[geos-commits] r3603 - in trunk: include/geos/geom src/geom
svn_geos at osgeo.org
Fri Apr 6 15:03:02 EDT 2012
Author: strk
Date: 2012-04-06 12:03:02 -0700 (Fri, 06 Apr 2012)
New Revision: 3603
trunk/include/geos/geom/CoordinateArraySequence.h
trunk/include/geos/geom/CoordinateArraySequenceFactory.h
trunk/include/geos/geom/CoordinateArraySequenceFactory.inl
trunk/include/geos/geom/CoordinateSequenceFactory.h
trunk/src/geom/CoordinateArraySequence.cpp
trunk/src/geom/CoordinateArraySequenceFactory.cpp
trunk/src/geom/CoordinateSequenceFactory.cpp
Add CoordinateSequence deep copy trhough CoordinateSequenceFactory
Modified: trunk/include/geos/geom/CoordinateArraySequence.h
--- trunk/include/geos/geom/CoordinateArraySequence.h 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/include/geos/geom/CoordinateArraySequence.h 2012-04-06 19:03:02 UTC (rev 3603)
@@ -37,8 +37,10 @@
class GEOS_DLL CoordinateArraySequence : public CoordinateSequence {
public:
- CoordinateArraySequence(const CoordinateArraySequence &cl);
+ CoordinateArraySequence(const CoordinateArraySequence &cl);
+ CoordinateArraySequence(const CoordinateSequence &cl);
CoordinateSequence *clone() const;
//const Coordinate& getCoordinate(int pos) const;
Modified: trunk/include/geos/geom/CoordinateArraySequenceFactory.h
--- trunk/include/geos/geom/CoordinateArraySequenceFactory.h 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/include/geos/geom/CoordinateArraySequenceFactory.h 2012-04-06 19:03:02 UTC (rev 3603)
@@ -55,6 +55,8 @@
/** @see CoordinateSequenceFactory::create(std::size_t, int) */
CoordinateSequence *create(std::size_t size, std::size_t dimension=0) const;
+ CoordinateSequence *create(const CoordinateSequence &coordSeq) const;
/** \brief
* Returns the singleton instance of CoordinateArraySequenceFactory
@@ -72,19 +74,3 @@
#endif
#endif // ndef GEOS_GEOM_COORDINATEARRAYSEQUENCEFACTORY_H
- * $Log$
- * Revision 1.4 2006/06/12 11:29:23 strk
- * unsigned int => size_t
- * Revision 1.3 2006/06/12 10:10:39 strk
- * Fixed getGeometryN() to take size_t rather then int, changed unsigned int parameters to size_t.
- * Revision 1.2 2006/03/24 09:52:41 strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.1 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
Modified: trunk/include/geos/geom/CoordinateArraySequenceFactory.inl
--- trunk/include/geos/geom/CoordinateArraySequenceFactory.inl 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/include/geos/geom/CoordinateArraySequenceFactory.inl 2012-04-06 19:03:02 UTC (rev 3603)
@@ -42,7 +42,14 @@
return new CoordinateArraySequence(size,dimension);
+INLINE CoordinateSequence *
+CoordinateArraySequenceFactory::create(const CoordinateSequence& seq)
+ const
+ return new CoordinateArraySequence(seq);
} // namespace geos::geom
} // namespace geos
Modified: trunk/include/geos/geom/CoordinateSequenceFactory.h
--- trunk/include/geos/geom/CoordinateSequenceFactory.h 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/include/geos/geom/CoordinateSequenceFactory.h 2012-04-06 19:03:02 UTC (rev 3603)
@@ -12,7 +12,7 @@
- * Last port: geom/CoordinateSequenceFactory.java rev 1.14 (JTS-1.10)
+ * Last port: geom/CoordinateSequenceFactory.java r591 (JTS-1.12)
@@ -79,6 +79,15 @@
virtual CoordinateSequence *create(std::size_t size,
std::size_t dimension) const=0;
+ /** \brief
+ * Creates a CoordinateSequence which is a copy of the given one.
+ * This method must handle null arguments by creating an empty sequence.
+ * @param coordSeq the coordinate sequence to copy
+ virtual CoordinateSequence *create(const CoordinateSequence &coordSeq) const=0;
virtual ~CoordinateSequenceFactory();
@@ -90,19 +99,3 @@
//#endif
#endif // ndef GEOS_GEOM_COORDINATESEQUENCEFACTORY_H
- * $Log$
- * Revision 1.4 2006/06/12 10:10:39 strk
- * Revision 1.3 2006/06/08 11:20:24 strk
- * Added missing virtual destructor to abstract classes.
Modified: trunk/src/geom/CoordinateArraySequence.cpp
--- trunk/src/geom/CoordinateArraySequence.cpp 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/src/geom/CoordinateArraySequence.cpp 2012-04-06 19:03:02 UTC (rev 3603)
@@ -59,6 +59,18 @@
+CoordinateArraySequence::CoordinateArraySequence(
+ const CoordinateSequence &c )
+ CoordinateSequence(c),
+ vect(new vector<Coordinate>(c.size())),
+ dimension(c.getDimension())
+ for (size_t i = 0, n = vect->size(); i < n; ++i) {
+ (*vect)[i] = c.getAt(i);
CoordinateArraySequence::clone() const
Modified: trunk/src/geom/CoordinateArraySequenceFactory.cpp
--- trunk/src/geom/CoordinateArraySequenceFactory.cpp 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/src/geom/CoordinateArraySequenceFactory.cpp 2012-04-06 19:03:02 UTC (rev 3603)
@@ -34,34 +34,3 @@
} // namespace geos
- * $Log$
- * Revision 1.3 2006/03/24 09:52:41 strk
- * Revision 1.2 2006/03/09 16:46:47 strk
- * Revision 1.1 2006/01/31 19:07:33 strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- * from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- * then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- * Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- * memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
Modified: trunk/src/geom/CoordinateSequenceFactory.cpp
--- trunk/src/geom/CoordinateSequenceFactory.cpp 2012-04-05 17:07:37 UTC (rev 3602)
+++ trunk/src/geom/CoordinateSequenceFactory.cpp 2012-04-06 19:03:02 UTC (rev 3603)
@@ -12,7 +12,7 @@
More information about the geos-commits
