[geos-commits] r3691 - trunk
svn_geos at osgeo.org
Mon Jun 25 08:17:16 PDT 2012
Author: strk
Date: 2012-06-25 08:17:15 -0700 (Mon, 25 Jun 2012)
New Revision: 3691
trunk/HOWTO_RELEASE
Add tarball verification step
Modified: trunk/HOWTO_RELEASE
--- trunk/HOWTO_RELEASE 2012-06-25 15:15:17 UTC (rev 3690)
+++ trunk/HOWTO_RELEASE 2012-06-25 15:17:15 UTC (rev 3691)
@@ -15,22 +15,24 @@
$base/trunk $base/tags/MAJOR.MINOR.PATCH
7: Export the tag and 'make dist-bzip2'.
- $ svn export http://svn.osgeo.org/geos/tags/MAJOR.MINOR.PATCH
- $ cd MAJOR.MINOR.PATCH
+ $ svn export $base/tags/$rev
+ $ cd $rev
$ ./autogen.sh && ./configure && make dist-bzip2
-8: Copy the tarball to upload.osgeo.org:/osgeo/download/geos
+8: Verify that you can unpack and build the tarball
-9: Increment all the version numbers for the next release, as below.
+9: Copy the tarball to upload.osgeo.org:/osgeo/download/geos
-10: Increment CAPI_INTERFACE_X in configure.in
+10: Increment all the version numbers for the next release, as below.
+11: Increment CAPI_INTERFACE_X in configure.in
- For a release with no interface changes just bump REVISION.
[ Even if *nothing* changed in CAPI ]
- Adding interfaces, bump CURRENT/AGE, set REVISION to 0.
- Deleting interfaces / compatibility issues - bump CURRENT, others to zero
[ THIS MUST BE CAREFULLY AVOIDED ]
-11: Increment release version:
+12: Increment release version:
- In configure.in
- In include/geos/version.h.vc
- In capi/geos_c.h.in
More information about the geos-commits
