
- PyObject *dict = PyDict_New();
- inst = PyInstance_NewRaw(data->newargs, dict);
- Py_DECREF(dict);
- return inst;
-#else
-#if (PY_VERSION_HEX >= 0x02010000)
- PyObject *inst;
- Py_DECREF(dict);
- return (PyObject *) inst;
-#else
- PyInstanceObject *inst = PyObject_NEW(PyInstanceObject, &PyInstance_Type);
- if (inst == NULL) {
- return NULL;
- inst->in_class = (PyClassObject *)data->newargs;
- Py_INCREF(inst->in_class);
- inst->in_dict = PyDict_New();
- if (inst->in_dict == NULL) {
- Py_DECREF(inst);
- return NULL;
-#ifdef Py_TPFLAGS_HAVE_WEAKREFS
- inst->in_weakreflist = NULL;
-#endif
-#ifdef Py_TPFLAGS_GC
- PyObject_GC_Init(inst);
-#endif
- PyDict_SetItem(inst->in_dict, SWIG_This(), swig_this);
-#endif
-#endif
-SWIGRUNTIME void
-SWIG_Python_SetSwigThis(PyObject *inst, PyObject *swig_this)
- PyObject *dict;
-#if (PY_VERSION_HEX >= 0x02020000) && !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
- dict = *dictptr;
- *dictptr = dict;
- return;
-#endif
- dict = PyObject_GetAttrString(inst, (char*)"__dict__");
- Py_DECREF(dict);
-SWIG_Python_InitShadowInstance(PyObject *args) {
- PyObject *obj[2];
- if (!SWIG_Python_UnpackTuple(args,(char*)"swiginit", 2, 2, obj)) {
- return NULL;
- } else {
- PySwigObject *sthis = SWIG_Python_GetSwigThis(obj[0]);
- if (sthis) {
- PySwigObject_append((PyObject*) sthis, obj[1]);
- } else {
- SWIG_Python_SetSwigThis(obj[0], obj[1]);
-/* Create a new pointer object */
-SWIG_Python_NewPointerObj(void *ptr, swig_type_info *type, int flags) {
- if (!ptr) {
- } else {
- int own = (flags & SWIG_POINTER_OWN) ? SWIG_POINTER_OWN : 0;
- PyObject *robj = PySwigObject_New(ptr, type, own);
- PySwigClientData *clientdata = type ? (PySwigClientData *)(type->clientdata) : 0;
- if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
- PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
- if (inst) {
- Py_DECREF(robj);
- robj = inst;
- return robj;
-/* Create a new packed object */
-SWIG_Python_NewPackedObj(void *ptr, size_t sz, swig_type_info *type) {
- return ptr ? PySwigPacked_New((void *) ptr, sz, type) : SWIG_Py_Void();
- * Get type list
-#ifdef SWIG_LINK_RUNTIME
-void *SWIG_ReturnGlobalTypeList(void *);
-#endif
-SWIGRUNTIME swig_module_info *
-SWIG_Python_GetModule(void) {
- static void *type_pointer = (void *)0;
- /* first check if module already created */
- if (!type_pointer) {
- type_pointer = SWIG_ReturnGlobalTypeList((void *)0);
-#else
- type_pointer = PyCObject_Import((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
- (char*)"type_pointer" SWIG_TYPE_TABLE_NAME);
- PyErr_Clear();
- type_pointer = (void *)0;
-#endif
- return (swig_module_info *) type_pointer;
-#if PY_MAJOR_VERSION < 2
-/* PyModule_AddObject function was introduced in Python 2.0. The following function
- is copied out of Python/modsupport.c in python version 2.3.4 */
-SWIGINTERN int
-PyModule_AddObject(PyObject *m, char *name, PyObject *o)
- PyObject *dict;
- if (!PyModule_Check(m)) {
- PyErr_SetString(PyExc_TypeError,
- "PyModule_AddObject() needs module as first arg");
- return SWIG_ERROR;
- if (!o) {
- "PyModule_AddObject() needs non-NULL value");
- dict = PyModule_GetDict(m);
- /* Internal error -- modules must have a dict! */
- PyErr_Format(PyExc_SystemError, "module '%s' has no __dict__",
- PyModule_GetName(m));
- if (PyDict_SetItemString(dict, name, o))
- Py_DECREF(o);
- return SWIG_OK;
-#endif
-SWIGRUNTIME void
-SWIG_Python_DestroyModule(void *vptr)
- swig_module_info *swig_module = (swig_module_info *) vptr;
- swig_type_info **types = swig_module->types;
- size_t i;
- for (i =0; i < swig_module->size; ++i) {
- swig_type_info *ty = types[i];
- if (ty->owndata) {
- PySwigClientData *data = (PySwigClientData *) ty->clientdata;
- if (data) PySwigClientData_Del(data);
- Py_DECREF(SWIG_This());
-SWIGRUNTIME void
-SWIG_Python_SetModule(swig_module_info *swig_module) {
- static PyMethodDef swig_empty_runtime_method_table[] = { {NULL, NULL, 0, NULL} };/* Sentinel */
- PyObject *module = Py_InitModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
- swig_empty_runtime_method_table);
- PyObject *pointer = PyCObject_FromVoidPtr((void *) swig_module, SWIG_Python_DestroyModule);
- if (pointer && module) {
- PyModule_AddObject(module, (char*)"type_pointer" SWIG_TYPE_TABLE_NAME, pointer);
- } else {
- Py_XDECREF(pointer);
-/* The python cached type query */
-SWIG_Python_TypeCache(void) {
- static PyObject *SWIG_STATIC_POINTER(cache) = PyDict_New();
- return cache;
-SWIG_Python_TypeQuery(const char *type)
- PyObject *cache = SWIG_Python_TypeCache();
- PyObject *key = PyString_FromString(type);
- PyObject *obj = PyDict_GetItem(cache, key);
- swig_type_info *descriptor;
- if (obj) {
- descriptor = (swig_type_info *) PyCObject_AsVoidPtr(obj);
- } else {
- swig_module_info *swig_module = SWIG_Python_GetModule();
- descriptor = SWIG_TypeQueryModule(swig_module, swig_module, type);
- if (descriptor) {
- obj = PyCObject_FromVoidPtr(descriptor, NULL);
- PyDict_SetItem(cache, key, obj);
- Py_DECREF(obj);
- Py_DECREF(key);
- return descriptor;
- For backward compatibility only
-#define SWIG_POINTER_EXCEPTION 0
-#define SWIG_arg_fail(arg) SWIG_Python_ArgFail(arg)
-#define SWIG_MustGetPtr(p, type, argnum, flags) SWIG_Python_MustGetPtr(p, type, argnum, flags)
-SWIGRUNTIME int
-SWIG_Python_AddErrMesg(const char* mesg, int infront)
- PyErr_Fetch(&type, &value, &traceback);
- if (value) {
- Py_XINCREF(type);
- PyErr_Clear();
- if (infront) {
- PyErr_Format(type, "%s %s", mesg, PyString_AsString(old_str));
- } else {
- return 1;
- } else {
- return 0;
-SWIGRUNTIME int
-SWIG_Python_ArgFail(int argnum)
- /* add information about failing argument */
- char mesg[256];
- PyOS_snprintf(mesg, sizeof(mesg), "argument number %d:", argnum);
- return SWIG_Python_AddErrMesg(mesg, 1);
- } else {
- return 0;
-PySwigObject_GetDesc(PyObject *self)
- PySwigObject *v = (PySwigObject *)self;
- swig_type_info *ty = v ? v->ty : 0;
- return ty ? ty->str : (char*)"";
-SWIGRUNTIME void
-SWIG_Python_TypeError(const char *type, PyObject *obj)
- if (type) {
-#if defined(SWIG_COBJECT_TYPES)
- if (obj && PySwigObject_Check(obj)) {
- const char *otype = (const char *) PySwigObject_GetDesc(obj);
- if (otype) {
- PyErr_Format(PyExc_TypeError, "a '%s' is expected, 'PySwigObject(%s)' is received",
- type, otype);
- return;
- } else
-#endif
- const char *otype = (obj ? obj->ob_type->tp_name : 0);
- if (otype) {
- PyObject *str = PyObject_Str(obj);
- const char *cstr = str ? PyString_AsString(str) : 0;
- if (cstr) {
- PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s(%s)' is received",
- type, otype, cstr);
- } else {
- PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s' is received",
- type, otype);
- Py_XDECREF(str);
- return;
- PyErr_Format(PyExc_TypeError, "a '%s' is expected", type);
- } else {
- PyErr_Format(PyExc_TypeError, "unexpected type is received");
-/* Convert a pointer value, signal an exception on a type mismatch */
-SWIGRUNTIME void *
-SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int argnum, int flags) {
- void *result;
- if (SWIG_Python_ConvertPtr(obj, &result, ty, flags) == -1) {
- PyErr_Clear();
- if (flags & SWIG_POINTER_EXCEPTION) {
- SWIG_Python_TypeError(SWIG_TypePrettyName(ty), obj);
- SWIG_Python_ArgFail(argnum);
- return result;
-#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
-#endif
-#endif
-#define SWIG_exception_fail(code, msg) do { SWIG_Error(code, msg); SWIG_fail; } while(0)
-#define SWIG_contract_assert(expr, msg) if (!(expr)) { SWIG_Error(SWIG_RuntimeError, msg); SWIG_fail; } else
- #define SWIG_exception(code, msg) do { SWIG_Error(code, msg); SWIG_fail;; } while(0)
-/* -------- TYPES TABLE (BEGIN) -------- */
-#define SWIGTYPE_p_GeosCoordinateSequence swig_types[0]
-#define SWIGTYPE_p_GeosGeometry swig_types[1]
-#define SWIGTYPE_p_GeosGeometryCollection swig_types[2]
-#define SWIGTYPE_p_GeosLineString swig_types[3]
-#define SWIGTYPE_p_GeosLinearRing swig_types[4]
-#define SWIGTYPE_p_GeosMultiLineString swig_types[5]
-#define SWIGTYPE_p_GeosMultiLinearRing swig_types[6]
-#define SWIGTYPE_p_GeosMultiPoint swig_types[7]
-#define SWIGTYPE_p_GeosMultiPolygon swig_types[8]
-#define SWIGTYPE_p_GeosPoint swig_types[9]
-#define SWIGTYPE_p_GeosPolygon swig_types[10]
-#define SWIGTYPE_p_char swig_types[11]
-#define SWIGTYPE_p_p_GeosLinearRing swig_types[12]
-#define SWIGTYPE_p_size_t swig_types[13]
-#define SWIGTYPE_p_std__invalid_argument swig_types[14]
-#define SWIGTYPE_p_swig__PySwigIterator swig_types[15]
-#define SWIGTYPE_p_unsigned_char swig_types[16]
-static swig_type_info *swig_types[18];
-static swig_module_info swig_module = {swig_types, 17, 0, 0, 0, 0};
-#define SWIG_TypeQuery(name) SWIG_TypeQueryModule(&swig_module, &swig_module, name)
-#define SWIG_MangledTypeQuery(name) SWIG_MangledTypeQueryModule(&swig_module, &swig_module, name)
-/* -------- TYPES TABLE (END) -------- */
-#if (PY_VERSION_HEX <= 0x02000000)
-# if !defined(SWIG_PYTHON_CLASSIC)
-# error "This python version requires swig to be run with the '-classic' option"
-# endif
-#endif
-#if (PY_VERSION_HEX <= 0x02020000)
-# error "This python version requires swig to be run with the '-nomodern' option"
-#endif
-# error "This python version requires swig to be run with the '-nomodernargs' option"
-#endif
- @(target):= _geos.so
-#define SWIG_init init_geos
-#define SWIG_name "_geos"
-#define SWIGVERSION 0x010331
-#define SWIG_VERSION SWIGVERSION
-#define SWIG_as_voidptr(a) const_cast< void * >(static_cast< const void * >(a))
-#define SWIG_as_voidptrptr(a) ((void)SWIG_as_voidptr(*a),reinterpret_cast< void** >(a))
-#include <stdexcept>
-namespace swig {
- class PyObject_ptr {
- protected:
- PyObject *_obj;
- public:
- PyObject_ptr() :_obj(0)
- PyObject_ptr(const PyObject_ptr& item) : _obj(item._obj)
- Py_XINCREF(_obj);
- PyObject_ptr(PyObject *obj, bool initial_ref = true) :_obj(obj)
- if (initial_ref) Py_XINCREF(_obj);
- PyObject_ptr & operator=(const PyObject_ptr& item)
- Py_XINCREF(item._obj);
- Py_XDECREF(_obj);
- _obj = item._obj;
- return *this;
- ~PyObject_ptr()
- Py_XDECREF(_obj);
- operator PyObject *() const
- return _obj;
- PyObject *operator->() const
- return _obj;
-namespace swig {
- struct PyObject_var : PyObject_ptr {
- PyObject_var(PyObject* obj = 0) : PyObject_ptr(obj, false) { }
- PyObject_var & operator = (PyObject* obj)
- Py_XDECREF(_obj);
- _obj = obj;
- return *this;
-#include <string>
-#include <iostream>
-#if defined(__SUNPRO_CC) && defined(_RWSTD_VER)
-# define SWIG_STD_NOASSIGN_STL
-# define SWIG_STD_NOINSERT_TEMPLATE_STL
-# define SWIG_STD_NOITERATOR_TRAITS_STL
-#endif
-#if defined(__GNUC__)
-# if __GNUC__ == 2 && __GNUC_MINOR <= 96
-# define SWIG_STD_NOMODERN_STL
-# endif
-#endif
-#include <string>
-namespace swig {
- struct stop_iteration {
- struct PySwigIterator {
- private:
- PyObject_ptr _seq;
- protected:
- PySwigIterator(PyObject *seq) : _seq(seq)
- public:
- virtual ~PySwigIterator() {}
- // Access iterator method, required by Python
- virtual PyObject *value() const = 0;
- // Forward iterator method, required by Python
- virtual PySwigIterator *incr(size_t n = 1) = 0;
- // Backward iterator method, very common in C++, but not required in Python
- virtual PySwigIterator *decr(size_t n = 1)
- throw stop_iteration();
- // Random access iterator methods, but not required in Python
- virtual ptrdiff_t distance(const PySwigIterator &x) const
- throw std::invalid_argument("operation not supported");
- virtual bool equal (const PySwigIterator &x) const
- // C++ common/needed methods
- virtual PySwigIterator *copy() const = 0;
- PyObject *next()
- PyObject *obj = value();
- incr();
- return obj;
- PyObject *previous()
- decr();
- return value();
- PySwigIterator *advance(ptrdiff_t n)
- return (n > 0) ? incr(n) : decr(-n);
- bool operator == (const PySwigIterator& x) const
- return equal(x);
- bool operator != (const PySwigIterator& x) const
- return ! operator==(x);
- PySwigIterator& operator += (ptrdiff_t n)
- return *advance(n);
- PySwigIterator& operator -= (ptrdiff_t n)
- return *advance(-n);
- PySwigIterator* operator + (ptrdiff_t n) const
- return copy()->advance(n);
- PySwigIterator* operator - (ptrdiff_t n) const
- return copy()->advance(-n);
- ptrdiff_t operator - (const PySwigIterator& x) const
- return x.distance(*this);
- static swig_type_info* descriptor() {
- static int init = 0;
- static swig_type_info* desc = 0;
- if (!init) {
- desc = SWIG_TypeQuery("swig::PySwigIterator *");
- init = 1;
- return desc;
-SWIGINTERN int
-SWIG_AsVal_double (PyObject *obj, double *val)
- int res = SWIG_TypeError;
- if (PyFloat_Check(obj)) {
- if (val) *val = PyFloat_AsDouble(obj);
- return SWIG_OK;
- } else if (PyInt_Check(obj)) {
- if (val) *val = PyInt_AsLong(obj);
- return SWIG_OK;
- } else if (PyLong_Check(obj)) {
- double v = PyLong_AsDouble(obj);
- if (!PyErr_Occurred()) {
- if (val) *val = v;
- return SWIG_OK;
- } else {
- PyErr_Clear();
-#ifdef SWIG_PYTHON_CAST_MODE
- int dispatch = 0;
- double d = PyFloat_AsDouble(obj);
- if (val) *val = d;
- return SWIG_AddCast(SWIG_OK);
- } else {
- PyErr_Clear();
- if (!dispatch) {
- long v = PyLong_AsLong(obj);
- return SWIG_AddCast(SWIG_AddCast(SWIG_OK));
- } else {
- PyErr_Clear();
-#endif
- return res;
-#include <float.h>
-#include <math.h>
-SWIG_CanCastAsInteger(double *d, double min, double max) {
- double x = *d;
- if ((min <= x && x <= max)) {
- double fx = floor(x);
- double cx = ceil(x);
- double rd = ((x - fx) < 0.5) ? fx : cx; /* simple rint */
- if ((errno == EDOM) || (errno == ERANGE)) {
- errno = 0;
- } else {
- double summ, reps, diff;
- if (rd < x) {
- diff = x - rd;
- } else if (rd > x) {
- diff = rd - x;
- } else {
- return 1;
- summ = rd + x;
- reps = diff/summ;
- if (reps < 8*DBL_EPSILON) {
- *d = rd;
- return 1;
- return 0;
-SWIGINTERN int
-SWIG_AsVal_unsigned_SS_long (PyObject *obj, unsigned long *val)
- if (PyInt_Check(obj)) {
- long v = PyInt_AsLong(obj);
- if (v >= 0) {
- return SWIG_OK;
- } else {
- return SWIG_OverflowError;
- unsigned long v = PyLong_AsUnsignedLong(obj);
- return SWIG_OK;
- } else {
- PyErr_Clear();
- int dispatch = 0;
- } else {
- PyErr_Clear();
- if (!dispatch) {
- double d;
- int res = SWIG_AddCast(SWIG_AsVal_double (obj,&d));
- if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, 0, ULONG_MAX)) {
- if (val) *val = (unsigned long)(d);
- return res;
-#endif
- return SWIG_TypeError;
-SWIG_AsVal_size_t (PyObject * obj, size_t *val)
- unsigned long v;
- int res = SWIG_AsVal_unsigned_SS_long (obj, val ? &v : 0);
- if (SWIG_IsOK(res) && val) *val = static_cast< size_t >(v);
- return res;
- #define SWIG_From_long PyInt_FromLong
-SWIGINTERNINLINE PyObject *
-SWIG_From_ptrdiff_t (ptrdiff_t value)
- return SWIG_From_long (static_cast< long >(value));
-SWIGINTERNINLINE PyObject*
- SWIG_From_bool (bool value)
- return PyBool_FromLong(value ? 1 : 0);
-SWIGINTERN int
-SWIG_AsVal_long (PyObject *obj, long* val)
- return SWIG_OK;
- return SWIG_OK;
- } else {
- PyErr_Clear();
- int dispatch = 0;
- } else {
- PyErr_Clear();
- if (!dispatch) {
- double d;
- if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, LONG_MIN, LONG_MAX)) {
- if (val) *val = (long)(d);
- return res;
-#endif
-SWIG_AsVal_ptrdiff_t (PyObject * obj, ptrdiff_t *val)
- long v;
- int res = SWIG_AsVal_long (obj, val ? &v : 0);
- if (SWIG_IsOK(res) && val) *val = static_cast< ptrdiff_t >(v);
- return res;
-#include <algorithm>
-#include <vector>
-#include "geos_c.h"
-/* Needed for va_start, etc. */
-#include <stdarg.h>
-SWIG_From_int (int value)
- return SWIG_From_long (value);
-SWIGINTERN swig_type_info*
-SWIG_pchar_descriptor(void)
- static swig_type_info* info = 0;
- if (!init) {
- info = SWIG_TypeQuery("_p_char");
- init = 1;
- return info;
-SWIG_FromCharPtrAndSize(const char* carray, size_t size)
- if (carray) {
- if (size > INT_MAX) {
- swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
- return pchar_descriptor ?
- SWIG_NewPointerObj(const_cast< char * >(carray), pchar_descriptor, 0) : SWIG_Py_Void();
- } else {
- return PyString_FromStringAndSize(carray, static_cast< int >(size));
- } else {
-SWIG_FromCharPtr(const char *cptr)
- return SWIG_FromCharPtrAndSize(cptr, (cptr ? strlen(cptr) : 0));
- static const int DEFAULT_QUADRANT_SEGMENTS=8;
-/* This is not thread safe ! */
-static const int MESSAGE_SIZE = 1000;
-static char message[MESSAGE_SIZE];
-void noticeHandler(const char *fmt, ...)
- va_list args;
- va_start(args, fmt);
- vsnprintf(message, sizeof(message) - 1, fmt, args);
- va_end(args);
-void errorHandler(const char *fmt, ...)
- va_list args;
- va_end(args);
-typedef void GeosCoordinateSequence;
-void checkCoordSeqBounds(const GEOSCoordSeq coordSeq, const size_t index)
- unsigned int size = 0;
- GEOSCoordSeq_getSize(coordSeq, &size);
- if (index < 0 || index >= size)
- throw std::runtime_error("Index out of bounds");
-SWIGINTERN GeosCoordinateSequence *new_GeosCoordinateSequence(size_t size,size_t dims){
- return (GeosCoordinateSequence*) GEOSCoordSeq_create(size, dims);
-SWIGINTERN void delete_GeosCoordinateSequence(GeosCoordinateSequence *self){
- GEOSCoordSeq coords = (GEOSCoordSeq) self;
- return GEOSCoordSeq_destroy(coords);
-SWIGINTERN GeosCoordinateSequence *GeosCoordinateSequence_clone(GeosCoordinateSequence *self){
- return (GeosCoordinateSequence*) GEOSCoordSeq_clone(coords);
-SWIGINTERN int GeosCoordinateSequence_setX(GeosCoordinateSequence *self,size_t idx,double val){
- checkCoordSeqBounds(coords, idx);
- return GEOSCoordSeq_setX(coords, idx, val);
-SWIGINTERN int GeosCoordinateSequence_setY(GeosCoordinateSequence *self,size_t idx,double val){
- return GEOSCoordSeq_setY(coords, idx, val);
-SWIGINTERN int GeosCoordinateSequence_setZ(GeosCoordinateSequence *self,size_t idx,double val){
- return GEOSCoordSeq_setZ(coords, idx, val);
-SWIGINTERN int GeosCoordinateSequence_setOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim,double val){
- return GEOSCoordSeq_setOrdinate(coords, idx, dim, val);
-SWIGINTERN double GeosCoordinateSequence_getX(GeosCoordinateSequence *self,size_t idx){
- double result;
- GEOSCoordSeq_getX(coords, idx, &result);
- return result;
- #define SWIG_From_double PyFloat_FromDouble
-SWIGINTERN double GeosCoordinateSequence_getY(GeosCoordinateSequence *self,size_t idx){
- double result;
- GEOSCoordSeq_getY(coords, idx, &result);
- return result;
-SWIGINTERN double GeosCoordinateSequence_getZ(GeosCoordinateSequence *self,size_t idx){
- double result;
- GEOSCoordSeq_getZ(coords, idx, &result);
- return result;
-SWIGINTERN double GeosCoordinateSequence_getOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim){
- double result;
- GEOSCoordSeq_getOrdinate(coords, idx, dim, &result);
- return result;
-SWIGINTERN unsigned int GeosCoordinateSequence_getSize(GeosCoordinateSequence *self){
- unsigned int result;
- GEOSCoordSeq_getSize(coords, &result);
- return result;
-SWIG_From_unsigned_SS_long (unsigned long value)
- return (value > LONG_MAX) ?
- PyLong_FromUnsignedLong(value) : PyInt_FromLong(static_cast< long >(value));
-SWIG_From_unsigned_SS_int (unsigned int value)
- return SWIG_From_unsigned_SS_long (value);
-SWIGINTERN unsigned int GeosCoordinateSequence_getDimensions(GeosCoordinateSequence *self){
- GEOSCoordSeq_getDimensions(coords, &result);
- return result;
-typedef void GeosGeometry;
-typedef void GeosPoint;
-typedef void GeosLineString;
-typedef void GeosLinearRing;
-typedef void GeosPolygon;
-typedef void GeosGeometryCollection;
-typedef void GeosMultiPoint;
-typedef void GeosMultiLineString;
-typedef void GeosMultiLinearRing;
-typedef void GeosMultiPolygon;
-bool checkBoolResult(char result)
- int intResult = (int) result;
- if (intResult == 1)
- return true;
- else if (intResult == 0)
- return false;
- else
- throw std::runtime_error(message);
-SWIGINTERN void delete_GeosGeometry(GeosGeometry *self){
- GEOSGeom geom = (GEOSGeom) self;
- GEOSGeom_destroy(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_clone(GeosGeometry *self){
- return GEOSGeom_clone(geom);
-SWIGINTERN char *GeosGeometry_geomType(GeosGeometry *self){
- return GEOSGeomType(geom);
-SWIGINTERN int GeosGeometry_typeId(GeosGeometry *self){
- return GEOSGeomTypeId(geom);
-SWIGINTERN void GeosGeometry_normalize(GeosGeometry *self){
- int result = GEOSNormalize(geom);
- if (result == -1)
-SWIGINTERN int GeosGeometry_getSRID(GeosGeometry *self){
- return GEOSGetSRID(geom);
-#include <limits.h>
-#ifndef LLONG_MIN
-# define LLONG_MIN LONG_LONG_MIN
-#endif
-#ifndef LLONG_MAX
-# define LLONG_MAX LONG_LONG_MAX
-#endif
-#ifndef ULLONG_MAX
-# define ULLONG_MAX ULONG_LONG_MAX
-#endif
-SWIGINTERN int
-SWIG_AsVal_int (PyObject * obj, int *val)
- long v;
- int res = SWIG_AsVal_long (obj, &v);
- if (SWIG_IsOK(res)) {
- if ((v < INT_MIN || v > INT_MAX)) {
- } else {
- if (val) *val = static_cast< int >(v);
- return res;
-SWIGINTERN void GeosGeometry_setSRID(GeosGeometry *self,int SRID){
- return GEOSSetSRID(geom, SRID);
-SWIGINTERN size_t GeosGeometry_getDimensions(GeosGeometry *self){
- return GEOSGeom_getDimensions(geom);
-SWIG_From_size_t (size_t value)
- return SWIG_From_unsigned_SS_long (static_cast< unsigned long >(value));
-SWIGINTERN size_t GeosGeometry_getNumGeometries(GeosGeometry *self){
- size_t result = GEOSGetNumGeometries(geom);
- if ((int)result == -1)
- return result;
-SWIGINTERN GeosGeometry *GeosGeometry_intersection(GeosGeometry *self,GeosGeometry *other){
- GEOSGeom otherGeom = (GEOSGeom) other;
- return (GeosGeometry*) GEOSIntersection(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_buffer(GeosGeometry *self,double width,int quadsegs){
- return (GeosGeometry*) GEOSBuffer(geom, width, quadsegs);
-SWIGINTERN GeosGeometry *GeosGeometry_convexHull(GeosGeometry *self){
- return (GeosGeometry*) GEOSConvexHull(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_difference(GeosGeometry *self,GeosGeometry *other){
- return (GeosGeometry*) GEOSDifference(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_symDifference(GeosGeometry *self,GeosGeometry *other){
- return (GeosGeometry*) GEOSSymDifference(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_boundary(GeosGeometry *self){
- return (GeosGeometry*) GEOSBoundary(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_geomUnion(GeosGeometry *self,GeosGeometry *other){
- return (GeosGeometry*) GEOSUnion(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_pointOnSurface(GeosGeometry *self){
- return (GeosGeometry*) GEOSPointOnSurface(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_getCentroid(GeosGeometry *self){
- return (GeosGeometry*) GEOSGetCentroid(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_getEnvelope(GeosGeometry *self){
- return (GeosGeometry*) GEOSEnvelope(geom);
-SWIGINTERN char *GeosGeometry_relate(GeosGeometry *self,GeosGeometry *other){
- return GEOSRelate(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_lineMerge(GeosGeometry *self){
- return GEOSLineMerge(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_simplify(GeosGeometry *self,double tolerance){
- return (GeosGeometry*) GEOSSimplify(geom, tolerance);
-SWIGINTERN GeosGeometry *GeosGeometry_topologyPreserveSimplify(GeosGeometry *self,double tolerance){
- return (GeosGeometry*) GEOSTopologyPreserveSimplify(geom, tolerance);
-SWIGINTERN int
-SWIG_AsCharPtrAndSize(PyObject *obj, char** cptr, size_t* psize, int *alloc)
- if (PyString_Check(obj)) {
- char *cstr; Py_ssize_t len;
- PyString_AsStringAndSize(obj, &cstr, &len);
- if (cptr) {
- if (alloc) {
- In python the user should not be able to modify the inner
- string representation. To warranty that, if you define
- SWIG_PYTHON_SAFE_CSTRINGS, a new/copy of the python string
- buffer is always returned.
- The default behavior is just to return the pointer value,
- so, be careful.
-#if defined(SWIG_PYTHON_SAFE_CSTRINGS)
- if (*alloc != SWIG_OLDOBJ)
-#else
- if (*alloc == SWIG_NEWOBJ)
-#endif
- *cptr = reinterpret_cast< char* >(memcpy((new char[len + 1]), cstr, sizeof(char)*(len + 1)));
- *alloc = SWIG_NEWOBJ;
- else {
- *cptr = cstr;
- *alloc = SWIG_OLDOBJ;
- } else {
- *cptr = PyString_AsString(obj);
- if (psize) *psize = len + 1;
- return SWIG_OK;
- } else {
- if (pchar_descriptor) {
- void* vptr = 0;
- if (SWIG_ConvertPtr(obj, &vptr, pchar_descriptor, 0) == SWIG_OK) {
- if (cptr) *cptr = (char *) vptr;
- if (psize) *psize = vptr ? (strlen((char *)vptr) + 1) : 0;
- if (alloc) *alloc = SWIG_OLDOBJ;
- return SWIG_OK;
-SWIGINTERN bool GeosGeometry_relatePattern(GeosGeometry *self,GeosGeometry const *other,char const *pat){
- return checkBoolResult(GEOSRelatePattern(geom, otherGeom, pat));
-SWIGINTERN bool GeosGeometry_disjoint(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSDisjoint(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_touches(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSTouches(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_intersects(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSIntersects(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_crosses(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSCrosses(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_within(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSWithin(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_contains(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSContains(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_overlaps(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSOverlaps(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_equals(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSEquals(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_equalsExact(GeosGeometry *self,GeosGeometry const *other,double tolerance){
- return checkBoolResult(GEOSEqualsExact(geom, otherGeom, tolerance));
-SWIGINTERN bool GeosGeometry_isEmpty(GeosGeometry *self){
- return checkBoolResult(GEOSisEmpty(geom));
-SWIGINTERN bool GeosGeometry_isValid(GeosGeometry *self){
- return checkBoolResult(GEOSisValid(geom));
-SWIGINTERN bool GeosGeometry_isSimple(GeosGeometry *self){
- return checkBoolResult(GEOSisSimple(geom));
-SWIGINTERN bool GeosGeometry_isRing(GeosGeometry *self){
- return checkBoolResult(GEOSisRing(geom));
-SWIGINTERN bool GeosGeometry_hasZ(GeosGeometry *self){
- return checkBoolResult(GEOSHasZ(geom));
-SWIGINTERN double GeosGeometry_area(GeosGeometry *self){
- double result;
- int code = GEOSArea(geom, &result);
- if (code == 0)
- return result;
-SWIGINTERN double GeosGeometry_length(GeosGeometry *self){
- double result;
- int code = GEOSLength(geom, &result);
- if (code == 0)
- return result;
-SWIGINTERN double GeosGeometry_distance(GeosGeometry *self,GeosGeometry const *other){
- double result;
- int code = GEOSDistance(geom, otherGeom, &result);
- if (code == 0)
- return result;
-SWIGINTERN void delete_GeosPoint(GeosPoint *self){
-SWIGINTERN GeosCoordinateSequence const *GeosPoint_getCoordSeq(GeosPoint *self){
- const GEOSCoordSeq result = (const GEOSCoordSeq) GEOSGeom_getCoordSeq(geom);
- if (result == NULL)
- return (const GeosCoordinateSequence*) result;
-SWIGINTERN void delete_GeosLineString(GeosLineString *self){
-SWIGINTERN GeosCoordinateSequence const *GeosLineString_getCoordSeq(GeosLineString *self){
-SWIGINTERN void delete_GeosLinearRing(GeosLinearRing *self){
-SWIGINTERN GeosCoordinateSequence const *GeosLinearRing_getCoordSeq(GeosLinearRing *self){
-SWIGINTERN void delete_GeosPolygon(GeosPolygon *self){
-SWIGINTERN GeosGeometry const *GeosPolygon_getExteriorRing(GeosPolygon *self){
- const GEOSGeom result = (const GEOSGeom) GEOSGetExteriorRing(geom);
- return (const GeosGeometry*) result;
-SWIGINTERN size_t GeosPolygon_getNumInteriorRings(GeosPolygon *self){
- size_t result = GEOSGetNumInteriorRings(geom);
- return result;
-SWIGINTERN GeosGeometry const *GeosPolygon_getInteriorRingN(GeosPolygon *self,size_t n){
- size_t size = GEOSGetNumInteriorRings(geom);
- if (n < 0 || n >= size)
- const GEOSGeom result = (const GEOSGeom) GEOSGetInteriorRingN(geom, n);
-SWIGINTERN void delete_GeosGeometryCollection(GeosGeometryCollection *self){
-SWIGINTERN GeosGeometry const *GeosGeometryCollection_getGeometryN(GeosGeometryCollection *self,size_t n){
- const GEOSGeom result = (const GEOSGeom) GEOSGetGeometryN(geom, n);
-SWIGINTERN void delete_GeosMultiPoint(GeosMultiPoint *self){
-SWIGINTERN void delete_GeosMultiLineString(GeosMultiLineString *self){
-SWIGINTERN void delete_GeosMultiLinearRing(GeosMultiLinearRing *self){
-SWIGINTERN void delete_GeosMultiPolygon(GeosMultiPolygon *self){
-GeosGeometry *createPoint(GeosCoordinateSequence *s)
- GEOSCoordSeq coords = (GEOSCoordSeq) s;
- GEOSGeom geom = GEOSGeom_createPoint(coords);
- if(geom == NULL)
- return (GeosGeometry*) geom;
-GeosGeometry *createLineString(GeosCoordinateSequence *s)
- GEOSGeom geom = GEOSGeom_createLineString(coords);
- if(geom == NULL)
-GeosGeometry *createLinearRing(GeosCoordinateSequence *s)
- GEOSGeom geom = GEOSGeom_createLinearRing(coords);
- if(geom == NULL)
-GeosGeometry *createPolygon(GeosLinearRing *shell, GeosLinearRing **holes, size_t nholes)
- GEOSGeom shellGeom = (GEOSGeom) shell;
- GEOSGeom* holeGeoms = (GEOSGeom*) holes;
- GEOSGeom geom = GEOSGeom_createPolygon(shellGeom, holeGeoms, nholes);
- if(geom == NULL)
-GeosGeometry* geomFromWKT(const char *wkt)
- if(wkt == NULL)
- throw std::runtime_error("Trying to create geometry from a NULL string");
- GEOSGeom geom = GEOSGeomFromWKT(wkt);
- if(geom == NULL)
-char* geomToWKT(const GeosGeometry* g)
- GEOSGeom geom = (GEOSGeom) g;
- return GEOSGeomToWKT(geom);
-int getWKBOutputDims()
- return GEOS_getWKBOutputDims();
-int setWKBOutputDims(int newDims)
- return GEOS_setWKBOutputDims(newDims);
-int getWKBByteOrder()
- return GEOS_getWKBByteOrder();
-int setWKBByteOrder(int byteOrder)
- return GEOS_setWKBByteOrder(byteOrder);
-GeosGeometry* geomFromWKB(const unsigned char *wkb, size_t size)
- GEOSGeom geom = GEOSGeomFromWKB_buf(wkb, size);
- if(geom == NULL)
-unsigned char *geomToWKB(const GeosGeometry* g, size_t *size)
- return GEOSGeomToWKB_buf(geom, size);
-/* use wkb parameter instead of hex so we can reuse the typemap above. */
-GeosGeometry* geomFromHEX(const unsigned char *wkb, size_t size)
- GEOSGeom geom = GEOSGeomFromHEX_buf(wkb, size);
- if(geom == NULL)
-unsigned char *geomToHEX(const GeosGeometry* g, size_t *size)
- return GEOSGeomToHEX_buf(geom, size);
-#ifdef __cplusplus
-extern "C" {
-#endif
-SWIGINTERN PyObject *_wrap_delete_PySwigIterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *resultobj = 0;
- swig::PySwigIterator *arg1 = (swig::PySwigIterator *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- PyObject * obj0 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_PySwigIterator",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_DISOWN | 0 );
- if (!SWIG_IsOK(res1)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_PySwigIterator" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- arg1 = reinterpret_cast< swig::PySwigIterator * >(argp1);
- delete arg1;
- resultobj = SWIG_Py_Void();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_value(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_value",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__PySwigIterator, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_value" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- try {
- result = (PyObject *)((swig::PySwigIterator const *)arg1)->value();
- catch(swig::stop_iteration &_e) {
- (void)_e;
- SWIG_SetErrorObj(PyExc_StopIteration, SWIG_Py_Void());
- SWIG_fail;
- resultobj = result;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_incr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- swig::PySwigIterator *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- PyObject * obj1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_incr",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_incr" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- ecode2 = SWIG_AsVal_size_t(obj1, &val2);
- if (!SWIG_IsOK(ecode2)) {
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_incr" "', argument " "2"" of type '" "size_t""'");
- arg2 = static_cast< size_t >(val2);
- try {
- result = (swig::PySwigIterator *)(arg1)->incr(arg2);
- (void)_e;
- SWIG_fail;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, 0 | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_incr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_incr",1,1,&obj0)) SWIG_fail;
- try {
- result = (swig::PySwigIterator *)(arg1)->incr();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_incr(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[3];
- int ii;
- if (!PyTuple_Check(args)) SWIG_fail;
- argc = PyObject_Length(args);
- for (ii = 0; (ii < argc) && (ii < 2); ii++) {
- argv[ii] = PyTuple_GET_ITEM(args,ii);
- if (argc == 1) {
- int _v;
- void *vptr = 0;
- int res = SWIG_ConvertPtr(argv[0], &vptr, SWIGTYPE_p_swig__PySwigIterator, 0);
- _v = SWIG_CheckState(res);
- if (_v) {
- return _wrap_PySwigIterator_incr__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- int res = SWIG_AsVal_size_t(argv[1], NULL);
- if (_v) {
- return _wrap_PySwigIterator_incr__SWIG_0(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'PySwigIterator_incr'.\n Possible C/C++ prototypes are:\n incr(size_t)\n incr()\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_decr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_decr",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_decr" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_decr" "', argument " "2"" of type '" "size_t""'");
- try {
- result = (swig::PySwigIterator *)(arg1)->decr(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_decr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_decr",1,1,&obj0)) SWIG_fail;
- try {
- result = (swig::PySwigIterator *)(arg1)->decr();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_decr(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- void *vptr = 0;
- if (_v) {
- return _wrap_PySwigIterator_decr__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- if (_v) {
- return _wrap_PySwigIterator_decr__SWIG_0(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'PySwigIterator_decr'.\n Possible C/C++ prototypes are:\n decr(size_t)\n decr()\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_distance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- swig::PySwigIterator *arg2 = 0 ;
- ptrdiff_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_distance",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_distance" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_swig__PySwigIterator, 0 | 0);
- if (!SWIG_IsOK(res2)) {
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator_distance" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator_distance" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- arg2 = reinterpret_cast< swig::PySwigIterator * >(argp2);
- try {
- result = ((swig::PySwigIterator const *)arg1)->distance((swig::PySwigIterator const &)*arg2);
- catch(std::invalid_argument &_e) {
- SWIG_Python_Raise(SWIG_NewPointerObj((new std::invalid_argument(static_cast< const std::invalid_argument& >(_e))),SWIGTYPE_p_std__invalid_argument,SWIG_POINTER_OWN), "std::invalid_argument", SWIGTYPE_p_std__invalid_argument); SWIG_fail;
- resultobj = SWIG_From_ptrdiff_t(static_cast< ptrdiff_t >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_equal(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_equal",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_equal" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator_equal" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator_equal" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- try {
- result = (bool)((swig::PySwigIterator const *)arg1)->equal((swig::PySwigIterator const &)*arg2);
- resultobj = SWIG_From_bool(static_cast< bool >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_copy(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_copy",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_copy" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->copy();
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_next(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_next",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_next" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- try {
- result = (PyObject *)(arg1)->next();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_previous(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_previous",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_previous" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- try {
- result = (PyObject *)(arg1)->previous();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_advance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator_advance",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_advance" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- ecode2 = SWIG_AsVal_ptrdiff_t(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_advance" "', argument " "2"" of type '" "ptrdiff_t""'");
- arg2 = static_cast< ptrdiff_t >(val2);
- try {
- result = (swig::PySwigIterator *)(arg1)->advance(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___eq__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator___eq__",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___eq__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___eq__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___eq__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- result = (bool)((swig::PySwigIterator const *)arg1)->operator ==((swig::PySwigIterator const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___ne__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator___ne__",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___ne__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___ne__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___ne__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- result = (bool)((swig::PySwigIterator const *)arg1)->operator !=((swig::PySwigIterator const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___iadd__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator___iadd__",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___iadd__" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___iadd__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- swig::PySwigIterator &_result_ref = (arg1)->operator +=(arg2);
- result = (swig::PySwigIterator *) &_result_ref;
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___isub__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator___isub__",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___isub__" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___isub__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- swig::PySwigIterator &_result_ref = (arg1)->operator -=(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___add__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator___add__",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___add__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___add__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->operator +(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___sub____SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"PySwigIterator___sub__",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___sub__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->operator -(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___sub____SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- result = ((swig::PySwigIterator const *)arg1)->operator -((swig::PySwigIterator const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___sub__(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- int res = SWIG_ConvertPtr(argv[1], 0, SWIGTYPE_p_swig__PySwigIterator, 0);
- if (_v) {
- return _wrap_PySwigIterator___sub____SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- int res = SWIG_AsVal_ptrdiff_t(argv[1], NULL);
- if (_v) {
- return _wrap_PySwigIterator___sub____SWIG_0(self, args);
-fail:
- Py_INCREF(Py_NotImplemented);
- return Py_NotImplemented;
-SWIGINTERN PyObject *PySwigIterator_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- if (!PyArg_UnpackTuple(args,(char*)"swigregister", 1, 1,&obj)) return NULL;
- SWIG_TypeNewClientData(SWIGTYPE_p_swig__PySwigIterator, SWIG_NewClientData(obj));
- return SWIG_Py_Void();
-SWIGINTERN PyObject *_wrap_version(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- char *result = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"version",0,0)) SWIG_fail;
- result = (char *)GEOSversion();
- resultobj = SWIG_FromCharPtr((const char *)result);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_CoordinateSequence(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg1 ;
- size_t arg2 ;
- GeosCoordinateSequence *result = 0 ;
- size_t val1 ;
- int ecode1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"new_CoordinateSequence",2,2,&obj0,&obj1)) SWIG_fail;
- ecode1 = SWIG_AsVal_size_t(obj0, &val1);
- if (!SWIG_IsOK(ecode1)) {
- SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_CoordinateSequence" "', argument " "1"" of type '" "size_t""'");
- arg1 = static_cast< size_t >(val1);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "new_CoordinateSequence" "', argument " "2"" of type '" "size_t""'");
- try
- result = (GeosCoordinateSequence *)new_GeosCoordinateSequence(arg1,arg2);
- catch (const std::exception& e)
- SWIG_exception(SWIG_RuntimeError, e.what());
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_NEW | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_delete_CoordinateSequence(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosCoordinateSequence *arg1 = (GeosCoordinateSequence *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_CoordinateSequence",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_CoordinateSequence" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- arg1 = reinterpret_cast< GeosCoordinateSequence * >(argp1);
- try
- delete_GeosCoordinateSequence(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_clone(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_clone",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_clone" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosCoordinateSequence *)GeosCoordinateSequence_clone(arg1);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_setX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- double arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- PyObject * obj2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setX",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setX" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setX" "', argument " "2"" of type '" "size_t""'");
- ecode3 = SWIG_AsVal_double(obj2, &val3);
- if (!SWIG_IsOK(ecode3)) {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setX" "', argument " "3"" of type '" "double""'");
- arg3 = static_cast< double >(val3);
- try
- result = (int)GeosCoordinateSequence_setX(arg1,arg2,arg3);
- resultobj = SWIG_From_int(static_cast< int >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_setY(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- double arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setY",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setY" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setY" "', argument " "2"" of type '" "size_t""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setY" "', argument " "3"" of type '" "double""'");
- try
- result = (int)GeosCoordinateSequence_setY(arg1,arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_setZ(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- double arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setZ",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setZ" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setZ" "', argument " "2"" of type '" "size_t""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setZ" "', argument " "3"" of type '" "double""'");
- try
- result = (int)GeosCoordinateSequence_setZ(arg1,arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_setOrdinate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- size_t arg3 ;
- double arg4 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- size_t val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- PyObject * obj3 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setOrdinate",4,4,&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setOrdinate" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setOrdinate" "', argument " "2"" of type '" "size_t""'");
- ecode3 = SWIG_AsVal_size_t(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setOrdinate" "', argument " "3"" of type '" "size_t""'");
- arg3 = static_cast< size_t >(val3);
- ecode4 = SWIG_AsVal_double(obj3, &val4);
- if (!SWIG_IsOK(ecode4)) {
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "CoordinateSequence_setOrdinate" "', argument " "4"" of type '" "double""'");
- arg4 = static_cast< double >(val4);
- try
- result = (int)GeosCoordinateSequence_setOrdinate(arg1,arg2,arg3,arg4);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_getX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getX",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getX" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getX" "', argument " "2"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getX(arg1,arg2);
- resultobj = SWIG_From_double(static_cast< double >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_getY(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getY",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getY" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getY" "', argument " "2"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getY(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_getZ(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getZ",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getZ" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getZ" "', argument " "2"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getZ(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_getOrdinate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- size_t arg3 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- size_t val3 ;
- int ecode3 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getOrdinate",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getOrdinate" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getOrdinate" "', argument " "2"" of type '" "size_t""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_getOrdinate" "', argument " "3"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getOrdinate(arg1,arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_getSize(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getSize",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getSize" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (unsigned int)GeosCoordinateSequence_getSize(arg1);
- resultobj = SWIG_From_unsigned_SS_int(static_cast< unsigned int >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_CoordinateSequence_getDimensions(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getDimensions",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getDimensions" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (unsigned int)GeosCoordinateSequence_getDimensions(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *CoordinateSequence_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosCoordinateSequence, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_Geometry(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosGeometry *arg1 = (GeosGeometry *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_Geometry",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometry, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Geometry" "', argument " "1"" of type '" "GeosGeometry *""'");
- arg1 = reinterpret_cast< GeosGeometry * >(argp1);
- try
- delete_GeosGeometry(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_clone(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosGeometry *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_clone",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometry, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_clone" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_clone(arg1);
- /* %typemap(out) GeosGeometry */
- SWIG_exception(SWIG_RuntimeError, message);
- GeosGeometry *geom = result;
- GEOSGeomTypes geomId = (GEOSGeomTypes)GEOSGeomTypeId((GEOSGeom) geom);
- switch (geomId)
- case GEOS_POINT:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_LINESTRING:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_LINEARRING:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_POLYGON:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_MULTIPOINT:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_MULTILINESTRING:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_MULTIPOLYGON:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_GEOMETRYCOLLECTION:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | SWIG_POINTER_OWN);
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_geomType(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_geomType",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_geomType" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (char *)GeosGeometry_geomType(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_typeId(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_typeId",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_typeId" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (int)GeosGeometry_typeId(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_normalize(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_normalize",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_normalize" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- GeosGeometry_normalize(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_getSRID(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_getSRID",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getSRID" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (int)GeosGeometry_getSRID(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_setSRID(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_setSRID",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_setSRID" "', argument " "1"" of type '" "GeosGeometry *""'");
- ecode2 = SWIG_AsVal_int(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_setSRID" "', argument " "2"" of type '" "int""'");
- arg2 = static_cast< int >(val2);
- try
- GeosGeometry_setSRID(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_getDimensions(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_getDimensions",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getDimensions" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = GeosGeometry_getDimensions(arg1);
- resultobj = SWIG_From_size_t(static_cast< size_t >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_getNumGeometries(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_getNumGeometries",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getNumGeometries" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = GeosGeometry_getNumGeometries(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_intersection(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosGeometry *arg2 = (GeosGeometry *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_intersection",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_intersection" "', argument " "1"" of type '" "GeosGeometry *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2,SWIGTYPE_p_GeosGeometry, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_intersection" "', argument " "2"" of type '" "GeosGeometry *""'");
- arg2 = reinterpret_cast< GeosGeometry * >(argp2);
- try
- result = (GeosGeometry *)GeosGeometry_intersection(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_buffer(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- int arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- int val3 ;
- int ecode3 = 0 ;
- arg3 = DEFAULT_QUADRANT_SEGMENTS;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_buffer",2,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_buffer" "', argument " "1"" of type '" "GeosGeometry *""'");
- ecode2 = SWIG_AsVal_double(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_buffer" "', argument " "2"" of type '" "double""'");
- arg2 = static_cast< double >(val2);
- if (obj2) {
- ecode3 = SWIG_AsVal_int(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Geometry_buffer" "', argument " "3"" of type '" "int""'");
- arg3 = static_cast< int >(val3);
- try
- result = (GeosGeometry *)GeosGeometry_buffer(arg1,arg2,arg3);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_convexHull(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_convexHull",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_convexHull" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_convexHull(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_difference(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_difference",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_difference" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_difference" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_difference(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_symDifference(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_symDifference",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_symDifference" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_symDifference" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_symDifference(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_boundary(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_boundary",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_boundary" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_boundary(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_union(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_union",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_union" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_union" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_geomUnion(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_pointOnSurface(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_pointOnSurface",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_pointOnSurface" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_pointOnSurface(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_getCentroid(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_getCentroid",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getCentroid" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_getCentroid(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_getEnvelope(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_getEnvelope",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getEnvelope" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_getEnvelope(arg1);
- switch (geomId)
- case GEOS_POINT:
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | 0);
- break;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | 0);
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_relate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_relate",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_relate" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_relate" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (char *)GeosGeometry_relate(arg1,arg2);
- delete[] result;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_lineMerge(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_lineMerge",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_lineMerge" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_lineMerge(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_simplify(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_simplify",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_simplify" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_simplify" "', argument " "2"" of type '" "double""'");
- try
- result = (GeosGeometry *)GeosGeometry_simplify(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_topologyPreserveSimplify(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_topologyPreserveSimplify",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_topologyPreserveSimplify" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_topologyPreserveSimplify" "', argument " "2"" of type '" "double""'");
- try
- result = (GeosGeometry *)GeosGeometry_topologyPreserveSimplify(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_relatePattern(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- char *arg3 = (char *) 0 ;
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- int res3 ;
- char *buf3 = 0 ;
- int alloc3 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_relatePattern",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_relatePattern" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_relatePattern" "', argument " "2"" of type '" "GeosGeometry const *""'");
- res3 = SWIG_AsCharPtrAndSize(obj2, &buf3, NULL, &alloc3);
- if (!SWIG_IsOK(res3)) {
- SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "Geometry_relatePattern" "', argument " "3"" of type '" "char const *""'");
- arg3 = reinterpret_cast< char * >(buf3);
- try
- result = (bool)GeosGeometry_relatePattern(arg1,(GeosGeometry const *)arg2,(char const *)arg3);
- if (alloc3 == SWIG_NEWOBJ) delete[] buf3;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_disjoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_disjoint",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_disjoint" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_disjoint" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_disjoint(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_touches(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_touches",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_touches" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_touches" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_touches(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_intersects(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_intersects",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_intersects" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_intersects" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_intersects(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_crosses(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_crosses",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_crosses" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_crosses" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_crosses(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_within(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_within",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_within" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_within" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_within(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_contains(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_contains",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_contains" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_contains" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_contains(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_overlaps(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_overlaps",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_overlaps" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_overlaps" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_overlaps(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_equals(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_equals",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_equals" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_equals" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_equals(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_equalsExact(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg3 ;
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_equalsExact",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_equalsExact" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_equalsExact" "', argument " "2"" of type '" "GeosGeometry const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Geometry_equalsExact" "', argument " "3"" of type '" "double""'");
- try
- result = (bool)GeosGeometry_equalsExact(arg1,(GeosGeometry const *)arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_isEmpty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_isEmpty",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isEmpty" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isEmpty(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_isValid(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_isValid",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isValid" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isValid(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_isSimple(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_isSimple",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isSimple" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isSimple(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_isRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_isRing",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isRing" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isRing(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_hasZ(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_hasZ",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_hasZ" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_hasZ(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_area(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_area",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_area" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (double)GeosGeometry_area(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_length(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_length",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_length" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (double)GeosGeometry_length(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Geometry_distance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Geometry_distance",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_distance" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_distance" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (double)GeosGeometry_distance(arg1,(GeosGeometry const *)arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *Geometry_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosGeometry, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_Point(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosPoint *arg1 = (GeosPoint *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_Point",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPoint, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Point" "', argument " "1"" of type '" "GeosPoint *""'");
- arg1 = reinterpret_cast< GeosPoint * >(argp1);
- try
- delete_GeosPoint(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Point_getCoordSeq(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Point_getCoordSeq",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPoint, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Point_getCoordSeq" "', argument " "1"" of type '" "GeosPoint *""'");
- try
- result = (GeosCoordinateSequence *)GeosPoint_getCoordSeq(arg1);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *Point_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosPoint, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_LineString(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosLineString *arg1 = (GeosLineString *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_LineString",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLineString, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_LineString" "', argument " "1"" of type '" "GeosLineString *""'");
- arg1 = reinterpret_cast< GeosLineString * >(argp1);
- try
- delete_GeosLineString(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_LineString_getCoordSeq(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"LineString_getCoordSeq",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLineString, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "LineString_getCoordSeq" "', argument " "1"" of type '" "GeosLineString *""'");
- try
- result = (GeosCoordinateSequence *)GeosLineString_getCoordSeq(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *LineString_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosLineString, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_LinearRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosLinearRing *arg1 = (GeosLinearRing *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_LinearRing",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_LinearRing" "', argument " "1"" of type '" "GeosLinearRing *""'");
- arg1 = reinterpret_cast< GeosLinearRing * >(argp1);
- try
- delete_GeosLinearRing(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_LinearRing_getCoordSeq(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"LinearRing_getCoordSeq",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLinearRing, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "LinearRing_getCoordSeq" "', argument " "1"" of type '" "GeosLinearRing *""'");
- try
- result = (GeosCoordinateSequence *)GeosLinearRing_getCoordSeq(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *LinearRing_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosLinearRing, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_Polygon(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosPolygon *arg1 = (GeosPolygon *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_Polygon",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPolygon, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Polygon" "', argument " "1"" of type '" "GeosPolygon *""'");
- arg1 = reinterpret_cast< GeosPolygon * >(argp1);
- try
- delete_GeosPolygon(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Polygon_getExteriorRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Polygon_getExteriorRing",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPolygon, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Polygon_getExteriorRing" "', argument " "1"" of type '" "GeosPolygon *""'");
- try
- result = (GeosGeometry *)GeosPolygon_getExteriorRing(arg1);
- if (result == NULL)
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Polygon_getNumInteriorRings(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *resultobj = 0;
- size_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- PyObject * obj0 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Polygon_getNumInteriorRings",1,1,&obj0)) SWIG_fail;
- if (!SWIG_IsOK(res1)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Polygon_getNumInteriorRings" "', argument " "1"" of type '" "GeosPolygon *""'");
- try
- result = GeosPolygon_getNumInteriorRings(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Polygon_getInteriorRingN(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"Polygon_getInteriorRingN",2,2,&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Polygon_getInteriorRingN" "', argument " "1"" of type '" "GeosPolygon *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Polygon_getInteriorRingN" "', argument " "2"" of type '" "size_t""'");
- try
- result = (GeosGeometry *)GeosPolygon_getInteriorRingN(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *Polygon_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosPolygon, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_GeometryCollection(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosGeometryCollection *arg1 = (GeosGeometryCollection *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_GeometryCollection",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometryCollection, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_GeometryCollection" "', argument " "1"" of type '" "GeosGeometryCollection *""'");
- arg1 = reinterpret_cast< GeosGeometryCollection * >(argp1);
- try
- delete_GeosGeometryCollection(arg1);
- resultobj = SWIG_Py_Void();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_GeometryCollection_getGeometryN(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- PyObject * obj1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"GeometryCollection_getGeometryN",2,2,&obj0,&obj1)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometryCollection, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "GeometryCollection_getGeometryN" "', argument " "1"" of type '" "GeosGeometryCollection *""'");
- ecode2 = SWIG_AsVal_size_t(obj1, &val2);
- if (!SWIG_IsOK(ecode2)) {
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "GeometryCollection_getGeometryN" "', argument " "2"" of type '" "size_t""'");
- arg2 = static_cast< size_t >(val2);
- try
- result = (GeosGeometry *)GeosGeometryCollection_getGeometryN(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *GeometryCollection_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosGeometryCollection, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_MultiPoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosMultiPoint *arg1 = (GeosMultiPoint *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_MultiPoint",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiPoint, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiPoint" "', argument " "1"" of type '" "GeosMultiPoint *""'");
- arg1 = reinterpret_cast< GeosMultiPoint * >(argp1);
- try
- delete_GeosMultiPoint(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *MultiPoint_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiPoint, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_MultiLineString(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosMultiLineString *arg1 = (GeosMultiLineString *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_MultiLineString",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiLineString, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiLineString" "', argument " "1"" of type '" "GeosMultiLineString *""'");
- arg1 = reinterpret_cast< GeosMultiLineString * >(argp1);
- try
- delete_GeosMultiLineString(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *MultiLineString_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiLineString, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_MultiLinearRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosMultiLinearRing *arg1 = (GeosMultiLinearRing *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_MultiLinearRing",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiLinearRing, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiLinearRing" "', argument " "1"" of type '" "GeosMultiLinearRing *""'");
- arg1 = reinterpret_cast< GeosMultiLinearRing * >(argp1);
- try
- delete_GeosMultiLinearRing(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *MultiLinearRing_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiLinearRing, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_delete_MultiPolygon(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosMultiPolygon *arg1 = (GeosMultiPolygon *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"delete_MultiPolygon",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiPolygon, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiPolygon" "', argument " "1"" of type '" "GeosMultiPolygon *""'");
- arg1 = reinterpret_cast< GeosMultiPolygon * >(argp1);
- try
- delete_GeosMultiPolygon(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *MultiPolygon_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiPolygon, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_createPoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"createPoint",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createPoint" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosGeometry *)createPoint(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_createLineString(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"createLineString",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createLineString" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosGeometry *)createLineString(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_createLinearRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"createLinearRing",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createLinearRing" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosGeometry *)createLinearRing(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_createPolygon(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- GeosLinearRing **arg2 = (GeosLinearRing **) 0 ;
- size_t arg3 ;
- int res1 = 0 ;
- arg2 = NULL;
- arg3 = 0;
- if(!PyArg_UnpackTuple(args,(char *)"createPolygon",1,2,&obj0,&obj1)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
- if (obj1) {
- if (obj1 == Py_None)
- arg2 = NULL;
- arg3 = 0;
- else
- /* Make sure the input can be treated as an array. */
- if (!PySequence_Check(obj1))
- SWIG_exception_fail(SWIG_RuntimeError, "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
- /* Get the length */
- arg3 = PySequence_Size(obj1);
- /* Allocate space for the C array. */
- arg2 = (GeosLinearRing**) malloc(arg3*sizeof(GeosLinearRing*));
- for(size_t i = 0; i<arg3; i++)
- /* Get the Python Object */
- PyObject *item = PySequence_GetItem(obj1,i);
- /* Get the underlying pointer and give up ownership of it. */
- GeosLinearRing *ring = NULL;
- int convertResult = SWIG_ConvertPtr(item, (void**)&ring, SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN);
- if (!SWIG_IsOK(convertResult)) {
- SWIG_exception_fail(SWIG_ArgError(convertResult), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
- /* Put the pointer in the array */
- arg2[i] = ring;
- try
- result = (GeosGeometry *)createPolygon(arg1,arg2,arg3);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- if (arg2) {
- free((void*) arg2);
- return resultobj;
-fail:
- if (arg2) {
- return NULL;
-SWIGINTERN PyObject *_wrap_geomFromWKT(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- char *arg1 = (char *) 0 ;
- int res1 ;
- char *buf1 = 0 ;
- int alloc1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"geomFromWKT",1,1,&obj0)) SWIG_fail;
- res1 = SWIG_AsCharPtrAndSize(obj0, &buf1, NULL, &alloc1);
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "geomFromWKT" "', argument " "1"" of type '" "char const *""'");
- arg1 = reinterpret_cast< char * >(buf1);
- try
- result = (GeosGeometry *)geomFromWKT((char const *)arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- if (alloc1 == SWIG_NEWOBJ) delete[] buf1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_geomToWKT(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"geomToWKT",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "geomToWKT" "', argument " "1"" of type '" "GeosGeometry const *""'");
- try
- result = (char *)geomToWKT((GeosGeometry const *)arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_getWKBOutputDims(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- if(!PyArg_UnpackTuple(args,(char *)"getWKBOutputDims",0,0)) SWIG_fail;
- try
- result = (int)getWKBOutputDims();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_setWKBOutputDims(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg1 ;
- int result;
- int val1 ;
- int ecode1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"setWKBOutputDims",1,1,&obj0)) SWIG_fail;
- ecode1 = SWIG_AsVal_int(obj0, &val1);
- SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "setWKBOutputDims" "', argument " "1"" of type '" "int""'");
- arg1 = static_cast< int >(val1);
- try
- result = (int)setWKBOutputDims(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_getWKBByteOrder(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- if(!PyArg_UnpackTuple(args,(char *)"getWKBByteOrder",0,0)) SWIG_fail;
- try
- result = (int)getWKBByteOrder();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_setWKBByteOrder(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg1 ;
- int result;
- int val1 ;
- int ecode1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"setWKBByteOrder",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "setWKBByteOrder" "', argument " "1"" of type '" "int""'");
- try
- result = (int)setWKBByteOrder(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_geomFromWKB(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- unsigned char *arg1 = (unsigned char *) 0 ;
- size_t arg2 ;
- int alloc1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"geomFromWKB",1,1,&obj0)) SWIG_fail;
- /* %typemap(in) (const unsigned char* wkb, size_t size) (int alloc1 = 0) */
- if (SWIG_AsCharPtrAndSize(obj0, (char**)&arg1, &arg2, &alloc1) != SWIG_OK)
- SWIG_exception(SWIG_RuntimeError, "Expecting a string");
- /* Don't want to include last null character! */
- arg2--;
- try
- result = (GeosGeometry *)geomFromWKB((unsigned char const *)arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_geomToWKB(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t *arg2 = (size_t *) 0 ;
- unsigned char *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t temp2 = 0 ;
- /* %typemap(in, numinputs=0) size_t *size (size_t temp2 = 0) */
- arg2 = &temp2;
- if(!PyArg_UnpackTuple(args,(char *)"geomToWKB",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "geomToWKB" "', argument " "1"" of type '" "GeosGeometry const *""'");
- try
- result = (unsigned char *)geomToWKB((GeosGeometry const *)arg1,arg2);
- /* %typemap(out) unsigned char* */
- /* %typemap(argout) size_t *size */
- resultobj = SWIG_FromCharPtrAndSize((const char*)result, *arg2);
- /* %typemap(freearg) size_t *size */
- std::free(result);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_geomFromHEX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- int alloc1 = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"geomFromHEX",1,1,&obj0)) SWIG_fail;
- arg2--;
- try
- result = (GeosGeometry *)geomFromHEX((unsigned char const *)arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_geomToHEX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- arg2 = &temp2;
- if(!PyArg_UnpackTuple(args,(char *)"geomToHEX",1,1,&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "geomToHEX" "', argument " "1"" of type '" "GeosGeometry const *""'");
- try
- result = (unsigned char *)geomToHEX((GeosGeometry const *)arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-static PyMethodDef SwigMethods[] = {
- { (char *)"delete_PySwigIterator", _wrap_delete_PySwigIterator, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_value", _wrap_PySwigIterator_value, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_incr", _wrap_PySwigIterator_incr, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_decr", _wrap_PySwigIterator_decr, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_distance", _wrap_PySwigIterator_distance, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_equal", _wrap_PySwigIterator_equal, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_copy", _wrap_PySwigIterator_copy, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_next", _wrap_PySwigIterator_next, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_previous", _wrap_PySwigIterator_previous, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_advance", _wrap_PySwigIterator_advance, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___eq__", _wrap_PySwigIterator___eq__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___ne__", _wrap_PySwigIterator___ne__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___iadd__", _wrap_PySwigIterator___iadd__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___isub__", _wrap_PySwigIterator___isub__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___add__", _wrap_PySwigIterator___add__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___sub__", _wrap_PySwigIterator___sub__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_swigregister", PySwigIterator_swigregister, METH_VARARGS, NULL},
- { (char *)"version", _wrap_version, METH_VARARGS, NULL},
- { (char *)"new_CoordinateSequence", _wrap_new_CoordinateSequence, METH_VARARGS, NULL},
- { (char *)"delete_CoordinateSequence", _wrap_delete_CoordinateSequence, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_clone", _wrap_CoordinateSequence_clone, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_setX", _wrap_CoordinateSequence_setX, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_setY", _wrap_CoordinateSequence_setY, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_setZ", _wrap_CoordinateSequence_setZ, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_setOrdinate", _wrap_CoordinateSequence_setOrdinate, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_getX", _wrap_CoordinateSequence_getX, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_getY", _wrap_CoordinateSequence_getY, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_getZ", _wrap_CoordinateSequence_getZ, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_getOrdinate", _wrap_CoordinateSequence_getOrdinate, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_getSize", _wrap_CoordinateSequence_getSize, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_getDimensions", _wrap_CoordinateSequence_getDimensions, METH_VARARGS, NULL},
- { (char *)"CoordinateSequence_swigregister", CoordinateSequence_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_Geometry", _wrap_delete_Geometry, METH_VARARGS, NULL},
- { (char *)"Geometry_clone", _wrap_Geometry_clone, METH_VARARGS, NULL},
- { (char *)"Geometry_geomType", _wrap_Geometry_geomType, METH_VARARGS, NULL},
- { (char *)"Geometry_typeId", _wrap_Geometry_typeId, METH_VARARGS, NULL},
- { (char *)"Geometry_normalize", _wrap_Geometry_normalize, METH_VARARGS, NULL},
- { (char *)"Geometry_getSRID", _wrap_Geometry_getSRID, METH_VARARGS, NULL},
- { (char *)"Geometry_setSRID", _wrap_Geometry_setSRID, METH_VARARGS, NULL},
- { (char *)"Geometry_getDimensions", _wrap_Geometry_getDimensions, METH_VARARGS, NULL},
- { (char *)"Geometry_getNumGeometries", _wrap_Geometry_getNumGeometries, METH_VARARGS, NULL},
- { (char *)"Geometry_intersection", _wrap_Geometry_intersection, METH_VARARGS, NULL},
- { (char *)"Geometry_buffer", _wrap_Geometry_buffer, METH_VARARGS, NULL},
- { (char *)"Geometry_convexHull", _wrap_Geometry_convexHull, METH_VARARGS, NULL},
- { (char *)"Geometry_difference", _wrap_Geometry_difference, METH_VARARGS, NULL},
- { (char *)"Geometry_symDifference", _wrap_Geometry_symDifference, METH_VARARGS, NULL},
- { (char *)"Geometry_boundary", _wrap_Geometry_boundary, METH_VARARGS, NULL},
- { (char *)"Geometry_union", _wrap_Geometry_union, METH_VARARGS, NULL},
- { (char *)"Geometry_pointOnSurface", _wrap_Geometry_pointOnSurface, METH_VARARGS, NULL},
- { (char *)"Geometry_getCentroid", _wrap_Geometry_getCentroid, METH_VARARGS, NULL},
- { (char *)"Geometry_getEnvelope", _wrap_Geometry_getEnvelope, METH_VARARGS, NULL},
- { (char *)"Geometry_relate", _wrap_Geometry_relate, METH_VARARGS, NULL},
- { (char *)"Geometry_lineMerge", _wrap_Geometry_lineMerge, METH_VARARGS, NULL},
- { (char *)"Geometry_simplify", _wrap_Geometry_simplify, METH_VARARGS, NULL},
- { (char *)"Geometry_topologyPreserveSimplify", _wrap_Geometry_topologyPreserveSimplify, METH_VARARGS, NULL},
- { (char *)"Geometry_relatePattern", _wrap_Geometry_relatePattern, METH_VARARGS, NULL},
- { (char *)"Geometry_disjoint", _wrap_Geometry_disjoint, METH_VARARGS, NULL},
- { (char *)"Geometry_touches", _wrap_Geometry_touches, METH_VARARGS, NULL},
- { (char *)"Geometry_intersects", _wrap_Geometry_intersects, METH_VARARGS, NULL},
- { (char *)"Geometry_crosses", _wrap_Geometry_crosses, METH_VARARGS, NULL},
- { (char *)"Geometry_within", _wrap_Geometry_within, METH_VARARGS, NULL},
- { (char *)"Geometry_contains", _wrap_Geometry_contains, METH_VARARGS, NULL},
- { (char *)"Geometry_overlaps", _wrap_Geometry_overlaps, METH_VARARGS, NULL},
- { (char *)"Geometry_equals", _wrap_Geometry_equals, METH_VARARGS, NULL},
- { (char *)"Geometry_equalsExact", _wrap_Geometry_equalsExact, METH_VARARGS, NULL},
- { (char *)"Geometry_isEmpty", _wrap_Geometry_isEmpty, METH_VARARGS, NULL},
- { (char *)"Geometry_isValid", _wrap_Geometry_isValid, METH_VARARGS, NULL},
- { (char *)"Geometry_isSimple", _wrap_Geometry_isSimple, METH_VARARGS, NULL},
- { (char *)"Geometry_isRing", _wrap_Geometry_isRing, METH_VARARGS, NULL},
- { (char *)"Geometry_hasZ", _wrap_Geometry_hasZ, METH_VARARGS, NULL},
- { (char *)"Geometry_area", _wrap_Geometry_area, METH_VARARGS, NULL},
- { (char *)"Geometry_length", _wrap_Geometry_length, METH_VARARGS, NULL},
- { (char *)"Geometry_distance", _wrap_Geometry_distance, METH_VARARGS, NULL},
- { (char *)"Geometry_swigregister", Geometry_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_Point", _wrap_delete_Point, METH_VARARGS, NULL},
- { (char *)"Point_getCoordSeq", _wrap_Point_getCoordSeq, METH_VARARGS, NULL},
- { (char *)"Point_swigregister", Point_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_LineString", _wrap_delete_LineString, METH_VARARGS, NULL},
- { (char *)"LineString_getCoordSeq", _wrap_LineString_getCoordSeq, METH_VARARGS, NULL},
- { (char *)"LineString_swigregister", LineString_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_LinearRing", _wrap_delete_LinearRing, METH_VARARGS, NULL},
- { (char *)"LinearRing_getCoordSeq", _wrap_LinearRing_getCoordSeq, METH_VARARGS, NULL},
- { (char *)"LinearRing_swigregister", LinearRing_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_Polygon", _wrap_delete_Polygon, METH_VARARGS, NULL},
- { (char *)"Polygon_getExteriorRing", _wrap_Polygon_getExteriorRing, METH_VARARGS, NULL},
- { (char *)"Polygon_getNumInteriorRings", _wrap_Polygon_getNumInteriorRings, METH_VARARGS, NULL},
- { (char *)"Polygon_getInteriorRingN", _wrap_Polygon_getInteriorRingN, METH_VARARGS, NULL},
- { (char *)"Polygon_swigregister", Polygon_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_GeometryCollection", _wrap_delete_GeometryCollection, METH_VARARGS, NULL},
- { (char *)"GeometryCollection_getGeometryN", _wrap_GeometryCollection_getGeometryN, METH_VARARGS, NULL},
- { (char *)"GeometryCollection_swigregister", GeometryCollection_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_MultiPoint", _wrap_delete_MultiPoint, METH_VARARGS, NULL},
- { (char *)"MultiPoint_swigregister", MultiPoint_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_MultiLineString", _wrap_delete_MultiLineString, METH_VARARGS, NULL},
- { (char *)"MultiLineString_swigregister", MultiLineString_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_MultiLinearRing", _wrap_delete_MultiLinearRing, METH_VARARGS, NULL},
- { (char *)"MultiLinearRing_swigregister", MultiLinearRing_swigregister, METH_VARARGS, NULL},
- { (char *)"delete_MultiPolygon", _wrap_delete_MultiPolygon, METH_VARARGS, NULL},
- { (char *)"MultiPolygon_swigregister", MultiPolygon_swigregister, METH_VARARGS, NULL},
- { (char *)"createPoint", _wrap_createPoint, METH_VARARGS, NULL},
- { (char *)"createLineString", _wrap_createLineString, METH_VARARGS, NULL},
- { (char *)"createLinearRing", _wrap_createLinearRing, METH_VARARGS, NULL},
- { (char *)"createPolygon", _wrap_createPolygon, METH_VARARGS, NULL},
- { (char *)"geomFromWKT", _wrap_geomFromWKT, METH_VARARGS, NULL},
- { (char *)"geomToWKT", _wrap_geomToWKT, METH_VARARGS, NULL},
- { (char *)"getWKBOutputDims", _wrap_getWKBOutputDims, METH_VARARGS, NULL},
- { (char *)"setWKBOutputDims", _wrap_setWKBOutputDims, METH_VARARGS, NULL},
- { (char *)"getWKBByteOrder", _wrap_getWKBByteOrder, METH_VARARGS, NULL},
- { (char *)"setWKBByteOrder", _wrap_setWKBByteOrder, METH_VARARGS, NULL},
- { (char *)"geomFromWKB", _wrap_geomFromWKB, METH_VARARGS, NULL},
- { (char *)"geomToWKB", _wrap_geomToWKB, METH_VARARGS, NULL},
- { (char *)"geomFromHEX", _wrap_geomFromHEX, METH_VARARGS, NULL},
- { (char *)"geomToHEX", _wrap_geomToHEX, METH_VARARGS, NULL},
- { NULL, NULL, 0, NULL }
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
-static void *_p_GeosMultiPolygonTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiPolygon *) x));
-static void *_p_GeosMultiPointTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiPoint *) x));
-static void *_p_GeosMultiLineStringTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiLineString *) x));
-static void *_p_GeosMultiLinearRingTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
-static void *_p_GeosPolygonTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosPolygon *) x));
-static void *_p_GeosMultiPolygonTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPolygon *) x));
-static void *_p_GeosPointTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosPoint *) x));
-static void *_p_GeosLineStringTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosLineString *) x));
-static void *_p_GeosLinearRingTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosLinearRing *) x));
-static void *_p_GeosMultiPointTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPoint *) x));
-static void *_p_GeosMultiLineStringTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLineString *) x));
-static void *_p_GeosMultiLinearRingTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
-static void *_p_GeosGeometryCollectionTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosGeometryCollection *) x));
-static swig_type_info _swigt__p_GeosCoordinateSequence = {"_p_GeosCoordinateSequence", "GeosCoordinateSequence *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosGeometry = {"_p_GeosGeometry", "GeosGeometry *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosGeometryCollection = {"_p_GeosGeometryCollection", "GeosGeometryCollection *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosLineString = {"_p_GeosLineString", "GeosLineString *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosLinearRing = {"_p_GeosLinearRing", "GeosLinearRing *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiLineString = {"_p_GeosMultiLineString", "GeosMultiLineString *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiLinearRing = {"_p_GeosMultiLinearRing", "GeosMultiLinearRing *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiPoint = {"_p_GeosMultiPoint", "GeosMultiPoint *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiPolygon = {"_p_GeosMultiPolygon", "GeosMultiPolygon *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosPoint = {"_p_GeosPoint", "GeosPoint *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosPolygon = {"_p_GeosPolygon", "GeosPolygon *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_char = {"_p_char", "char *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_p_GeosLinearRing = {"_p_p_GeosLinearRing", "GeosLinearRing **", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_size_t = {"_p_size_t", "size_t *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__invalid_argument = {"_p_std__invalid_argument", "std::invalid_argument *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_swig__PySwigIterator = {"_p_swig__PySwigIterator", "swig::PySwigIterator *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_unsigned_char = {"_p_unsigned_char", "unsigned char *", 0, 0, (void*)0, 0};
-static swig_type_info *swig_type_initial[] = {
- &_swigt__p_GeosCoordinateSequence,
- &_swigt__p_GeosGeometry,
- &_swigt__p_GeosGeometryCollection,
- &_swigt__p_GeosLineString,
- &_swigt__p_GeosLinearRing,
- &_swigt__p_GeosMultiLineString,
- &_swigt__p_GeosMultiLinearRing,
- &_swigt__p_GeosMultiPoint,
- &_swigt__p_GeosMultiPolygon,
- &_swigt__p_GeosPoint,
- &_swigt__p_GeosPolygon,
- &_swigt__p_char,
- &_swigt__p_p_GeosLinearRing,
- &_swigt__p_size_t,
- &_swigt__p_std__invalid_argument,
- &_swigt__p_swig__PySwigIterator,
- &_swigt__p_unsigned_char,
-static swig_cast_info _swigc__p_GeosCoordinateSequence[] = { {&_swigt__p_GeosCoordinateSequence, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosGeometry[] = { {&_swigt__p_GeosPolygon, _p_GeosPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosPoint, _p_GeosPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometry, 0, 0, 0}, {&_swigt__p_GeosLineString, _p_GeosLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosLinearRing, _p_GeosLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometryCollection, _p_GeosGeometryCollectionTo_p_GeosGeometry, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosGeometryCollection[] = { {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosGeometryCollection, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosLineString[] = { {&_swigt__p_GeosLineString, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosLinearRing[] = { {&_swigt__p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiLineString[] = { {&_swigt__p_GeosMultiLineString, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiLinearRing[] = { {&_swigt__p_GeosMultiLinearRing, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiPoint[] = { {&_swigt__p_GeosMultiPoint, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiPolygon[] = { {&_swigt__p_GeosMultiPolygon, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosPoint[] = { {&_swigt__p_GeosPoint, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosPolygon[] = { {&_swigt__p_GeosPolygon, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_char[] = { {&_swigt__p_char, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_p_GeosLinearRing[] = { {&_swigt__p_p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_size_t[] = { {&_swigt__p_size_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__invalid_argument[] = { {&_swigt__p_std__invalid_argument, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_swig__PySwigIterator[] = { {&_swigt__p_swig__PySwigIterator, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_unsigned_char[] = { {&_swigt__p_unsigned_char, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info *swig_cast_initial[] = {
- _swigc__p_GeosCoordinateSequence,
- _swigc__p_GeosGeometry,
- _swigc__p_GeosGeometryCollection,
- _swigc__p_GeosLineString,
- _swigc__p_GeosLinearRing,
- _swigc__p_GeosMultiLineString,
- _swigc__p_GeosMultiLinearRing,
- _swigc__p_GeosMultiPoint,
- _swigc__p_GeosMultiPolygon,
- _swigc__p_GeosPoint,
- _swigc__p_GeosPolygon,
- _swigc__p_char,
- _swigc__p_p_GeosLinearRing,
- _swigc__p_size_t,
- _swigc__p_std__invalid_argument,
- _swigc__p_swig__PySwigIterator,
- _swigc__p_unsigned_char,
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
-static swig_const_info swig_const_table[] = {
-{0, 0, 0, 0.0, 0, 0}};
-#ifdef __cplusplus
-#endif
- * Type initialization:
- * This problem is tough by the requirement that no dynamic
- * memory is used. Also, since swig_type_info structures store pointers to
- * swig_cast_info structures and swig_cast_info structures store pointers back
- * to swig_type_info structures, we need some lookup code at initialization.
- * The idea is that swig generates all the structures that are needed.
- * The runtime then collects these partially filled structures.
- * The SWIG_InitializeModule function takes these initial arrays out of
- * swig_module, and does all the lookup, filling in the swig_module.types
- * array with the correct data and linking the correct swig_cast_info
- * structures together.
- * The generated swig_type_info structures are assigned staticly to an initial
- * array. We just loop through that array, and handle each type individually.
- * First we lookup if this type has been already loaded, and if so, use the
- * loaded structure instead of the generated one. Then we have to fill in the
- * cast linked list. The cast data is initially stored in something like a
- * two-dimensional array. Each row corresponds to a type (there are the same
- * number of rows as there are in the swig_type_initial array). Each entry in
- * a column is one of the swig_cast_info structures for that type.
- * The cast_initial array is actually an array of arrays, because each row has
- * a variable number of columns. So to actually build the cast linked list,
- * we find the array of casts associated with the type, and loop through it
- * adding the casts to the list. The one last trick we need to do is making
- * sure the type pointer in the swig_cast_info struct is correct.
- * First off, we lookup the cast->type name to see if it is already loaded.
- * There are three cases to handle:
- * 1) If the cast->type has already been loaded AND the type we are adding
- * casting info to has not been loaded (it is in this module), THEN we
- * replace the cast->type pointer with the type pointer that has already
- * been loaded.
- * 2) If BOTH types (the one we are adding casting info to, and the
- * cast->type) are loaded, THEN the cast info has already been loaded by
- * the previous module so we just ignore it.
- * 3) Finally, if cast->type has not already been loaded, then we add that
- * swig_cast_info to the linked list (because the cast->type) pointer will
- * be correct.
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* c-mode */
-#endif
-#endif
-#if 0
-#define SWIGRUNTIME_DEBUG
-#endif
-SWIGRUNTIME void
-SWIG_InitializeModule(void *clientdata) {
- size_t i;
- swig_module_info *module_head, *iter;
- int found;
- clientdata = clientdata;
- /* check to see if the circular list has been setup, if not, set it up */
- if (swig_module.next==0) {
- /* Initialize the swig_module */
- swig_module.type_initial = swig_type_initial;
- swig_module.cast_initial = swig_cast_initial;
- swig_module.next = &swig_module;
- /* Try and load any already created modules */
- module_head = SWIG_GetModule(clientdata);
- if (!module_head) {
- /* This is the first module loaded for this interpreter */
- /* so set the swig module into the interpreter */
- SWIG_SetModule(clientdata, &swig_module);
- module_head = &swig_module;
- } else {
- /* the interpreter has loaded a SWIG module, but has it loaded this one? */
- found=0;
- iter=module_head;
- do {
- if (iter==&swig_module) {
- found=1;
- break;
- iter=iter->next;
- } while (iter!= module_head);
- /* if the is found in the list, then all is done and we may leave */
- if (found) return;
- /* otherwise we must add out module into the list */
- swig_module.next = module_head->next;
- module_head->next = &swig_module;
- /* Now work on filling in swig_module.types */
-#ifdef SWIGRUNTIME_DEBUG
- printf("SWIG_InitializeModule: size %d\n", swig_module.size);
-#endif
- for (i = 0; i < swig_module.size; ++i) {
- swig_type_info *type = 0;
- swig_type_info *ret;
- swig_cast_info *cast;
- printf("SWIG_InitializeModule: type %d %s\n", i, swig_module.type_initial[i]->name);
-#endif
- /* if there is another module already loaded */
- if (swig_module.next != &swig_module) {
- type = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, swig_module.type_initial[i]->name);
- if (type) {
- /* Overwrite clientdata field */
- printf("SWIG_InitializeModule: found type %s\n", type->name);
-#endif
- if (swig_module.type_initial[i]->clientdata) {
- type->clientdata = swig_module.type_initial[i]->clientdata;
- printf("SWIG_InitializeModule: found and overwrite type %s \n", type->name);
-#endif
- } else {
- type = swig_module.type_initial[i];
- /* Insert casting types */
- cast = swig_module.cast_initial[i];
- while (cast->type) {
- /* Don't need to add information already in the list */
- ret = 0;
- printf("SWIG_InitializeModule: look cast %s\n", cast->type->name);
-#endif
- ret = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, cast->type->name);
- if (ret) printf("SWIG_InitializeModule: found cast %s\n", ret->name);
-#endif
- if (ret) {
- if (type == swig_module.type_initial[i]) {
- printf("SWIG_InitializeModule: skip old type %s\n", ret->name);
-#endif
- cast->type = ret;
- ret = 0;
- } else {
- /* Check for casting already in the list */
- swig_cast_info *ocast = SWIG_TypeCheck(ret->name, type);
- if (ocast) printf("SWIG_InitializeModule: skip old cast %s\n", ret->name);
-#endif
- if (!ocast) ret = 0;
- if (!ret) {
- printf("SWIG_InitializeModule: adding cast %s\n", cast->type->name);
-#endif
- if (type->cast) {
- type->cast->prev = cast;
- cast->next = type->cast;
- type->cast = cast;
- cast++;
- /* Set entry in modules->types array equal to the type */
- swig_module.types[i] = type;
- swig_module.types[i] = 0;
- printf("**** SWIG_InitializeModule: Cast List ******\n");
- int j = 0;
- swig_cast_info *cast = swig_module.cast_initial[i];
- printf("SWIG_InitializeModule: cast type %s\n", cast->type->name);
- cast++;
- ++j;
- printf("---- Total casts: %d\n",j);
-#endif
-/* This function will propagate the clientdata field of type to
-* any new swig_type_info structures that have been added into the list
-* of equivalent types. It is like calling
-* SWIG_TypeClientData(type, clientdata) a second time.
-SWIGRUNTIME void
-SWIG_PropagateClientData(void) {
- size_t i;
- swig_cast_info *equiv;
- static int init_run = 0;
- if (init_run) return;
- init_run = 1;
- for (i = 0; i < swig_module.size; i++) {
- if (swig_module.types[i]->clientdata) {
- equiv = swig_module.types[i]->cast;
- while (equiv) {
- if (!equiv->converter) {
- if (equiv->type && !equiv->type->clientdata)
- SWIG_TypeClientData(equiv->type, swig_module.types[i]->clientdata);
- equiv = equiv->next;
-#ifdef __cplusplus
-#if 0
- /* c-mode */
-#endif
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
- /* Python-specific SWIG API */
-#define SWIG_newvarlink() SWIG_Python_newvarlink()
-#define SWIG_addvarlink(p, name, get_attr, set_attr) SWIG_Python_addvarlink(p, name, get_attr, set_attr)
-#define SWIG_InstallConstants(d, constants) SWIG_Python_InstallConstants(d, constants)
- * global variable support code.
- typedef struct swig_globalvar {
- char *name; /* Name of global variable */
- PyObject *(*get_attr)(void); /* Return the current value */
- int (*set_attr)(PyObject *); /* Set the value */
- struct swig_globalvar *next;
- } swig_globalvar;
- typedef struct swig_varlinkobject {
- PyObject_HEAD
- swig_globalvar *vars;
- } swig_varlinkobject;
- SWIGINTERN PyObject *
- swig_varlink_repr(swig_varlinkobject *SWIGUNUSEDPARM(v)) {
- return PyString_FromString("<Swig global variables>");
- swig_varlink_str(swig_varlinkobject *v) {
- PyObject *str = PyString_FromString("(");
- swig_globalvar *var;
- for (var = v->vars; var; var=var->next) {
- PyString_ConcatAndDel(&str,PyString_FromString(var->name));
- if (var->next) PyString_ConcatAndDel(&str,PyString_FromString(", "));
- PyString_ConcatAndDel(&str,PyString_FromString(")"));
- return str;
- SWIGINTERN int
- swig_varlink_print(swig_varlinkobject *v, FILE *fp, int SWIGUNUSEDPARM(flags)) {
- PyObject *str = swig_varlink_str(v);
- fprintf(fp,"Swig global variables ");
- fprintf(fp,"%s\n", PyString_AsString(str));
- Py_DECREF(str);
- return 0;
- SWIGINTERN void
- swig_varlink_dealloc(swig_varlinkobject *v) {
- swig_globalvar *var = v->vars;
- while (var) {
- swig_globalvar *n = var->next;
- free(var->name);
- free(var);
- var = n;
- swig_varlink_getattr(swig_varlinkobject *v, char *n) {
- PyObject *res = NULL;
- while (var) {
- if (strcmp(var->name,n) == 0) {
- res = (*var->get_attr)();
- break;
- var = var->next;
- if (res == NULL && !PyErr_Occurred()) {
- PyErr_SetString(PyExc_NameError,"Unknown C global variable");
- return res;
- SWIGINTERN int
- swig_varlink_setattr(swig_varlinkobject *v, char *n, PyObject *p) {
- int res = 1;
- while (var) {
- res = (*var->set_attr)(p);
- break;
- var = var->next;
- if (res == 1 && !PyErr_Occurred()) {
- return res;
- SWIGINTERN PyTypeObject*
- swig_varlink_type(void) {
- static char varlink__doc__[] = "Swig var link object";
- static PyTypeObject varlink_type;
- static int type_init = 0;
- if (!type_init) {
- const PyTypeObject tmp
- PyObject_HEAD_INIT(NULL)
- 0, /* Number of items in variable part (ob_size) */
- (char *)"swigvarlink", /* Type name (tp_name) */
- sizeof(swig_varlinkobject), /* Basic size (tp_basicsize) */
- 0, /* Itemsize (tp_itemsize) */
- (destructor) swig_varlink_dealloc, /* Deallocator (tp_dealloc) */
- (printfunc) swig_varlink_print, /* Print (tp_print) */
- (getattrfunc) swig_varlink_getattr, /* get attr (tp_getattr) */
- (setattrfunc) swig_varlink_setattr, /* Set attr (tp_setattr) */
- 0, /* tp_compare */
- (reprfunc) swig_varlink_repr, /* tp_repr */
- 0, /* tp_as_number */
- 0, /* tp_as_sequence */
- 0, /* tp_as_mapping */
- 0, /* tp_hash */
- 0, /* tp_call */
- (reprfunc)swig_varlink_str, /* tp_str */
- 0, /* tp_getattro */
- 0, /* tp_setattro */
- 0, /* tp_as_buffer */
- 0, /* tp_flags */
- varlink__doc__, /* tp_doc */
- 0, /* tp_traverse */
- 0, /* tp_clear */
- 0, /* tp_richcompare */
- 0, /* tp_weaklistoffset */
-#if PY_VERSION_HEX >= 0x02020000
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, /* tp_iter -> tp_weaklist */
-#endif
-#if PY_VERSION_HEX >= 0x02030000
- 0, /* tp_del */
-#endif
-#ifdef COUNT_ALLOCS
- 0,0,0,0 /* tp_alloc -> tp_next */
-#endif
- varlink_type = tmp;
- varlink_type.ob_type = &PyType_Type;
- type_init = 1;
- return &varlink_type;
- /* Create a variable linking object for use later */
- SWIG_Python_newvarlink(void) {
- swig_varlinkobject *result = PyObject_NEW(swig_varlinkobject, swig_varlink_type());
- if (result) {
- result->vars = 0;
- return ((PyObject*) result);
- SWIGINTERN void
- SWIG_Python_addvarlink(PyObject *p, char *name, PyObject *(*get_attr)(void), int (*set_attr)(PyObject *p)) {
- swig_varlinkobject *v = (swig_varlinkobject *) p;
- swig_globalvar *gv = (swig_globalvar *) malloc(sizeof(swig_globalvar));
- if (gv) {
- size_t size = strlen(name)+1;
- gv->name = (char *)malloc(size);
- if (gv->name) {
- strncpy(gv->name,name,size);
- gv->get_attr = get_attr;
- gv->set_attr = set_attr;
- gv->next = v->vars;
- v->vars = gv;
- SWIG_globals(void) {
- static PyObject *_SWIG_globals = 0;
- if (!_SWIG_globals) _SWIG_globals = SWIG_newvarlink();
- return _SWIG_globals;
- * constants/methods manipulation
- /* Install Constants */
- SWIGINTERN void
- SWIG_Python_InstallConstants(PyObject *d, swig_const_info constants[]) {
- PyObject *obj = 0;
- size_t i;
- for (i = 0; constants[i].type; ++i) {
- switch(constants[i].type) {
- case SWIG_PY_POINTER:
- obj = SWIG_NewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
- break;
- case SWIG_PY_BINARY:
- obj = SWIG_NewPackedObj(constants[i].pvalue, constants[i].lvalue, *(constants[i].ptype));
- break;
- default:
- obj = 0;
- break;
- if (obj) {
- PyDict_SetItemString(d, constants[i].name, obj);
- Py_DECREF(obj);
- /* Fix SwigMethods to carry the callback ptrs when needed */
- SWIGINTERN void
- SWIG_Python_FixMethods(PyMethodDef *methods,
- swig_const_info *const_table,
- swig_type_info **types,
- swig_type_info **types_initial) {
- size_t i;
- for (i = 0; methods[i].ml_name; ++i) {
- const char *c = methods[i].ml_doc;
- if (c && (c = strstr(c, "swig_ptr: "))) {
- int j;
- swig_const_info *ci = 0;
- const char *name = c + 10;
- for (j = 0; const_table[j].type; ++j) {
- if (strncmp(const_table[j].name, name,
- strlen(const_table[j].name)) == 0) {
- ci = &(const_table[j]);
- break;
- if (ci) {
- size_t shift = (ci->ptype) - types;
- swig_type_info *ty = types_initial[shift];
- size_t ldoc = (c - methods[i].ml_doc);
- size_t lptr = strlen(ty->name)+2*sizeof(void*)+2;
- char *ndoc = (char*)malloc(ldoc + lptr + 10);
- if (ndoc) {
- char *buff = ndoc;
- void *ptr = (ci->type == SWIG_PY_POINTER) ? ci->pvalue : 0;
- if (ptr) {
- strncpy(buff, methods[i].ml_doc, ldoc);
- buff += ldoc;
- strncpy(buff, "swig_ptr: ", 10);
- buff += 10;
- SWIG_PackVoidPtr(buff, ptr, ty->name, lptr);
- methods[i].ml_doc = ndoc;
-#ifdef __cplusplus
-#endif
- * Partial Init method
-#ifdef __cplusplus
-extern "C"
-#endif
-SWIGEXPORT void SWIG_init(void) {
- PyObject *m, *d;
- SWIG_Python_FixMethods(SwigMethods, swig_const_table, swig_types, swig_type_initial);
- m = Py_InitModule((char *) SWIG_name, SwigMethods);
- d = PyModule_GetDict(m);
- SWIG_InitializeModule(0);
- SWIG_InstallConstants(d,swig_const_table);
- SWIG_Python_SetConstant(d, "GEOS_VERSION_MAJOR",SWIG_From_int(static_cast< int >(3)));
- SWIG_Python_SetConstant(d, "GEOS_VERSION_MINOR",SWIG_From_int(static_cast< int >(0)));
- SWIG_Python_SetConstant(d, "GEOS_VERSION",SWIG_FromCharPtr("3.0.0rc4"));
- SWIG_Python_SetConstant(d, "GEOS_JTS_PORT",SWIG_FromCharPtr("1.7.1"));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MAJOR",SWIG_From_int(static_cast< int >(1)));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MINOR",SWIG_From_int(static_cast< int >(3)));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_PATCH",SWIG_From_int(static_cast< int >(3)));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_FIRST_INTERFACE",SWIG_From_int(static_cast< int >(1)));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_LAST_INTERFACE",SWIG_From_int(static_cast< int >((1+3))));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION",SWIG_FromCharPtr("3.0.0rc4-CAPI-1.3.3"));
- SWIG_Python_SetConstant(d, "GEOS_POINT",SWIG_From_int(static_cast< int >(GEOS_POINT)));
- SWIG_Python_SetConstant(d, "GEOS_LINESTRING",SWIG_From_int(static_cast< int >(GEOS_LINESTRING)));
- SWIG_Python_SetConstant(d, "GEOS_LINEARRING",SWIG_From_int(static_cast< int >(GEOS_LINEARRING)));
- SWIG_Python_SetConstant(d, "GEOS_POLYGON",SWIG_From_int(static_cast< int >(GEOS_POLYGON)));
- SWIG_Python_SetConstant(d, "GEOS_MULTIPOINT",SWIG_From_int(static_cast< int >(GEOS_MULTIPOINT)));
- SWIG_Python_SetConstant(d, "GEOS_MULTILINESTRING",SWIG_From_int(static_cast< int >(GEOS_MULTILINESTRING)));
- SWIG_Python_SetConstant(d, "GEOS_MULTIPOLYGON",SWIG_From_int(static_cast< int >(GEOS_MULTIPOLYGON)));
- SWIG_Python_SetConstant(d, "GEOS_GEOMETRYCOLLECTION",SWIG_From_int(static_cast< int >(GEOS_GEOMETRYCOLLECTION)));
- SWIG_Python_SetConstant(d, "GEOS_WKB_XDR",SWIG_From_int(static_cast< int >(GEOS_WKB_XDR)));
- SWIG_Python_SetConstant(d, "GEOS_WKB_NDR",SWIG_From_int(static_cast< int >(GEOS_WKB_NDR)));
- initGEOS(noticeHandler, errorHandler);
+ * This file was automatically generated by SWIG (http://www.swig.org).
+ * Version 1.3.40
+ * This file is not intended to be easily readable and contains a number of
+ * coding conventions designed to improve portability and efficiency. Do not make
+ * changes to this file unless you know what you are doing--modify the SWIG
+ * interface file instead.
+#define SWIGPYTHON
+#define SWIG_PYTHON_DIRECTOR_NO_VTABLE
+#ifdef __cplusplus
+/* SwigValueWrapper is described in swig.swg */
+template<typename T> class SwigValueWrapper {
+ struct SwigMovePointer {
+ T *ptr;
+ SwigMovePointer(T *p) : ptr(p) { }
+ ~SwigMovePointer() { delete ptr; }
+ SwigMovePointer& operator=(SwigMovePointer& rhs) { T* oldptr = ptr; ptr = 0; delete oldptr; ptr = rhs.ptr; rhs.ptr = 0; return *this; }
+ } pointer;
+ SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
+ SwigValueWrapper(const SwigValueWrapper<T>& rhs);
+public:
+ SwigValueWrapper() : pointer(0) { }
+ SwigValueWrapper& operator=(const T& t) { SwigMovePointer tmp(new T(t)); pointer = tmp; return *this; }
+ operator T&() const { return *pointer.ptr; }
+ T *operator&() { return pointer.ptr; }
+template <typename T> T SwigValueInit() {
+ return T();
+#endif
+ * This section contains generic SWIG labels for method/variable
+ * declarations/attributes, and other compiler dependent labels.
+/* template workaround for compilers that cannot correctly implement the C++ standard */
+#ifndef SWIGTEMPLATEDISAMBIGUATOR
+# if defined(__SUNPRO_CC) && (__SUNPRO_CC <= 0x560)
+# define SWIGTEMPLATEDISAMBIGUATOR template
+# elif defined(__HP_aCC)
+/* Needed even with `aCC -AA' when `aCC -V' reports HP ANSI C++ B3910B A.03.55 */
+/* If we find a maximum version that requires this, the test would be __HP_aCC <= 35500 for A.03.55 */
+# else
+# endif
+#endif
+/* inline attribute */
+#ifndef SWIGINLINE
+# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
+# define SWIGINLINE inline
+# else
+# endif
+#endif
+/* attribute recognised by some compilers to avoid 'unused' warnings */
+#ifndef SWIGUNUSED
+# if defined(__GNUC__)
+# if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
+# define SWIGUNUSED __attribute__ ((__unused__))
+# else
+# endif
+# elif defined(__ICC)
+# else
+# endif
+#endif
+#ifndef SWIG_MSC_UNSUPPRESS_4505
+# if defined(_MSC_VER)
+# pragma warning(disable : 4505) /* unreferenced local function has been removed */
+# endif
+#endif
+#ifndef SWIGUNUSEDPARM
+# ifdef __cplusplus
+# define SWIGUNUSEDPARM(p)
+# else
+# define SWIGUNUSEDPARM(p) p SWIGUNUSED
+# endif
+#endif
+/* internal SWIG method */
+#ifndef SWIGINTERN
+# define SWIGINTERN static SWIGUNUSED
+#endif
+/* internal inline SWIG method */
+#ifndef SWIGINTERNINLINE
+# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
+#endif
+/* exporting methods */
+#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
+# ifndef GCC_HASCLASSVISIBILITY
+# define GCC_HASCLASSVISIBILITY
+# endif
+#endif
+#ifndef SWIGEXPORT
+# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
+# if defined(STATIC_LINKED)
+# define SWIGEXPORT
+# else
+# define SWIGEXPORT __declspec(dllexport)
+# endif
+# else
+# if defined(__GNUC__) && defined(GCC_HASCLASSVISIBILITY)
+# define SWIGEXPORT __attribute__ ((visibility("default")))
+# else
+# endif
+# endif
+#endif
+/* calling conventions for Windows */
+#ifndef SWIGSTDCALL
+# define SWIGSTDCALL __stdcall
+# else
+# endif
+#endif
+/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
+#if !defined(SWIG_NO_CRT_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
+# define _CRT_SECURE_NO_DEPRECATE
+#endif
+/* Deal with Microsoft's attempt at deprecating methods in the standard C++ library */
+#if !defined(SWIG_NO_SCL_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_SCL_SECURE_NO_DEPRECATE)
+# define _SCL_SECURE_NO_DEPRECATE
+#endif
+/* Python.h has to appear first */
+#include <Python.h>
+ * swigrun.swg
+ * This file contains generic C API SWIG runtime support for pointer
+ * type checking.
+/* This should only be incremented when either the layout of swig_type_info changes,
+ or for whatever reason, the runtime changes incompatibly */
+#define SWIG_RUNTIME_VERSION "4"
+/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
+#ifdef SWIG_TYPE_TABLE
+# define SWIG_QUOTE_STRING(x) #x
+# define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
+# define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
+#else
+#endif
+ You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
+ creating a static or dynamic library from the SWIG runtime code.
+ In 99.9% of the cases, SWIG just needs to declare them as 'static'.
+ But only do this if strictly necessary, ie, if you have problems
+ with your compiler or suchlike.
+#ifndef SWIGRUNTIME
+# define SWIGRUNTIME SWIGINTERN
+#endif
+#ifndef SWIGRUNTIMEINLINE
+# define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
+#endif
+/* Generic buffer size */
+#ifndef SWIG_BUFFER_SIZE
+# define SWIG_BUFFER_SIZE 1024
+#endif
+/* Flags for pointer conversions */
+#define SWIG_POINTER_DISOWN 0x1
+#define SWIG_CAST_NEW_MEMORY 0x2
+/* Flags for new pointer objects */
+#define SWIG_POINTER_OWN 0x1
+ Flags/methods for returning states.
+ The SWIG conversion methods, as ConvertPtr, return and integer
+ that tells if the conversion was successful or not. And if not,
+ an error code can be returned (see swigerrors.swg for the codes).
+ Use the following macros/flags to set or process the returning
+ states.
+ In old versions of SWIG, code such as the following was usually written:
+ if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
+ // success code
+ } else {
+ //fail code
+ Now you can be more explicit:
+ int res = SWIG_ConvertPtr(obj,vptr,ty.flags);
+ if (SWIG_IsOK(res)) {
+ // success code
+ } else {
+ // fail code
+ which is the same really, but now you can also do
+ Type *ptr;
+ int res = SWIG_ConvertPtr(obj,(void **)(&ptr),ty.flags);
+ // success code
+ if (SWIG_IsNewObj(res) {
+ delete *ptr;
+ } else {
+ } else {
+ // fail code
+ I.e., now SWIG_ConvertPtr can return new objects and you can
+ identify the case and take care of the deallocation. Of course that
+ also requires SWIG_ConvertPtr to return new result values, such as
+ int SWIG_ConvertPtr(obj, ptr,...) {
+ if (<obj is ok>) {
+ if (<need new object>) {
+ *ptr = <ptr to new allocated object>;
+ return SWIG_NEWOBJ;
+ } else {
+ *ptr = <ptr to old object>;
+ return SWIG_OLDOBJ;
+ } else {
+ return SWIG_BADOBJ;
+ Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
+ more explicit by returning SWIG_BADOBJ, SWIG_ERROR or any of the
+ SWIG errors code.
+ Finally, if the SWIG_CASTRANK_MODE is enabled, the result code
+ allows to return the 'cast rank', for example, if you have this
+ int food(double)
+ int fooi(int);
+ and you call
+ food(1) // cast rank '1' (1 -> 1.0)
+ fooi(1) // cast rank '0'
+ just use the SWIG_AddCast()/SWIG_CheckState()
+#define SWIG_OK (0)
+#define SWIG_ERROR (-1)
+#define SWIG_IsOK(r) (r >= 0)
+#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
+/* The CastRankLimit says how many bits are used for the cast rank */
+#define SWIG_CASTRANKLIMIT (1 << 8)
+/* The NewMask denotes the object was created (using new/malloc) */
+#define SWIG_NEWOBJMASK (SWIG_CASTRANKLIMIT << 1)
+/* The TmpMask is for in/out typemaps that use temporal objects */
+#define SWIG_TMPOBJMASK (SWIG_NEWOBJMASK << 1)
+/* Simple returning values */
+#define SWIG_BADOBJ (SWIG_ERROR)
+#define SWIG_OLDOBJ (SWIG_OK)
+#define SWIG_NEWOBJ (SWIG_OK | SWIG_NEWOBJMASK)
+#define SWIG_TMPOBJ (SWIG_OK | SWIG_TMPOBJMASK)
+/* Check, add and del mask methods */
+#define SWIG_AddNewMask(r) (SWIG_IsOK(r) ? (r | SWIG_NEWOBJMASK) : r)
+#define SWIG_DelNewMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_NEWOBJMASK) : r)
+#define SWIG_IsNewObj(r) (SWIG_IsOK(r) && (r & SWIG_NEWOBJMASK))
+#define SWIG_AddTmpMask(r) (SWIG_IsOK(r) ? (r | SWIG_TMPOBJMASK) : r)
+#define SWIG_DelTmpMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_TMPOBJMASK) : r)
+#define SWIG_IsTmpObj(r) (SWIG_IsOK(r) && (r & SWIG_TMPOBJMASK))
+/* Cast-Rank Mode */
+#if defined(SWIG_CASTRANK_MODE)
+# ifndef SWIG_TypeRank
+# define SWIG_TypeRank unsigned long
+# endif
+# ifndef SWIG_MAXCASTRANK /* Default cast allowed */
+# define SWIG_MAXCASTRANK (2)
+# endif
+# define SWIG_CASTRANKMASK ((SWIG_CASTRANKLIMIT) -1)
+# define SWIG_CastRank(r) (r & SWIG_CASTRANKMASK)
+SWIGINTERNINLINE int SWIG_AddCast(int r) {
+ return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
+SWIGINTERNINLINE int SWIG_CheckState(int r) {
+ return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
+#else /* no cast-rank mode */
+# define SWIG_AddCast
+# define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
+#endif
+#include <string.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+typedef void *(*swig_converter_func)(void *, int *);
+typedef struct swig_type_info *(*swig_dycast_func)(void **);
+/* Structure to store information on one type */
+typedef struct swig_type_info {
+ const char *name; /* mangled name of this type */
+ const char *str; /* human readable name of this type */
+ swig_dycast_func dcast; /* dynamic cast function down a hierarchy */
+ struct swig_cast_info *cast; /* linked list of types that can cast into this type */
+ void *clientdata; /* language specific type data */
+ int owndata; /* flag if the structure owns the clientdata */
+} swig_type_info;
+/* Structure to store a type and conversion function used for casting */
+typedef struct swig_cast_info {
+ swig_type_info *type; /* pointer to type that is equivalent to this type */
+ swig_converter_func converter; /* function to cast the void pointers */
+ struct swig_cast_info *next; /* pointer to next cast in linked list */
+ struct swig_cast_info *prev; /* pointer to the previous cast */
+} swig_cast_info;
+/* Structure used to store module information
+ * Each module generates one structure like this, and the runtime collects
+ * all of these structures and stores them in a circularly linked list.*/
+typedef struct swig_module_info {
+ swig_type_info **types; /* Array of pointers to swig_type_info structures that are in this module */
+ size_t size; /* Number of types in this module */
+ struct swig_module_info *next; /* Pointer to next element in circularly linked list */
+ swig_type_info **type_initial; /* Array of initially generated type structures */
+ swig_cast_info **cast_initial; /* Array of initially generated casting structures */
+ void *clientdata; /* Language specific module data */
+} swig_module_info;
+ Compare two type names skipping the space characters, therefore
+ "char*" == "char *" and "Class<int>" == "Class<int >", etc.
+ Return 0 when the two name types are equivalent, as in
+ strncmp, but skipping ' '.
+SWIGRUNTIME int
+SWIG_TypeNameComp(const char *f1, const char *l1,
+ const char *f2, const char *l2) {
+ for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
+ while ((*f1 == ' ') && (f1 != l1)) ++f1;
+ while ((*f2 == ' ') && (f2 != l2)) ++f2;
+ if (*f1 != *f2) return (*f1 > *f2) ? 1 : -1;
+ return (int)((l1 - f1) - (l2 - f2));
+ Check type equivalence in a name list like <name1>|<name2>|...
+ Return 0 if not equal, 1 if equal
+SWIGRUNTIME int
+SWIG_TypeEquiv(const char *nb, const char *tb) {
+ int equiv = 0;
+ const char* te = tb + strlen(tb);
+ const char* ne = nb;
+ while (!equiv && *ne) {
+ for (nb = ne; *ne; ++ne) {
+ if (*ne == '|') break;
+ equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
+ if (*ne) ++ne;
+ return equiv;
+ Return 0 if equal, -1 if nb < tb, 1 if nb > tb
+SWIGRUNTIME int
+SWIG_TypeCompare(const char *nb, const char *tb) {
+ int equiv = 0;
+ if (*ne) ++ne;
+ return equiv;
+ Check the typename
+SWIGRUNTIME swig_cast_info *
+SWIG_TypeCheck(const char *c, swig_type_info *ty) {
+ if (ty) {
+ swig_cast_info *iter = ty->cast;
+ while (iter) {
+ if (strcmp(iter->type->name, c) == 0) {
+ if (iter == ty->cast)
+ return iter;
+ /* Move iter to the top of the linked list */
+ iter->prev->next = iter->next;
+ if (iter->next)
+ iter->next->prev = iter->prev;
+ iter->next = ty->cast;
+ iter->prev = 0;
+ if (ty->cast) ty->cast->prev = iter;
+ ty->cast = iter;
+ return iter;
+ iter = iter->next;
+ return 0;
+ Identical to SWIG_TypeCheck, except strcmp is replaced with a pointer comparison
+SWIG_TypeCheckStruct(swig_type_info *from, swig_type_info *ty) {
+ if (ty) {
+ while (iter) {
+ if (iter->type == from) {
+ return iter;
+ if (iter->next)
+ iter->prev = 0;
+ ty->cast = iter;
+ return iter;
+ return 0;
+ Cast a pointer up an inheritance hierarchy
+SWIGRUNTIMEINLINE void *
+SWIG_TypeCast(swig_cast_info *ty, void *ptr, int *newmemory) {
+ return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr, newmemory);
+ Dynamic pointer casting. Down an inheritance hierarchy
+SWIGRUNTIME swig_type_info *
+SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
+ swig_type_info *lastty = ty;
+ if (!ty || !ty->dcast) return ty;
+ while (ty && (ty->dcast)) {
+ ty = (*ty->dcast)(ptr);
+ if (ty) lastty = ty;
+ return lastty;
+ Return the name associated with this type
+SWIGRUNTIMEINLINE const char *
+SWIG_TypeName(const swig_type_info *ty) {
+ return ty->name;
+ Return the pretty name associated with this type,
+ that is an unmangled type name in a form presentable to the user.
+SWIGRUNTIME const char *
+SWIG_TypePrettyName(const swig_type_info *type) {
+ /* The "str" field contains the equivalent pretty names of the
+ type, separated by vertical-bar characters. We choose
+ to print the last name, as it is often (?) the most
+ specific. */
+ if (!type) return NULL;
+ if (type->str != NULL) {
+ const char *last_name = type->str;
+ const char *s;
+ for (s = type->str; *s; s++)
+ if (*s == '|') last_name = s+1;
+ return last_name;
+ else
+ return type->name;
+ Set the clientdata field for a type
+SWIGRUNTIME void
+SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
+ swig_cast_info *cast = ti->cast;
+ /* if (ti->clientdata == clientdata) return; */
+ ti->clientdata = clientdata;
+ while (cast) {
+ if (!cast->converter) {
+ swig_type_info *tc = cast->type;
+ if (!tc->clientdata) {
+ SWIG_TypeClientData(tc, clientdata);
+ cast = cast->next;
+SWIGRUNTIME void
+SWIG_TypeNewClientData(swig_type_info *ti, void *clientdata) {
+ SWIG_TypeClientData(ti, clientdata);
+ ti->owndata = 1;
+ Search for a swig_type_info structure only by mangled name
+ Search is a O(log #types)
+ We start searching at module start, and finish searching when start == end.
+ Note: if start == end at the beginning of the function, we go all the way around
+ the circular list.
+SWIG_MangledTypeQueryModule(swig_module_info *start,
+ swig_module_info *end,
+ const char *name) {
+ swig_module_info *iter = start;
+ do {
+ if (iter->size) {
+ register size_t l = 0;
+ register size_t r = iter->size - 1;
+ do {
+ /* since l+r >= 0, we can (>> 1) instead (/ 2) */
+ register size_t i = (l + r) >> 1;
+ const char *iname = iter->types[i]->name;
+ if (iname) {
+ register int compare = strcmp(name, iname);
+ if (compare == 0) {
+ return iter->types[i];
+ } else if (compare < 0) {
+ if (i) {
+ r = i - 1;
+ } else {
+ break;
+ } else if (compare > 0) {
+ l = i + 1;
+ } else {
+ break; /* should never happen */
+ } while (l <= r);
+ } while (iter != end);
+ return 0;
+ Search for a swig_type_info structure for either a mangled name or a human readable name.
+ It first searches the mangled names of the types, which is a O(log #types)
+ If a type is not found it then searches the human readable names, which is O(#types).
+SWIG_TypeQueryModule(swig_module_info *start,
+ /* STEP 1: Search the name field using binary search */
+ swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
+ if (ret) {
+ return ret;
+ } else {
+ /* STEP 2: If the type hasn't been found, do a complete search
+ of the str field (the human readable name) */
+ do {
+ register size_t i = 0;
+ for (; i < iter->size; ++i) {
+ if (iter->types[i]->str && (SWIG_TypeEquiv(iter->types[i]->str, name)))
+ /* neither found a match */
+ return 0;
+ Pack binary data into a string
+SWIGRUNTIME char *
+SWIG_PackData(char *c, void *ptr, size_t sz) {
+ static const char hex[17] = "0123456789abcdef";
+ register const unsigned char *u = (unsigned char *) ptr;
+ register const unsigned char *eu = u + sz;
+ for (; u != eu; ++u) {
+ register unsigned char uu = *u;
+ *(c++) = hex[(uu & 0xf0) >> 4];
+ *(c++) = hex[uu & 0xf];
+ return c;
+ Unpack binary data from a string
+SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
+ register unsigned char *u = (unsigned char *) ptr;
+ register char d = *(c++);
+ register unsigned char uu;
+ if ((d >= '0') && (d <= '9'))
+ uu = ((d - '0') << 4);
+ else if ((d >= 'a') && (d <= 'f'))
+ uu = ((d - ('a'-10)) << 4);
+ else
+ return (char *) 0;
+ d = *(c++);
+ uu |= (d - '0');
+ uu |= (d - ('a'-10));
+ else
+ *u = uu;
+ return c;
+ Pack 'void *' into a string buffer.
+SWIGRUNTIME char *
+SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
+ char *r = buff;
+ if ((2*sizeof(void *) + 2) > bsz) return 0;
+ *(r++) = '_';
+ r = SWIG_PackData(r,&ptr,sizeof(void *));
+ if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
+ strcpy(r,name);
+ return buff;
+SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
+ if (*c != '_') {
+ if (strcmp(c,"NULL") == 0) {
+ *ptr = (void *) 0;
+ return name;
+ } else {
+ return 0;
+ return SWIG_UnpackData(++c,ptr,sizeof(void *));
+SWIGRUNTIME char *
+SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
+ char *r = buff;
+ size_t lname = (name ? strlen(name) : 0);
+ if ((2*sz + 2 + lname) > bsz) return 0;
+ *(r++) = '_';
+ r = SWIG_PackData(r,ptr,sz);
+ if (lname) {
+ strncpy(r,name,lname+1);
+ } else {
+ *r = 0;
+ return buff;
+SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
+ if (*c != '_') {
+ memset(ptr,0,sz);
+ return name;
+ } else {
+ return 0;
+ return SWIG_UnpackData(++c,ptr,sz);
+#ifdef __cplusplus
+#endif
+/* Errors in SWIG */
+#define SWIG_UnknownError -1
+#define SWIG_IOError -2
+#define SWIG_RuntimeError -3
+#define SWIG_IndexError -4
+#define SWIG_TypeError -5
+#define SWIG_DivisionByZero -6
+#define SWIG_OverflowError -7
+#define SWIG_SyntaxError -8
+#define SWIG_ValueError -9
+#define SWIG_SystemError -10
+#define SWIG_AttributeError -11
+#define SWIG_MemoryError -12
+#define SWIG_NullReferenceError -13
+/* Compatibility macros for Python 3 */
+#if PY_VERSION_HEX >= 0x03000000
+#define PyClass_Check(obj) PyObject_IsInstance(obj, (PyObject *)&PyType_Type)
+#define PyInt_Check(x) PyLong_Check(x)
+#define PyInt_AsLong(x) PyLong_AsLong(x)
+#define PyInt_FromLong(x) PyLong_FromLong(x)
+#define PyString_Format(fmt, args) PyUnicode_Format(fmt, args)
+#endif
+#ifndef Py_TYPE
+# define Py_TYPE(op) ((op)->ob_type)
+#endif
+/* SWIG APIs for compatibility of both Python 2 & 3 */
+# define SWIG_Python_str_FromFormat PyUnicode_FromFormat
+#else
+# define SWIG_Python_str_FromFormat PyString_FromFormat
+#endif
+/* Warning: This function will allocate a new string in Python 3,
+ * so please call SWIG_Python_str_DelForPy3(x) to free the space.
+SWIGINTERN char*
+SWIG_Python_str_AsChar(PyObject *str)
+ char *cstr;
+ char *newstr;
+ Py_ssize_t len;
+ str = PyUnicode_AsUTF8String(str);
+ PyBytes_AsStringAndSize(str, &cstr, &len);
+ newstr = (char *) malloc(len+1);
+ memcpy(newstr, cstr, len+1);
+ Py_XDECREF(str);
+ return newstr;
+#else
+ return PyString_AsString(str);
+#endif
+# define SWIG_Python_str_DelForPy3(x) free( (void*) (x) )
+#else
+#endif
+SWIGINTERN PyObject*
+SWIG_Python_str_FromChar(const char *c)
+ return PyUnicode_FromString(c);
+#else
+ return PyString_FromString(c);
+#endif
+/* Add PyOS_snprintf for old Pythons */
+#if PY_VERSION_HEX < 0x02020000
+# if defined(_MSC_VER) || defined(__BORLANDC__) || defined(_WATCOM)
+# define PyOS_snprintf _snprintf
+# else
+# define PyOS_snprintf snprintf
+# endif
+#endif
+/* A crude PyString_FromFormat implementation for old Pythons */
+#ifndef SWIG_PYBUFFER_SIZE
+# define SWIG_PYBUFFER_SIZE 1024
+#endif
+static PyObject *
+PyString_FromFormat(const char *fmt, ...) {
+ va_list ap;
+ char buf[SWIG_PYBUFFER_SIZE * 2];
+ int res;
+ va_start(ap, fmt);
+ res = vsnprintf(buf, sizeof(buf), fmt, ap);
+ va_end(ap);
+ return (res < 0 || res >= (int)sizeof(buf)) ? 0 : PyString_FromString(buf);
+#endif
+/* Add PyObject_Del for old Pythons */
+#if PY_VERSION_HEX < 0x01060000
+# define PyObject_Del(op) PyMem_DEL((op))
+#endif
+#ifndef PyObject_DEL
+# define PyObject_DEL PyObject_Del
+#endif
+/* A crude PyExc_StopIteration exception for old Pythons */
+# ifndef PyExc_StopIteration
+# define PyExc_StopIteration PyExc_RuntimeError
+# endif
+# ifndef PyObject_GenericGetAttr
+# define PyObject_GenericGetAttr 0
+# endif
+#endif
+/* Py_NotImplemented is defined in 2.1 and up. */
+#if PY_VERSION_HEX < 0x02010000
+# ifndef Py_NotImplemented
+# define Py_NotImplemented PyExc_RuntimeError
+# endif
+#endif
+/* A crude PyString_AsStringAndSize implementation for old Pythons */
+# ifndef PyString_AsStringAndSize
+# define PyString_AsStringAndSize(obj, s, len) {*s = PyString_AsString(obj); *len = *s ? strlen(*s) : 0;}
+# endif
+#endif
+/* PySequence_Size for old Pythons */
+#if PY_VERSION_HEX < 0x02000000
+# ifndef PySequence_Size
+# define PySequence_Size PySequence_Length
+# endif
+#endif
+/* PyBool_FromLong for old Pythons */
+#if PY_VERSION_HEX < 0x02030000
+static
+PyObject *PyBool_FromLong(long ok)
+ PyObject *result = ok ? Py_True : Py_False;
+ Py_INCREF(result);
+ return result;
+#endif
+/* Py_ssize_t for old Pythons */
+/* This code is as recommended by: */
+/* http://www.python.org/dev/peps/pep-0353/#conversion-guidelines */
+#if PY_VERSION_HEX < 0x02050000 && !defined(PY_SSIZE_T_MIN)
+typedef int Py_ssize_t;
+# define PY_SSIZE_T_MAX INT_MAX
+# define PY_SSIZE_T_MIN INT_MIN
+#endif
+ * error manipulation
+SWIGRUNTIME PyObject*
+SWIG_Python_ErrorType(int code) {
+ PyObject* type = 0;
+ switch(code) {
+ case SWIG_MemoryError:
+ type = PyExc_MemoryError;
+ break;
+ case SWIG_IOError:
+ type = PyExc_IOError;
+ break;
+ case SWIG_RuntimeError:
+ type = PyExc_RuntimeError;
+ break;
+ case SWIG_IndexError:
+ type = PyExc_IndexError;
+ break;
+ case SWIG_TypeError:
+ type = PyExc_TypeError;
+ break;
+ case SWIG_DivisionByZero:
+ type = PyExc_ZeroDivisionError;
+ break;
+ case SWIG_OverflowError:
+ type = PyExc_OverflowError;
+ break;
+ case SWIG_SyntaxError:
+ type = PyExc_SyntaxError;
+ break;
+ case SWIG_ValueError:
+ type = PyExc_ValueError;
+ break;
+ case SWIG_SystemError:
+ type = PyExc_SystemError;
+ break;
+ case SWIG_AttributeError:
+ type = PyExc_AttributeError;
+ break;
+ default:
+ return type;
+SWIGRUNTIME void
+SWIG_Python_AddErrorMsg(const char* mesg)
+ PyObject *type = 0;
+ PyObject *value = 0;
+ PyObject *traceback = 0;
+ if (PyErr_Occurred()) PyErr_Fetch(&type, &value, &traceback);
+ if (value) {
+ char *tmp;
+ PyObject *old_str = PyObject_Str(value);
+ PyErr_Clear();
+ Py_XINCREF(type);
+ PyErr_Format(type, "%s %s", tmp = SWIG_Python_str_AsChar(old_str), mesg);
+ SWIG_Python_str_DelForPy3(tmp);
+ Py_DECREF(old_str);
+ Py_DECREF(value);
+ } else {
+ PyErr_SetString(PyExc_RuntimeError, mesg);
+#if defined(SWIG_PYTHON_NO_THREADS)
+# if defined(SWIG_PYTHON_THREADS)
+# undef SWIG_PYTHON_THREADS
+# endif
+#endif
+#if defined(SWIG_PYTHON_THREADS) /* Threading support is enabled */
+# if !defined(SWIG_PYTHON_USE_GIL) && !defined(SWIG_PYTHON_NO_USE_GIL)
+# if (PY_VERSION_HEX >= 0x02030000) /* For 2.3 or later, use the PyGILState calls */
+# define SWIG_PYTHON_USE_GIL
+# endif
+# endif
+# if defined(SWIG_PYTHON_USE_GIL) /* Use PyGILState threads calls */
+# ifndef SWIG_PYTHON_INITIALIZE_THREADS
+# define SWIG_PYTHON_INITIALIZE_THREADS PyEval_InitThreads()
+# endif
+# ifdef __cplusplus /* C++ code */
+ class SWIG_Python_Thread_Block {
+ bool status;
+ PyGILState_STATE state;
+ public:
+ void end() { if (status) { PyGILState_Release(state); status = false;} }
+ SWIG_Python_Thread_Block() : status(true), state(PyGILState_Ensure()) {}
+ ~SWIG_Python_Thread_Block() { end(); }
+ class SWIG_Python_Thread_Allow {
+ bool status;
+ PyThreadState *save;
+ public:
+ void end() { if (status) { PyEval_RestoreThread(save); status = false; }}
+ SWIG_Python_Thread_Allow() : status(true), save(PyEval_SaveThread()) {}
+ ~SWIG_Python_Thread_Allow() { end(); }
+# define SWIG_PYTHON_THREAD_BEGIN_BLOCK SWIG_Python_Thread_Block _swig_thread_block
+# define SWIG_PYTHON_THREAD_END_BLOCK _swig_thread_block.end()
+# define SWIG_PYTHON_THREAD_BEGIN_ALLOW SWIG_Python_Thread_Allow _swig_thread_allow
+# define SWIG_PYTHON_THREAD_END_ALLOW _swig_thread_allow.end()
+# else /* C code */
+# define SWIG_PYTHON_THREAD_BEGIN_BLOCK PyGILState_STATE _swig_thread_block = PyGILState_Ensure()
+# define SWIG_PYTHON_THREAD_END_BLOCK PyGILState_Release(_swig_thread_block)
+# define SWIG_PYTHON_THREAD_BEGIN_ALLOW PyThreadState *_swig_thread_allow = PyEval_SaveThread()
+# define SWIG_PYTHON_THREAD_END_ALLOW PyEval_RestoreThread(_swig_thread_allow)
+# endif
+# else /* Old thread way, not implemented, user must provide it */
+# if !defined(SWIG_PYTHON_INITIALIZE_THREADS)
+# endif
+# if !defined(SWIG_PYTHON_THREAD_BEGIN_BLOCK)
+# endif
+# if !defined(SWIG_PYTHON_THREAD_END_BLOCK)
+# endif
+# if !defined(SWIG_PYTHON_THREAD_BEGIN_ALLOW)
+# endif
+# if !defined(SWIG_PYTHON_THREAD_END_ALLOW)
+# endif
+# endif
+#else /* No thread support */
+#endif
+ * Python API portion that goes into the runtime
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* cc-mode */
+#endif
+#endif
+ * Constant declarations
+/* Constant Types */
+#define SWIG_PY_POINTER 4
+#define SWIG_PY_BINARY 5
+/* Constant information structure */
+typedef struct swig_const_info {
+ int type;
+ char *name;
+ long lvalue;
+ double dvalue;
+ void *pvalue;
+ swig_type_info **ptype;
+} swig_const_info;
+ * Wrapper of PyInstanceMethod_New() used in Python 3
+ * It is exported to the generated module, used for -fastproxy
+SWIGRUNTIME PyObject* SWIG_PyInstanceMethod_New(PyObject *self, PyObject *func)
+ return PyInstanceMethod_New(func);
+#else
+ return NULL;
+#endif
+#ifdef __cplusplus
+#if 0
+{ /* cc-mode */
+#endif
+#endif
+ * See the LICENSE file for information on copyright, usage and redistribution
+ * of SWIG, and the README file for authors - http://www.swig.org/release.html.
+ * pyrun.swg
+ * This file contains the runtime support for Python modules
+ * and includes code for managing global variables and pointer
+ * type checking.
+/* Common SWIG API */
+/* for raw pointers */
+#define SWIG_Python_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
+#define SWIG_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtr(obj, pptr, type, flags)
+#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, own)
+#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(ptr, type, flags)
+#define SWIG_CheckImplicit(ty) SWIG_Python_CheckImplicit(ty)
+#define SWIG_AcquirePtr(ptr, src) SWIG_Python_AcquirePtr(ptr, src)
+#define swig_owntype int
+/* for raw packed data */
+#define SWIG_ConvertPacked(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
+#define SWIG_NewPackedObj(ptr, sz, type) SWIG_Python_NewPackedObj(ptr, sz, type)
+/* for class or struct pointers */
+#define SWIG_ConvertInstance(obj, pptr, type, flags) SWIG_ConvertPtr(obj, pptr, type, flags)
+#define SWIG_NewInstanceObj(ptr, type, flags) SWIG_NewPointerObj(ptr, type, flags)
+/* for C or C++ function pointers */
+#define SWIG_ConvertFunctionPtr(obj, pptr, type) SWIG_Python_ConvertFunctionPtr(obj, pptr, type)
+#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_Python_NewPointerObj(ptr, type, 0)
+/* for C++ member pointers, ie, member methods */
+#define SWIG_ConvertMember(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
+#define SWIG_NewMemberObj(ptr, sz, type) SWIG_Python_NewPackedObj(ptr, sz, type)
+/* Runtime API */
+#define SWIG_GetModule(clientdata) SWIG_Python_GetModule()
+#define SWIG_SetModule(clientdata, pointer) SWIG_Python_SetModule(pointer)
+#define SWIG_NewClientData(obj) SwigPyClientData_New(obj)
+#define SWIG_SetErrorObj SWIG_Python_SetErrorObj
+#define SWIG_SetErrorMsg SWIG_Python_SetErrorMsg
+#define SWIG_ErrorType(code) SWIG_Python_ErrorType(code)
+#define SWIG_Error(code, msg) SWIG_Python_SetErrorMsg(SWIG_ErrorType(code), msg)
+#define SWIG_fail goto fail
+/* Runtime API implementation */
+/* Error manipulation */
+SWIGINTERN void
+SWIG_Python_SetErrorObj(PyObject *errtype, PyObject *obj) {
+ SWIG_PYTHON_THREAD_BEGIN_BLOCK;
+ PyErr_SetObject(errtype, obj);
+ Py_DECREF(obj);
+ SWIG_PYTHON_THREAD_END_BLOCK;
+SWIGINTERN void
+SWIG_Python_SetErrorMsg(PyObject *errtype, const char *msg) {
+ PyErr_SetString(errtype, (char *) msg);
+#define SWIG_Python_Raise(obj, type, desc) SWIG_Python_SetErrorObj(SWIG_Python_ExceptionType(desc), obj)
+/* Set a constant value */
+SWIGINTERN void
+SWIG_Python_SetConstant(PyObject *d, const char *name, PyObject *obj) {
+ PyDict_SetItemString(d, (char*) name, obj);
+ Py_DECREF(obj);
+/* Append a value to the result obj */
+SWIG_Python_AppendOutput(PyObject* result, PyObject* obj) {
+#if !defined(SWIG_PYTHON_OUTPUT_TUPLE)
+ if (!result) {
+ result = obj;
+ } else if (result == Py_None) {
+ Py_DECREF(result);
+ result = obj;
+ } else {
+ if (!PyList_Check(result)) {
+ PyObject *o2 = result;
+ result = PyList_New(1);
+ PyList_SetItem(result, 0, o2);
+ PyList_Append(result,obj);
+ Py_DECREF(obj);
+ return result;
+#else
+ PyObject* o2;
+ PyObject* o3;
+ if (!result) {
+ result = obj;
+ result = obj;
+ } else {
+ if (!PyTuple_Check(result)) {
+ o2 = result;
+ result = PyTuple_New(1);
+ PyTuple_SET_ITEM(result, 0, o2);
+ o3 = PyTuple_New(1);
+ PyTuple_SET_ITEM(o3, 0, obj);
+ o2 = result;
+ result = PySequence_Concat(o2, o3);
+ Py_DECREF(o2);
+ Py_DECREF(o3);
+ return result;
+#endif
+/* Unpack the argument tuple */
+SWIGINTERN int
+SWIG_Python_UnpackTuple(PyObject *args, const char *name, Py_ssize_t min, Py_ssize_t max, PyObject **objs)
+ if (!args) {
+ if (!min && !max) {
+ return 1;
+ } else {
+ PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got none",
+ name, (min == max ? "" : "at least "), (int)min);
+ return 0;
+ if (!PyTuple_Check(args)) {
+ PyErr_SetString(PyExc_SystemError, "UnpackTuple() argument list is not a tuple");
+ return 0;
+ } else {
+ register Py_ssize_t l = PyTuple_GET_SIZE(args);
+ if (l < min) {
+ PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got %d",
+ name, (min == max ? "" : "at least "), (int)min, (int)l);
+ return 0;
+ } else if (l > max) {
+ name, (min == max ? "" : "at most "), (int)max, (int)l);
+ return 0;
+ } else {
+ register int i;
+ for (i = 0; i < l; ++i) {
+ objs[i] = PyTuple_GET_ITEM(args, i);
+ for (; l < max; ++l) {
+ objs[l] = 0;
+ return i + 1;
+/* A functor is a function object with one single object argument */
+#if PY_VERSION_HEX >= 0x02020000
+#define SWIG_Python_CallFunctor(functor, obj) PyObject_CallFunctionObjArgs(functor, obj, NULL);
+#else
+#define SWIG_Python_CallFunctor(functor, obj) PyObject_CallFunction(functor, "O", obj);
+#endif
+ Helper for static pointer initialization for both C and C++ code, for example
+ static PyObject *SWIG_STATIC_POINTER(MyVar) = NewSomething(...);
+#ifdef __cplusplus
+#define SWIG_STATIC_POINTER(var) var
+#else
+#define SWIG_STATIC_POINTER(var) var = 0; if (!var) var
+#endif
+ * Pointer declarations
+#define SWIG_POINTER_NOSHADOW (SWIG_POINTER_OWN << 1)
+#define SWIG_POINTER_NEW (SWIG_POINTER_NOSHADOW | SWIG_POINTER_OWN)
+#define SWIG_POINTER_IMPLICIT_CONV (SWIG_POINTER_DISOWN << 1)
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* cc-mode */
+#endif
+#endif
+/* How to access Py_None */
+#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
+# ifndef SWIG_PYTHON_NO_BUILD_NONE
+# ifndef SWIG_PYTHON_BUILD_NONE
+# define SWIG_PYTHON_BUILD_NONE
+# endif
+# endif
+#endif
+#ifdef SWIG_PYTHON_BUILD_NONE
+# ifdef Py_None
+# undef Py_None
+# define Py_None SWIG_Py_None()
+# endif
+SWIGRUNTIMEINLINE PyObject *
+_SWIG_Py_None(void)
+ PyObject *none = Py_BuildValue((char*)"");
+ Py_DECREF(none);
+ return none;
+SWIGRUNTIME PyObject *
+SWIG_Py_None(void)
+ static PyObject *SWIG_STATIC_POINTER(none) = _SWIG_Py_None();
+ return none;
+#endif
+/* The python void return value */
+SWIG_Py_Void(void)
+ PyObject *none = Py_None;
+ Py_INCREF(none);
+ return none;
+/* SwigPyClientData */
+typedef struct {
+ PyObject *klass;
+ PyObject *newraw;
+ PyObject *newargs;
+ PyObject *destroy;
+ int delargs;
+ int implicitconv;
+} SwigPyClientData;
+SWIGRUNTIMEINLINE int
+SWIG_Python_CheckImplicit(swig_type_info *ty)
+ SwigPyClientData *data = (SwigPyClientData *)ty->clientdata;
+ return data ? data->implicitconv : 0;
+SWIG_Python_ExceptionType(swig_type_info *desc) {
+ SwigPyClientData *data = desc ? (SwigPyClientData *) desc->clientdata : 0;
+ PyObject *klass = data ? data->klass : 0;
+ return (klass ? klass : PyExc_RuntimeError);
+SWIGRUNTIME SwigPyClientData *
+SwigPyClientData_New(PyObject* obj)
+ if (!obj) {
+ return 0;
+ } else {
+ SwigPyClientData *data = (SwigPyClientData *)malloc(sizeof(SwigPyClientData));
+ /* the klass element */
+ data->klass = obj;
+ Py_INCREF(data->klass);
+ /* the newraw method and newargs arguments used to create a new raw instance */
+ if (PyClass_Check(obj)) {
+ data->newraw = 0;
+ data->newargs = obj;
+ Py_INCREF(obj);
+ } else {
+#if (PY_VERSION_HEX < 0x02020000)
+ data->newraw = 0;
+#else
+ data->newraw = PyObject_GetAttrString(data->klass, (char *)"__new__");
+#endif
+ if (data->newraw) {
+ Py_INCREF(data->newraw);
+ data->newargs = PyTuple_New(1);
+ PyTuple_SetItem(data->newargs, 0, obj);
+ } else {
+ Py_INCREF(data->newargs);
+ /* the destroy method, aka as the C++ delete method */
+ data->destroy = PyObject_GetAttrString(data->klass, (char *)"__swig_destroy__");
+ if (PyErr_Occurred()) {
+ PyErr_Clear();
+ data->destroy = 0;
+ if (data->destroy) {
+ int flags;
+ Py_INCREF(data->destroy);
+ flags = PyCFunction_GET_FLAGS(data->destroy);
+#ifdef METH_O
+ data->delargs = !(flags & (METH_O));
+#else
+ data->delargs = 0;
+#endif
+ } else {
+ data->implicitconv = 0;
+ return data;
+SWIGRUNTIME void
+SwigPyClientData_Del(SwigPyClientData* data)
+ Py_XDECREF(data->newraw);
+ Py_XDECREF(data->newargs);
+ Py_XDECREF(data->destroy);
+/* =============== SwigPyObject =====================*/
+typedef struct {
+ PyObject_HEAD
+ void *ptr;
+ swig_type_info *ty;
+ int own;
+ PyObject *next;
+} SwigPyObject;
+SwigPyObject_long(SwigPyObject *v)
+ return PyLong_FromVoidPtr(v->ptr);
+SwigPyObject_format(const char* fmt, SwigPyObject *v)
+ PyObject *res = NULL;
+ PyObject *args = PyTuple_New(1);
+ if (args) {
+ if (PyTuple_SetItem(args, 0, SwigPyObject_long(v)) == 0) {
+ PyObject *ofmt = SWIG_Python_str_FromChar(fmt);
+ if (ofmt) {
+ res = PyUnicode_Format(ofmt,args);
+#else
+ res = PyString_Format(ofmt,args);
+#endif
+ Py_DECREF(ofmt);
+ Py_DECREF(args);
+ return res;
+SwigPyObject_oct(SwigPyObject *v)
+ return SwigPyObject_format("%o",v);
+SwigPyObject_hex(SwigPyObject *v)
+ return SwigPyObject_format("%x",v);
+#ifdef METH_NOARGS
+SwigPyObject_repr(SwigPyObject *v)
+#else
+SwigPyObject_repr(SwigPyObject *v, PyObject *args)
+#endif
+ const char *name = SWIG_TypePrettyName(v->ty);
+ PyObject *repr = SWIG_Python_str_FromFormat("<Swig Object of type '%s' at %p>", name, v);
+ if (v->next) {
+#ifdef METH_NOARGS
+ PyObject *nrep = SwigPyObject_repr((SwigPyObject *)v->next);
+#else
+ PyObject *nrep = SwigPyObject_repr((SwigPyObject *)v->next, args);
+#endif
+ PyObject *joined = PyUnicode_Concat(repr, nrep);
+ Py_DecRef(repr);
+ Py_DecRef(nrep);
+ repr = joined;
+#else
+ PyString_ConcatAndDel(&repr,nrep);
+#endif
+ return repr;
+SWIGRUNTIME int
+SwigPyObject_print(SwigPyObject *v, FILE *fp, int SWIGUNUSEDPARM(flags))
+ char *str;
+#ifdef METH_NOARGS
+ PyObject *repr = SwigPyObject_repr(v);
+#else
+ PyObject *repr = SwigPyObject_repr(v, NULL);
+#endif
+ if (repr) {
+ str = SWIG_Python_str_AsChar(repr);
+ fputs(str, fp);
+ SWIG_Python_str_DelForPy3(str);
+ Py_DECREF(repr);
+ return 0;
+ } else {
+ return 1;
+SwigPyObject_str(SwigPyObject *v)
+ char result[SWIG_BUFFER_SIZE];
+ return SWIG_PackVoidPtr(result, v->ptr, v->ty->name, sizeof(result)) ?
+ SWIG_Python_str_FromChar(result) : 0;
+SWIGRUNTIME int
+SwigPyObject_compare(SwigPyObject *v, SwigPyObject *w)
+ void *i = v->ptr;
+ void *j = w->ptr;
+ return (i < j) ? -1 : ((i > j) ? 1 : 0);
+/* Added for Python 3.x, would it also be useful for Python 2.x? */
+SwigPyObject_richcompare(SwigPyObject *v, SwigPyObject *w, int op)
+ PyObject* res;
+ if( op != Py_EQ && op != Py_NE ) {
+ Py_INCREF(Py_NotImplemented);
+ return Py_NotImplemented;
+ if( (SwigPyObject_compare(v, w)==0) == (op == Py_EQ) )
+ res = Py_True;
+ else
+ res = Py_False;
+ Py_INCREF(res);
+ return res;
+SWIGRUNTIME PyTypeObject* _PySwigObject_type(void);
+SwigPyObject_type(void) {
+ static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigObject_type();
+ return type;
+SwigPyObject_Check(PyObject *op) {
+ return (Py_TYPE(op) == SwigPyObject_type())
+ || (strcmp(Py_TYPE(op)->tp_name,"SwigPyObject") == 0);
+SwigPyObject_New(void *ptr, swig_type_info *ty, int own);
+SWIGRUNTIME void
+SwigPyObject_dealloc(PyObject *v)
+ SwigPyObject *sobj = (SwigPyObject *) v;
+ PyObject *next = sobj->next;
+ if (sobj->own == SWIG_POINTER_OWN) {
+ swig_type_info *ty = sobj->ty;
+ SwigPyClientData *data = ty ? (SwigPyClientData *) ty->clientdata : 0;
+ PyObject *destroy = data ? data->destroy : 0;
+ if (destroy) {
+ /* destroy is always a VARARGS method */
+ PyObject *res;
+ if (data->delargs) {
+ /* we need to create a temporary object to carry the destroy operation */
+ PyObject *tmp = SwigPyObject_New(sobj->ptr, ty, 0);
+ res = SWIG_Python_CallFunctor(destroy, tmp);
+ Py_DECREF(tmp);
+ } else {
+ PyCFunction meth = PyCFunction_GET_FUNCTION(destroy);
+ PyObject *mself = PyCFunction_GET_SELF(destroy);
+ res = ((*meth)(mself, v));
+ Py_XDECREF(res);
+#if !defined(SWIG_PYTHON_SILENT_MEMLEAK)
+ else {
+ const char *name = SWIG_TypePrettyName(ty);
+ printf("swig/python detected a memory leak of type '%s', no destructor found.\n", (name ? name : "unknown"));
+#endif
+ Py_XDECREF(next);
+ PyObject_DEL(v);
+SwigPyObject_append(PyObject* v, PyObject* next)
+#ifndef METH_O
+ PyObject *tmp = 0;
+ if (!PyArg_ParseTuple(next,(char *)"O:append", &tmp)) return NULL;
+ next = tmp;
+#endif
+ if (!SwigPyObject_Check(next)) {
+ return NULL;
+ sobj->next = next;
+ Py_INCREF(next);
+ return SWIG_Py_Void();
+#ifdef METH_NOARGS
+SwigPyObject_next(PyObject* v)
+#else
+SwigPyObject_next(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
+#endif
+ if (sobj->next) {
+ Py_INCREF(sobj->next);
+ return sobj->next;
+ } else {
+#ifdef METH_NOARGS
+SwigPyObject_disown(PyObject *v)
+#else
+SwigPyObject_disown(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
+#endif
+ SwigPyObject *sobj = (SwigPyObject *)v;
+ sobj->own = 0;
+#ifdef METH_NOARGS
+SwigPyObject_acquire(PyObject *v)
+#else
+SwigPyObject_acquire(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
+#endif
+ sobj->own = SWIG_POINTER_OWN;
+SwigPyObject_own(PyObject *v, PyObject *args)
+ PyObject *val = 0;
+ if (!PyArg_ParseTuple(args,(char *)"|O:own",&val))
+#else
+ if (!PyArg_UnpackTuple(args, (char *)"own", 0, 1, &val))
+#endif
+ return NULL;
+ else
+ PyObject *obj = PyBool_FromLong(sobj->own);
+ if (val) {
+#ifdef METH_NOARGS
+ if (PyObject_IsTrue(val)) {
+ SwigPyObject_acquire(v);
+ } else {
+ SwigPyObject_disown(v);
+#else
+ SwigPyObject_acquire(v,args);
+ } else {
+ SwigPyObject_disown(v,args);
+#endif
+ return obj;
+#ifdef METH_O
+static PyMethodDef
+swigobject_methods[] = {
+ {(char *)"disown", (PyCFunction)SwigPyObject_disown, METH_NOARGS, (char *)"releases ownership of the pointer"},
+ {(char *)"acquire", (PyCFunction)SwigPyObject_acquire, METH_NOARGS, (char *)"aquires ownership of the pointer"},
+ {(char *)"own", (PyCFunction)SwigPyObject_own, METH_VARARGS, (char *)"returns/sets ownership of the pointer"},
+ {(char *)"append", (PyCFunction)SwigPyObject_append, METH_O, (char *)"appends another 'this' object"},
+ {(char *)"next", (PyCFunction)SwigPyObject_next, METH_NOARGS, (char *)"returns the next 'this' object"},
+ {(char *)"__repr__",(PyCFunction)SwigPyObject_repr, METH_NOARGS, (char *)"returns object representation"},
+ {0, 0, 0, 0}
+#else
+static PyMethodDef
+ {(char *)"disown", (PyCFunction)SwigPyObject_disown, METH_VARARGS, (char *)"releases ownership of the pointer"},
+ {(char *)"acquire", (PyCFunction)SwigPyObject_acquire, METH_VARARGS, (char *)"aquires ownership of the pointer"},
+ {(char *)"append", (PyCFunction)SwigPyObject_append, METH_VARARGS, (char *)"appends another 'this' object"},
+ {(char *)"next", (PyCFunction)SwigPyObject_next, METH_VARARGS, (char *)"returns the next 'this' object"},
+ {(char *)"__repr__",(PyCFunction)SwigPyObject_repr, METH_VARARGS, (char *)"returns object representation"},
+ {0, 0, 0, 0}
+#endif
+SWIGINTERN PyObject *
+SwigPyObject_getattr(SwigPyObject *sobj,char *name)
+ return Py_FindMethod(swigobject_methods, (PyObject *)sobj, name);
+#endif
+_PySwigObject_type(void) {
+ static char swigobject_doc[] = "Swig object carries a C/C++ instance pointer";
+ static PyNumberMethods SwigPyObject_as_number = {
+ (binaryfunc)0, /*nb_add*/
+ (binaryfunc)0, /*nb_subtract*/
+ (binaryfunc)0, /*nb_multiply*/
+ /* nb_divide removed in Python 3 */
+#if PY_VERSION_HEX < 0x03000000
+ (binaryfunc)0, /*nb_divide*/
+#endif
+ (binaryfunc)0, /*nb_remainder*/
+ (binaryfunc)0, /*nb_divmod*/
+ (ternaryfunc)0,/*nb_power*/
+ (unaryfunc)0, /*nb_negative*/
+ (unaryfunc)0, /*nb_positive*/
+ (unaryfunc)0, /*nb_absolute*/
+ (inquiry)0, /*nb_nonzero*/
+ 0, /*nb_invert*/
+ 0, /*nb_lshift*/
+ 0, /*nb_rshift*/
+ 0, /*nb_and*/
+ 0, /*nb_xor*/
+ 0, /*nb_or*/
+ 0, /*nb_coerce*/
+#endif
+ (unaryfunc)SwigPyObject_long, /*nb_int*/
+ (unaryfunc)SwigPyObject_long, /*nb_long*/
+#else
+ 0, /*nb_reserved*/
+#endif
+ (unaryfunc)0, /*nb_float*/
+ (unaryfunc)SwigPyObject_oct, /*nb_oct*/
+ (unaryfunc)SwigPyObject_hex, /*nb_hex*/
+#endif
+#if PY_VERSION_HEX >= 0x03000000 /* 3.0 */
+ 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_index, nb_inplace_divide removed */
+#elif PY_VERSION_HEX >= 0x02050000 /* 2.5.0 */
+ 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_index */
+#elif PY_VERSION_HEX >= 0x02020000 /* 2.2.0 */
+ 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_true_divide */
+#elif PY_VERSION_HEX >= 0x02000000 /* 2.0.0 */
+ 0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_or */
+#endif
+ static PyTypeObject swigpyobject_type;
+ static int type_init = 0;
+ if (!type_init) {
+ const PyTypeObject tmp
+ /* PyObject header changed in Python 3 */
+ PyVarObject_HEAD_INIT(&PyType_Type, 0)
+#else
+ PyObject_HEAD_INIT(NULL)
+ 0, /* ob_size */
+#endif
+ (char *)"SwigPyObject", /* tp_name */
+ sizeof(SwigPyObject), /* tp_basicsize */
+ 0, /* tp_itemsize */
+ (destructor)SwigPyObject_dealloc, /* tp_dealloc */
+ (printfunc)SwigPyObject_print, /* tp_print */
+ (getattrfunc)SwigPyObject_getattr, /* tp_getattr */
+#else
+ (getattrfunc)0, /* tp_getattr */
+#endif
+ (setattrfunc)0, /* tp_setattr */
+ 0, /* tp_reserved in 3.0.1, tp_compare in 3.0.0 but not used */
+#else
+ (cmpfunc)SwigPyObject_compare, /* tp_compare */
+#endif
+ (reprfunc)SwigPyObject_repr, /* tp_repr */
+ &SwigPyObject_as_number, /* tp_as_number */
+ 0, /* tp_as_sequence */
+ 0, /* tp_as_mapping */
+ (hashfunc)0, /* tp_hash */
+ (ternaryfunc)0, /* tp_call */
+ (reprfunc)SwigPyObject_str, /* tp_str */
+ PyObject_GenericGetAttr, /* tp_getattro */
+ 0, /* tp_setattro */
+ 0, /* tp_as_buffer */
+ Py_TPFLAGS_DEFAULT, /* tp_flags */
+ swigobject_doc, /* tp_doc */
+ 0, /* tp_traverse */
+ 0, /* tp_clear */
+ (richcmpfunc)SwigPyObject_richcompare, /* tp_richcompare */
+ 0, /* tp_weaklistoffset */
+ 0, /* tp_iter */
+ 0, /* tp_iternext */
+ swigobject_methods, /* tp_methods */
+ 0, /* tp_members */
+ 0, /* tp_getset */
+ 0, /* tp_base */
+ 0, /* tp_dict */
+ 0, /* tp_descr_get */
+ 0, /* tp_descr_set */
+ 0, /* tp_dictoffset */
+ 0, /* tp_init */
+ 0, /* tp_alloc */
+ 0, /* tp_new */
+ 0, /* tp_free */
+ 0, /* tp_is_gc */
+ 0, /* tp_bases */
+ 0, /* tp_mro */
+ 0, /* tp_cache */
+ 0, /* tp_subclasses */
+ 0, /* tp_weaklist */
+#endif
+#if PY_VERSION_HEX >= 0x02030000
+ 0, /* tp_del */
+#endif
+#ifdef COUNT_ALLOCS
+ 0,0,0,0 /* tp_alloc -> tp_next */
+#endif
+ swigpyobject_type = tmp;
+ /* for Python 3 we already assigned ob_type in PyVarObject_HEAD_INIT() */
+ swigpyobject_type.ob_type = &PyType_Type;
+#endif
+ type_init = 1;
+ return &swigpyobject_type;
+ SwigPyObject *sobj = PyObject_NEW(SwigPyObject, SwigPyObject_type());
+ if (sobj) {
+ sobj->ptr = ptr;
+ sobj->ty = ty;
+ sobj->own = own;
+ sobj->next = 0;
+ return (PyObject *)sobj;
+ * Implements a simple Swig Packed type, and use it instead of string
+typedef struct {
+ PyObject_HEAD
+ void *pack;
+ size_t size;
+} SwigPyPacked;
+SWIGRUNTIME int
+SwigPyPacked_print(SwigPyPacked *v, FILE *fp, int SWIGUNUSEDPARM(flags))
+ fputs("<Swig Packed ", fp);
+ if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))) {
+ fputs("at ", fp);
+ fputs(result, fp);
+ fputs(v->ty->name,fp);
+ fputs(">", fp);
+ return 0;
+SwigPyPacked_repr(SwigPyPacked *v)
+ return SWIG_Python_str_FromFormat("<Swig Packed at %s%s>", result, v->ty->name);
+ } else {
+ return SWIG_Python_str_FromFormat("<Swig Packed %s>", v->ty->name);
+SwigPyPacked_str(SwigPyPacked *v)
+ if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))){
+ return SWIG_Python_str_FromFormat("%s%s", result, v->ty->name);
+ } else {
+ return SWIG_Python_str_FromChar(v->ty->name);
+SWIGRUNTIME int
+SwigPyPacked_compare(SwigPyPacked *v, SwigPyPacked *w)
+ size_t i = v->size;
+ size_t j = w->size;
+ int s = (i < j) ? -1 : ((i > j) ? 1 : 0);
+ return s ? s : strncmp((char *)v->pack, (char *)w->pack, 2*v->size);
+SWIGRUNTIME PyTypeObject* _PySwigPacked_type(void);
+SwigPyPacked_type(void) {
+ static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigPacked_type();
+ return type;
+SwigPyPacked_Check(PyObject *op) {
+ return ((op)->ob_type == _PySwigPacked_type())
+ || (strcmp((op)->ob_type->tp_name,"SwigPyPacked") == 0);
+SWIGRUNTIME void
+SwigPyPacked_dealloc(PyObject *v)
+ if (SwigPyPacked_Check(v)) {
+ SwigPyPacked *sobj = (SwigPyPacked *) v;
+ free(sobj->pack);
+ PyObject_DEL(v);
+_PySwigPacked_type(void) {
+ static char swigpacked_doc[] = "Swig object carries a C/C++ instance pointer";
+ static PyTypeObject swigpypacked_type;
+ if (!type_init) {
+#if PY_VERSION_HEX>=0x03000000
+#else
+ 0, /* ob_size */
+#endif
+ (char *)"SwigPyPacked", /* tp_name */
+ sizeof(SwigPyPacked), /* tp_basicsize */
+ (destructor)SwigPyPacked_dealloc, /* tp_dealloc */
+ (printfunc)SwigPyPacked_print, /* tp_print */
+ 0, /* tp_reserved in 3.0.1 */
+#else
+ (cmpfunc)SwigPyPacked_compare, /* tp_compare */
+#endif
+ (reprfunc)SwigPyPacked_repr, /* tp_repr */
+ 0, /* tp_as_number */
+ (reprfunc)SwigPyPacked_str, /* tp_str */
+ swigpacked_doc, /* tp_doc */
+ 0, /* tp_clear */
+ 0, /* tp_richcompare */
+ 0, /* tp_iter */
+ 0, /* tp_methods */
+ 0, /* tp_base */
+ 0, /* tp_dict */
+ 0, /* tp_init */
+ 0, /* tp_alloc */
+ 0, /* tp_new */
+ 0, /* tp_free */
+ 0, /* tp_is_gc */
+ 0, /* tp_bases */
+ 0, /* tp_mro */
+ 0, /* tp_cache */
+#endif
+ 0, /* tp_del */
+#endif
+#endif
+ swigpypacked_type = tmp;
+ /* for Python 3 the ob_type already assigned in PyVarObject_HEAD_INIT() */
+ swigpypacked_type.ob_type = &PyType_Type;
+#endif
+ type_init = 1;
+ return &swigpypacked_type;
+SwigPyPacked_New(void *ptr, size_t size, swig_type_info *ty)
+ SwigPyPacked *sobj = PyObject_NEW(SwigPyPacked, SwigPyPacked_type());
+ if (sobj) {
+ void *pack = malloc(size);
+ if (pack) {
+ memcpy(pack, ptr, size);
+ sobj->pack = pack;
+ sobj->ty = ty;
+ sobj->size = size;
+ } else {
+ PyObject_DEL((PyObject *) sobj);
+ sobj = 0;
+ return (PyObject *) sobj;
+SwigPyPacked_UnpackData(PyObject *obj, void *ptr, size_t size)
+ if (SwigPyPacked_Check(obj)) {
+ SwigPyPacked *sobj = (SwigPyPacked *)obj;
+ if (sobj->size != size) return 0;
+ memcpy(ptr, sobj->pack, size);
+ return sobj->ty;
+ } else {
+ return 0;
+ * pointers/data manipulation
+_SWIG_This(void)
+ return SWIG_Python_str_FromChar("this");
+SWIG_This(void)
+ static PyObject *SWIG_STATIC_POINTER(swig_this) = _SWIG_This();
+ return swig_this;
+/* #define SWIG_PYTHON_SLOW_GETSET_THIS */
+/* TODO: I don't know how to implement the fast getset in Python 3 right now */
+#define SWIG_PYTHON_SLOW_GETSET_THIS
+#endif
+SWIGRUNTIME SwigPyObject *
+SWIG_Python_GetSwigThis(PyObject *pyobj)
+ if (SwigPyObject_Check(pyobj)) {
+ return (SwigPyObject *) pyobj;
+ } else {
+ PyObject *obj = 0;
+#if (!defined(SWIG_PYTHON_SLOW_GETSET_THIS) && (PY_VERSION_HEX >= 0x02030000))
+ if (PyInstance_Check(pyobj)) {
+ obj = _PyInstance_Lookup(pyobj, SWIG_This());
+ } else {
+ PyObject **dictptr = _PyObject_GetDictPtr(pyobj);
+ if (dictptr != NULL) {
+ PyObject *dict = *dictptr;
+ obj = dict ? PyDict_GetItem(dict, SWIG_This()) : 0;
+ } else {
+#ifdef PyWeakref_CheckProxy
+ if (PyWeakref_CheckProxy(pyobj)) {
+ PyObject *wobj = PyWeakref_GET_OBJECT(pyobj);
+ return wobj ? SWIG_Python_GetSwigThis(wobj) : 0;
+#endif
+ obj = PyObject_GetAttr(pyobj,SWIG_This());
+ if (obj) {
+ Py_DECREF(obj);
+ } else {
+ if (PyErr_Occurred()) PyErr_Clear();
+ return 0;
+#else
+ if (obj) {
+ Py_DECREF(obj);
+ } else {
+ return 0;
+#endif
+ if (obj && !SwigPyObject_Check(obj)) {
+ /* a PyObject is called 'this', try to get the 'real this'
+ SwigPyObject from it */
+ return SWIG_Python_GetSwigThis(obj);
+ return (SwigPyObject *)obj;
+/* Acquire a pointer value */
+SWIGRUNTIME int
+SWIG_Python_AcquirePtr(PyObject *obj, int own) {
+ if (own == SWIG_POINTER_OWN) {
+ SwigPyObject *sobj = SWIG_Python_GetSwigThis(obj);
+ if (sobj) {
+ int oldown = sobj->own;
+ sobj->own = own;
+ return oldown;
+ return 0;
+/* Convert a pointer value */
+SWIGRUNTIME int
+SWIG_Python_ConvertPtrAndOwn(PyObject *obj, void **ptr, swig_type_info *ty, int flags, int *own) {
+ if (!obj) return SWIG_ERROR;
+ if (obj == Py_None) {
+ if (ptr) *ptr = 0;
+ return SWIG_OK;
+ } else {
+ if (own)
+ *own = 0;
+ while (sobj) {
+ void *vptr = sobj->ptr;
+ if (ty) {
+ swig_type_info *to = sobj->ty;
+ if (to == ty) {
+ /* no type cast needed */
+ if (ptr) *ptr = vptr;
+ break;
+ } else {
+ swig_cast_info *tc = SWIG_TypeCheck(to->name,ty);
+ if (!tc) {
+ sobj = (SwigPyObject *)sobj->next;
+ } else {
+ if (ptr) {
+ int newmemory = 0;
+ *ptr = SWIG_TypeCast(tc,vptr,&newmemory);
+ if (newmemory == SWIG_CAST_NEW_MEMORY) {
+ assert(own);
+ if (own)
+ *own = *own | SWIG_CAST_NEW_MEMORY;
+ break;
+ } else {
+ break;
+ if (sobj) {
+ if (own)
+ *own = *own | sobj->own;
+ if (flags & SWIG_POINTER_DISOWN) {
+ sobj->own = 0;
+ return SWIG_OK;
+ } else {
+ int res = SWIG_ERROR;
+ if (flags & SWIG_POINTER_IMPLICIT_CONV) {
+ if (data && !data->implicitconv) {
+ PyObject *klass = data->klass;
+ if (klass) {
+ PyObject *impconv;
+ data->implicitconv = 1; /* avoid recursion and call 'explicit' constructors*/
+ impconv = SWIG_Python_CallFunctor(klass, obj);
+ PyErr_Clear();
+ impconv = 0;
+ if (impconv) {
+ SwigPyObject *iobj = SWIG_Python_GetSwigThis(impconv);
+ if (iobj) {
+ void *vptr;
+ res = SWIG_Python_ConvertPtrAndOwn((PyObject*)iobj, &vptr, ty, 0, 0);
+ if (ptr) {
+ *ptr = vptr;
+ /* transfer the ownership to 'ptr' */
+ iobj->own = 0;
+ res = SWIG_AddCast(res);
+ res = SWIG_AddNewMask(res);
+ } else {
+ Py_DECREF(impconv);
+ return res;
+/* Convert a function ptr value */
+SWIGRUNTIME int
+SWIG_Python_ConvertFunctionPtr(PyObject *obj, void **ptr, swig_type_info *ty) {
+ if (!PyCFunction_Check(obj)) {
+ return SWIG_ConvertPtr(obj, ptr, ty, 0);
+ } else {
+ void *vptr = 0;
+ /* here we get the method pointer for callbacks */
+ const char *doc = (((PyCFunctionObject *)obj) -> m_ml -> ml_doc);
+ const char *desc = doc ? strstr(doc, "swig_ptr: ") : 0;
+ if (desc)
+ desc = ty ? SWIG_UnpackVoidPtr(desc + 10, &vptr, ty->name) : 0;
+ if (!desc)
+ return SWIG_ERROR;
+ if (ty) {
+ swig_cast_info *tc = SWIG_TypeCheck(desc,ty);
+ if (tc) {
+ assert(!newmemory); /* newmemory handling not yet implemented */
+ } else {
+ } else {
+ *ptr = vptr;
+ return SWIG_OK;
+/* Convert a packed value value */
+SWIGRUNTIME int
+SWIG_Python_ConvertPacked(PyObject *obj, void *ptr, size_t sz, swig_type_info *ty) {
+ swig_type_info *to = SwigPyPacked_UnpackData(obj, ptr, sz);
+ if (!to) return SWIG_ERROR;
+ if (ty) {
+ if (to != ty) {
+ /* check type cast? */
+ if (!tc) return SWIG_ERROR;
+ return SWIG_OK;
+ * Create a new pointer object
+ Create a new instance object, without calling __init__, and set the
+ 'this' attribute.
+SWIG_Python_NewShadowInstance(SwigPyClientData *data, PyObject *swig_this)
+#if (PY_VERSION_HEX >= 0x02020000)
+ PyObject *inst = 0;
+ PyObject *newraw = data->newraw;
+ if (newraw) {
+ inst = PyObject_Call(newraw, data->newargs, NULL);
+ if (inst) {
+#if !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
+ PyObject **dictptr = _PyObject_GetDictPtr(inst);
+ if (dict == NULL) {
+ dict = PyDict_New();
+ *dictptr = dict;
+ PyDict_SetItem(dict, SWIG_This(), swig_this);
+#else
+ PyObject *key = SWIG_This();
+ PyObject_SetAttr(inst, key, swig_this);
+#endif
+ } else {
+ inst = PyBaseObject_Type.tp_new((PyTypeObject*) data->newargs, Py_None, Py_None);
+ PyObject_SetAttr(inst, SWIG_This(), swig_this);
+ Py_TYPE(inst)->tp_flags &= ~Py_TPFLAGS_VALID_VERSION_TAG;
+#else
+ PyObject *dict = PyDict_New();
+ inst = PyInstance_NewRaw(data->newargs, dict);
+ Py_DECREF(dict);
+#endif
+ return inst;
+#else
+#if (PY_VERSION_HEX >= 0x02010000)
+ PyObject *inst;
+ Py_DECREF(dict);
+ return (PyObject *) inst;
+#else
+ PyInstanceObject *inst = PyObject_NEW(PyInstanceObject, &PyInstance_Type);
+ if (inst == NULL) {
+ return NULL;
+ inst->in_class = (PyClassObject *)data->newargs;
+ Py_INCREF(inst->in_class);
+ inst->in_dict = PyDict_New();
+ if (inst->in_dict == NULL) {
+ Py_DECREF(inst);
+ return NULL;
+#ifdef Py_TPFLAGS_HAVE_WEAKREFS
+ inst->in_weakreflist = NULL;
+#endif
+#ifdef Py_TPFLAGS_GC
+ PyObject_GC_Init(inst);
+#endif
+ PyDict_SetItem(inst->in_dict, SWIG_This(), swig_this);
+#endif
+#endif
+SWIGRUNTIME void
+SWIG_Python_SetSwigThis(PyObject *inst, PyObject *swig_this)
+ PyObject *dict;
+#if (PY_VERSION_HEX >= 0x02020000) && !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
+ dict = *dictptr;
+ *dictptr = dict;
+ return;
+#endif
+ dict = PyObject_GetAttrString(inst, (char*)"__dict__");
+ Py_DECREF(dict);
+SWIG_Python_InitShadowInstance(PyObject *args) {
+ PyObject *obj[2];
+ if (!SWIG_Python_UnpackTuple(args,(char*)"swiginit", 2, 2, obj)) {
+ return NULL;
+ } else {
+ SwigPyObject *sthis = SWIG_Python_GetSwigThis(obj[0]);
+ if (sthis) {
+ SwigPyObject_append((PyObject*) sthis, obj[1]);
+ } else {
+ SWIG_Python_SetSwigThis(obj[0], obj[1]);
+/* Create a new pointer object */
+SWIG_Python_NewPointerObj(void *ptr, swig_type_info *type, int flags) {
+ if (!ptr) {
+ } else {
+ int own = (flags & SWIG_POINTER_OWN) ? SWIG_POINTER_OWN : 0;
+ PyObject *robj = SwigPyObject_New(ptr, type, own);
+ SwigPyClientData *clientdata = type ? (SwigPyClientData *)(type->clientdata) : 0;
+ if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
+ PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
+ if (inst) {
+ Py_DECREF(robj);
+ robj = inst;
+ return robj;
+/* Create a new packed object */
+SWIG_Python_NewPackedObj(void *ptr, size_t sz, swig_type_info *type) {
+ return ptr ? SwigPyPacked_New((void *) ptr, sz, type) : SWIG_Py_Void();
+ * Get type list
+#ifdef SWIG_LINK_RUNTIME
+void *SWIG_ReturnGlobalTypeList(void *);
+#endif
+SWIGRUNTIME swig_module_info *
+SWIG_Python_GetModule(void) {
+ static void *type_pointer = (void *)0;
+ /* first check if module already created */
+ if (!type_pointer) {
+ type_pointer = SWIG_ReturnGlobalTypeList((void *)0);
+#else
+ type_pointer = PyCObject_Import((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
+ (char*)"type_pointer" SWIG_TYPE_TABLE_NAME);
+ PyErr_Clear();
+ type_pointer = (void *)0;
+#endif
+ return (swig_module_info *) type_pointer;
+#if PY_MAJOR_VERSION < 2
+/* PyModule_AddObject function was introduced in Python 2.0. The following function
+ is copied out of Python/modsupport.c in python version 2.3.4 */
+SWIGINTERN int
+PyModule_AddObject(PyObject *m, char *name, PyObject *o)
+ PyObject *dict;
+ if (!PyModule_Check(m)) {
+ PyErr_SetString(PyExc_TypeError,
+ "PyModule_AddObject() needs module as first arg");
+ if (!o) {
+ "PyModule_AddObject() needs non-NULL value");
+ dict = PyModule_GetDict(m);
+ /* Internal error -- modules must have a dict! */
+ PyErr_Format(PyExc_SystemError, "module '%s' has no __dict__",
+ PyModule_GetName(m));
+ if (PyDict_SetItemString(dict, name, o))
+ Py_DECREF(o);
+ return SWIG_OK;
+#endif
+SWIGRUNTIME void
+SWIG_Python_DestroyModule(void *vptr)
+ swig_module_info *swig_module = (swig_module_info *) vptr;
+ swig_type_info **types = swig_module->types;
+ size_t i;
+ for (i =0; i < swig_module->size; ++i) {
+ swig_type_info *ty = types[i];
+ if (ty->owndata) {
+ SwigPyClientData *data = (SwigPyClientData *) ty->clientdata;
+ if (data) SwigPyClientData_Del(data);
+ Py_DECREF(SWIG_This());
+SWIGRUNTIME void
+SWIG_Python_SetModule(swig_module_info *swig_module) {
+ static PyMethodDef swig_empty_runtime_method_table[] = { {NULL, NULL, 0, NULL} };/* Sentinel */
+ /* Add a dummy module object into sys.modules */
+ PyObject *module = PyImport_AddModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION);
+#else
+ PyObject *module = Py_InitModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
+ swig_empty_runtime_method_table);
+#endif
+ PyObject *pointer = PyCObject_FromVoidPtr((void *) swig_module, SWIG_Python_DestroyModule);
+ if (pointer && module) {
+ PyModule_AddObject(module, (char*)"type_pointer" SWIG_TYPE_TABLE_NAME, pointer);
+ } else {
+ Py_XDECREF(pointer);
+/* The python cached type query */
+SWIG_Python_TypeCache(void) {
+ static PyObject *SWIG_STATIC_POINTER(cache) = PyDict_New();
+ return cache;
+SWIG_Python_TypeQuery(const char *type)
+ PyObject *cache = SWIG_Python_TypeCache();
+ PyObject *key = SWIG_Python_str_FromChar(type);
+ PyObject *obj = PyDict_GetItem(cache, key);
+ swig_type_info *descriptor;
+ if (obj) {
+ descriptor = (swig_type_info *) PyCObject_AsVoidPtr(obj);
+ } else {
+ swig_module_info *swig_module = SWIG_Python_GetModule();
+ descriptor = SWIG_TypeQueryModule(swig_module, swig_module, type);
+ if (descriptor) {
+ obj = PyCObject_FromVoidPtr(descriptor, NULL);
+ PyDict_SetItem(cache, key, obj);
+ Py_DECREF(obj);
+ Py_DECREF(key);
+ return descriptor;
+ For backward compatibility only
+#define SWIG_POINTER_EXCEPTION 0
+#define SWIG_arg_fail(arg) SWIG_Python_ArgFail(arg)
+#define SWIG_MustGetPtr(p, type, argnum, flags) SWIG_Python_MustGetPtr(p, type, argnum, flags)
+SWIGRUNTIME int
+SWIG_Python_AddErrMesg(const char* mesg, int infront)
+ PyErr_Fetch(&type, &value, &traceback);
+ if (value) {
+ char *tmp;
+ Py_XINCREF(type);
+ PyErr_Clear();
+ if (infront) {
+ PyErr_Format(type, "%s %s", mesg, tmp = SWIG_Python_str_AsChar(old_str));
+ } else {
+ return 1;
+ } else {
+ return 0;
+SWIGRUNTIME int
+SWIG_Python_ArgFail(int argnum)
+ /* add information about failing argument */
+ char mesg[256];
+ PyOS_snprintf(mesg, sizeof(mesg), "argument number %d:", argnum);
+ return SWIG_Python_AddErrMesg(mesg, 1);
+ } else {
+ return 0;
+SwigPyObject_GetDesc(PyObject *self)
+ SwigPyObject *v = (SwigPyObject *)self;
+ swig_type_info *ty = v ? v->ty : 0;
+ return ty ? ty->str : (char*)"";
+SWIGRUNTIME void
+SWIG_Python_TypeError(const char *type, PyObject *obj)
+ if (type) {
+#if defined(SWIG_COBJECT_TYPES)
+ if (obj && SwigPyObject_Check(obj)) {
+ const char *otype = (const char *) SwigPyObject_GetDesc(obj);
+ if (otype) {
+ PyErr_Format(PyExc_TypeError, "a '%s' is expected, 'SwigPyObject(%s)' is received",
+ type, otype);
+ return;
+ } else
+#endif
+ const char *otype = (obj ? obj->ob_type->tp_name : 0);
+ if (otype) {
+ PyObject *str = PyObject_Str(obj);
+ const char *cstr = str ? SWIG_Python_str_AsChar(str) : 0;
+ if (cstr) {
+ PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s(%s)' is received",
+ type, otype, cstr);
+ SWIG_Python_str_DelForPy3(cstr);
+ } else {
+ PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s' is received",
+ type, otype);
+ Py_XDECREF(str);
+ return;
+ PyErr_Format(PyExc_TypeError, "a '%s' is expected", type);
+ } else {
+ PyErr_Format(PyExc_TypeError, "unexpected type is received");
+/* Convert a pointer value, signal an exception on a type mismatch */
+SWIGRUNTIME void *
+SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int argnum, int flags) {
+ void *result;
+ if (SWIG_Python_ConvertPtr(obj, &result, ty, flags) == -1) {
+ PyErr_Clear();
+#if SWIG_POINTER_EXCEPTION
+ if (flags) {
+ SWIG_Python_TypeError(SWIG_TypePrettyName(ty), obj);
+ SWIG_Python_ArgFail(argnum);
+#endif
+ return result;
+#ifdef __cplusplus
+#if 0
+{ /* cc-mode */
+#endif
+#endif
+#define SWIG_exception_fail(code, msg) do { SWIG_Error(code, msg); SWIG_fail; } while(0)
+#define SWIG_contract_assert(expr, msg) if (!(expr)) { SWIG_Error(SWIG_RuntimeError, msg); SWIG_fail; } else
+ #define SWIG_exception(code, msg) do { SWIG_Error(code, msg); SWIG_fail;; } while(0)
+/* -------- TYPES TABLE (BEGIN) -------- */
+#define SWIGTYPE_p_GeosCoordinateSequence swig_types[0]
+#define SWIGTYPE_p_GeosGeometry swig_types[1]
+#define SWIGTYPE_p_GeosGeometryCollection swig_types[2]
+#define SWIGTYPE_p_GeosIndexItem swig_types[3]
+#define SWIGTYPE_p_GeosLineString swig_types[4]
+#define SWIGTYPE_p_GeosLinearRing swig_types[5]
+#define SWIGTYPE_p_GeosMultiLineString swig_types[6]
+#define SWIGTYPE_p_GeosMultiLinearRing swig_types[7]
+#define SWIGTYPE_p_GeosMultiPoint swig_types[8]
+#define SWIGTYPE_p_GeosMultiPolygon swig_types[9]
+#define SWIGTYPE_p_GeosPoint swig_types[10]
+#define SWIGTYPE_p_GeosPolygon swig_types[11]
+#define SWIGTYPE_p_GeosPreparedGeometry swig_types[12]
+#define SWIGTYPE_p_GeosQueryCallback swig_types[13]
+#define SWIGTYPE_p_GeosSTRtree swig_types[14]
+#define SWIGTYPE_p_GeosWkbReader swig_types[15]
+#define SWIGTYPE_p_GeosWkbWriter swig_types[16]
+#define SWIGTYPE_p_GeosWktReader swig_types[17]
+#define SWIGTYPE_p_GeosWktWriter swig_types[18]
+#define SWIGTYPE_p_char swig_types[19]
+#define SWIGTYPE_p_p_GeosLinearRing swig_types[20]
+#define SWIGTYPE_p_size_t swig_types[21]
+#define SWIGTYPE_p_std__invalid_argument swig_types[22]
+#define SWIGTYPE_p_swig__SwigPyIterator swig_types[23]
+#define SWIGTYPE_p_unsigned_char swig_types[24]
+static swig_type_info *swig_types[26];
+static swig_module_info swig_module = {swig_types, 25, 0, 0, 0, 0};
+#define SWIG_TypeQuery(name) SWIG_TypeQueryModule(&swig_module, &swig_module, name)
+#define SWIG_MangledTypeQuery(name) SWIG_MangledTypeQueryModule(&swig_module, &swig_module, name)
+/* -------- TYPES TABLE (END) -------- */
+#if (PY_VERSION_HEX <= 0x02000000)
+# if !defined(SWIG_PYTHON_CLASSIC)
+# error "This python version requires swig to be run with the '-classic' option"
+# endif
+#endif
+#if (PY_VERSION_HEX <= 0x02020000)
+# error "This python version requires swig to be run with the '-nomodern' option"
+#endif
+# error "This python version requires swig to be run with the '-nomodernargs' option"
+#endif
+ @(target):= _geos.so
+# define SWIG_init PyInit__geos
+#else
+# define SWIG_init init_geos
+#endif
+#define SWIG_name "_geos"
+#define SWIGVERSION 0x010340
+#define SWIG_VERSION SWIGVERSION
+#define SWIG_as_voidptr(a) const_cast< void * >(static_cast< const void * >(a))
+#define SWIG_as_voidptrptr(a) ((void)SWIG_as_voidptr(*a),reinterpret_cast< void** >(a))
+#include <stdexcept>
+namespace swig {
+ class SwigPtr_PyObject {
+ protected:
+ PyObject *_obj;
+ public:
+ SwigPtr_PyObject() :_obj(0)
+ SwigPtr_PyObject(const SwigPtr_PyObject& item) : _obj(item._obj)
+ Py_XINCREF(_obj);
+ SwigPtr_PyObject(PyObject *obj, bool initial_ref = true) :_obj(obj)
+ if (initial_ref) {
+ Py_XINCREF(_obj);
+ SwigPtr_PyObject & operator=(const SwigPtr_PyObject& item)
+ Py_XINCREF(item._obj);
+ Py_XDECREF(_obj);
+ _obj = item._obj;
+ return *this;
+ ~SwigPtr_PyObject()
+ Py_XDECREF(_obj);
+ operator PyObject *() const
+ return _obj;
+ PyObject *operator->() const
+ return _obj;
+namespace swig {
+ struct SwigVar_PyObject : SwigPtr_PyObject {
+ SwigVar_PyObject(PyObject* obj = 0) : SwigPtr_PyObject(obj, false) { }
+ SwigVar_PyObject & operator = (PyObject* obj)
+ Py_XDECREF(_obj);
+ _obj = obj;
+ return *this;
+#include <string>
+#include <iostream>
+#if defined(__GNUC__)
+# if __GNUC__ == 2 && __GNUC_MINOR <= 96
+# define SWIG_STD_NOMODERN_STL
+# endif
+#endif
+#include <string>
+namespace swig {
+ struct stop_iteration {
+ struct SwigPyIterator {
+ private:
+ SwigPtr_PyObject _seq;
+ protected:
+ SwigPyIterator(PyObject *seq) : _seq(seq)
+ public:
+ virtual ~SwigPyIterator() {}
+ // Access iterator method, required by Python
+ virtual PyObject *value() const = 0;
+ // Forward iterator method, required by Python
+ virtual SwigPyIterator *incr(size_t n = 1) = 0;
+ // Backward iterator method, very common in C++, but not required in Python
+ virtual SwigPyIterator *decr(size_t /*n*/ = 1)
+ throw stop_iteration();
+ // Random access iterator methods, but not required in Python
+ virtual ptrdiff_t distance(const SwigPyIterator &/*x*/) const
+ throw std::invalid_argument("operation not supported");
+ virtual bool equal (const SwigPyIterator &/*x*/) const
+ // C++ common/needed methods
+ virtual SwigPyIterator *copy() const = 0;
+ PyObject *next()
+ SWIG_PYTHON_THREAD_BEGIN_BLOCK; // disable threads
+ PyObject *obj = value();
+ incr();
+ SWIG_PYTHON_THREAD_END_BLOCK; // re-enable threads
+ return obj;
+ /* Make an alias for Python 3.x */
+ PyObject *__next__()
+ return next();
+ PyObject *previous()
+ decr();
+ return obj;
+ SwigPyIterator *advance(ptrdiff_t n)
+ return (n > 0) ? incr(n) : decr(-n);
+ bool operator == (const SwigPyIterator& x) const
+ return equal(x);
+ bool operator != (const SwigPyIterator& x) const
+ return ! operator==(x);
+ SwigPyIterator& operator += (ptrdiff_t n)
+ return *advance(n);
+ SwigPyIterator& operator -= (ptrdiff_t n)
+ return *advance(-n);
+ SwigPyIterator* operator + (ptrdiff_t n) const
+ return copy()->advance(n);
+ SwigPyIterator* operator - (ptrdiff_t n) const
+ return copy()->advance(-n);
+ ptrdiff_t operator - (const SwigPyIterator& x) const
+ return x.distance(*this);
+ static swig_type_info* descriptor() {
+ static int init = 0;
+ static swig_type_info* desc = 0;
+ if (!init) {
+ desc = SWIG_TypeQuery("swig::SwigPyIterator *");
+ init = 1;
+ return desc;
+SWIGINTERN int
+SWIG_AsVal_double (PyObject *obj, double *val)
+ int res = SWIG_TypeError;
+ if (PyFloat_Check(obj)) {
+ if (val) *val = PyFloat_AsDouble(obj);
+ return SWIG_OK;
+ } else if (PyInt_Check(obj)) {
+ if (val) *val = PyInt_AsLong(obj);
+ return SWIG_OK;
+ } else if (PyLong_Check(obj)) {
+ double v = PyLong_AsDouble(obj);
+ if (!PyErr_Occurred()) {
+ if (val) *val = v;
+ return SWIG_OK;
+ } else {
+ PyErr_Clear();
+#ifdef SWIG_PYTHON_CAST_MODE
+ int dispatch = 0;
+ double d = PyFloat_AsDouble(obj);
+ if (val) *val = d;
+ return SWIG_AddCast(SWIG_OK);
+ } else {
+ PyErr_Clear();
+ if (!dispatch) {
+ long v = PyLong_AsLong(obj);
+ return SWIG_AddCast(SWIG_AddCast(SWIG_OK));
+ } else {
+ PyErr_Clear();
+#endif
+ return res;
+#include <float.h>
+#include <math.h>
+SWIG_CanCastAsInteger(double *d, double min, double max) {
+ double x = *d;
+ if ((min <= x && x <= max)) {
+ double fx = floor(x);
+ double cx = ceil(x);
+ double rd = ((x - fx) < 0.5) ? fx : cx; /* simple rint */
+ if ((errno == EDOM) || (errno == ERANGE)) {
+ errno = 0;
+ } else {
+ double summ, reps, diff;
+ if (rd < x) {
+ diff = x - rd;
+ } else if (rd > x) {
+ diff = rd - x;
+ } else {
+ return 1;
+ summ = rd + x;
+ reps = diff/summ;
+ if (reps < 8*DBL_EPSILON) {
+ *d = rd;
+ return 1;
+ return 0;
+SWIGINTERN int
+SWIG_AsVal_unsigned_SS_long (PyObject *obj, unsigned long *val)
+ if (PyInt_Check(obj)) {
+ long v = PyInt_AsLong(obj);
+ if (v >= 0) {
+ return SWIG_OK;
+ } else {
+ return SWIG_OverflowError;
+ unsigned long v = PyLong_AsUnsignedLong(obj);
+ return SWIG_OK;
+ } else {
+ PyErr_Clear();
+ int dispatch = 0;
+ } else {
+ PyErr_Clear();
+ if (!dispatch) {
+ double d;
+ int res = SWIG_AddCast(SWIG_AsVal_double (obj,&d));
+ if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, 0, ULONG_MAX)) {
+ if (val) *val = (unsigned long)(d);
+ return res;
+#endif
+ return SWIG_TypeError;
+SWIGINTERNINLINE int
+SWIG_AsVal_size_t (PyObject * obj, size_t *val)
+ unsigned long v;
+ int res = SWIG_AsVal_unsigned_SS_long (obj, val ? &v : 0);
+ if (SWIG_IsOK(res) && val) *val = static_cast< size_t >(v);
+ return res;
+ #define SWIG_From_long PyInt_FromLong
+SWIGINTERNINLINE PyObject *
+SWIG_From_ptrdiff_t (ptrdiff_t value)
+ return SWIG_From_long (static_cast< long >(value));
+SWIGINTERNINLINE PyObject*
+ SWIG_From_bool (bool value)
+ return PyBool_FromLong(value ? 1 : 0);
+SWIGINTERN int
+SWIG_AsVal_long (PyObject *obj, long* val)
+ return SWIG_OK;
+ return SWIG_OK;
+ } else {
+ PyErr_Clear();
+ int dispatch = 0;
+ } else {
+ PyErr_Clear();
+ if (!dispatch) {
+ double d;
+ if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, LONG_MIN, LONG_MAX)) {
+ if (val) *val = (long)(d);
+ return res;
+#endif
+SWIG_AsVal_ptrdiff_t (PyObject * obj, ptrdiff_t *val)
+ long v;
+ int res = SWIG_AsVal_long (obj, val ? &v : 0);
+ if (SWIG_IsOK(res) && val) *val = static_cast< ptrdiff_t >(v);
+ return res;
+#include <algorithm>
+#include <vector>
+#include "geos_c.h"
+/* Needed for va_start, etc. */
+#include <stdarg.h>
+SWIG_From_int (int value)
+ return SWIG_From_long (value);
+SWIGINTERN swig_type_info*
+SWIG_pchar_descriptor(void)
+ static swig_type_info* info = 0;
+ if (!init) {
+ info = SWIG_TypeQuery("_p_char");
+ init = 1;
+ return info;
+SWIG_FromCharPtrAndSize(const char* carray, size_t size)
+ if (carray) {
+ if (size > INT_MAX) {
+ swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
+ return pchar_descriptor ?
+ SWIG_NewPointerObj(const_cast< char * >(carray), pchar_descriptor, 0) : SWIG_Py_Void();
+ } else {
+ return PyUnicode_FromStringAndSize(carray, static_cast< int >(size));
+#else
+ return PyString_FromStringAndSize(carray, static_cast< int >(size));
+#endif
+ } else {
+SWIG_FromCharPtr(const char *cptr)
+ return SWIG_FromCharPtrAndSize(cptr, (cptr ? strlen(cptr) : 0));
+ static const int DEFAULT_QUADRANT_SEGMENTS=8;
+/* This is not thread safe ! */
+static const int MESSAGE_SIZE = 1000;
+static char message[MESSAGE_SIZE];
+void noticeHandler(const char *fmt, ...)
+ va_list args;
+ va_start(args, fmt);
+ vsnprintf(message, sizeof(message) - 1, fmt, args);
+ va_end(args);
+void errorHandler(const char *fmt, ...)
+ va_list args;
+ va_end(args);
+typedef void GeosCoordinateSequence;
+void checkCoordSeqBounds(const GEOSCoordSeq coordSeq, const size_t index)
+ unsigned int size = 0;
+ GEOSCoordSeq_getSize(coordSeq, &size);
+ if (index < 0 || index >= size)
+ throw std::runtime_error("Index out of bounds");
+SWIGINTERN GeosCoordinateSequence *new_GeosCoordinateSequence(size_t size,size_t dims){
+ return (GeosCoordinateSequence*) GEOSCoordSeq_create(size, dims);
+SWIGINTERN void delete_GeosCoordinateSequence(GeosCoordinateSequence *self){
+ GEOSCoordSeq coords = (GEOSCoordSeq) self;
+ return GEOSCoordSeq_destroy(coords);
+SWIGINTERN GeosCoordinateSequence *GeosCoordinateSequence_clone(GeosCoordinateSequence *self){
+ return (GeosCoordinateSequence*) GEOSCoordSeq_clone(coords);
+SWIGINTERN int GeosCoordinateSequence_setX(GeosCoordinateSequence *self,size_t idx,double val){
+ checkCoordSeqBounds(coords, idx);
+ return GEOSCoordSeq_setX(coords, idx, val);
+SWIGINTERN int GeosCoordinateSequence_setY(GeosCoordinateSequence *self,size_t idx,double val){
+ return GEOSCoordSeq_setY(coords, idx, val);
+SWIGINTERN int GeosCoordinateSequence_setZ(GeosCoordinateSequence *self,size_t idx,double val){
+ return GEOSCoordSeq_setZ(coords, idx, val);
+SWIGINTERN int GeosCoordinateSequence_setOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim,double val){
+ return GEOSCoordSeq_setOrdinate(coords, idx, dim, val);
+SWIGINTERN double GeosCoordinateSequence_getX(GeosCoordinateSequence *self,size_t idx){
+ double result;
+ GEOSCoordSeq_getX(coords, idx, &result);
+ return result;
+ #define SWIG_From_double PyFloat_FromDouble
+SWIGINTERN double GeosCoordinateSequence_getY(GeosCoordinateSequence *self,size_t idx){
+ double result;
+ GEOSCoordSeq_getY(coords, idx, &result);
+ return result;
+SWIGINTERN double GeosCoordinateSequence_getZ(GeosCoordinateSequence *self,size_t idx){
+ double result;
+ GEOSCoordSeq_getZ(coords, idx, &result);
+ return result;
+SWIGINTERN double GeosCoordinateSequence_getOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim){
+ double result;
+ GEOSCoordSeq_getOrdinate(coords, idx, dim, &result);
+ return result;
+SWIGINTERN unsigned int GeosCoordinateSequence_getSize(GeosCoordinateSequence *self){
+ unsigned int result;
+ GEOSCoordSeq_getSize(coords, &result);
+ return result;
+SWIG_From_unsigned_SS_long (unsigned long value)
+ return (value > LONG_MAX) ?
+ PyLong_FromUnsignedLong(value) : PyInt_FromLong(static_cast< long >(value));
+SWIG_From_unsigned_SS_int (unsigned int value)
+ return SWIG_From_unsigned_SS_long (value);
+SWIGINTERN unsigned int GeosCoordinateSequence_getDimensions(GeosCoordinateSequence *self){
+ GEOSCoordSeq_getDimensions(coords, &result);
+ return result;
+typedef void GeosGeometry;
+typedef void GeosPoint;
+typedef void GeosLineString;
+typedef void GeosLinearRing;
+typedef void GeosPolygon;
+typedef void GeosGeometryCollection;
+typedef void GeosMultiPoint;
+typedef void GeosMultiLineString;
+typedef void GeosMultiLinearRing;
+typedef void GeosMultiPolygon;
+typedef void GeosWktReader;
+typedef void GeosWktWriter;
+typedef void GeosWkbReader;
+typedef void GeosWkbWriter;
+bool checkBoolResult(char result)
+ int intResult = (int) result;
+ if (intResult == 1)
+ return true;
+ else if (intResult == 0)
+ return false;
+ else
+ throw std::runtime_error(message);
+SWIGINTERN void delete_GeosGeometry(GeosGeometry *self){
+ GEOSGeom geom = (GEOSGeom) self;
+ GEOSGeom_destroy(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_clone(GeosGeometry *self){
+ return GEOSGeom_clone(geom);
+SWIGINTERN char *GeosGeometry_geomType(GeosGeometry *self){
+ return GEOSGeomType(geom);
+SWIGINTERN int GeosGeometry_typeId(GeosGeometry *self){
+ return GEOSGeomTypeId(geom);
+SWIGINTERN void GeosGeometry_normalize(GeosGeometry *self){
+ int result = GEOSNormalize(geom);
+ if (result == -1)
+SWIGINTERN int GeosGeometry_getSRID(GeosGeometry *self){
+ return GEOSGetSRID(geom);
+#include <limits.h>
+#if !defined(SWIG_NO_LLONG_MAX)
+# if !defined(LLONG_MAX) && defined(__GNUC__) && defined (__LONG_LONG_MAX__)
+# define LLONG_MAX __LONG_LONG_MAX__
+# define LLONG_MIN (-LLONG_MAX - 1LL)
+# define ULLONG_MAX (LLONG_MAX * 2ULL + 1ULL)
+# endif
+#endif
+SWIGINTERN int
+SWIG_AsVal_int (PyObject * obj, int *val)
+ long v;
+ int res = SWIG_AsVal_long (obj, &v);
+ if (SWIG_IsOK(res)) {
+ if ((v < INT_MIN || v > INT_MAX)) {
+ } else {
+ if (val) *val = static_cast< int >(v);
+ return res;
+SWIGINTERN void GeosGeometry_setSRID(GeosGeometry *self,int SRID){
+ return GEOSSetSRID(geom, SRID);
+SWIGINTERN size_t GeosGeometry_getDimensions(GeosGeometry *self){
+ return GEOSGeom_getDimensions(geom);
+SWIG_From_size_t (size_t value)
+ return SWIG_From_unsigned_SS_long (static_cast< unsigned long >(value));
+SWIGINTERN size_t GeosGeometry_getNumGeometries(GeosGeometry *self){
+ size_t result = GEOSGetNumGeometries(geom);
+ if ((int)result == -1)
+ return result;
+SWIGINTERN GeosGeometry *GeosGeometry_intersection(GeosGeometry *self,GeosGeometry *other){
+ GEOSGeom otherGeom = (GEOSGeom) other;
+ return (GeosGeometry*) GEOSIntersection(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_buffer(GeosGeometry *self,double width,int quadsegs){
+ return (GeosGeometry*) GEOSBuffer(geom, width, quadsegs);
+SWIGINTERN GeosGeometry *GeosGeometry_convexHull(GeosGeometry *self){
+ return (GeosGeometry*) GEOSConvexHull(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_difference(GeosGeometry *self,GeosGeometry *other){
+ return (GeosGeometry*) GEOSDifference(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_symDifference(GeosGeometry *self,GeosGeometry *other){
+ return (GeosGeometry*) GEOSSymDifference(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_boundary(GeosGeometry *self){
+ return (GeosGeometry*) GEOSBoundary(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_geomUnion(GeosGeometry *self,GeosGeometry *other){
+ return (GeosGeometry*) GEOSUnion(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_pointOnSurface(GeosGeometry *self){
+ return (GeosGeometry*) GEOSPointOnSurface(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_getCentroid(GeosGeometry *self){
+ return (GeosGeometry*) GEOSGetCentroid(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_getEnvelope(GeosGeometry *self){
+ return (GeosGeometry*) GEOSEnvelope(geom);
+SWIGINTERN char *GeosGeometry_relate(GeosGeometry *self,GeosGeometry *other){
+ return GEOSRelate(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_lineMerge(GeosGeometry *self){
+ return GEOSLineMerge(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_simplify(GeosGeometry *self,double tolerance){
+ return (GeosGeometry*) GEOSSimplify(geom, tolerance);
+SWIGINTERN GeosGeometry *GeosGeometry_topologyPreserveSimplify(GeosGeometry *self,double tolerance){
+ return (GeosGeometry*) GEOSTopologyPreserveSimplify(geom, tolerance);
+SWIGINTERN int
+SWIG_AsCharPtrAndSize(PyObject *obj, char** cptr, size_t* psize, int *alloc)
+ if (PyUnicode_Check(obj))
+#else
+ if (PyString_Check(obj))
+#endif
+ char *cstr; Py_ssize_t len;
+ if (!alloc && cptr) {
+ /* We can't allow converting without allocation, since the internal
+ representation of string in Python 3 is UCS-2/UCS-4 but we require
+ a UTF-8 representation.
+ TODO(bhy) More detailed explanation */
+ return SWIG_RuntimeError;
+ obj = PyUnicode_AsUTF8String(obj);
+ PyBytes_AsStringAndSize(obj, &cstr, &len);
+ if(alloc) *alloc = SWIG_NEWOBJ;
+#else
+ PyString_AsStringAndSize(obj, &cstr, &len);
+#endif
+ if (cptr) {
+ if (alloc) {
+ In python the user should not be able to modify the inner
+ string representation. To warranty that, if you define
+ SWIG_PYTHON_SAFE_CSTRINGS, a new/copy of the python string
+ buffer is always returned.
+ The default behavior is just to return the pointer value,
+ so, be careful.
+#if defined(SWIG_PYTHON_SAFE_CSTRINGS)
+ if (*alloc != SWIG_OLDOBJ)
+#else
+ if (*alloc == SWIG_NEWOBJ)
+#endif
+ *cptr = reinterpret_cast< char* >(memcpy((new char[len + 1]), cstr, sizeof(char)*(len + 1)));
+ *alloc = SWIG_NEWOBJ;
+ else {
+ *cptr = cstr;
+ *alloc = SWIG_OLDOBJ;
+ } else {
+ #if PY_VERSION_HEX>=0x03000000
+ assert(0); /* Should never reach here in Python 3 */
+ #endif
+ *cptr = SWIG_Python_str_AsChar(obj);
+ if (psize) *psize = len + 1;
+ Py_XDECREF(obj);
+#endif
+ return SWIG_OK;
+ } else {
+ if (pchar_descriptor) {
+ void* vptr = 0;
+ if (SWIG_ConvertPtr(obj, &vptr, pchar_descriptor, 0) == SWIG_OK) {
+ if (cptr) *cptr = (char *) vptr;
+ if (psize) *psize = vptr ? (strlen((char *)vptr) + 1) : 0;
+ if (alloc) *alloc = SWIG_OLDOBJ;
+ return SWIG_OK;
+SWIGINTERN bool GeosGeometry_relatePattern(GeosGeometry *self,GeosGeometry const *other,char const *pat){
+ return checkBoolResult(GEOSRelatePattern(geom, otherGeom, pat));
+SWIGINTERN bool GeosGeometry_disjoint(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSDisjoint(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_touches(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSTouches(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_intersects(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSIntersects(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_crosses(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSCrosses(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_within(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSWithin(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_contains(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSContains(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_overlaps(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSOverlaps(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_equals(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSEquals(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_equalsExact(GeosGeometry *self,GeosGeometry const *other,double tolerance){
+ return checkBoolResult(GEOSEqualsExact(geom, otherGeom, tolerance));
+SWIGINTERN bool GeosGeometry_isEmpty(GeosGeometry *self){
+ return checkBoolResult(GEOSisEmpty(geom));
+SWIGINTERN bool GeosGeometry_isValid(GeosGeometry *self){
+ return checkBoolResult(GEOSisValid(geom));
+SWIGINTERN bool GeosGeometry_isSimple(GeosGeometry *self){
+ return checkBoolResult(GEOSisSimple(geom));
+SWIGINTERN bool GeosGeometry_isRing(GeosGeometry *self){
+ return checkBoolResult(GEOSisRing(geom));
+SWIGINTERN bool GeosGeometry_hasZ(GeosGeometry *self){
+ return checkBoolResult(GEOSHasZ(geom));
+SWIGINTERN double GeosGeometry_area(GeosGeometry *self){
+ double result;
+ int code = GEOSArea(geom, &result);
+ if (code == 0)
+ return result;
+SWIGINTERN double GeosGeometry_length(GeosGeometry *self){
+ double result;
+ int code = GEOSLength(geom, &result);
+ if (code == 0)
+ return result;
+SWIGINTERN double GeosGeometry_distance(GeosGeometry *self,GeosGeometry const *other){
+ double result;
+ int code = GEOSDistance(geom, otherGeom, &result);
+ if (code == 0)
+ return result;
+SWIGINTERN void delete_GeosPoint(GeosPoint *self){
+SWIGINTERN GeosCoordinateSequence const *GeosPoint_getCoordSeq(GeosPoint *self){
+ const GEOSCoordSeq result = (const GEOSCoordSeq) GEOSGeom_getCoordSeq(geom);
+ if (result == NULL)
+ return (const GeosCoordinateSequence*) result;
+SWIGINTERN void delete_GeosLineString(GeosLineString *self){
+SWIGINTERN GeosCoordinateSequence const *GeosLineString_getCoordSeq(GeosLineString *self){
+SWIGINTERN void delete_GeosLinearRing(GeosLinearRing *self){
+SWIGINTERN GeosCoordinateSequence const *GeosLinearRing_getCoordSeq(GeosLinearRing *self){
+SWIGINTERN void delete_GeosPolygon(GeosPolygon *self){
+SWIGINTERN GeosGeometry const *GeosPolygon_getExteriorRing(GeosPolygon *self){
+ const GEOSGeom result = (const GEOSGeom) GEOSGetExteriorRing(geom);
+ return (const GeosGeometry*) result;
+SWIGINTERN size_t GeosPolygon_getNumInteriorRings(GeosPolygon *self){
+ size_t result = GEOSGetNumInteriorRings(geom);
+ return result;
+SWIGINTERN GeosGeometry const *GeosPolygon_getInteriorRingN(GeosPolygon *self,size_t n){
+ size_t size = GEOSGetNumInteriorRings(geom);
+ if (n < 0 || n >= size)
+ const GEOSGeom result = (const GEOSGeom) GEOSGetInteriorRingN(geom, n);
+SWIGINTERN void delete_GeosGeometryCollection(GeosGeometryCollection *self){
+SWIGINTERN GeosGeometry const *GeosGeometryCollection_getGeometryN(GeosGeometryCollection *self,size_t n){
+ const GEOSGeom result = (const GEOSGeom) GEOSGetGeometryN(geom, n);
+SWIGINTERN void delete_GeosMultiPoint(GeosMultiPoint *self){
+SWIGINTERN void delete_GeosMultiLineString(GeosMultiLineString *self){
+SWIGINTERN void delete_GeosMultiLinearRing(GeosMultiLinearRing *self){
+SWIGINTERN void delete_GeosMultiPolygon(GeosMultiPolygon *self){
+GeosGeometry *createPoint(GeosCoordinateSequence *s)
+ GEOSCoordSeq coords = (GEOSCoordSeq) s;
+ GEOSGeom geom = GEOSGeom_createPoint(coords);
+ if(geom == NULL)
+ return (GeosGeometry*) geom;
+GeosGeometry *createLineString(GeosCoordinateSequence *s)
+ GEOSGeom geom = GEOSGeom_createLineString(coords);
+ if(geom == NULL)
+GeosGeometry *createLinearRing(GeosCoordinateSequence *s)
+ GEOSGeom geom = GEOSGeom_createLinearRing(coords);
+ if(geom == NULL)
+GeosGeometry *createPolygon(GeosLinearRing *shell, GeosLinearRing **holes, size_t nholes)
+ GEOSGeom shellGeom = (GEOSGeom) shell;
+ GEOSGeom* holeGeoms = (GEOSGeom*) holes;
+ GEOSGeom geom = GEOSGeom_createPolygon(shellGeom, holeGeoms, nholes);
+ if(geom == NULL)
+typedef void GeosPreparedGeometry;
+SWIGINTERN GeosPreparedGeometry *new_GeosPreparedGeometry(GeosGeometry const *source){
+ const GEOSPreparedGeometry *prep = GEOSPrepare((const GEOSGeometry *)source);
+ if(prep == NULL)
+ return (GeosPreparedGeometry *) prep;
+SWIGINTERN void delete_GeosPreparedGeometry(GeosPreparedGeometry *self){
+ GEOSPreparedGeometry *prep = (GEOSPreparedGeometry *) self;
+ return GEOSPreparedGeom_destroy(prep);
+SWIGINTERN bool GeosPreparedGeometry_contains(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedContains(prep, otherGeom));
+SWIGINTERN bool GeosPreparedGeometry_containsProperly(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedContainsProperly(prep, otherGeom));
+SWIGINTERN bool GeosPreparedGeometry_covers(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedCovers(prep, otherGeom));
+SWIGINTERN bool GeosPreparedGeometry_intersects(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedIntersects(prep, otherGeom));
+typedef void GeosSTRtree;
+/* GeosIndexItem typedef'd here so it can be %typemap(typecheck)'d
+ as a native object by each language specially */
+typedef void *GeosIndexItem;
+typedef GEOSQueryCallback GeosQueryCallback;
+SWIGINTERN GeosSTRtree *new_GeosSTRtree(int nodeCapacity){
+ GEOSSTRtree *tree = GEOSSTRtree_create(nodeCapacity);
+ if(tree == NULL)
+ return (GeosSTRtree *) tree;
+SWIGINTERN void delete_GeosSTRtree(GeosSTRtree *self){
+ GEOSSTRtree *tree = (GEOSSTRtree *) self;
+ return GEOSSTRtree_destroy(tree);
+SWIGINTERN void GeosSTRtree_insert(GeosSTRtree *self,GeosGeometry const *g,GeosIndexItem item){
+ const GEOSGeometry *geom = (const GEOSGeometry *) g;
+ GEOSSTRtree_insert(tree, geom, item);
+SWIGINTERN void GeosSTRtree_remove(GeosSTRtree *self,GeosGeometry const *g,GeosIndexItem item){
+ GEOSSTRtree_remove(tree, geom, item);
+SWIGINTERN void GeosSTRtree_query(GeosSTRtree *self,GeosGeometry const *g,GeosQueryCallback callback,GeosIndexItem accumulator){
+ GEOSSTRtree_query(tree, geom, callback, accumulator);
+SWIGINTERN void GeosSTRtree_iterate(GeosSTRtree *self,GeosQueryCallback callback,GeosIndexItem accumulator){
+ GEOSSTRtree_iterate(tree, callback, accumulator);
+SWIGINTERN GeosWktReader *new_GeosWktReader(){
+ return GEOSWKTReader_create();
+SWIGINTERN void delete_GeosWktReader(GeosWktReader *self){
+ GEOSWKTReader *reader = (GEOSWKTReader*) self;
+ GEOSWKTReader_destroy(reader);
+SWIGINTERN GeosGeometry *GeosWktReader_read(GeosWktReader *self,char const *wkt){
+ if(wkt == NULL)
+ throw std::runtime_error("Trying to create geometry from a NULL string");
+ GEOSGeometry *geom = GEOSWKTReader_read(reader, wkt);
+ if(geom == NULL)
+SWIGINTERN GeosWktWriter *new_GeosWktWriter(){
+ return GEOSWKTWriter_create();
+SWIGINTERN void delete_GeosWktWriter(GeosWktWriter *self){
+ GEOSWKTWriter *writer = (GEOSWKTWriter*) self;
+ GEOSWKTWriter_destroy(writer);
+SWIGINTERN char *GeosWktWriter_write(GeosWktWriter *self,GeosGeometry const *g){
+ GEOSGeom geom = (GEOSGeom) g;
+ return GEOSWKTWriter_write(writer, geom);
+SWIGINTERN GeosWkbReader *new_GeosWkbReader(){
+ return GEOSWKBReader_create();
+SWIGINTERN void delete_GeosWkbReader(GeosWkbReader *self){
+ GEOSWKBReader *reader = (GEOSWKBReader*) self;
+ GEOSWKBReader_destroy(reader);
+SWIGINTERN GeosGeometry *GeosWkbReader_read(GeosWkbReader *self,unsigned char const *wkb,size_t size){
+ if(wkb == NULL)
+ GEOSGeometry *geom = GEOSWKBReader_read(reader, wkb, size);
+ if(geom == NULL)
+SWIGINTERN GeosGeometry *GeosWkbReader_readHEX(GeosWkbReader *self,unsigned char const *wkb,size_t size){
+ if(wkb == NULL)
+ GEOSGeometry *geom = GEOSWKBReader_readHEX(reader, wkb, size);
+ if(geom == NULL)
+SWIGINTERN GeosWkbWriter *new_GeosWkbWriter(){
+ return GEOSWKBWriter_create();
+SWIGINTERN void delete_GeosWkbWriter(GeosWkbWriter *self){
+ GEOSWKBWriter *writer = (GEOSWKBWriter*) self;
+ GEOSWKBWriter_destroy(writer);
+SWIGINTERN int GeosWkbWriter_getOutputDimension(GeosWkbWriter *self){
+ return GEOSWKBWriter_getOutputDimension(writer);
+SWIGINTERN void GeosWkbWriter_setOutputDimension(GeosWkbWriter *self,int newDimension){
+ GEOSWKBWriter_setOutputDimension(writer, newDimension);
+SWIGINTERN int GeosWkbWriter_getByteOrder(GeosWkbWriter *self){
+ return GEOSWKBWriter_getByteOrder(writer);
+SWIGINTERN void GeosWkbWriter_setByteOrder(GeosWkbWriter *self,int newByteOrder){
+ return GEOSWKBWriter_setByteOrder(writer, newByteOrder);
+SWIGINTERN bool GeosWkbWriter_getIncludeSRID(GeosWkbWriter *self){
+ return GEOSWKBWriter_getIncludeSRID(writer);
+SWIGINTERN int
+SWIG_AsVal_bool (PyObject *obj, bool *val)
+ int r = PyObject_IsTrue(obj);
+ if (r == -1)
+ if (val) *val = r ? true : false;
+ return SWIG_OK;
+SWIGINTERN void GeosWkbWriter_setIncludeSRID(GeosWkbWriter *self,bool newIncludeSRID){
+ return GEOSWKBWriter_setIncludeSRID(writer, newIncludeSRID);
+SWIGINTERN unsigned char *GeosWkbWriter_write(GeosWkbWriter *self,GeosGeometry const *g,size_t *size){
+ return GEOSWKBWriter_write(writer, geom, size);
+SWIGINTERN unsigned char *GeosWkbWriter_writeHEX(GeosWkbWriter *self,GeosGeometry const *g,size_t *size){
+ return GEOSWKBWriter_writeHEX(writer, geom, size);
+#ifdef __cplusplus
+extern "C" {
+#endif
+SWIGINTERN PyObject *_wrap_delete_SwigPyIterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *resultobj = 0;
+ swig::SwigPyIterator *arg1 = (swig::SwigPyIterator *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ PyObject * obj0 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_SwigPyIterator",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__SwigPyIterator, SWIG_POINTER_DISOWN | 0 );
+ if (!SWIG_IsOK(res1)) {
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_SwigPyIterator" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ arg1 = reinterpret_cast< swig::SwigPyIterator * >(argp1);
+ delete arg1;
+ resultobj = SWIG_Py_Void();
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_value(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ PyObject *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_value",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__SwigPyIterator, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_value" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ try {
+ result = (PyObject *)((swig::SwigPyIterator const *)arg1)->value();
+ catch(swig::stop_iteration &_e) {
+ (void)_e;
+ SWIG_SetErrorObj(PyExc_StopIteration, SWIG_Py_Void());
+ SWIG_fail;
+ resultobj = result;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_incr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ PyObject * obj1 = 0 ;
+ swig::SwigPyIterator *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_incr",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_incr" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ ecode2 = SWIG_AsVal_size_t(obj1, &val2);
+ if (!SWIG_IsOK(ecode2)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator_incr" "', argument " "2"" of type '" "size_t""'");
+ arg2 = static_cast< size_t >(val2);
+ try {
+ result = (swig::SwigPyIterator *)(arg1)->incr(arg2);
+ (void)_e;
+ SWIG_fail;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__SwigPyIterator, 0 | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_incr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_incr",1,1,&obj0)) SWIG_fail;
+ try {
+ result = (swig::SwigPyIterator *)(arg1)->incr();
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_incr(PyObject *self, PyObject *args) {
+ int argc;
+ PyObject *argv[3];
+ int ii;
+ if (!PyTuple_Check(args)) SWIG_fail;
+ argc = (int)PyObject_Length(args);
+ for (ii = 0; (ii < argc) && (ii < 2); ii++) {
+ argv[ii] = PyTuple_GET_ITEM(args,ii);
+ if (argc == 1) {
+ int _v;
+ void *vptr = 0;
+ int res = SWIG_ConvertPtr(argv[0], &vptr, SWIGTYPE_p_swig__SwigPyIterator, 0);
+ _v = SWIG_CheckState(res);
+ if (_v) {
+ return _wrap_SwigPyIterator_incr__SWIG_1(self, args);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ int res = SWIG_AsVal_size_t(argv[1], NULL);
+ if (_v) {
+ return _wrap_SwigPyIterator_incr__SWIG_0(self, args);
+fail:
+ SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'SwigPyIterator_incr'.\n"
+ " Possible C/C++ prototypes are:\n"
+ " incr(swig::SwigPyIterator *,size_t)\n"
+ " incr(swig::SwigPyIterator *)\n");
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_decr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_decr",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_decr" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator_decr" "', argument " "2"" of type '" "size_t""'");
+ try {
+ result = (swig::SwigPyIterator *)(arg1)->decr(arg2);
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_decr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_decr",1,1,&obj0)) SWIG_fail;
+ try {
+ result = (swig::SwigPyIterator *)(arg1)->decr();
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_decr(PyObject *self, PyObject *args) {
+ int argc;
+ int ii;
+ if (argc == 1) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ return _wrap_SwigPyIterator_decr__SWIG_1(self, args);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ if (_v) {
+ return _wrap_SwigPyIterator_decr__SWIG_0(self, args);
+fail:
+ SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'SwigPyIterator_decr'.\n"
+ " decr(swig::SwigPyIterator *,size_t)\n"
+ " decr(swig::SwigPyIterator *)\n");
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_distance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ swig::SwigPyIterator *arg2 = 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ ptrdiff_t result;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_distance",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_distance" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_swig__SwigPyIterator, 0 | 0);
+ if (!SWIG_IsOK(res2)) {
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "SwigPyIterator_distance" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "SwigPyIterator_distance" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ arg2 = reinterpret_cast< swig::SwigPyIterator * >(argp2);
+ try {
+ result = ((swig::SwigPyIterator const *)arg1)->distance((swig::SwigPyIterator const &)*arg2);
+ catch(std::invalid_argument &_e) {
+ SWIG_Python_Raise(SWIG_NewPointerObj((new std::invalid_argument(static_cast< const std::invalid_argument& >(_e))),SWIGTYPE_p_std__invalid_argument,SWIG_POINTER_OWN), "std::invalid_argument", SWIGTYPE_p_std__invalid_argument); SWIG_fail;
+ resultobj = SWIG_From_ptrdiff_t(static_cast< ptrdiff_t >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_equal(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_equal",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_equal" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "SwigPyIterator_equal" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "SwigPyIterator_equal" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ try {
+ result = (bool)((swig::SwigPyIterator const *)arg1)->equal((swig::SwigPyIterator const &)*arg2);
+ resultobj = SWIG_From_bool(static_cast< bool >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_copy(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_copy",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_copy" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ result = (swig::SwigPyIterator *)((swig::SwigPyIterator const *)arg1)->copy();
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__SwigPyIterator, SWIG_POINTER_OWN | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_next(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_next",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_next" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ try {
+ result = (PyObject *)(arg1)->next();
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___next__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___next__",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___next__" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ try {
+ result = (PyObject *)(arg1)->__next__();
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_previous(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_previous",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_previous" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ try {
+ result = (PyObject *)(arg1)->previous();
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator_advance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator_advance",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator_advance" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ ecode2 = SWIG_AsVal_ptrdiff_t(obj1, &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator_advance" "', argument " "2"" of type '" "ptrdiff_t""'");
+ arg2 = static_cast< ptrdiff_t >(val2);
+ try {
+ result = (swig::SwigPyIterator *)(arg1)->advance(arg2);
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___eq__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___eq__",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___eq__" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "SwigPyIterator___eq__" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "SwigPyIterator___eq__" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ result = (bool)((swig::SwigPyIterator const *)arg1)->operator ==((swig::SwigPyIterator const &)*arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___ne__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___ne__",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___ne__" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "SwigPyIterator___ne__" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "SwigPyIterator___ne__" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ result = (bool)((swig::SwigPyIterator const *)arg1)->operator !=((swig::SwigPyIterator const &)*arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___iadd__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___iadd__",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___iadd__" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator___iadd__" "', argument " "2"" of type '" "ptrdiff_t""'");
+ try {
+ result = (swig::SwigPyIterator *) &(arg1)->operator +=(arg2);
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___isub__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___isub__",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___isub__" "', argument " "1"" of type '" "swig::SwigPyIterator *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator___isub__" "', argument " "2"" of type '" "ptrdiff_t""'");
+ try {
+ result = (swig::SwigPyIterator *) &(arg1)->operator -=(arg2);
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___add__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___add__",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___add__" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator___add__" "', argument " "2"" of type '" "ptrdiff_t""'");
+ try {
+ result = (swig::SwigPyIterator *)((swig::SwigPyIterator const *)arg1)->operator +(arg2);
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___sub____SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"SwigPyIterator___sub__",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "SwigPyIterator___sub__" "', argument " "1"" of type '" "swig::SwigPyIterator const *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "SwigPyIterator___sub__" "', argument " "2"" of type '" "ptrdiff_t""'");
+ try {
+ result = (swig::SwigPyIterator *)((swig::SwigPyIterator const *)arg1)->operator -(arg2);
+ (void)_e;
+ SWIG_fail;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___sub____SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ ptrdiff_t result;
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "SwigPyIterator___sub__" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "SwigPyIterator___sub__" "', argument " "2"" of type '" "swig::SwigPyIterator const &""'");
+ result = ((swig::SwigPyIterator const *)arg1)->operator -((swig::SwigPyIterator const &)*arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_SwigPyIterator___sub__(PyObject *self, PyObject *args) {
+ int argc;
+ int ii;
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ int res = SWIG_ConvertPtr(argv[1], 0, SWIGTYPE_p_swig__SwigPyIterator, 0);
+ if (_v) {
+ return _wrap_SwigPyIterator___sub____SWIG_1(self, args);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ int res = SWIG_AsVal_ptrdiff_t(argv[1], NULL);
+ if (_v) {
+ return _wrap_SwigPyIterator___sub____SWIG_0(self, args);
+fail:
+ Py_INCREF(Py_NotImplemented);
+ return Py_NotImplemented;
+SWIGINTERN PyObject *SwigPyIterator_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ if (!PyArg_UnpackTuple(args,(char*)"swigregister", 1, 1,&obj)) return NULL;
+ SWIG_TypeNewClientData(SWIGTYPE_p_swig__SwigPyIterator, SWIG_NewClientData(obj));
+ return SWIG_Py_Void();
+SWIGINTERN PyObject *_wrap_version(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ char *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"version",0,0)) SWIG_fail;
+ result = (char *)GEOSversion();
+ resultobj = SWIG_FromCharPtr((const char *)result);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_new_CoordinateSequence(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg1 ;
+ size_t arg2 ;
+ size_t val1 ;
+ int ecode1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ GeosCoordinateSequence *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"new_CoordinateSequence",2,2,&obj0,&obj1)) SWIG_fail;
+ ecode1 = SWIG_AsVal_size_t(obj0, &val1);
+ if (!SWIG_IsOK(ecode1)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_CoordinateSequence" "', argument " "1"" of type '" "size_t""'");
+ arg1 = static_cast< size_t >(val1);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "new_CoordinateSequence" "', argument " "2"" of type '" "size_t""'");
+ try
+ result = (GeosCoordinateSequence *)new_GeosCoordinateSequence(arg1,arg2);
+ catch (const std::exception& e)
+ SWIG_exception(SWIG_RuntimeError, e.what());
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_CoordinateSequence(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosCoordinateSequence *arg1 = (GeosCoordinateSequence *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_CoordinateSequence",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_CoordinateSequence" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ arg1 = reinterpret_cast< GeosCoordinateSequence * >(argp1);
+ try
+ delete_GeosCoordinateSequence(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_clone(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_clone",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_clone" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ try
+ result = (GeosCoordinateSequence *)GeosCoordinateSequence_clone(arg1);
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_OWN | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_setX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ PyObject * obj2 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setX",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setX" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setX" "', argument " "2"" of type '" "size_t""'");
+ ecode3 = SWIG_AsVal_double(obj2, &val3);
+ if (!SWIG_IsOK(ecode3)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setX" "', argument " "3"" of type '" "double""'");
+ arg3 = static_cast< double >(val3);
+ try
+ result = (int)GeosCoordinateSequence_setX(arg1,arg2,arg3);
+ resultobj = SWIG_From_int(static_cast< int >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_setY(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setY",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setY" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setY" "', argument " "2"" of type '" "size_t""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setY" "', argument " "3"" of type '" "double""'");
+ try
+ result = (int)GeosCoordinateSequence_setY(arg1,arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_setZ(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setZ",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setZ" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setZ" "', argument " "2"" of type '" "size_t""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setZ" "', argument " "3"" of type '" "double""'");
+ try
+ result = (int)GeosCoordinateSequence_setZ(arg1,arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_setOrdinate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ size_t arg3 ;
+ double arg4 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ size_t val3 ;
+ int ecode3 = 0 ;
+ double val4 ;
+ int ecode4 = 0 ;
+ PyObject * obj3 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_setOrdinate",4,4,&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_setOrdinate" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_setOrdinate" "', argument " "2"" of type '" "size_t""'");
+ ecode3 = SWIG_AsVal_size_t(obj2, &val3);
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_setOrdinate" "', argument " "3"" of type '" "size_t""'");
+ arg3 = static_cast< size_t >(val3);
+ ecode4 = SWIG_AsVal_double(obj3, &val4);
+ if (!SWIG_IsOK(ecode4)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "CoordinateSequence_setOrdinate" "', argument " "4"" of type '" "double""'");
+ arg4 = static_cast< double >(val4);
+ try
+ result = (int)GeosCoordinateSequence_setOrdinate(arg1,arg2,arg3,arg4);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_getX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getX",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getX" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getX" "', argument " "2"" of type '" "size_t""'");
+ try
+ result = (double)GeosCoordinateSequence_getX(arg1,arg2);
+ resultobj = SWIG_From_double(static_cast< double >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_getY(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getY",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getY" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getY" "', argument " "2"" of type '" "size_t""'");
+ try
+ result = (double)GeosCoordinateSequence_getY(arg1,arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_getZ(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getZ",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getZ" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getZ" "', argument " "2"" of type '" "size_t""'");
+ try
+ result = (double)GeosCoordinateSequence_getZ(arg1,arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_getOrdinate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ size_t arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ size_t val3 ;
+ int ecode3 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getOrdinate",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getOrdinate" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "CoordinateSequence_getOrdinate" "', argument " "2"" of type '" "size_t""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "CoordinateSequence_getOrdinate" "', argument " "3"" of type '" "size_t""'");
+ try
+ result = (double)GeosCoordinateSequence_getOrdinate(arg1,arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_getSize(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getSize",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getSize" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ try
+ result = (unsigned int)GeosCoordinateSequence_getSize(arg1);
+ resultobj = SWIG_From_unsigned_SS_int(static_cast< unsigned int >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_CoordinateSequence_getDimensions(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"CoordinateSequence_getDimensions",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "CoordinateSequence_getDimensions" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ try
+ result = (unsigned int)GeosCoordinateSequence_getDimensions(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *CoordinateSequence_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosCoordinateSequence, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_Geometry(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosGeometry *arg1 = (GeosGeometry *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_Geometry",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometry, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Geometry" "', argument " "1"" of type '" "GeosGeometry *""'");
+ arg1 = reinterpret_cast< GeosGeometry * >(argp1);
+ try
+ delete_GeosGeometry(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_clone(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ GeosGeometry *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_clone",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_clone" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_clone(arg1);
+ /* %typemap(out) GeosGeometry */
+ SWIG_exception(SWIG_RuntimeError, message);
+ GeosGeometry *geom = result;
+ GEOSGeomTypes geomId = (GEOSGeomTypes)GEOSGeomTypeId((GEOSGeom) geom);
+ switch (geomId)
+ case GEOS_POINT:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_LINESTRING:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_LINEARRING:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_POLYGON:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTIPOINT:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTILINESTRING:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTIPOLYGON:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_GEOMETRYCOLLECTION:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | SWIG_POINTER_OWN);
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_geomType(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_geomType",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_geomType" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (char *)GeosGeometry_geomType(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_typeId(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_typeId",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_typeId" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (int)GeosGeometry_typeId(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_normalize(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_normalize",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_normalize" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ GeosGeometry_normalize(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_getSRID(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_getSRID",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getSRID" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (int)GeosGeometry_getSRID(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_setSRID(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_setSRID",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_setSRID" "', argument " "1"" of type '" "GeosGeometry *""'");
+ ecode2 = SWIG_AsVal_int(obj1, &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_setSRID" "', argument " "2"" of type '" "int""'");
+ arg2 = static_cast< int >(val2);
+ try
+ GeosGeometry_setSRID(arg1,arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_getDimensions(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_getDimensions",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getDimensions" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = GeosGeometry_getDimensions(arg1);
+ resultobj = SWIG_From_size_t(static_cast< size_t >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_getNumGeometries(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_getNumGeometries",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getNumGeometries" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = GeosGeometry_getNumGeometries(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_intersection(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosGeometry *arg2 = (GeosGeometry *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_intersection",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_intersection" "', argument " "1"" of type '" "GeosGeometry *""'");
+ res2 = SWIG_ConvertPtr(obj1, &argp2,SWIGTYPE_p_GeosGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_intersection" "', argument " "2"" of type '" "GeosGeometry *""'");
+ arg2 = reinterpret_cast< GeosGeometry * >(argp2);
+ try
+ result = (GeosGeometry *)GeosGeometry_intersection(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_buffer(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ double arg2 ;
+ int arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double val2 ;
+ int ecode2 = 0 ;
+ int val3 ;
+ int ecode3 = 0 ;
+ arg3 = DEFAULT_QUADRANT_SEGMENTS;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_buffer",2,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_buffer" "', argument " "1"" of type '" "GeosGeometry *""'");
+ ecode2 = SWIG_AsVal_double(obj1, &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_buffer" "', argument " "2"" of type '" "double""'");
+ arg2 = static_cast< double >(val2);
+ if (obj2) {
+ ecode3 = SWIG_AsVal_int(obj2, &val3);
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Geometry_buffer" "', argument " "3"" of type '" "int""'");
+ arg3 = static_cast< int >(val3);
+ try
+ result = (GeosGeometry *)GeosGeometry_buffer(arg1,arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_convexHull(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_convexHull",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_convexHull" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_convexHull(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_difference(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_difference",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_difference" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_difference" "', argument " "2"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_difference(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_symDifference(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_symDifference",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_symDifference" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_symDifference" "', argument " "2"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_symDifference(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_boundary(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_boundary",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_boundary" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_boundary(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_union(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_union",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_union" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_union" "', argument " "2"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_geomUnion(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_pointOnSurface(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_pointOnSurface",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_pointOnSurface" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_pointOnSurface(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_getCentroid(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_getCentroid",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getCentroid" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_getCentroid(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_getEnvelope(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_getEnvelope",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_getEnvelope" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_getEnvelope(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | 0);
+ break;
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | 0);
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_relate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_relate",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_relate" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_relate" "', argument " "2"" of type '" "GeosGeometry *""'");
+ try
+ result = (char *)GeosGeometry_relate(arg1,arg2);
+ delete[] result;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_lineMerge(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_lineMerge",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_lineMerge" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_lineMerge(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_simplify(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ double arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_simplify",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_simplify" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_simplify" "', argument " "2"" of type '" "double""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_simplify(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_topologyPreserveSimplify(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ double arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_topologyPreserveSimplify",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_topologyPreserveSimplify" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Geometry_topologyPreserveSimplify" "', argument " "2"" of type '" "double""'");
+ try
+ result = (GeosGeometry *)GeosGeometry_topologyPreserveSimplify(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_relatePattern(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ char *arg3 = (char *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ int res3 ;
+ char *buf3 = 0 ;
+ int alloc3 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_relatePattern",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_relatePattern" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_relatePattern" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ res3 = SWIG_AsCharPtrAndSize(obj2, &buf3, NULL, &alloc3);
+ if (!SWIG_IsOK(res3)) {
+ SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "Geometry_relatePattern" "', argument " "3"" of type '" "char const *""'");
+ arg3 = reinterpret_cast< char * >(buf3);
+ try
+ result = (bool)GeosGeometry_relatePattern(arg1,(GeosGeometry const *)arg2,(char const *)arg3);
+ if (alloc3 == SWIG_NEWOBJ) delete[] buf3;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_disjoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_disjoint",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_disjoint" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_disjoint" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_disjoint(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_touches(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_touches",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_touches" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_touches" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_touches(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_intersects(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_intersects",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_intersects" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_intersects" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_intersects(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_crosses(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_crosses",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_crosses" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_crosses" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_crosses(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_within(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_within",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_within" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_within" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_within(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_contains(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_contains",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_contains" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_contains" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_contains(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_overlaps(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_overlaps",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_overlaps" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_overlaps" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_overlaps(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_equals(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_equals",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_equals" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_equals" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosGeometry_equals(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_equalsExact(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_equalsExact",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_equalsExact" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_equalsExact" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Geometry_equalsExact" "', argument " "3"" of type '" "double""'");
+ try
+ result = (bool)GeosGeometry_equalsExact(arg1,(GeosGeometry const *)arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_isEmpty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_isEmpty",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isEmpty" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (bool)GeosGeometry_isEmpty(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_isValid(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_isValid",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isValid" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (bool)GeosGeometry_isValid(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_isSimple(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_isSimple",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isSimple" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (bool)GeosGeometry_isSimple(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_isRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_isRing",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_isRing" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (bool)GeosGeometry_isRing(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_hasZ(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_hasZ",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_hasZ" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (bool)GeosGeometry_hasZ(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_area(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_area",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_area" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (double)GeosGeometry_area(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_length(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_length",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_length" "', argument " "1"" of type '" "GeosGeometry *""'");
+ try
+ result = (double)GeosGeometry_length(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Geometry_distance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ double result;
+ if(!PyArg_UnpackTuple(args,(char *)"Geometry_distance",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Geometry_distance" "', argument " "1"" of type '" "GeosGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Geometry_distance" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (double)GeosGeometry_distance(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *Geometry_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosGeometry, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_Point(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosPoint *arg1 = (GeosPoint *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_Point",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPoint, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Point" "', argument " "1"" of type '" "GeosPoint *""'");
+ arg1 = reinterpret_cast< GeosPoint * >(argp1);
+ try
+ delete_GeosPoint(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Point_getCoordSeq(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Point_getCoordSeq",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPoint, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Point_getCoordSeq" "', argument " "1"" of type '" "GeosPoint *""'");
+ try
+ result = (GeosCoordinateSequence *)GeosPoint_getCoordSeq(arg1);
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *Point_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosPoint, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_LineString(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosLineString *arg1 = (GeosLineString *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_LineString",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLineString, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_LineString" "', argument " "1"" of type '" "GeosLineString *""'");
+ arg1 = reinterpret_cast< GeosLineString * >(argp1);
+ try
+ delete_GeosLineString(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_LineString_getCoordSeq(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"LineString_getCoordSeq",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLineString, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "LineString_getCoordSeq" "', argument " "1"" of type '" "GeosLineString *""'");
+ try
+ result = (GeosCoordinateSequence *)GeosLineString_getCoordSeq(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *LineString_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosLineString, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_LinearRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosLinearRing *arg1 = (GeosLinearRing *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_LinearRing",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_LinearRing" "', argument " "1"" of type '" "GeosLinearRing *""'");
+ arg1 = reinterpret_cast< GeosLinearRing * >(argp1);
+ try
+ delete_GeosLinearRing(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_LinearRing_getCoordSeq(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"LinearRing_getCoordSeq",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosLinearRing, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "LinearRing_getCoordSeq" "', argument " "1"" of type '" "GeosLinearRing *""'");
+ try
+ result = (GeosCoordinateSequence *)GeosLinearRing_getCoordSeq(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *LinearRing_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosLinearRing, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_Polygon(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosPolygon *arg1 = (GeosPolygon *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_Polygon",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPolygon, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Polygon" "', argument " "1"" of type '" "GeosPolygon *""'");
+ arg1 = reinterpret_cast< GeosPolygon * >(argp1);
+ try
+ delete_GeosPolygon(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Polygon_getExteriorRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *resultobj = 0;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ PyObject * obj0 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Polygon_getExteriorRing",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPolygon, 0 | 0 );
+ if (!SWIG_IsOK(res1)) {
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Polygon_getExteriorRing" "', argument " "1"" of type '" "GeosPolygon *""'");
+ try
+ result = (GeosGeometry *)GeosPolygon_getExteriorRing(arg1);
+ if (result == NULL)
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Polygon_getNumInteriorRings(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t result;
+ if(!PyArg_UnpackTuple(args,(char *)"Polygon_getNumInteriorRings",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Polygon_getNumInteriorRings" "', argument " "1"" of type '" "GeosPolygon *""'");
+ try
+ result = GeosPolygon_getNumInteriorRings(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Polygon_getInteriorRingN(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ PyObject * obj1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"Polygon_getInteriorRingN",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Polygon_getInteriorRingN" "', argument " "1"" of type '" "GeosPolygon *""'");
+ ecode2 = SWIG_AsVal_size_t(obj1, &val2);
+ if (!SWIG_IsOK(ecode2)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Polygon_getInteriorRingN" "', argument " "2"" of type '" "size_t""'");
+ arg2 = static_cast< size_t >(val2);
+ try
+ result = (GeosGeometry *)GeosPolygon_getInteriorRingN(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *Polygon_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosPolygon, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_GeometryCollection(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosGeometryCollection *arg1 = (GeosGeometryCollection *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_GeometryCollection",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometryCollection, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_GeometryCollection" "', argument " "1"" of type '" "GeosGeometryCollection *""'");
+ arg1 = reinterpret_cast< GeosGeometryCollection * >(argp1);
+ try
+ delete_GeosGeometryCollection(arg1);
+ resultobj = SWIG_Py_Void();
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_GeometryCollection_getGeometryN(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"GeometryCollection_getGeometryN",2,2,&obj0,&obj1)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosGeometryCollection, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "GeometryCollection_getGeometryN" "', argument " "1"" of type '" "GeosGeometryCollection *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "GeometryCollection_getGeometryN" "', argument " "2"" of type '" "size_t""'");
+ try
+ result = (GeosGeometry *)GeosGeometryCollection_getGeometryN(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *GeometryCollection_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosGeometryCollection, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_MultiPoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosMultiPoint *arg1 = (GeosMultiPoint *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_MultiPoint",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiPoint, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiPoint" "', argument " "1"" of type '" "GeosMultiPoint *""'");
+ arg1 = reinterpret_cast< GeosMultiPoint * >(argp1);
+ try
+ delete_GeosMultiPoint(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *MultiPoint_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiPoint, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_MultiLineString(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosMultiLineString *arg1 = (GeosMultiLineString *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_MultiLineString",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiLineString, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiLineString" "', argument " "1"" of type '" "GeosMultiLineString *""'");
+ arg1 = reinterpret_cast< GeosMultiLineString * >(argp1);
+ try
+ delete_GeosMultiLineString(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *MultiLineString_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiLineString, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_MultiLinearRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosMultiLinearRing *arg1 = (GeosMultiLinearRing *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_MultiLinearRing",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiLinearRing, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiLinearRing" "', argument " "1"" of type '" "GeosMultiLinearRing *""'");
+ arg1 = reinterpret_cast< GeosMultiLinearRing * >(argp1);
+ try
+ delete_GeosMultiLinearRing(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *MultiLinearRing_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiLinearRing, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_delete_MultiPolygon(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosMultiPolygon *arg1 = (GeosMultiPolygon *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_MultiPolygon",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosMultiPolygon, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_MultiPolygon" "', argument " "1"" of type '" "GeosMultiPolygon *""'");
+ arg1 = reinterpret_cast< GeosMultiPolygon * >(argp1);
+ try
+ delete_GeosMultiPolygon(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *MultiPolygon_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosMultiPolygon, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_createPoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"createPoint",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createPoint" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ try
+ result = (GeosGeometry *)createPoint(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_createLineString(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"createLineString",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createLineString" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ try
+ result = (GeosGeometry *)createLineString(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_createLinearRing(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"createLinearRing",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createLinearRing" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
+ try
+ result = (GeosGeometry *)createLinearRing(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_createPolygon(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosLinearRing **arg2 = (GeosLinearRing **) 0 ;
+ size_t arg3 ;
+ int res1 = 0 ;
+ arg2 = NULL;
+ arg3 = 0;
+ if(!PyArg_UnpackTuple(args,(char *)"createPolygon",1,2,&obj0,&obj1)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
+ if (obj1) {
+ if (obj1 == Py_None)
+ arg2 = NULL;
+ arg3 = 0;
+ else
+ /* Make sure the input can be treated as an array. */
+ if (!PySequence_Check(obj1))
+ SWIG_exception_fail(SWIG_RuntimeError, "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
+ /* Get the length */
+ arg3 = PySequence_Size(obj1);
+ /* Allocate space for the C array. */
+ arg2 = (GeosLinearRing**) malloc(arg3*sizeof(GeosLinearRing*));
+ for(size_t i = 0; i<arg3; i++)
+ /* Get the Python Object */
+ PyObject *item = PySequence_GetItem(obj1,i);
+ /* Get the underlying pointer and give up ownership of it. */
+ GeosLinearRing *ring = NULL;
+ int convertResult = SWIG_ConvertPtr(item, (void**)&ring, SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN);
+ if (!SWIG_IsOK(convertResult)) {
+ SWIG_exception_fail(SWIG_ArgError(convertResult), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
+ /* Put the pointer in the array */
+ arg2[i] = ring;
+ try
+ result = (GeosGeometry *)createPolygon(arg1,arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ if (arg2) {
+ free((void*) arg2);
+ return resultobj;
+fail:
+ if (arg2) {
+ return NULL;
+SWIGINTERN PyObject *_wrap_new_Prepared(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ GeosPreparedGeometry *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"new_Prepared",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_Prepared" "', argument " "1"" of type '" "GeosGeometry const *""'");
+ try
+ result = (GeosPreparedGeometry *)new_GeosPreparedGeometry((GeosGeometry const *)arg1);
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPreparedGeometry, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_Prepared(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosPreparedGeometry *arg1 = (GeosPreparedGeometry *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_Prepared",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPreparedGeometry, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Prepared" "', argument " "1"" of type '" "GeosPreparedGeometry *""'");
+ arg1 = reinterpret_cast< GeosPreparedGeometry * >(argp1);
+ try
+ delete_GeosPreparedGeometry(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Prepared_contains(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Prepared_contains",2,2,&obj0,&obj1)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosPreparedGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Prepared_contains" "', argument " "1"" of type '" "GeosPreparedGeometry *""'");
+ if (!SWIG_IsOK(res2)) {
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Prepared_contains" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosPreparedGeometry_contains(arg1,(GeosGeometry const *)arg2);
+ resultobj = SWIG_From_bool(static_cast< bool >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Prepared_containsProperly(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Prepared_containsProperly",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Prepared_containsProperly" "', argument " "1"" of type '" "GeosPreparedGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Prepared_containsProperly" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosPreparedGeometry_containsProperly(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Prepared_covers(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Prepared_covers",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Prepared_covers" "', argument " "1"" of type '" "GeosPreparedGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Prepared_covers" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosPreparedGeometry_covers(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_Prepared_intersects(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"Prepared_intersects",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Prepared_intersects" "', argument " "1"" of type '" "GeosPreparedGeometry *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Prepared_intersects" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (bool)GeosPreparedGeometry_intersects(arg1,(GeosGeometry const *)arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *Prepared_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosPreparedGeometry, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_new_STRtree(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int arg1 ;
+ int val1 ;
+ int ecode1 = 0 ;
+ GeosSTRtree *result = 0 ;
+ arg1 = 10;
+ if(!PyArg_UnpackTuple(args,(char *)"new_STRtree",0,1,&obj0)) SWIG_fail;
+ if (obj0) {
+ ecode1 = SWIG_AsVal_int(obj0, &val1);
+ SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_STRtree" "', argument " "1"" of type '" "int""'");
+ arg1 = static_cast< int >(val1);
+ try
+ result = (GeosSTRtree *)new_GeosSTRtree(arg1);
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosSTRtree, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_STRtree(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosSTRtree *arg1 = (GeosSTRtree *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_STRtree",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosSTRtree, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_STRtree" "', argument " "1"" of type '" "GeosSTRtree *""'");
+ arg1 = reinterpret_cast< GeosSTRtree * >(argp1);
+ try
+ delete_GeosSTRtree(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_STRtree_insert(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosIndexItem arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ void *argp3 ;
+ int res3 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"STRtree_insert",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosSTRtree, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "STRtree_insert" "', argument " "1"" of type '" "GeosSTRtree *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "STRtree_insert" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ res3 = SWIG_ConvertPtr(obj2, &argp3, SWIGTYPE_p_GeosIndexItem, 0 | 0);
+ SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "STRtree_insert" "', argument " "3"" of type '" "GeosIndexItem""'");
+ if (!argp3) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "STRtree_insert" "', argument " "3"" of type '" "GeosIndexItem""'");
+ } else {
+ GeosIndexItem * temp = reinterpret_cast< GeosIndexItem * >(argp3);
+ arg3 = *temp;
+ if (SWIG_IsNewObj(res3)) delete temp;
+ try
+ GeosSTRtree_insert(arg1,(GeosGeometry const *)arg2,arg3);
+ catch (const std::exception& e)
+ SWIG_exception(SWIG_RuntimeError, e.what());
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_STRtree_remove(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ void *argp3 ;
+ int res3 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"STRtree_remove",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "STRtree_remove" "', argument " "1"" of type '" "GeosSTRtree *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "STRtree_remove" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "STRtree_remove" "', argument " "3"" of type '" "GeosIndexItem""'");
+ if (!argp3) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "STRtree_remove" "', argument " "3"" of type '" "GeosIndexItem""'");
+ } else {
+ arg3 = *temp;
+ try
+ GeosSTRtree_remove(arg1,(GeosGeometry const *)arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_STRtree_query(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosQueryCallback arg3 ;
+ GeosIndexItem arg4 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ void *argp3 ;
+ int res3 = 0 ;
+ void *argp4 ;
+ int res4 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"STRtree_query",4,4,&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "STRtree_query" "', argument " "1"" of type '" "GeosSTRtree *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "STRtree_query" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ res3 = SWIG_ConvertPtr(obj2, &argp3, SWIGTYPE_p_GeosQueryCallback, 0 | 0);
+ SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "STRtree_query" "', argument " "3"" of type '" "GeosQueryCallback""'");
+ if (!argp3) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "STRtree_query" "', argument " "3"" of type '" "GeosQueryCallback""'");
+ } else {
+ GeosQueryCallback * temp = reinterpret_cast< GeosQueryCallback * >(argp3);
+ arg3 = *temp;
+ res4 = SWIG_ConvertPtr(obj3, &argp4, SWIGTYPE_p_GeosIndexItem, 0 | 0);
+ if (!SWIG_IsOK(res4)) {
+ SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "STRtree_query" "', argument " "4"" of type '" "GeosIndexItem""'");
+ if (!argp4) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "STRtree_query" "', argument " "4"" of type '" "GeosIndexItem""'");
+ } else {
+ GeosIndexItem * temp = reinterpret_cast< GeosIndexItem * >(argp4);
+ arg4 = *temp;
+ if (SWIG_IsNewObj(res4)) delete temp;
+ try
+ GeosSTRtree_query(arg1,(GeosGeometry const *)arg2,arg3,arg4);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_STRtree_iterate(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosQueryCallback arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 ;
+ int res2 = 0 ;
+ void *argp3 ;
+ int res3 = 0 ;
+ PyObject * obj2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"STRtree_iterate",3,3,&obj0,&obj1,&obj2)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "STRtree_iterate" "', argument " "1"" of type '" "GeosSTRtree *""'");
+ res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_GeosQueryCallback, 0 | 0);
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "STRtree_iterate" "', argument " "2"" of type '" "GeosQueryCallback""'");
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "STRtree_iterate" "', argument " "2"" of type '" "GeosQueryCallback""'");
+ } else {
+ GeosQueryCallback * temp = reinterpret_cast< GeosQueryCallback * >(argp2);
+ arg2 = *temp;
+ if (SWIG_IsNewObj(res2)) delete temp;
+ SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "STRtree_iterate" "', argument " "3"" of type '" "GeosIndexItem""'");
+ if (!argp3) {
+ SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "STRtree_iterate" "', argument " "3"" of type '" "GeosIndexItem""'");
+ } else {
+ arg3 = *temp;
+ try
+ GeosSTRtree_iterate(arg1,arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *STRtree_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ if (!PyArg_UnpackTuple(args,(char*)"swigregister", 1, 1,&obj)) return NULL;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosSTRtree, SWIG_NewClientData(obj));
+ return SWIG_Py_Void();
+SWIGINTERN PyObject *_wrap_new_WktReader(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWktReader *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"new_WktReader",0,0)) SWIG_fail;
+ try
+ result = (GeosWktReader *)new_GeosWktReader();
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosWktReader, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_WktReader(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWktReader *arg1 = (GeosWktReader *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_WktReader",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWktReader, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_WktReader" "', argument " "1"" of type '" "GeosWktReader *""'");
+ arg1 = reinterpret_cast< GeosWktReader * >(argp1);
+ try
+ delete_GeosWktReader(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WktReader_read(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ char *arg2 = (char *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int res2 ;
+ char *buf2 = 0 ;
+ int alloc2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WktReader_read",2,2,&obj0,&obj1)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWktReader, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WktReader_read" "', argument " "1"" of type '" "GeosWktReader *""'");
+ res2 = SWIG_AsCharPtrAndSize(obj1, &buf2, NULL, &alloc2);
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "WktReader_read" "', argument " "2"" of type '" "char const *""'");
+ arg2 = reinterpret_cast< char * >(buf2);
+ try
+ result = (GeosGeometry *)GeosWktReader_read(arg1,(char const *)arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ if (alloc2 == SWIG_NEWOBJ) delete[] buf2;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *WktReader_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosWktReader, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_new_WktWriter(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWktWriter *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"new_WktWriter",0,0)) SWIG_fail;
+ try
+ result = (GeosWktWriter *)new_GeosWktWriter();
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosWktWriter, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_WktWriter(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWktWriter *arg1 = (GeosWktWriter *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_WktWriter",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWktWriter, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_WktWriter" "', argument " "1"" of type '" "GeosWktWriter *""'");
+ arg1 = reinterpret_cast< GeosWktWriter * >(argp1);
+ try
+ delete_GeosWktWriter(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WktWriter_write(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ char *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WktWriter_write",2,2,&obj0,&obj1)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWktWriter, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WktWriter_write" "', argument " "1"" of type '" "GeosWktWriter *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "WktWriter_write" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (char *)GeosWktWriter_write(arg1,(GeosGeometry const *)arg2);
+ resultobj = SWIG_FromCharPtr((const char *)result);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *WktWriter_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosWktWriter, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_new_WkbReader(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWkbReader *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"new_WkbReader",0,0)) SWIG_fail;
+ try
+ result = (GeosWkbReader *)new_GeosWkbReader();
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosWkbReader, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_WkbReader(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWkbReader *arg1 = (GeosWkbReader *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_WkbReader",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWkbReader, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_WkbReader" "', argument " "1"" of type '" "GeosWkbReader *""'");
+ arg1 = reinterpret_cast< GeosWkbReader * >(argp1);
+ try
+ delete_GeosWkbReader(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbReader_read(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ unsigned char *arg2 = (unsigned char *) 0 ;
+ size_t arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int alloc2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbReader_read",2,2,&obj0,&obj1)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWkbReader, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbReader_read" "', argument " "1"" of type '" "GeosWkbReader *""'");
+ /* %typemap(in) (const unsigned char* wkb, size_t size) (int alloc2 = 0) */
+ if (SWIG_AsCharPtrAndSize(obj1, (char**)&arg2, &arg3, &alloc2) != SWIG_OK)
+ SWIG_exception(SWIG_RuntimeError, "Expecting a string");
+ /* Don't want to include last null character! */
+ arg3--;
+ try
+ result = (GeosGeometry *)GeosWkbReader_read(arg1,(unsigned char const *)arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbReader_readHEX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ size_t arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int alloc2 = 0 ;
+ GeosGeometry *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbReader_readHEX",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbReader_readHEX" "', argument " "1"" of type '" "GeosWkbReader *""'");
+ arg3--;
+ try
+ result = (GeosGeometry *)GeosWkbReader_readHEX(arg1,(unsigned char const *)arg2,arg3);
+ /* %typemap(out) GeosGeometry */
+ SWIG_exception(SWIG_RuntimeError, message);
+ GeosGeometry *geom = result;
+ GEOSGeomTypes geomId = (GEOSGeomTypes)GEOSGeomTypeId((GEOSGeom) geom);
+ switch (geomId)
+ case GEOS_POINT:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_LINESTRING:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_LINEARRING:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_POLYGON:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTIPOINT:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTILINESTRING:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTIPOLYGON:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_GEOMETRYCOLLECTION:
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | SWIG_POINTER_OWN);
+ break;
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *WkbReader_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosWkbReader, SWIG_NewClientData(obj));
+SWIGINTERN PyObject *_wrap_new_WkbWriter(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWkbWriter *result = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"new_WkbWriter",0,0)) SWIG_fail;
+ try
+ result = (GeosWkbWriter *)new_GeosWkbWriter();
+ resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosWkbWriter, SWIG_POINTER_NEW | 0 );
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_delete_WkbWriter(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosWkbWriter *arg1 = (GeosWkbWriter *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"delete_WkbWriter",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWkbWriter, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_WkbWriter" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ arg1 = reinterpret_cast< GeosWkbWriter * >(argp1);
+ try
+ delete_GeosWkbWriter(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_getOutputDimension(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_getOutputDimension",1,1,&obj0)) SWIG_fail;
+ res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_GeosWkbWriter, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_getOutputDimension" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ try
+ result = (int)GeosWkbWriter_getOutputDimension(arg1);
+ resultobj = SWIG_From_int(static_cast< int >(result));
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_setOutputDimension(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_setOutputDimension",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_setOutputDimension" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ ecode2 = SWIG_AsVal_int(obj1, &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "WkbWriter_setOutputDimension" "', argument " "2"" of type '" "int""'");
+ arg2 = static_cast< int >(val2);
+ try
+ GeosWkbWriter_setOutputDimension(arg1,arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_getByteOrder(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_getByteOrder",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_getByteOrder" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ try
+ result = (int)GeosWkbWriter_getByteOrder(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_setByteOrder(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ int arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_setByteOrder",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_setByteOrder" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "WkbWriter_setByteOrder" "', argument " "2"" of type '" "int""'");
+ try
+ GeosWkbWriter_setByteOrder(arg1,arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_getIncludeSRID(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_getIncludeSRID",1,1,&obj0)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_getIncludeSRID" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ try
+ result = (bool)GeosWkbWriter_getIncludeSRID(arg1);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_setIncludeSRID(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ bool arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool val2 ;
+ int ecode2 = 0 ;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_setIncludeSRID",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_setIncludeSRID" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ ecode2 = SWIG_AsVal_bool(obj1, &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "WkbWriter_setIncludeSRID" "', argument " "2"" of type '" "bool""'");
+ arg2 = static_cast< bool >(val2);
+ try
+ GeosWkbWriter_setIncludeSRID(arg1,arg2);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_write(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ GeosGeometry *arg2 = (GeosGeometry *) 0 ;
+ size_t *arg3 = (size_t *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ size_t temp3 = 0 ;
+ unsigned char *result = 0 ;
+ /* %typemap(in, numinputs=0) size_t *size (size_t temp3 = 0) */
+ arg3 = &temp3;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_write",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_write" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ res2 = SWIG_ConvertPtr(obj1, &argp2,SWIGTYPE_p_GeosGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "WkbWriter_write" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ arg2 = reinterpret_cast< GeosGeometry * >(argp2);
+ try
+ result = (unsigned char *)GeosWkbWriter_write(arg1,(GeosGeometry const *)arg2,arg3);
+ /* %typemap(out) unsigned char* */
+ /* %typemap(argout) size_t *size */
+ resultobj = SWIG_FromCharPtrAndSize((const char*)result, *arg3);
+ /* %typemap(freearg) size_t *size */
+ std::free(result);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *_wrap_WkbWriter_writeHEX(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ arg3 = &temp3;
+ if(!PyArg_UnpackTuple(args,(char *)"WkbWriter_writeHEX",2,2,&obj0,&obj1)) SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "WkbWriter_writeHEX" "', argument " "1"" of type '" "GeosWkbWriter *""'");
+ SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "WkbWriter_writeHEX" "', argument " "2"" of type '" "GeosGeometry const *""'");
+ try
+ result = (unsigned char *)GeosWkbWriter_writeHEX(arg1,(GeosGeometry const *)arg2,arg3);
+ return resultobj;
+fail:
+ return NULL;
+SWIGINTERN PyObject *WkbWriter_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
+ PyObject *obj;
+ SWIG_TypeNewClientData(SWIGTYPE_p_GeosWkbWriter, SWIG_NewClientData(obj));
+static PyMethodDef SwigMethods[] = {
+ { (char *)"SWIG_PyInstanceMethod_New", (PyCFunction)SWIG_PyInstanceMethod_New, METH_O, NULL},
+ { (char *)"delete_SwigPyIterator", _wrap_delete_SwigPyIterator, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_value", _wrap_SwigPyIterator_value, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_incr", _wrap_SwigPyIterator_incr, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_decr", _wrap_SwigPyIterator_decr, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_distance", _wrap_SwigPyIterator_distance, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_equal", _wrap_SwigPyIterator_equal, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_copy", _wrap_SwigPyIterator_copy, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_next", _wrap_SwigPyIterator_next, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___next__", _wrap_SwigPyIterator___next__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_previous", _wrap_SwigPyIterator_previous, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_advance", _wrap_SwigPyIterator_advance, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___eq__", _wrap_SwigPyIterator___eq__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___ne__", _wrap_SwigPyIterator___ne__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___iadd__", _wrap_SwigPyIterator___iadd__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___isub__", _wrap_SwigPyIterator___isub__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___add__", _wrap_SwigPyIterator___add__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator___sub__", _wrap_SwigPyIterator___sub__, METH_VARARGS, NULL},
+ { (char *)"SwigPyIterator_swigregister", SwigPyIterator_swigregister, METH_VARARGS, NULL},
+ { (char *)"version", _wrap_version, METH_VARARGS, NULL},
+ { (char *)"new_CoordinateSequence", _wrap_new_CoordinateSequence, METH_VARARGS, NULL},
+ { (char *)"delete_CoordinateSequence", _wrap_delete_CoordinateSequence, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_clone", _wrap_CoordinateSequence_clone, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_setX", _wrap_CoordinateSequence_setX, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_setY", _wrap_CoordinateSequence_setY, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_setZ", _wrap_CoordinateSequence_setZ, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_setOrdinate", _wrap_CoordinateSequence_setOrdinate, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_getX", _wrap_CoordinateSequence_getX, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_getY", _wrap_CoordinateSequence_getY, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_getZ", _wrap_CoordinateSequence_getZ, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_getOrdinate", _wrap_CoordinateSequence_getOrdinate, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_getSize", _wrap_CoordinateSequence_getSize, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_getDimensions", _wrap_CoordinateSequence_getDimensions, METH_VARARGS, NULL},
+ { (char *)"CoordinateSequence_swigregister", CoordinateSequence_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_Geometry", _wrap_delete_Geometry, METH_VARARGS, NULL},
+ { (char *)"Geometry_clone", _wrap_Geometry_clone, METH_VARARGS, NULL},
+ { (char *)"Geometry_geomType", _wrap_Geometry_geomType, METH_VARARGS, NULL},
+ { (char *)"Geometry_typeId", _wrap_Geometry_typeId, METH_VARARGS, NULL},
+ { (char *)"Geometry_normalize", _wrap_Geometry_normalize, METH_VARARGS, NULL},
+ { (char *)"Geometry_getSRID", _wrap_Geometry_getSRID, METH_VARARGS, NULL},
+ { (char *)"Geometry_setSRID", _wrap_Geometry_setSRID, METH_VARARGS, NULL},
+ { (char *)"Geometry_getDimensions", _wrap_Geometry_getDimensions, METH_VARARGS, NULL},
+ { (char *)"Geometry_getNumGeometries", _wrap_Geometry_getNumGeometries, METH_VARARGS, NULL},
+ { (char *)"Geometry_intersection", _wrap_Geometry_intersection, METH_VARARGS, NULL},
+ { (char *)"Geometry_buffer", _wrap_Geometry_buffer, METH_VARARGS, NULL},
+ { (char *)"Geometry_convexHull", _wrap_Geometry_convexHull, METH_VARARGS, NULL},
+ { (char *)"Geometry_difference", _wrap_Geometry_difference, METH_VARARGS, NULL},
+ { (char *)"Geometry_symDifference", _wrap_Geometry_symDifference, METH_VARARGS, NULL},
+ { (char *)"Geometry_boundary", _wrap_Geometry_boundary, METH_VARARGS, NULL},
+ { (char *)"Geometry_union", _wrap_Geometry_union, METH_VARARGS, NULL},
+ { (char *)"Geometry_pointOnSurface", _wrap_Geometry_pointOnSurface, METH_VARARGS, NULL},
+ { (char *)"Geometry_getCentroid", _wrap_Geometry_getCentroid, METH_VARARGS, NULL},
+ { (char *)"Geometry_getEnvelope", _wrap_Geometry_getEnvelope, METH_VARARGS, NULL},
+ { (char *)"Geometry_relate", _wrap_Geometry_relate, METH_VARARGS, NULL},
+ { (char *)"Geometry_lineMerge", _wrap_Geometry_lineMerge, METH_VARARGS, NULL},
+ { (char *)"Geometry_simplify", _wrap_Geometry_simplify, METH_VARARGS, NULL},
+ { (char *)"Geometry_topologyPreserveSimplify", _wrap_Geometry_topologyPreserveSimplify, METH_VARARGS, NULL},
+ { (char *)"Geometry_relatePattern", _wrap_Geometry_relatePattern, METH_VARARGS, NULL},
+ { (char *)"Geometry_disjoint", _wrap_Geometry_disjoint, METH_VARARGS, NULL},
+ { (char *)"Geometry_touches", _wrap_Geometry_touches, METH_VARARGS, NULL},
+ { (char *)"Geometry_intersects", _wrap_Geometry_intersects, METH_VARARGS, NULL},
+ { (char *)"Geometry_crosses", _wrap_Geometry_crosses, METH_VARARGS, NULL},
+ { (char *)"Geometry_within", _wrap_Geometry_within, METH_VARARGS, NULL},
+ { (char *)"Geometry_contains", _wrap_Geometry_contains, METH_VARARGS, NULL},
+ { (char *)"Geometry_overlaps", _wrap_Geometry_overlaps, METH_VARARGS, NULL},
+ { (char *)"Geometry_equals", _wrap_Geometry_equals, METH_VARARGS, NULL},
+ { (char *)"Geometry_equalsExact", _wrap_Geometry_equalsExact, METH_VARARGS, NULL},
+ { (char *)"Geometry_isEmpty", _wrap_Geometry_isEmpty, METH_VARARGS, NULL},
+ { (char *)"Geometry_isValid", _wrap_Geometry_isValid, METH_VARARGS, NULL},
+ { (char *)"Geometry_isSimple", _wrap_Geometry_isSimple, METH_VARARGS, NULL},
+ { (char *)"Geometry_isRing", _wrap_Geometry_isRing, METH_VARARGS, NULL},
+ { (char *)"Geometry_hasZ", _wrap_Geometry_hasZ, METH_VARARGS, NULL},
+ { (char *)"Geometry_area", _wrap_Geometry_area, METH_VARARGS, NULL},
+ { (char *)"Geometry_length", _wrap_Geometry_length, METH_VARARGS, NULL},
+ { (char *)"Geometry_distance", _wrap_Geometry_distance, METH_VARARGS, NULL},
+ { (char *)"Geometry_swigregister", Geometry_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_Point", _wrap_delete_Point, METH_VARARGS, NULL},
+ { (char *)"Point_getCoordSeq", _wrap_Point_getCoordSeq, METH_VARARGS, NULL},
+ { (char *)"Point_swigregister", Point_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_LineString", _wrap_delete_LineString, METH_VARARGS, NULL},
+ { (char *)"LineString_getCoordSeq", _wrap_LineString_getCoordSeq, METH_VARARGS, NULL},
+ { (char *)"LineString_swigregister", LineString_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_LinearRing", _wrap_delete_LinearRing, METH_VARARGS, NULL},
+ { (char *)"LinearRing_getCoordSeq", _wrap_LinearRing_getCoordSeq, METH_VARARGS, NULL},
+ { (char *)"LinearRing_swigregister", LinearRing_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_Polygon", _wrap_delete_Polygon, METH_VARARGS, NULL},
+ { (char *)"Polygon_getExteriorRing", _wrap_Polygon_getExteriorRing, METH_VARARGS, NULL},
+ { (char *)"Polygon_getNumInteriorRings", _wrap_Polygon_getNumInteriorRings, METH_VARARGS, NULL},
+ { (char *)"Polygon_getInteriorRingN", _wrap_Polygon_getInteriorRingN, METH_VARARGS, NULL},
+ { (char *)"Polygon_swigregister", Polygon_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_GeometryCollection", _wrap_delete_GeometryCollection, METH_VARARGS, NULL},
+ { (char *)"GeometryCollection_getGeometryN", _wrap_GeometryCollection_getGeometryN, METH_VARARGS, NULL},
+ { (char *)"GeometryCollection_swigregister", GeometryCollection_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_MultiPoint", _wrap_delete_MultiPoint, METH_VARARGS, NULL},
+ { (char *)"MultiPoint_swigregister", MultiPoint_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_MultiLineString", _wrap_delete_MultiLineString, METH_VARARGS, NULL},
+ { (char *)"MultiLineString_swigregister", MultiLineString_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_MultiLinearRing", _wrap_delete_MultiLinearRing, METH_VARARGS, NULL},
+ { (char *)"MultiLinearRing_swigregister", MultiLinearRing_swigregister, METH_VARARGS, NULL},
+ { (char *)"delete_MultiPolygon", _wrap_delete_MultiPolygon, METH_VARARGS, NULL},
+ { (char *)"MultiPolygon_swigregister", MultiPolygon_swigregister, METH_VARARGS, NULL},
+ { (char *)"createPoint", _wrap_createPoint, METH_VARARGS, NULL},
+ { (char *)"createLineString", _wrap_createLineString, METH_VARARGS, NULL},
+ { (char *)"createLinearRing", _wrap_createLinearRing, METH_VARARGS, NULL},
+ { (char *)"createPolygon", _wrap_createPolygon, METH_VARARGS, NULL},
+ { (char *)"new_Prepared", _wrap_new_Prepared, METH_VARARGS, NULL},
+ { (char *)"delete_Prepared", _wrap_delete_Prepared, METH_VARARGS, NULL},
+ { (char *)"Prepared_contains", _wrap_Prepared_contains, METH_VARARGS, NULL},
+ { (char *)"Prepared_containsProperly", _wrap_Prepared_containsProperly, METH_VARARGS, NULL},
+ { (char *)"Prepared_covers", _wrap_Prepared_covers, METH_VARARGS, NULL},
+ { (char *)"Prepared_intersects", _wrap_Prepared_intersects, METH_VARARGS, NULL},
+ { (char *)"Prepared_swigregister", Prepared_swigregister, METH_VARARGS, NULL},
+ { (char *)"new_STRtree", _wrap_new_STRtree, METH_VARARGS, NULL},
+ { (char *)"delete_STRtree", _wrap_delete_STRtree, METH_VARARGS, NULL},
+ { (char *)"STRtree_insert", _wrap_STRtree_insert, METH_VARARGS, NULL},
+ { (char *)"STRtree_remove", _wrap_STRtree_remove, METH_VARARGS, NULL},
+ { (char *)"STRtree_query", _wrap_STRtree_query, METH_VARARGS, NULL},
+ { (char *)"STRtree_iterate", _wrap_STRtree_iterate, METH_VARARGS, NULL},
+ { (char *)"STRtree_swigregister", STRtree_swigregister, METH_VARARGS, NULL},
+ { (char *)"new_WktReader", _wrap_new_WktReader, METH_VARARGS, NULL},
+ { (char *)"delete_WktReader", _wrap_delete_WktReader, METH_VARARGS, NULL},
+ { (char *)"WktReader_read", _wrap_WktReader_read, METH_VARARGS, NULL},
+ { (char *)"WktReader_swigregister", WktReader_swigregister, METH_VARARGS, NULL},
+ { (char *)"new_WktWriter", _wrap_new_WktWriter, METH_VARARGS, NULL},
+ { (char *)"delete_WktWriter", _wrap_delete_WktWriter, METH_VARARGS, NULL},
+ { (char *)"WktWriter_write", _wrap_WktWriter_write, METH_VARARGS, NULL},
+ { (char *)"WktWriter_swigregister", WktWriter_swigregister, METH_VARARGS, NULL},
+ { (char *)"new_WkbReader", _wrap_new_WkbReader, METH_VARARGS, NULL},
+ { (char *)"delete_WkbReader", _wrap_delete_WkbReader, METH_VARARGS, NULL},
+ { (char *)"WkbReader_read", _wrap_WkbReader_read, METH_VARARGS, NULL},
+ { (char *)"WkbReader_readHEX", _wrap_WkbReader_readHEX, METH_VARARGS, NULL},
+ { (char *)"WkbReader_swigregister", WkbReader_swigregister, METH_VARARGS, NULL},
+ { (char *)"new_WkbWriter", _wrap_new_WkbWriter, METH_VARARGS, NULL},
+ { (char *)"delete_WkbWriter", _wrap_delete_WkbWriter, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_getOutputDimension", _wrap_WkbWriter_getOutputDimension, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_setOutputDimension", _wrap_WkbWriter_setOutputDimension, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_getByteOrder", _wrap_WkbWriter_getByteOrder, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_setByteOrder", _wrap_WkbWriter_setByteOrder, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_getIncludeSRID", _wrap_WkbWriter_getIncludeSRID, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_setIncludeSRID", _wrap_WkbWriter_setIncludeSRID, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_write", _wrap_WkbWriter_write, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_writeHEX", _wrap_WkbWriter_writeHEX, METH_VARARGS, NULL},
+ { (char *)"WkbWriter_swigregister", WkbWriter_swigregister, METH_VARARGS, NULL},
+ { NULL, NULL, 0, NULL }
+/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
+static void *_p_GeosMultiPolygonTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiPolygon *) x));
+static void *_p_GeosMultiPointTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiPoint *) x));
+static void *_p_GeosMultiLineStringTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiLineString *) x));
+static void *_p_GeosMultiLinearRingTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
+static void *_p_GeosPolygonTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosPolygon *) x));
+static void *_p_GeosMultiPolygonTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPolygon *) x));
+static void *_p_GeosPointTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosPoint *) x));
+static void *_p_GeosLineStringTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosLineString *) x));
+static void *_p_GeosLinearRingTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosLinearRing *) x));
+static void *_p_GeosMultiPointTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPoint *) x));
+static void *_p_GeosMultiLineStringTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLineString *) x));
+static void *_p_GeosMultiLinearRingTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
+static void *_p_GeosGeometryCollectionTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosGeometryCollection *) x));
+static swig_type_info _swigt__p_GeosCoordinateSequence = {"_p_GeosCoordinateSequence", "GeosCoordinateSequence *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosGeometry = {"_p_GeosGeometry", "GeosGeometry *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosGeometryCollection = {"_p_GeosGeometryCollection", "GeosGeometryCollection *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosIndexItem = {"_p_GeosIndexItem", "GeosIndexItem *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosLineString = {"_p_GeosLineString", "GeosLineString *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosLinearRing = {"_p_GeosLinearRing", "GeosLinearRing *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiLineString = {"_p_GeosMultiLineString", "GeosMultiLineString *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiLinearRing = {"_p_GeosMultiLinearRing", "GeosMultiLinearRing *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiPoint = {"_p_GeosMultiPoint", "GeosMultiPoint *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiPolygon = {"_p_GeosMultiPolygon", "GeosMultiPolygon *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosPoint = {"_p_GeosPoint", "GeosPoint *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosPolygon = {"_p_GeosPolygon", "GeosPolygon *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosPreparedGeometry = {"_p_GeosPreparedGeometry", "GeosPreparedGeometry *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosQueryCallback = {"_p_GeosQueryCallback", "GeosQueryCallback *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosSTRtree = {"_p_GeosSTRtree", "GeosSTRtree *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWkbReader = {"_p_GeosWkbReader", "GeosWkbReader *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWkbWriter = {"_p_GeosWkbWriter", "GeosWkbWriter *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWktReader = {"_p_GeosWktReader", "GeosWktReader *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWktWriter = {"_p_GeosWktWriter", "GeosWktWriter *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_char = {"_p_char", "char *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_p_GeosLinearRing = {"_p_p_GeosLinearRing", "GeosLinearRing **", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_size_t = {"_p_size_t", "size_t *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_std__invalid_argument = {"_p_std__invalid_argument", "std::invalid_argument *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_swig__SwigPyIterator = {"_p_swig__SwigPyIterator", "swig::SwigPyIterator *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_unsigned_char = {"_p_unsigned_char", "unsigned char *", 0, 0, (void*)0, 0};
+static swig_type_info *swig_type_initial[] = {
+ &_swigt__p_GeosCoordinateSequence,
+ &_swigt__p_GeosGeometry,
+ &_swigt__p_GeosGeometryCollection,
+ &_swigt__p_GeosIndexItem,
+ &_swigt__p_GeosLineString,
+ &_swigt__p_GeosLinearRing,
+ &_swigt__p_GeosMultiLineString,
+ &_swigt__p_GeosMultiLinearRing,
+ &_swigt__p_GeosMultiPoint,
+ &_swigt__p_GeosMultiPolygon,
+ &_swigt__p_GeosPoint,
+ &_swigt__p_GeosPolygon,
+ &_swigt__p_GeosPreparedGeometry,
+ &_swigt__p_GeosQueryCallback,
+ &_swigt__p_GeosSTRtree,
+ &_swigt__p_GeosWkbReader,
+ &_swigt__p_GeosWkbWriter,
+ &_swigt__p_GeosWktReader,
+ &_swigt__p_GeosWktWriter,
+ &_swigt__p_char,
+ &_swigt__p_p_GeosLinearRing,
+ &_swigt__p_size_t,
+ &_swigt__p_std__invalid_argument,
+ &_swigt__p_swig__SwigPyIterator,
+ &_swigt__p_unsigned_char,
+static swig_cast_info _swigc__p_GeosCoordinateSequence[] = { {&_swigt__p_GeosCoordinateSequence, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosGeometry[] = { {&_swigt__p_GeosPolygon, _p_GeosPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosPoint, _p_GeosPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometry, 0, 0, 0}, {&_swigt__p_GeosLineString, _p_GeosLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosLinearRing, _p_GeosLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometryCollection, _p_GeosGeometryCollectionTo_p_GeosGeometry, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosGeometryCollection[] = { {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosGeometryCollection, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosIndexItem[] = { {&_swigt__p_GeosIndexItem, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosLineString[] = { {&_swigt__p_GeosLineString, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosLinearRing[] = { {&_swigt__p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiLineString[] = { {&_swigt__p_GeosMultiLineString, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiLinearRing[] = { {&_swigt__p_GeosMultiLinearRing, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiPoint[] = { {&_swigt__p_GeosMultiPoint, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiPolygon[] = { {&_swigt__p_GeosMultiPolygon, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosPoint[] = { {&_swigt__p_GeosPoint, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosPolygon[] = { {&_swigt__p_GeosPolygon, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosPreparedGeometry[] = { {&_swigt__p_GeosPreparedGeometry, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosQueryCallback[] = { {&_swigt__p_GeosQueryCallback, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosSTRtree[] = { {&_swigt__p_GeosSTRtree, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWkbReader[] = { {&_swigt__p_GeosWkbReader, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWkbWriter[] = { {&_swigt__p_GeosWkbWriter, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWktReader[] = { {&_swigt__p_GeosWktReader, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWktWriter[] = { {&_swigt__p_GeosWktWriter, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_char[] = { {&_swigt__p_char, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_p_GeosLinearRing[] = { {&_swigt__p_p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_size_t[] = { {&_swigt__p_size_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_std__invalid_argument[] = { {&_swigt__p_std__invalid_argument, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_swig__SwigPyIterator[] = { {&_swigt__p_swig__SwigPyIterator, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_unsigned_char[] = { {&_swigt__p_unsigned_char, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info *swig_cast_initial[] = {
+ _swigc__p_GeosCoordinateSequence,
+ _swigc__p_GeosGeometry,
+ _swigc__p_GeosGeometryCollection,
+ _swigc__p_GeosIndexItem,
+ _swigc__p_GeosLineString,
+ _swigc__p_GeosLinearRing,
+ _swigc__p_GeosMultiLineString,
+ _swigc__p_GeosMultiLinearRing,
+ _swigc__p_GeosMultiPoint,
+ _swigc__p_GeosMultiPolygon,
+ _swigc__p_GeosPoint,
+ _swigc__p_GeosPolygon,
+ _swigc__p_GeosPreparedGeometry,
+ _swigc__p_GeosQueryCallback,
+ _swigc__p_GeosSTRtree,
+ _swigc__p_GeosWkbReader,
+ _swigc__p_GeosWkbWriter,
+ _swigc__p_GeosWktReader,
+ _swigc__p_GeosWktWriter,
+ _swigc__p_char,
+ _swigc__p_p_GeosLinearRing,
+ _swigc__p_size_t,
+ _swigc__p_std__invalid_argument,
+ _swigc__p_swig__SwigPyIterator,
+ _swigc__p_unsigned_char,
+/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
+static swig_const_info swig_const_table[] = {
+{0, 0, 0, 0.0, 0, 0}};
+#ifdef __cplusplus
+#endif
+ * Type initialization:
+ * This problem is tough by the requirement that no dynamic
+ * memory is used. Also, since swig_type_info structures store pointers to
+ * swig_cast_info structures and swig_cast_info structures store pointers back
+ * to swig_type_info structures, we need some lookup code at initialization.
+ * The idea is that swig generates all the structures that are needed.
+ * The runtime then collects these partially filled structures.
+ * The SWIG_InitializeModule function takes these initial arrays out of
+ * swig_module, and does all the lookup, filling in the swig_module.types
+ * array with the correct data and linking the correct swig_cast_info
+ * structures together.
+ * The generated swig_type_info structures are assigned staticly to an initial
+ * array. We just loop through that array, and handle each type individually.
+ * First we lookup if this type has been already loaded, and if so, use the
+ * loaded structure instead of the generated one. Then we have to fill in the
+ * cast linked list. The cast data is initially stored in something like a
+ * two-dimensional array. Each row corresponds to a type (there are the same
+ * number of rows as there are in the swig_type_initial array). Each entry in
+ * a column is one of the swig_cast_info structures for that type.
+ * The cast_initial array is actually an array of arrays, because each row has
+ * a variable number of columns. So to actually build the cast linked list,
+ * we find the array of casts associated with the type, and loop through it
+ * adding the casts to the list. The one last trick we need to do is making
+ * sure the type pointer in the swig_cast_info struct is correct.
+ * First off, we lookup the cast->type name to see if it is already loaded.
+ * There are three cases to handle:
+ * 1) If the cast->type has already been loaded AND the type we are adding
+ * casting info to has not been loaded (it is in this module), THEN we
+ * replace the cast->type pointer with the type pointer that has already
+ * been loaded.
+ * 2) If BOTH types (the one we are adding casting info to, and the
+ * cast->type) are loaded, THEN the cast info has already been loaded by
+ * the previous module so we just ignore it.
+ * 3) Finally, if cast->type has not already been loaded, then we add that
+ * swig_cast_info to the linked list (because the cast->type) pointer will
+ * be correct.
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* c-mode */
+#endif
+#endif
+#if 0
+#define SWIGRUNTIME_DEBUG
+#endif
+SWIGRUNTIME void
+SWIG_InitializeModule(void *clientdata) {
+ size_t i;
+ swig_module_info *module_head, *iter;
+ int found, init;
+ clientdata = clientdata;
+ /* check to see if the circular list has been setup, if not, set it up */
+ if (swig_module.next==0) {
+ /* Initialize the swig_module */
+ swig_module.type_initial = swig_type_initial;
+ swig_module.cast_initial = swig_cast_initial;
+ swig_module.next = &swig_module;
+ init = 1;
+ } else {
+ init = 0;
+ /* Try and load any already created modules */
+ module_head = SWIG_GetModule(clientdata);
+ if (!module_head) {
+ /* This is the first module loaded for this interpreter */
+ /* so set the swig module into the interpreter */
+ SWIG_SetModule(clientdata, &swig_module);
+ module_head = &swig_module;
+ } else {
+ /* the interpreter has loaded a SWIG module, but has it loaded this one? */
+ found=0;
+ iter=module_head;
+ do {
+ if (iter==&swig_module) {
+ found=1;
+ break;
+ iter=iter->next;
+ } while (iter!= module_head);
+ /* if the is found in the list, then all is done and we may leave */
+ if (found) return;
+ /* otherwise we must add out module into the list */
+ swig_module.next = module_head->next;
+ module_head->next = &swig_module;
+ /* When multiple interpeters are used, a module could have already been initialized in
+ a different interpreter, but not yet have a pointer in this interpreter.
+ In this case, we do not want to continue adding types... everything should be
+ set up already */
+ if (init == 0) return;
+ /* Now work on filling in swig_module.types */
+#ifdef SWIGRUNTIME_DEBUG
+ printf("SWIG_InitializeModule: size %d\n", swig_module.size);
+#endif
+ for (i = 0; i < swig_module.size; ++i) {
+ swig_type_info *type = 0;
+ swig_type_info *ret;
+ swig_cast_info *cast;
+ printf("SWIG_InitializeModule: type %d %s\n", i, swig_module.type_initial[i]->name);
+#endif
+ /* if there is another module already loaded */
+ if (swig_module.next != &swig_module) {
+ type = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, swig_module.type_initial[i]->name);
+ if (type) {
+ /* Overwrite clientdata field */
+ printf("SWIG_InitializeModule: found type %s\n", type->name);
+#endif
+ if (swig_module.type_initial[i]->clientdata) {
+ type->clientdata = swig_module.type_initial[i]->clientdata;
+ printf("SWIG_InitializeModule: found and overwrite type %s \n", type->name);
+#endif
+ } else {
+ type = swig_module.type_initial[i];
+ /* Insert casting types */
+ cast = swig_module.cast_initial[i];
+ while (cast->type) {
+ /* Don't need to add information already in the list */
+ ret = 0;
+ printf("SWIG_InitializeModule: look cast %s\n", cast->type->name);
+#endif
+ ret = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, cast->type->name);
+ if (ret) printf("SWIG_InitializeModule: found cast %s\n", ret->name);
+#endif
+ if (ret) {
+ if (type == swig_module.type_initial[i]) {
+ printf("SWIG_InitializeModule: skip old type %s\n", ret->name);
+#endif
+ cast->type = ret;
+ ret = 0;
+ } else {
+ /* Check for casting already in the list */
+ swig_cast_info *ocast = SWIG_TypeCheck(ret->name, type);
+ if (ocast) printf("SWIG_InitializeModule: skip old cast %s\n", ret->name);
+#endif
+ if (!ocast) ret = 0;
+ if (!ret) {
+ printf("SWIG_InitializeModule: adding cast %s\n", cast->type->name);
+#endif
+ if (type->cast) {
+ type->cast->prev = cast;
+ cast->next = type->cast;
+ type->cast = cast;
+ cast++;
+ /* Set entry in modules->types array equal to the type */
+ swig_module.types[i] = type;
+ swig_module.types[i] = 0;
+ printf("**** SWIG_InitializeModule: Cast List ******\n");
+ int j = 0;
+ swig_cast_info *cast = swig_module.cast_initial[i];
+ printf("SWIG_InitializeModule: cast type %s\n", cast->type->name);
+ cast++;
+ ++j;
+ printf("---- Total casts: %d\n",j);
+#endif
+/* This function will propagate the clientdata field of type to
+* any new swig_type_info structures that have been added into the list
+* of equivalent types. It is like calling
+* SWIG_TypeClientData(type, clientdata) a second time.
+SWIGRUNTIME void
+SWIG_PropagateClientData(void) {
+ size_t i;
+ swig_cast_info *equiv;
+ static int init_run = 0;
+ if (init_run) return;
+ init_run = 1;
+ for (i = 0; i < swig_module.size; i++) {
+ if (swig_module.types[i]->clientdata) {
+ equiv = swig_module.types[i]->cast;
+ while (equiv) {
+ if (!equiv->converter) {
+ if (equiv->type && !equiv->type->clientdata)
+ SWIG_TypeClientData(equiv->type, swig_module.types[i]->clientdata);
+ equiv = equiv->next;
+#ifdef __cplusplus
+#if 0
+ /* c-mode */
+#endif
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+ /* Python-specific SWIG API */
+#define SWIG_newvarlink() SWIG_Python_newvarlink()
+#define SWIG_addvarlink(p, name, get_attr, set_attr) SWIG_Python_addvarlink(p, name, get_attr, set_attr)
+#define SWIG_InstallConstants(d, constants) SWIG_Python_InstallConstants(d, constants)
+ * global variable support code.
+ typedef struct swig_globalvar {
+ char *name; /* Name of global variable */
+ PyObject *(*get_attr)(void); /* Return the current value */
+ int (*set_attr)(PyObject *); /* Set the value */
+ struct swig_globalvar *next;
+ } swig_globalvar;
+ typedef struct swig_varlinkobject {
+ PyObject_HEAD
+ swig_globalvar *vars;
+ } swig_varlinkobject;
+ SWIGINTERN PyObject *
+ swig_varlink_repr(swig_varlinkobject *SWIGUNUSEDPARM(v)) {
+#if PY_VERSION_HEX >= 0x03000000
+ return PyUnicode_InternFromString("<Swig global variables>");
+#else
+ return PyString_FromString("<Swig global variables>");
+#endif
+ swig_varlink_str(swig_varlinkobject *v) {
+ PyObject *str = PyUnicode_InternFromString("(");
+ PyObject *tail;
+ PyObject *joined;
+ swig_globalvar *var;
+ for (var = v->vars; var; var=var->next) {
+ tail = PyUnicode_FromString(var->name);
+ joined = PyUnicode_Concat(str, tail);
+ Py_DecRef(str);
+ Py_DecRef(tail);
+ str = joined;
+ if (var->next) {
+ tail = PyUnicode_InternFromString(", ");
+ Py_DecRef(str);
+ Py_DecRef(tail);
+ str = joined;
+ tail = PyUnicode_InternFromString(")");
+ Py_DecRef(str);
+ Py_DecRef(tail);
+ str = joined;
+#else
+ PyObject *str = PyString_FromString("(");
+ PyString_ConcatAndDel(&str,PyString_FromString(var->name));
+ if (var->next) PyString_ConcatAndDel(&str,PyString_FromString(", "));
+ PyString_ConcatAndDel(&str,PyString_FromString(")"));
+#endif
+ return str;
+ SWIGINTERN int
+ swig_varlink_print(swig_varlinkobject *v, FILE *fp, int SWIGUNUSEDPARM(flags)) {
+ char *tmp;
+ PyObject *str = swig_varlink_str(v);
+ fprintf(fp,"Swig global variables ");
+ fprintf(fp,"%s\n", tmp = SWIG_Python_str_AsChar(str));
+ SWIG_Python_str_DelForPy3(tmp);
+ Py_DECREF(str);
+ return 0;
+ SWIGINTERN void
+ swig_varlink_dealloc(swig_varlinkobject *v) {
+ swig_globalvar *var = v->vars;
+ while (var) {
+ swig_globalvar *n = var->next;
+ free(var->name);
+ free(var);
+ var = n;
+ swig_varlink_getattr(swig_varlinkobject *v, char *n) {
+ PyObject *res = NULL;
+ while (var) {
+ if (strcmp(var->name,n) == 0) {
+ res = (*var->get_attr)();
+ break;
+ var = var->next;
+ if (res == NULL && !PyErr_Occurred()) {
+ PyErr_SetString(PyExc_NameError,"Unknown C global variable");
+ return res;
+ SWIGINTERN int
+ swig_varlink_setattr(swig_varlinkobject *v, char *n, PyObject *p) {
+ int res = 1;
+ while (var) {
+ res = (*var->set_attr)(p);
+ break;
+ var = var->next;
+ if (res == 1 && !PyErr_Occurred()) {
+ return res;
+ SWIGINTERN PyTypeObject*
+ swig_varlink_type(void) {
+ static char varlink__doc__[] = "Swig var link object";
+ static PyTypeObject varlink_type;
+ static int type_init = 0;
+ if (!type_init) {
+ const PyTypeObject tmp
+ /* PyObject header changed in Python 3 */
+ PyVarObject_HEAD_INIT(&PyType_Type, 0)
+#else
+ PyObject_HEAD_INIT(NULL)
+ 0, /* Number of items in variable part (ob_size) */
+#endif
+ (char *)"swigvarlink", /* Type name (tp_name) */
+ sizeof(swig_varlinkobject), /* Basic size (tp_basicsize) */
+ 0, /* Itemsize (tp_itemsize) */
+ (destructor) swig_varlink_dealloc, /* Deallocator (tp_dealloc) */
+ (printfunc) swig_varlink_print, /* Print (tp_print) */
+ (getattrfunc) swig_varlink_getattr, /* get attr (tp_getattr) */
+ (setattrfunc) swig_varlink_setattr, /* Set attr (tp_setattr) */
+ 0, /* tp_compare */
+ (reprfunc) swig_varlink_repr, /* tp_repr */
+ 0, /* tp_as_number */
+ 0, /* tp_as_sequence */
+ 0, /* tp_as_mapping */
+ 0, /* tp_hash */
+ 0, /* tp_call */
+ (reprfunc) swig_varlink_str, /* tp_str */
+ 0, /* tp_getattro */
+ 0, /* tp_setattro */
+ 0, /* tp_as_buffer */
+ 0, /* tp_flags */
+ varlink__doc__, /* tp_doc */
+ 0, /* tp_traverse */
+ 0, /* tp_clear */
+ 0, /* tp_richcompare */
+ 0, /* tp_weaklistoffset */
+#if PY_VERSION_HEX >= 0x02020000
+ 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, /* tp_iter -> tp_weaklist */
+#endif
+#if PY_VERSION_HEX >= 0x02030000
+ 0, /* tp_del */
+#endif
+#ifdef COUNT_ALLOCS
+ 0,0,0,0 /* tp_alloc -> tp_next */
+#endif
+ varlink_type = tmp;
+ /* for Python 3 we already assigned ob_type in PyVarObject_HEAD_INIT() */
+#if PY_VERSION_HEX < 0x03000000
+ varlink_type.ob_type = &PyType_Type;
+#endif
+ type_init = 1;
+ return &varlink_type;
+ /* Create a variable linking object for use later */
+ SWIG_Python_newvarlink(void) {
+ swig_varlinkobject *result = PyObject_NEW(swig_varlinkobject, swig_varlink_type());
+ if (result) {
+ result->vars = 0;
+ return ((PyObject*) result);
+ SWIGINTERN void
+ SWIG_Python_addvarlink(PyObject *p, char *name, PyObject *(*get_attr)(void), int (*set_attr)(PyObject *p)) {
+ swig_varlinkobject *v = (swig_varlinkobject *) p;
+ swig_globalvar *gv = (swig_globalvar *) malloc(sizeof(swig_globalvar));
+ if (gv) {
+ size_t size = strlen(name)+1;
+ gv->name = (char *)malloc(size);
+ if (gv->name) {
+ strncpy(gv->name,name,size);
+ gv->get_attr = get_attr;
+ gv->set_attr = set_attr;
+ gv->next = v->vars;
+ v->vars = gv;
+ SWIG_globals(void) {
+ static PyObject *_SWIG_globals = 0;
+ if (!_SWIG_globals) _SWIG_globals = SWIG_newvarlink();
+ return _SWIG_globals;
+ * constants/methods manipulation
+ /* Install Constants */
+ SWIGINTERN void
+ SWIG_Python_InstallConstants(PyObject *d, swig_const_info constants[]) {
+ PyObject *obj = 0;
+ size_t i;
+ for (i = 0; constants[i].type; ++i) {
+ switch(constants[i].type) {
+ case SWIG_PY_POINTER:
+ obj = SWIG_NewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
+ break;
+ case SWIG_PY_BINARY:
+ obj = SWIG_NewPackedObj(constants[i].pvalue, constants[i].lvalue, *(constants[i].ptype));
+ break;
+ default:
+ obj = 0;
+ break;
+ if (obj) {
+ PyDict_SetItemString(d, constants[i].name, obj);
+ Py_DECREF(obj);
+ /* Fix SwigMethods to carry the callback ptrs when needed */
+ SWIGINTERN void
+ SWIG_Python_FixMethods(PyMethodDef *methods,
+ swig_const_info *const_table,
+ swig_type_info **types,
+ swig_type_info **types_initial) {
+ size_t i;
+ for (i = 0; methods[i].ml_name; ++i) {
+ const char *c = methods[i].ml_doc;
+ if (c && (c = strstr(c, "swig_ptr: "))) {
+ int j;
+ swig_const_info *ci = 0;
+ const char *name = c + 10;
+ for (j = 0; const_table[j].type; ++j) {
+ if (strncmp(const_table[j].name, name,
+ strlen(const_table[j].name)) == 0) {
+ ci = &(const_table[j]);
+ break;
+ if (ci) {
+ size_t shift = (ci->ptype) - types;
+ swig_type_info *ty = types_initial[shift];
+ size_t ldoc = (c - methods[i].ml_doc);
+ size_t lptr = strlen(ty->name)+2*sizeof(void*)+2;
+ char *ndoc = (char*)malloc(ldoc + lptr + 10);
+ if (ndoc) {
+ char *buff = ndoc;
+ void *ptr = (ci->type == SWIG_PY_POINTER) ? ci->pvalue : 0;
+ if (ptr) {
+ strncpy(buff, methods[i].ml_doc, ldoc);
+ buff += ldoc;
+ strncpy(buff, "swig_ptr: ", 10);
+ buff += 10;
+ SWIG_PackVoidPtr(buff, ptr, ty->name, lptr);
+ methods[i].ml_doc = ndoc;
+#ifdef __cplusplus
+#endif
+ * Partial Init method
+#ifdef __cplusplus
+extern "C"
+#endif
+SWIGEXPORT
+PyObject*
+#else
+void
+#endif
+SWIG_init(void) {
+ PyObject *m, *d;
+ static struct PyModuleDef SWIG_module = {
+ PyModuleDef_HEAD_INIT,
+ (char *) SWIG_name,
+ NULL,
+ -1,
+ SwigMethods,
+ NULL,
+ NULL,
+ NULL,
+ NULL
+#endif
+ SWIG_Python_FixMethods(SwigMethods, swig_const_table, swig_types, swig_type_initial);
+ m = PyModule_Create(&SWIG_module);
+#else
+ m = Py_InitModule((char *) SWIG_name, SwigMethods);
+#endif
+ d = PyModule_GetDict(m);
+ SWIG_InitializeModule(0);
+ SWIG_InstallConstants(d,swig_const_table);
+ SWIG_Python_SetConstant(d, "GEOS_VERSION_MAJOR",SWIG_From_int(static_cast< int >(3)));
+ SWIG_Python_SetConstant(d, "GEOS_VERSION_MINOR",SWIG_From_int(static_cast< int >(3)));
+ SWIG_Python_SetConstant(d, "GEOS_VERSION",SWIG_FromCharPtr("3.3.4dev"));
+ SWIG_Python_SetConstant(d, "GEOS_JTS_PORT",SWIG_FromCharPtr("1.12.0"));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MAJOR",SWIG_From_int(static_cast< int >(1)));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MINOR",SWIG_From_int(static_cast< int >(7)));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_PATCH",SWIG_From_int(static_cast< int >(3)));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_FIRST_INTERFACE",SWIG_From_int(static_cast< int >(1)));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_LAST_INTERFACE",SWIG_From_int(static_cast< int >((1+7))));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION",SWIG_FromCharPtr("3.3.4dev-CAPI-1.7.3"));
+ SWIG_Python_SetConstant(d, "GEOS_POINT",SWIG_From_int(static_cast< int >(GEOS_POINT)));
+ SWIG_Python_SetConstant(d, "GEOS_LINESTRING",SWIG_From_int(static_cast< int >(GEOS_LINESTRING)));
+ SWIG_Python_SetConstant(d, "GEOS_LINEARRING",SWIG_From_int(static_cast< int >(GEOS_LINEARRING)));
+ SWIG_Python_SetConstant(d, "GEOS_POLYGON",SWIG_From_int(static_cast< int >(GEOS_POLYGON)));
+ SWIG_Python_SetConstant(d, "GEOS_MULTIPOINT",SWIG_From_int(static_cast< int >(GEOS_MULTIPOINT)));
+ SWIG_Python_SetConstant(d, "GEOS_MULTILINESTRING",SWIG_From_int(static_cast< int >(GEOS_MULTILINESTRING)));
+ SWIG_Python_SetConstant(d, "GEOS_MULTIPOLYGON",SWIG_From_int(static_cast< int >(GEOS_MULTIPOLYGON)));
+ SWIG_Python_SetConstant(d, "GEOS_GEOMETRYCOLLECTION",SWIG_From_int(static_cast< int >(GEOS_GEOMETRYCOLLECTION)));
+ SWIG_Python_SetConstant(d, "GEOS_WKB_XDR",SWIG_From_int(static_cast< int >(GEOS_WKB_XDR)));
+ SWIG_Python_SetConstant(d, "GEOS_WKB_NDR",SWIG_From_int(static_cast< int >(GEOS_WKB_NDR)));
+ initGEOS(noticeHandler, errorHandler);
+ return m;
+#else
+ return;
+#endif
More information about the geos-commits
