[geos-commits] r3697 - trunk
svn_geos at osgeo.org
Tue Jun 26 13:41:26 PDT 2012
Author: mloskot
Date: 2012-06-26 13:41:23 -0700 (Tue, 26 Jun 2012)
New Revision: 3697
trunk/CMakeLists.txt
[CMake] Corrected description of default value for GEOS_ENABLE_MACOSX_FRAMEWORK option
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2012-06-26 20:34:10 UTC (rev 3696)
+++ trunk/CMakeLists.txt 2012-06-26 20:41:23 UTC (rev 3697)
@@ -73,7 +73,7 @@
if(APPLE)
option(GEOS_ENABLE_MACOSX_FRAMEWORK
- "Set to OFF|ON (default) to build GEOS as a Mac OS X framework" OFF)
+ "Set to ON|OFF (default) to build GEOS as a Mac OS X framework" OFF)
option(GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT
"Set to ON|OFF (default) to add Unix compatibility to the Mac OS X framework" OFF)
endif()
More information about the geos-commits
