[geos-commits] r3678 - in branches/3.3: . capi tests/unit/capi
svn_geos at osgeo.org
Fri Jun 22 08:31:50 PDT 2012
Author: strk
Date: 2012-06-22 08:31:49 -0700 (Fri, 22 Jun 2012)
New Revision: 3678
branches/3.3/NEWS
branches/3.3/capi/geos_ts_c.cpp
branches/3.3/tests/unit/capi/GEOSGetCentroidTest.cpp
Always return POINT from GEOSGetCentroid, even for EMPTY (#560)
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2012-06-22 15:03:33 UTC (rev 3677)
+++ branches/3.3/NEWS 2012-06-22 15:31:49 UTC (rev 3678)
@@ -4,6 +4,7 @@
- Bug fixes / improvements
- Correctly increment CAPI lib version from 3.3.3 (#558)
- Port robustness fix to CentroidArea (#559)
+ - Always return POINT from GEOSGetCentroid, even for EMPTY (#560)
Changes in 3.3.4
2012-05-31
Modified: branches/3.3/capi/geos_ts_c.cpp
--- branches/3.3/capi/geos_ts_c.cpp 2012-06-22 15:03:33 UTC (rev 3677)
+++ branches/3.3/capi/geos_ts_c.cpp 2012-06-22 15:31:49 UTC (rev 3678)
@@ -2763,7 +2763,7 @@
if (0 == ret)
const GeometryFactory *gf = handle->geomFactory;
- return gf->createGeometryCollection();
+ return gf->createPoint();
return ret;
Modified: branches/3.3/tests/unit/capi/GEOSGetCentroidTest.cpp
--- branches/3.3/tests/unit/capi/GEOSGetCentroidTest.cpp 2012-06-22 15:03:33 UTC (rev 3677)
+++ branches/3.3/tests/unit/capi/GEOSGetCentroidTest.cpp 2012-06-22 15:31:49 UTC (rev 3678)
@@ -151,5 +151,24 @@
+ // Empty geometry -- see http://trac.osgeo.org/geos/ticket/560
+ template<>
+ template<>
+ void object::test<5>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING EMPTY");
+ ensure( 0 != geom1_ );
+ geom2_ = GEOSGetCentroid(geom1_);
+ ensure( 0 != geom2_ );
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ ensure_equals(std::string(wkt_), std::string( "POINT EMPTY"));
} // namespace tut
More information about the geos-commits
