[geos-commits] r3575 - in trunk: src/simplify tests/unit/simplify
svn_geos at osgeo.org
Thu Mar 22 04:39:12 EDT 2012
Author: strk
Date: 2012-03-22 01:39:12 -0700 (Thu, 22 Mar 2012)
New Revision: 3575
trunk/src/simplify/TaggedLineString.cpp
trunk/src/simplify/TaggedLineStringSimplifier.cpp
trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
Fix simplification of collections with empty items (#519)
Modified: trunk/src/simplify/TaggedLineString.cpp
--- trunk/src/simplify/TaggedLineString.cpp 2012-03-22 08:34:59 UTC (rev 3574)
+++ trunk/src/simplify/TaggedLineString.cpp 2012-03-22 08:39:12 UTC (rev 3575)
@@ -78,16 +78,21 @@
<< endl;
#endif
- segs.reserve(pts->size()-1);
- for (std::size_t i=0, n=pts->size()-1; i<n; i++)
+ if ( pts->size() )
- TaggedLineSegment* seg = new TaggedLineSegment(
- pts->getAt(i),
- pts->getAt(i+1),
- parentLine, i);
- segs.push_back(seg);
+ segs.reserve(pts->size()-1);
+ for (std::size_t i=0, n=pts->size()-1; i<n; i++)
+ TaggedLineSegment* seg = new TaggedLineSegment(
+ pts->getAt(i),
+ pts->getAt(i+1),
+ parentLine, i);
+ segs.push_back(seg);
#if GEOS_DEBUG
@@ -156,18 +161,18 @@
std::size_t i=0, size=segs.size();
- assert(size);
+ if ( size ) {
+ for (; i<size; i++)
+ TaggedLineSegment* seg = segs[i];
+ assert(seg);
+ pts->push_back(seg->p0);
- for (; i<size; i++)
- TaggedLineSegment* seg = segs[i];
- assert(seg);
- pts->push_back(seg->p0);
+ // add last point
+ pts->push_back(segs[size-1]->p1);
- // add last point
- pts->push_back(segs[size-1]->p1);
return pts;
Modified: trunk/src/simplify/TaggedLineStringSimplifier.cpp
--- trunk/src/simplify/TaggedLineStringSimplifier.cpp 2012-03-22 08:34:59 UTC (rev 3574)
+++ trunk/src/simplify/TaggedLineStringSimplifier.cpp 2012-03-22 08:39:12 UTC (rev 3575)
@@ -75,6 +75,7 @@
<< std::endl;
#endif
+ if ( ! linePts->size() ) return;
simplifySection(0, linePts->size() - 1, 0);
Modified: trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
--- trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp 2012-03-22 08:34:59 UTC (rev 3574)
+++ trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp 2012-03-22 08:39:12 UTC (rev 3575)
@@ -5,6 +5,7 @@
#include <utility.h>
// geos
#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
@@ -28,12 +29,15 @@
geos::geom::PrecisionModel pm;
geos::geom::GeometryFactory gf;
geos::io::WKTReader wktreader;
+ geos::io::WKTWriter wktwriter;
typedef geos::geom::Geometry::AutoPtr GeomPtr;
test_tpsimp_data()
- : pm(1.0), gf(&pm), wktreader(&gf)
+ : pm(1.0), gf(&pm), wktreader(&gf), wktwriter()
+ //wktwriter.setTrim(1);
typedef test_group<test_tpsimp_data> group;
@@ -207,5 +211,22 @@
ensure( "Simplified geometry is invalid!", simplified->isValid() );
ensure_equals_geometry(g.get(), simplified.get() );
+ // GeometryCollection with empty elements
+ // See http://trac.osgeo.org/geos/ticket/519
+ template<>
+ template<>
+ void object::test<11>()
+ std::string wkt("GEOMETRYCOLLECTION ( \
+ LINESTRING (0 0, 10 0), POLYGON EMPTY)");
+ GeomPtr g(wktreader.read(wkt));
+ GeomPtr simp= TopologyPreservingSimplifier::simplify(g.get(), 1);
+ ensure( "Simplified geometry is invalid!", simp->isValid() );
+ ensure_equals(wktwriter.write(simp.get()),
+ "GEOMETRYCOLLECTION (LINESTRING (0 0, 10 0))");
} // namespace tut
More information about the geos-commits
