[geos-commits] r3571 - branches/3.2/source/algorithm
svn_geos at osgeo.org
Thu Feb 16 13:19:33 EST 2012
Author: pramsey
Date: 2012-02-16 10:19:32 -0800 (Thu, 16 Feb 2012)
New Revision: 3571
branches/3.2/source/algorithm/RobustDeterminant.cpp
Update provenance for Olivier Devillers.
Modified: branches/3.2/source/algorithm/RobustDeterminant.cpp
--- branches/3.2/source/algorithm/RobustDeterminant.cpp 2012-02-16 18:19:24 UTC (rev 3570)
+++ branches/3.2/source/algorithm/RobustDeterminant.cpp 2012-02-16 18:19:32 UTC (rev 3571)
@@ -4,9 +4,9 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (c) Olivier Devillers <Olivier.Devillers at sophia.inria.fr>
+ * Copyright (c) 1995 Olivier Devillers <Olivier.Devillers at sophia.inria.fr>
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
* Copyright (C) 2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
@@ -15,6 +15,21 @@
+ * RobustDeterminant implements an algorithm to compute the
+ * sign of a 2x2 determinant for double precision values robustly.
+ * It is a direct translation of code developed by Olivier Devillers.
+ * The original code carries the following copyright notice:
+ * Author : Olivier Devillers
+ * Olivier.Devillers at sophia.inria.fr
+ * http:/www.inria.fr:/prisme/personnel/devillers/anglais/determinant.html
+ * Olivier Devillers has allowed the code to be distributed under
+ * the LGPL (2012-02-16) saying "It is ok for LGPL distribution."
* Last port: algorithm/RobustDeterminant.java 1.15 (JTS-1.10)
More information about the geos-commits
