[geos-commits] r3557 - branches/3.3
svn_geos at osgeo.org
Thu Jan 5 12:00:00 EST 2012
Author: strk
Date: 2012-01-05 09:00:00 -0800 (Thu, 05 Jan 2012)
New Revision: 3557
branches/3.3/ChangeLog
Update ChangeLog for the 3.3.2 release
Modified: branches/3.3/ChangeLog
--- branches/3.3/ChangeLog 2012-01-05 16:56:56 UTC (rev 3556)
+++ branches/3.3/ChangeLog 2012-01-05 17:00:00 UTC (rev 3557)
@@ -1,3 +1,194 @@
+2012-01-05 16:56 Sandro Santilli <strk at keybit.net>
+ * [r3556] NEWS, configure.in: Prepare for 3.3.2 release
+2011-12-16 14:12 Sandro Santilli <strk at keybit.net>
+ * [r3554] src/operation/overlay/snap/LineStringSnapper.cpp: Make
+ debugging output of LineStringSnapper more readable
+2011-12-15 14:18 Sandro Santilli <strk at keybit.net>
+ * [r3552] NEWS, include/geos/geom/BinaryOp.h,
+ tests/xmltester/Makefile.am,
+ tests/xmltester/tests/ticket/bug488.xml: Check validity after
+ snapping in BinaryOp. Fixes bug #488
+ Adds regression test. This is a GEOS-only approach.
+2011-12-15 11:35 Sandro Santilli <strk at keybit.net>
+ * [r3551] include/geos/operation/overlay/OverlayOp.h: indent
+2011-12-15 10:58 Sandro Santilli <strk at keybit.net>
+ * [r3549] include/geos/geom/BinaryOp.h: Fix build with
+ CBR_BEFORE_SNAPPING undefined
+2011-12-12 15:11 Howard Butler <hobu.inc at gmail.com>
+ * [r3547] NEWS: a note about #500 fix
+2011-12-12 15:04 Howard Butler <hobu.inc at gmail.com>
+ * [r3545] src/operation/overlay/OverlayNodeFactory.cpp: apply patch
+ for #500 to fix clang's complaint about a missing default
+ initialization
+2011-12-12 10:09 Sandro Santilli <strk at keybit.net>
+ * [r3543] NEWS, src/algorithm/CGAlgorithms.cpp: Apply Shoelace
+ formula for area calculation (#485)
+2011-12-12 09:57 Sandro Santilli <strk at keybit.net>
+ * [r3541] NEWS, macros/geos.m4, tools/geos-config.in: Add --clibs
+ to geos-config and GEOS_C_LIBS to geos.m4 (#497)
+2011-12-09 10:46 Sandro Santilli <strk at keybit.net>
+ * [r3539] NEWS: typo
+2011-12-09 10:44 Sandro Santilli <strk at keybit.net>
+ * [r3538] NEWS, include/geos/geom/Geometry.h,
+ include/geos/operation/overlay/snap/GeometrySnapper.h,
+ include/geos/operation/overlay/snap/SnapOverlayOp.h,
+ src/operation/overlay/snap/GeometrySnapper.cpp,
+ src/operation/overlay/snap/SnapOverlayOp.cpp: Fix C++11 build by
+ avoiding std::pair<auto_ptr> (#491)
+2011-12-09 10:12 Sandro Santilli <strk at keybit.net>
+ * [r3537] NEWS, src/operation/buffer/BufferOp.cpp,
+ tests/unit/operation/buffer/BufferOpTest.cpp,
+ tests/xmltester/tests/safe/TestBufferJagged.xml,
+ tests/xmltester/tests/safe/buffer-1.01.xml: Improve buffer
+ robustness by reverting to non snaprounding noder
+ This commit fixes all cases reported in
+ http://trac.osgeo.org/geos/wiki/BufferRobustness
+ They include #495 and #494
+2011-12-09 08:47 Sandro Santilli <strk at keybit.net>
+ * [r3533] tests/xmltester/tests/general/TestUnaryUnionFloating.xml:
+ Oops, forgot this one in previous commit
+2011-12-09 08:46 Sandro Santilli <strk at keybit.net>
+ * [r3532] NEWS,
+ include/geos/operation/union/CascadedPolygonUnion.h,
+ src/operation/union/CascadedPolygonUnion.cpp,
+ tests/xmltester/tests/general/TestUnaryUnion.xml: Fix
+ CascadedPolygonUnion to discard non-polygonal components created
+ during unioning
+ This is to avoid failures and provide more desirable behaviour.
+ Includes automated testing. Closes ticket #499.
+ * [r3531] tests/xmltester/XMLTester.cpp: Allow XML tests not to
+ specify a precision model, defaulting to floating
+ This allows running some JTS tests w/out touching them
+2011-12-06 17:26 Sandro Santilli <strk at keybit.net>
+ * [r3527] NEWS, include/geos/noding/snapround/HotPixel.h,
+ src/noding/snapround/HotPixel.cpp, tests/unit/Makefile.am,
+ tests/unit/noding/snapround,
+ tests/unit/noding/snapround/HotPixelTest.cpp: HotPixel: do not
+ invalidate reference to original point. Fixes #498.
+2011-12-02 09:44 Sandro Santilli <strk at keybit.net>
+ * [r3526] tests/xmltester/tests/safe/buffer-1.01.xml: Add
+ <resultMatcher> tag to make the test runnable with JTS
+2011-11-30 09:49 Sandro Santilli <strk at keybit.net>
+ * [r3524] NEWS, include/geos/noding/snapround/MCIndexSnapRounder.h,
+ src/noding/snapround/MCIndexSnapRounder.cpp,
+ tests/unit/operation/buffer/BufferOpTest.cpp: Fix
+ MCIndexSnapRounder use of provided precision model.
+ Fixes bug #473 (RightmostEdgeFinder assertion failure).
+ Includes regression test.
+2011-11-29 14:01 Sandro Santilli <strk at keybit.net>
+ * [r3521] NEWS, src/geom/Coordinate.cpp: Use 18 significant digits
+ for TopologyException point coordinates
+2011-11-28 08:40 Sandro Santilli <strk at keybit.net>
+ * [r3519] NEWS, src/operation/buffer/BufferBuilder.cpp,
+ tests/xmltester/tests/safe/buffer-1.01.xml: BufferBuilder: fix
+ handling of collapsed edges skipping. Fixes #494.
+ Includes regression test, provided by SAFE.
+2011-11-04 20:52 Sandro Santilli <strk at keybit.net>
+ * [r3516] tests/unit/capi/GEOSisValidDetailTest.cpp: Allow any case
+ in NaN for testcase purposes (#486)
+2011-11-04 17:45 Sandro Santilli <strk at keybit.net>
+ * [r3513] NEWS, src/operation/union/UnaryUnionOp.cpp,
+ tests/unit/operation/union/UnaryUnionOpTest.cpp,
+ tests/xmltester/tests/general/TestUnaryUnion.xml: Fix noding of
+ self-intersecting lines through UnaryUnion (#482)
+ Includes updated tests from JTS
+2011-11-04 15:00 Sandro Santilli <strk at keybit.net>
+ * [r3512] src/index/sweepline/SweepLineIndex.cpp: Fix
+ initialization order
+2011-10-26 16:08 Sandro Santilli <strk at keybit.net>
+ * [r3507] tests/unit/Makefile.am,
+ tests/unit/operation/buffer/BufferParametersTest.cpp: Add test
+ for BufferParameters class
+2011-10-26 14:29 Sandro Santilli <strk at keybit.net>
+ * [r3506] NEWS: Add changes introduced by last commit
+2011-10-19 00:47 Mateusz Loskot <mateusz at loskot.net>
+ * [r3503] CMakeLists.txt: ported from trunk: Fixed CMAKE_CXX_FLAGS
+ overridind -std=gnu++0x (#489)
+2011-10-18 22:08 Mateusz Loskot <mateusz at loskot.net>
+ * [r3500] CMakeLists.txt: Missing versions update in CMake
+ configuration (#490)
+2011-10-04 16:18 Sandro Santilli <strk at keybit.net>
+ * [r3496] NEWS: Add missing CAPI additions of 3.3.0 to NEWS file
+2011-09-27 16:02 Sandro Santilli <strk at keybit.net>
+ * [r3490] NEWS: Prepare slot for 3.3.2 news
+2011-09-27 15:41 Sandro Santilli <strk at keybit.net>
+ * [r3489] configure.in: Bump versions up for next (3.3.2) release
+2011-09-27 15:34 Sandro Santilli <strk at keybit.net>
+ * [r3487] ChangeLog, NEWS, configure.in: Set version to 3.3.1
+ final, update ChangeLog and set release date in NEWS
2011-09-27 12:41 Sandro Santilli <strk at keybit.net>
* [r3486] NEWS: Merge items
More information about the geos-commits
