[geos-commits] r3709 - branches/3.3/swig/python
svn_geos at osgeo.org
Fri Sep 7 04:26:29 PDT 2012
Author: strk
Date: 2012-09-07 04:26:28 -0700 (Fri, 07 Sep 2012)
New Revision: 3709
branches/3.3/swig/python/geos.py
branches/3.3/swig/python/geos_wrap.cxx
Regenerate swig files with swig 2.0.4
Modified: branches/3.3/swig/python/geos.py
--- branches/3.3/swig/python/geos.py 2012-09-06 18:22:53 UTC (rev 3708)
+++ branches/3.3/swig/python/geos.py 2012-09-07 11:26:28 UTC (rev 3709)
@@ -1,9 +1,11 @@
# This file was automatically generated by SWIG (http://www.swig.org).
-# Version 1.3.40
+# Version 2.0.4
# Do not make changes to this file unless you know what you are doing--modify
# the SWIG interface file instead.
from sys import version_info
if version_info >= (2,6,0):
def swig_import_helper():
@@ -38,7 +40,7 @@
return
method = class_type.__swig_setmethods__.get(name,None)
if method: return method(self,value)
- if (not static) or hasattr(self,name):
+ if (not static):
self.__dict__[name] = value
else:
raise AttributeError("You cannot add attributes to %s" % self)
@@ -103,7 +105,6 @@
GEOS_VERSION_MAJOR = _geos.GEOS_VERSION_MAJOR
GEOS_VERSION_MINOR = _geos.GEOS_VERSION_MINOR
-GEOS_VERSION_PATCH = _geos.GEOS_VERSION_PATCH
GEOS_VERSION = _geos.GEOS_VERSION
GEOS_JTS_PORT = _geos.GEOS_JTS_PORT
GEOS_CAPI_VERSION_MAJOR = _geos.GEOS_CAPI_VERSION_MAJOR
Modified: branches/3.3/swig/python/geos_wrap.cxx
--- branches/3.3/swig/python/geos_wrap.cxx 2012-09-06 18:22:53 UTC (rev 3708)
+++ branches/3.3/swig/python/geos_wrap.cxx 2012-09-07 11:26:28 UTC (rev 3709)
@@ -1,6 +1,6 @@
* This file was automatically generated by SWIG (http://www.swig.org).
- * Version 1.3.40
+ * Version 2.0.4
* This file is not intended to be easily readable and contains a number of
* coding conventions designed to improve portability and efficiency. Do not make
@@ -201,7 +201,7 @@
Flags/methods for returning states.
- The SWIG conversion methods, as ConvertPtr, return and integer
+ The SWIG conversion methods, as ConvertPtr, return an integer
that tells if the conversion was successful or not. And if not,
an error code can be returned (see swigerrors.swg for the codes).
@@ -756,7 +756,15 @@
#define PyInt_Check(x) PyLong_Check(x)
#define PyInt_AsLong(x) PyLong_AsLong(x)
#define PyInt_FromLong(x) PyLong_FromLong(x)
+#define PyString_Check(name) PyBytes_Check(name)
+#define PyString_FromString(x) PyUnicode_FromString(x)
#define PyString_Format(fmt, args) PyUnicode_Format(fmt, args)
+#define PyString_AsString(str) PyBytes_AsString(str)
+#define PyString_Size(str) PyBytes_Size(str)
+#define PyString_InternFromString(key) PyUnicode_InternFromString(key)
+#define Py_TPFLAGS_HAVE_CLASS Py_TPFLAGS_BASETYPE
+#define PyString_AS_STRING(x) PyUnicode_AS_STRING(x)
+#define _PyLong_FromSsize_t(x) PyLong_FromSsize_t(x)
#endif
@@ -896,8 +904,65 @@
typedef int Py_ssize_t;
# define PY_SSIZE_T_MAX INT_MAX
# define PY_SSIZE_T_MIN INT_MIN
+typedef inquiry lenfunc;
+typedef intargfunc ssizeargfunc;
+typedef intintargfunc ssizessizeargfunc;
+typedef intobjargproc ssizeobjargproc;
+typedef intintobjargproc ssizessizeobjargproc;
+typedef getreadbufferproc readbufferproc;
+typedef getwritebufferproc writebufferproc;
+typedef getsegcountproc segcountproc;
+typedef getcharbufferproc charbufferproc;
+static long PyNumber_AsSsize_t (PyObject *x, void *SWIGUNUSEDPARM(exc))
+ long result = 0;
+ PyObject *i = PyNumber_Int(x);
+ if (i) {
+ result = PyInt_AsLong(i);
+ Py_DECREF(i);
+ return result;
#endif
+#if PY_VERSION_HEX < 0x02040000
+#define Py_VISIT(op) \
+ do { \
+ if (op) { \
+ int vret = visit((op), arg); \
+ if (vret) \
+ return vret; \
+ } while (0)
+#endif
+#if PY_VERSION_HEX < 0x02030000
+typedef struct {
+ PyTypeObject type;
+ PyNumberMethods as_number;
+ PyMappingMethods as_mapping;
+ PySequenceMethods as_sequence;
+ PyBufferProcs as_buffer;
+ PyObject *name, *slots;
+} PyHeapTypeObject;
+#endif
+typedef destructor freefunc;
+#endif
+#if ((PY_MAJOR_VERSION == 2 && PY_MINOR_VERSION > 6) || \
+ (PY_MAJOR_VERSION == 3 && PY_MINOR_VERSION > 0) || \
+ (PY_MAJOR_VERSION > 3))
+# define SWIGPY_USE_CAPSULE
+# define SWIGPY_CAPSULE_NAME ((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION ".type_pointer_capsule" SWIG_TYPE_TABLE_NAME)
+#endif
+#if PY_VERSION_HEX < 0x03020000
+#define PyDescr_TYPE(x) (((PyDescrObject *)(x))->d_type)
+#define PyDescr_NAME(x) (((PyDescrObject *)(x))->d_name)
+#endif
* error manipulation
@@ -1042,10 +1107,7 @@
#ifdef __cplusplus
extern "C" {
-#if 0
-} /* cc-mode */
#endif
-#endif
* Constant declarations
@@ -1070,27 +1132,24 @@
* Wrapper of PyInstanceMethod_New() used in Python 3
* It is exported to the generated module, used for -fastproxy
-SWIGRUNTIME PyObject* SWIG_PyInstanceMethod_New(PyObject *self, PyObject *func)
+#if PY_VERSION_HEX >= 0x03000000
+SWIGRUNTIME PyObject* SWIG_PyInstanceMethod_New(PyObject *SWIGUNUSEDPARM(self), PyObject *func)
-#if PY_VERSION_HEX >= 0x03000000
return PyInstanceMethod_New(func);
#else
+SWIGRUNTIME PyObject* SWIG_PyInstanceMethod_New(PyObject *SWIGUNUSEDPARM(self), PyObject *SWIGUNUSEDPARM(func))
return NULL;
#endif
#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
-#endif
#endif
- * See the LICENSE file for information on copyright, usage and redistribution
- * of SWIG, and the README file for authors - http://www.swig.org/release.html.
* pyrun.swg
* This file contains the runtime support for Python modules
@@ -1105,7 +1164,15 @@
#define SWIG_Python_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
#define SWIG_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtr(obj, pptr, type, flags)
#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, own)
-#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(ptr, type, flags)
+#ifdef SWIGPYTHON_BUILTIN
+#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(self, ptr, type, flags)
+#else
+#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(NULL, ptr, type, flags)
+#endif
+#define SWIG_InternalNewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(NULL, ptr, type, flags)
#define SWIG_CheckImplicit(ty) SWIG_Python_CheckImplicit(ty)
#define SWIG_AcquirePtr(ptr, src) SWIG_Python_AcquirePtr(ptr, src)
#define swig_owntype int
@@ -1120,7 +1187,7 @@
/* for C or C++ function pointers */
#define SWIG_ConvertFunctionPtr(obj, pptr, type) SWIG_Python_ConvertFunctionPtr(obj, pptr, type)
-#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_Python_NewPointerObj(ptr, type, 0)
+#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_Python_NewPointerObj(NULL, ptr, type, 0)
/* for C++ member pointers, ie, member methods */
#define SWIG_ConvertMember(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
@@ -1163,12 +1230,33 @@
/* Set a constant value */
+#if defined(SWIGPYTHON_BUILTIN)
SWIGINTERN void
+SwigPyBuiltin_AddPublicSymbol(PyObject *seq, const char *key) {
+ PyObject *s = PyString_InternFromString(key);
+ PyList_Append(seq, s);
+ Py_DECREF(s);
+SWIGINTERN void
+SWIG_Python_SetConstant(PyObject *d, PyObject *public_interface, const char *name, PyObject *obj) {
+ PyDict_SetItemString(d, (char *)name, obj);
+ Py_DECREF(obj);
+ if (public_interface)
+ SwigPyBuiltin_AddPublicSymbol(public_interface, name);
+#else
+SWIGINTERN void
SWIG_Python_SetConstant(PyObject *d, const char *name, PyObject *obj) {
- PyDict_SetItemString(d, (char*) name, obj);
Py_DECREF(obj);
+#endif
/* Append a value to the result obj */
SWIGINTERN PyObject*
@@ -1229,6 +1317,14 @@
if (!PyTuple_Check(args)) {
+ if (min <= 1 && max >= 1) {
+ register int i;
+ objs[0] = args;
+ for (i = 1; i < max; ++i) {
+ objs[i] = 0;
+ return 2;
PyErr_SetString(PyExc_SystemError, "UnpackTuple() argument list is not a tuple");
return 0;
} else {
@@ -1281,12 +1377,12 @@
#define SWIG_POINTER_IMPLICIT_CONV (SWIG_POINTER_DISOWN << 1)
+#define SWIG_BUILTIN_TP_INIT (SWIG_POINTER_OWN << 2)
+#define SWIG_BUILTIN_INIT (SWIG_BUILTIN_TP_INIT | SWIG_POINTER_OWN)
#ifdef __cplusplus
extern "C" {
-#if 0
-} /* cc-mode */
#endif
-#endif
/* How to access Py_None */
#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
@@ -1336,6 +1432,7 @@
PyObject *destroy;
int delargs;
int implicitconv;
+ PyTypeObject *pytype;
} SwigPyClientData;
SWIGRUNTIMEINLINE int
@@ -1402,13 +1499,13 @@
data->delargs = 0;
data->implicitconv = 0;
+ data->pytype = 0;
return data;
SWIGRUNTIME void
-SwigPyClientData_Del(SwigPyClientData* data)
+SwigPyClientData_Del(SwigPyClientData *data) {
Py_XDECREF(data->newraw);
Py_XDECREF(data->newargs);
Py_XDECREF(data->destroy);
@@ -1422,6 +1519,9 @@
swig_type_info *ty;
int own;
PyObject *next;
+ PyObject *dict;
+#endif
} SwigPyObject;
SWIGRUNTIME PyObject *
@@ -1472,21 +1572,21 @@
#endif
const char *name = SWIG_TypePrettyName(v->ty);
- PyObject *repr = SWIG_Python_str_FromFormat("<Swig Object of type '%s' at %p>", name, v);
+ PyObject *repr = SWIG_Python_str_FromFormat("<Swig Object of type '%s' at %p>", name, (void *)v);
if (v->next) {
-#ifdef METH_NOARGS
+# ifdef METH_NOARGS
PyObject *nrep = SwigPyObject_repr((SwigPyObject *)v->next);
-#else
+# else
PyObject *nrep = SwigPyObject_repr((SwigPyObject *)v->next, args);
-#endif
+# endif
+# if PY_VERSION_HEX >= 0x03000000
PyObject *joined = PyUnicode_Concat(repr, nrep);
Py_DecRef(repr);
Py_DecRef(nrep);
repr = joined;
-#else
+# else
PyString_ConcatAndDel(&repr,nrep);
-#endif
+# endif
return repr;
@@ -1536,27 +1636,43 @@
Py_INCREF(Py_NotImplemented);
return Py_NotImplemented;
- if( (SwigPyObject_compare(v, w)==0) == (op == Py_EQ) )
- res = Py_True;
- else
- res = Py_False;
- Py_INCREF(res);
+ res = PyBool_FromLong( (SwigPyObject_compare(v, w)==0) == (op == Py_EQ) ? 1 : 0);
return res;
-SWIGRUNTIME PyTypeObject* _PySwigObject_type(void);
+SWIGRUNTIME PyTypeObject* SwigPyObject_TypeOnce(void);
+static swig_type_info *SwigPyObject_stype = 0;
SwigPyObject_type(void) {
- static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigObject_type();
+ SwigPyClientData *cd;
+ assert(SwigPyObject_stype);
+ cd = (SwigPyClientData*) SwigPyObject_stype->clientdata;
+ assert(cd);
+ assert(cd->pytype);
+ return cd->pytype;
+#else
+SwigPyObject_type(void) {
+ static PyTypeObject *SWIG_STATIC_POINTER(type) = SwigPyObject_TypeOnce();
return type;
+#endif
SwigPyObject_Check(PyObject *op) {
+ PyTypeObject *target_tp = SwigPyObject_type();
+ if (PyType_IsSubtype(op->ob_type, target_tp))
+ return 1;
+ return (strcmp(op->ob_type->tp_name, "SwigPyObject") == 0);
+#else
return (Py_TYPE(op) == SwigPyObject_type())
|| (strcmp(Py_TYPE(op)->tp_name,"SwigPyObject") == 0);
+#endif
@@ -1722,9 +1838,9 @@
#endif
-_PySwigObject_type(void) {
+SwigPyObject_TypeOnce(void) {
static char swigobject_doc[] = "Swig object carries a C/C++ instance pointer";
static PyNumberMethods SwigPyObject_as_number = {
(binaryfunc)0, /*nb_add*/
(binaryfunc)0, /*nb_subtract*/
@@ -1771,85 +1887,89 @@
#endif
- static PyTypeObject swigpyobject_type;
+ static PyTypeObject swigpyobject_type;
static int type_init = 0;
if (!type_init) {
- const PyTypeObject tmp
- /* PyObject header changed in Python 3 */
+ const PyTypeObject tmp = {
+ /* PyObject header changed in Python 3 */
- PyVarObject_HEAD_INIT(&PyType_Type, 0)
-#else
- PyObject_HEAD_INIT(NULL)
- 0, /* ob_size */
+ PyVarObject_HEAD_INIT(NULL, 0)
+#else
+ PyObject_HEAD_INIT(NULL)
+ 0, /* ob_size */
#endif
- (char *)"SwigPyObject", /* tp_name */
- sizeof(SwigPyObject), /* tp_basicsize */
- 0, /* tp_itemsize */
- (destructor)SwigPyObject_dealloc, /* tp_dealloc */
- (printfunc)SwigPyObject_print, /* tp_print */
+ (char *)"SwigPyObject", /* tp_name */
+ sizeof(SwigPyObject), /* tp_basicsize */
+ 0, /* tp_itemsize */
+ (destructor)SwigPyObject_dealloc, /* tp_dealloc */
+ (printfunc)SwigPyObject_print, /* tp_print */
#if PY_VERSION_HEX < 0x02020000
- (getattrfunc)SwigPyObject_getattr, /* tp_getattr */
+ (getattrfunc)SwigPyObject_getattr, /* tp_getattr */
#else
- (getattrfunc)0, /* tp_getattr */
+ (getattrfunc)0, /* tp_getattr */
#endif
- (setattrfunc)0, /* tp_setattr */
+ (setattrfunc)0, /* tp_setattr */
0, /* tp_reserved in 3.0.1, tp_compare in 3.0.0 but not used */
#else
- (cmpfunc)SwigPyObject_compare, /* tp_compare */
+ (cmpfunc)SwigPyObject_compare, /* tp_compare */
#endif
- (reprfunc)SwigPyObject_repr, /* tp_repr */
- &SwigPyObject_as_number, /* tp_as_number */
- 0, /* tp_as_sequence */
- 0, /* tp_as_mapping */
- (hashfunc)0, /* tp_hash */
- (ternaryfunc)0, /* tp_call */
- (reprfunc)SwigPyObject_str, /* tp_str */
- PyObject_GenericGetAttr, /* tp_getattro */
- 0, /* tp_setattro */
- 0, /* tp_as_buffer */
- Py_TPFLAGS_DEFAULT, /* tp_flags */
- swigobject_doc, /* tp_doc */
- 0, /* tp_traverse */
- 0, /* tp_clear */
- (richcmpfunc)SwigPyObject_richcompare, /* tp_richcompare */
- 0, /* tp_weaklistoffset */
+ (reprfunc)SwigPyObject_repr, /* tp_repr */
+ &SwigPyObject_as_number, /* tp_as_number */
+ 0, /* tp_as_sequence */
+ 0, /* tp_as_mapping */
+ (hashfunc)0, /* tp_hash */
+ (ternaryfunc)0, /* tp_call */
+ (reprfunc)SwigPyObject_str, /* tp_str */
+ PyObject_GenericGetAttr, /* tp_getattro */
+ 0, /* tp_setattro */
+ 0, /* tp_as_buffer */
+ Py_TPFLAGS_DEFAULT, /* tp_flags */
+ swigobject_doc, /* tp_doc */
+ 0, /* tp_traverse */
+ 0, /* tp_clear */
+ (richcmpfunc)SwigPyObject_richcompare,/* tp_richcompare */
+ 0, /* tp_weaklistoffset */
#if PY_VERSION_HEX >= 0x02020000
- 0, /* tp_iter */
- 0, /* tp_iternext */
- swigobject_methods, /* tp_methods */
- 0, /* tp_members */
- 0, /* tp_getset */
- 0, /* tp_base */
- 0, /* tp_dict */
- 0, /* tp_descr_get */
- 0, /* tp_descr_set */
- 0, /* tp_dictoffset */
- 0, /* tp_init */
- 0, /* tp_alloc */
- 0, /* tp_new */
- 0, /* tp_free */
- 0, /* tp_is_gc */
- 0, /* tp_bases */
- 0, /* tp_mro */
- 0, /* tp_cache */
- 0, /* tp_subclasses */
- 0, /* tp_weaklist */
+ 0, /* tp_iter */
+ 0, /* tp_iternext */
+ swigobject_methods, /* tp_methods */
+ 0, /* tp_members */
+ 0, /* tp_getset */
+ 0, /* tp_base */
+ 0, /* tp_dict */
+ 0, /* tp_descr_get */
+ 0, /* tp_descr_set */
+ 0, /* tp_dictoffset */
+ 0, /* tp_init */
+ 0, /* tp_alloc */
+ 0, /* tp_new */
+ 0, /* tp_free */
+ 0, /* tp_is_gc */
+ 0, /* tp_bases */
+ 0, /* tp_mro */
+ 0, /* tp_cache */
+ 0, /* tp_subclasses */
+ 0, /* tp_weaklist */
#endif
#if PY_VERSION_HEX >= 0x02030000
- 0, /* tp_del */
+ 0, /* tp_del */
#endif
+#if PY_VERSION_HEX >= 0x02060000
+ 0, /* tp_version */
+#endif
#ifdef COUNT_ALLOCS
- 0,0,0,0 /* tp_alloc -> tp_next */
+ 0,0,0,0 /* tp_alloc -> tp_next */
#endif
swigpyobject_type = tmp;
- /* for Python 3 we already assigned ob_type in PyVarObject_HEAD_INIT() */
-#if PY_VERSION_HEX < 0x03000000
+ type_init = 1;
+#if PY_VERSION_HEX < 0x02020000
swigpyobject_type.ob_type = &PyType_Type;
+#else
+ if (PyType_Ready(&swigpyobject_type) < 0)
+ return NULL;
#endif
- type_init = 1;
return &swigpyobject_type;
@@ -1923,17 +2043,17 @@
return s ? s : strncmp((char *)v->pack, (char *)w->pack, 2*v->size);
-SWIGRUNTIME PyTypeObject* _PySwigPacked_type(void);
+SWIGRUNTIME PyTypeObject* SwigPyPacked_TypeOnce(void);
SwigPyPacked_type(void) {
- static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigPacked_type();
+ static PyTypeObject *SWIG_STATIC_POINTER(type) = SwigPyPacked_TypeOnce();
return type;
SwigPyPacked_Check(PyObject *op) {
- return ((op)->ob_type == _PySwigPacked_type())
+ return ((op)->ob_type == SwigPyPacked_TypeOnce())
|| (strcmp((op)->ob_type->tp_name,"SwigPyPacked") == 0);
@@ -1948,83 +2068,87 @@
-_PySwigPacked_type(void) {
+SwigPyPacked_TypeOnce(void) {
static char swigpacked_doc[] = "Swig object carries a C/C++ instance pointer";
static PyTypeObject swigpypacked_type;
- static int type_init = 0;
+ static int type_init = 0;
if (!type_init) {
#if PY_VERSION_HEX>=0x03000000
#else
- 0, /* ob_size */
+ 0, /* ob_size */
#endif
- (char *)"SwigPyPacked", /* tp_name */
- sizeof(SwigPyPacked), /* tp_basicsize */
- (destructor)SwigPyPacked_dealloc, /* tp_dealloc */
- (printfunc)SwigPyPacked_print, /* tp_print */
+ (char *)"SwigPyPacked", /* tp_name */
+ sizeof(SwigPyPacked), /* tp_basicsize */
+ (destructor)SwigPyPacked_dealloc, /* tp_dealloc */
+ (printfunc)SwigPyPacked_print, /* tp_print */
- 0, /* tp_reserved in 3.0.1 */
+ 0, /* tp_reserved in 3.0.1 */
#else
- (cmpfunc)SwigPyPacked_compare, /* tp_compare */
+ (cmpfunc)SwigPyPacked_compare, /* tp_compare */
#endif
- (reprfunc)SwigPyPacked_repr, /* tp_repr */
- 0, /* tp_as_number */
- (reprfunc)SwigPyPacked_str, /* tp_str */
- swigpacked_doc, /* tp_doc */
- 0, /* tp_clear */
- 0, /* tp_richcompare */
+ (reprfunc)SwigPyPacked_repr, /* tp_repr */
+ 0, /* tp_as_number */
+ (reprfunc)SwigPyPacked_str, /* tp_str */
+ swigpacked_doc, /* tp_doc */
+ 0, /* tp_clear */
+ 0, /* tp_richcompare */
- 0, /* tp_iter */
- 0, /* tp_methods */
- 0, /* tp_base */
- 0, /* tp_dict */
- 0, /* tp_init */
- 0, /* tp_alloc */
- 0, /* tp_new */
- 0, /* tp_free */
- 0, /* tp_is_gc */
- 0, /* tp_bases */
- 0, /* tp_mro */
- 0, /* tp_cache */
+ 0, /* tp_iter */
+ 0, /* tp_methods */
+ 0, /* tp_base */
+ 0, /* tp_dict */
+ 0, /* tp_init */
+ 0, /* tp_alloc */
+ 0, /* tp_new */
+ 0, /* tp_free */
+ 0, /* tp_is_gc */
+ 0, /* tp_bases */
+ 0, /* tp_mro */
+ 0, /* tp_cache */
#endif
- 0, /* tp_del */
+ 0, /* tp_del */
#endif
+#endif
#ifdef COUNT_ALLOCS
#endif
swigpypacked_type = tmp;
- /* for Python 3 the ob_type already assigned in PyVarObject_HEAD_INIT() */
+ type_init = 1;
swigpypacked_type.ob_type = &PyType_Type;
+#else
+ if (PyType_Ready(&swigpypacked_type) < 0)
+ return NULL;
#endif
- type_init = 1;
return &swigpypacked_type;
@@ -2071,10 +2195,13 @@
return SWIG_Python_str_FromChar("this");
+static PyObject *swig_this = NULL;
SWIG_This(void)
- static PyObject *SWIG_STATIC_POINTER(swig_this) = _SWIG_This();
+ if (swig_this == NULL)
+ swig_this = _SWIG_This();
return swig_this;
@@ -2088,50 +2215,65 @@
SWIGRUNTIME SwigPyObject *
SWIG_Python_GetSwigThis(PyObject *pyobj)
- if (SwigPyObject_Check(pyobj)) {
+ PyObject *obj;
+ if (SwigPyObject_Check(pyobj))
return (SwigPyObject *) pyobj;
+ (void)obj;
+# ifdef PyWeakref_CheckProxy
+ if (PyWeakref_CheckProxy(pyobj)) {
+ pyobj = PyWeakref_GET_OBJECT(pyobj);
+ if (pyobj && SwigPyObject_Check(pyobj))
+ return (SwigPyObject*) pyobj;
+# endif
+ return NULL;
+#else
+ obj = 0;
+#if (!defined(SWIG_PYTHON_SLOW_GETSET_THIS) && (PY_VERSION_HEX >= 0x02030000))
+ if (PyInstance_Check(pyobj)) {
+ obj = _PyInstance_Lookup(pyobj, SWIG_This());
} else {
- PyObject *obj = 0;
-#if (!defined(SWIG_PYTHON_SLOW_GETSET_THIS) && (PY_VERSION_HEX >= 0x02030000))
- if (PyInstance_Check(pyobj)) {
- obj = _PyInstance_Lookup(pyobj, SWIG_This());
+ PyObject **dictptr = _PyObject_GetDictPtr(pyobj);
+ if (dictptr != NULL) {
+ PyObject *dict = *dictptr;
+ obj = dict ? PyDict_GetItem(dict, SWIG_This()) : 0;
} else {
- PyObject **dictptr = _PyObject_GetDictPtr(pyobj);
- if (dictptr != NULL) {
- PyObject *dict = *dictptr;
- obj = dict ? PyDict_GetItem(dict, SWIG_This()) : 0;
- } else {
#ifdef PyWeakref_CheckProxy
- if (PyWeakref_CheckProxy(pyobj)) {
- PyObject *wobj = PyWeakref_GET_OBJECT(pyobj);
- return wobj ? SWIG_Python_GetSwigThis(wobj) : 0;
+ PyObject *wobj = PyWeakref_GET_OBJECT(pyobj);
+ return wobj ? SWIG_Python_GetSwigThis(wobj) : 0;
#endif
- obj = PyObject_GetAttr(pyobj,SWIG_This());
- if (obj) {
- Py_DECREF(obj);
- } else {
- if (PyErr_Occurred()) PyErr_Clear();
- return 0;
+ obj = PyObject_GetAttr(pyobj,SWIG_This());
+ if (obj) {
+ Py_DECREF(obj);
+ } else {
+ if (PyErr_Occurred()) PyErr_Clear();
+ return 0;
#else
- if (obj) {
- Py_DECREF(obj);
- } else {
- return 0;
+ if (obj) {
+ Py_DECREF(obj);
+ } else {
+ return 0;
#endif
- if (obj && !SwigPyObject_Check(obj)) {
- /* a PyObject is called 'this', try to get the 'real this'
- SwigPyObject from it */
- return SWIG_Python_GetSwigThis(obj);
- return (SwigPyObject *)obj;
+ if (obj && !SwigPyObject_Check(obj)) {
+ /* a PyObject is called 'this', try to get the 'real this'
+ SwigPyObject from it */
+ return SWIG_Python_GetSwigThis(obj);
+ return (SwigPyObject *)obj;
+#endif
/* Acquire a pointer value */
@@ -2153,91 +2295,97 @@
SWIGRUNTIME int
SWIG_Python_ConvertPtrAndOwn(PyObject *obj, void **ptr, swig_type_info *ty, int flags, int *own) {
- if (!obj) return SWIG_ERROR;
+ int res;
+ SwigPyObject *sobj;
+ if (!obj)
+ return SWIG_ERROR;
if (obj == Py_None) {
- if (ptr) *ptr = 0;
+ if (ptr)
+ *ptr = 0;
return SWIG_OK;
+ res = SWIG_ERROR;
+ sobj = SWIG_Python_GetSwigThis(obj);
+ if (own)
+ *own = 0;
+ while (sobj) {
+ void *vptr = sobj->ptr;
+ if (ty) {
+ swig_type_info *to = sobj->ty;
+ if (to == ty) {
+ /* no type cast needed */
+ if (ptr) *ptr = vptr;
+ break;
+ } else {
+ swig_cast_info *tc = SWIG_TypeCheck(to->name,ty);
+ if (!tc) {
+ sobj = (SwigPyObject *)sobj->next;
+ } else {
+ if (ptr) {
+ int newmemory = 0;
+ *ptr = SWIG_TypeCast(tc,vptr,&newmemory);
+ if (newmemory == SWIG_CAST_NEW_MEMORY) {
+ assert(own); /* badly formed typemap which will lead to a memory leak - it must set and use own to delete *ptr */
+ if (own)
+ *own = *own | SWIG_CAST_NEW_MEMORY;
+ break;
+ } else {
+ break;
+ if (sobj) {
+ if (own)
+ *own = *own | sobj->own;
+ if (flags & SWIG_POINTER_DISOWN) {
+ sobj->own = 0;
+ res = SWIG_OK;
} else {
- SwigPyObject *sobj = SWIG_Python_GetSwigThis(obj);
- if (own)
- *own = 0;
- while (sobj) {
- void *vptr = sobj->ptr;
- if (ty) {
- swig_type_info *to = sobj->ty;
- if (to == ty) {
- /* no type cast needed */
- if (ptr) *ptr = vptr;
- break;
- } else {
- swig_cast_info *tc = SWIG_TypeCheck(to->name,ty);
- if (!tc) {
- sobj = (SwigPyObject *)sobj->next;
- } else {
- if (ptr) {
- int newmemory = 0;
- *ptr = SWIG_TypeCast(tc,vptr,&newmemory);
- if (newmemory == SWIG_CAST_NEW_MEMORY) {
- assert(own);
- if (own)
- *own = *own | SWIG_CAST_NEW_MEMORY;
+ if (flags & SWIG_POINTER_IMPLICIT_CONV) {
+ SwigPyClientData *data = ty ? (SwigPyClientData *) ty->clientdata : 0;
+ if (data && !data->implicitconv) {
+ PyObject *klass = data->klass;
+ if (klass) {
+ PyObject *impconv;
+ data->implicitconv = 1; /* avoid recursion and call 'explicit' constructors*/
+ impconv = SWIG_Python_CallFunctor(klass, obj);
+ data->implicitconv = 0;
+ if (PyErr_Occurred()) {
+ PyErr_Clear();
+ impconv = 0;
+ if (impconv) {
+ SwigPyObject *iobj = SWIG_Python_GetSwigThis(impconv);
+ if (iobj) {
+ void *vptr;
+ res = SWIG_Python_ConvertPtrAndOwn((PyObject*)iobj, &vptr, ty, 0, 0);
+ if (SWIG_IsOK(res)) {
+ if (ptr) {
+ *ptr = vptr;
+ /* transfer the ownership to 'ptr' */
+ iobj->own = 0;
+ res = SWIG_AddCast(res);
+ res = SWIG_AddNewMask(res);
+ } else {
- break;
- } else {
- break;
+ Py_DECREF(impconv);
- if (sobj) {
- if (own)
- *own = *own | sobj->own;
- if (flags & SWIG_POINTER_DISOWN) {
- sobj->own = 0;
- return SWIG_OK;
- } else {
- int res = SWIG_ERROR;
- if (flags & SWIG_POINTER_IMPLICIT_CONV) {
- SwigPyClientData *data = ty ? (SwigPyClientData *) ty->clientdata : 0;
- if (data && !data->implicitconv) {
- PyObject *klass = data->klass;
- if (klass) {
- PyObject *impconv;
- data->implicitconv = 1; /* avoid recursion and call 'explicit' constructors*/
- impconv = SWIG_Python_CallFunctor(klass, obj);
- data->implicitconv = 0;
- if (PyErr_Occurred()) {
- PyErr_Clear();
- impconv = 0;
- if (impconv) {
- SwigPyObject *iobj = SWIG_Python_GetSwigThis(impconv);
- if (iobj) {
- void *vptr;
- res = SWIG_Python_ConvertPtrAndOwn((PyObject*)iobj, &vptr, ty, 0, 0);
- if (SWIG_IsOK(res)) {
- if (ptr) {
- *ptr = vptr;
- /* transfer the ownership to 'ptr' */
- iobj->own = 0;
- res = SWIG_AddCast(res);
- res = SWIG_AddNewMask(res);
- } else {
- Py_DECREF(impconv);
- return res;
+ return res;
/* Convert a function ptr value */
@@ -2407,22 +2555,54 @@
/* Create a new pointer object */
-SWIG_Python_NewPointerObj(void *ptr, swig_type_info *type, int flags) {
- if (!ptr) {
+SWIG_Python_NewPointerObj(PyObject *self, void *ptr, swig_type_info *type, int flags) {
+ SwigPyClientData *clientdata;
+ PyObject * robj;
+ int own;
+ if (!ptr)
return SWIG_Py_Void();
- } else {
- int own = (flags & SWIG_POINTER_OWN) ? SWIG_POINTER_OWN : 0;
- PyObject *robj = SwigPyObject_New(ptr, type, own);
- SwigPyClientData *clientdata = type ? (SwigPyClientData *)(type->clientdata) : 0;
- if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
- PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
- if (inst) {
- Py_DECREF(robj);
- robj = inst;
+ clientdata = type ? (SwigPyClientData *)(type->clientdata) : 0;
+ own = (flags & SWIG_POINTER_OWN) ? SWIG_POINTER_OWN : 0;
+ if (clientdata && clientdata->pytype) {
+ SwigPyObject *newobj;
+ if (flags & SWIG_BUILTIN_TP_INIT) {
+ newobj = (SwigPyObject*) self;
+ if (newobj->ptr) {
+ PyObject *next_self = clientdata->pytype->tp_alloc(clientdata->pytype, 0);
+ while (newobj->next)
+ newobj = (SwigPyObject *) newobj->next;
+ newobj->next = next_self;
+ newobj = (SwigPyObject *)next_self;
+ } else {
+ newobj = PyObject_New(SwigPyObject, clientdata->pytype);
- return robj;
+ if (newobj) {
+ newobj->ptr = ptr;
+ newobj->ty = type;
+ newobj->own = own;
+ newobj->next = 0;
+ newobj->dict = 0;
+#endif
+ return (PyObject*) newobj;
+ return SWIG_Py_Void();
+ assert(!(flags & SWIG_BUILTIN_TP_INIT));
+ robj = SwigPyObject_New(ptr, type, own);
+ if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
+ PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
+ if (inst) {
+ Py_DECREF(robj);
+ robj = inst;
+ return robj;
/* Create a new packed object */
@@ -2448,8 +2628,12 @@
#ifdef SWIG_LINK_RUNTIME
type_pointer = SWIG_ReturnGlobalTypeList((void *)0);
#else
+# ifdef SWIGPY_USE_CAPSULE
+ type_pointer = PyCapsule_Import(SWIGPY_CAPSULE_NAME, 0);
+# else
type_pointer = PyCObject_Import((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
(char*)"type_pointer" SWIG_TYPE_TABLE_NAME);
+# endif
PyErr_Clear();
type_pointer = (void *)0;
@@ -2492,9 +2676,17 @@
#endif
SWIGRUNTIME void
+#ifdef SWIGPY_USE_CAPSULE
+SWIG_Python_DestroyModule(PyObject *obj)
+#else
SWIG_Python_DestroyModule(void *vptr)
+#endif
+ swig_module_info *swig_module = (swig_module_info *) PyCapsule_GetPointer(obj, SWIGPY_CAPSULE_NAME);
+#else
swig_module_info *swig_module = (swig_module_info *) vptr;
+#endif
swig_type_info **types = swig_module->types;
size_t i;
for (i =0; i < swig_module->size; ++i) {
@@ -2505,25 +2697,33 @@
Py_DECREF(SWIG_This());
+ swig_this = NULL;
SWIGRUNTIME void
SWIG_Python_SetModule(swig_module_info *swig_module) {
- static PyMethodDef swig_empty_runtime_method_table[] = { {NULL, NULL, 0, NULL} };/* Sentinel */
/* Add a dummy module object into sys.modules */
PyObject *module = PyImport_AddModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION);
#else
- PyObject *module = Py_InitModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
- swig_empty_runtime_method_table);
+ static PyMethodDef swig_empty_runtime_method_table[] = { {NULL, NULL, 0, NULL} }; /* Sentinel */
+ PyObject *module = Py_InitModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION, swig_empty_runtime_method_table);
#endif
+ PyObject *pointer = PyCapsule_New((void *) swig_module, SWIGPY_CAPSULE_NAME, SWIG_Python_DestroyModule);
+ if (pointer && module) {
+ PyModule_AddObject(module, (char*)"type_pointer_capsule" SWIG_TYPE_TABLE_NAME, pointer);
+ } else {
+ Py_XDECREF(pointer);
+#else
PyObject *pointer = PyCObject_FromVoidPtr((void *) swig_module, SWIG_Python_DestroyModule);
PyModule_AddObject(module, (char*)"type_pointer" SWIG_TYPE_TABLE_NAME, pointer);
} else {
+#endif
/* The python cached type query */
@@ -2541,12 +2741,20 @@
PyObject *obj = PyDict_GetItem(cache, key);
swig_type_info *descriptor;
if (obj) {
+ descriptor = (swig_type_info *) PyCapsule_GetPointer(obj, NULL);
+#else
descriptor = (swig_type_info *) PyCObject_AsVoidPtr(obj);
+#endif
} else {
swig_module_info *swig_module = SWIG_Python_GetModule();
descriptor = SWIG_TypeQueryModule(swig_module, swig_module, type);
if (descriptor) {
+ obj = PyCapsule_New((void*) descriptor, NULL, NULL);
+#else
obj = PyCObject_FromVoidPtr(descriptor, NULL);
+#endif
PyDict_SetItem(cache, key, obj);
Py_DECREF(obj);
@@ -2650,7 +2858,7 @@
/* Convert a pointer value, signal an exception on a type mismatch */
SWIGRUNTIME void *
-SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int argnum, int flags) {
+SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int SWIGUNUSEDPARM(argnum), int flags) {
void *result;
if (SWIG_Python_ConvertPtr(obj, &result, ty, flags) == -1) {
PyErr_Clear();
@@ -2664,12 +2872,61 @@
return result;
+SWIGRUNTIME int
+SWIG_Python_NonDynamicSetAttr(PyObject *obj, PyObject *name, PyObject *value) {
+ PyTypeObject *tp = obj->ob_type;
+ PyObject *descr;
+ PyObject *encoded_name;
+ descrsetfunc f;
+ int res;
-#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
+#ifdef Py_USING_UNICODE
+ if (PyString_Check(name)) {
+ name = PyUnicode_Decode(PyString_AsString(name), PyString_Size(name), NULL, NULL);
+ if (!name)
+ return -1;
+ } else if (!PyUnicode_Check(name))
+#else
+ if (!PyString_Check(name))
#endif
+ PyErr_Format(PyExc_TypeError, "attribute name must be string, not '%.200s'", name->ob_type->tp_name);
+ return -1;
+ } else {
+ Py_INCREF(name);
+ if (!tp->tp_dict) {
+ if (PyType_Ready(tp) < 0)
+ goto done;
+ res = -1;
+ descr = _PyType_Lookup(tp, name);
+ f = NULL;
+ if (descr != NULL)
+ f = descr->ob_type->tp_descr_set;
+ if (!f) {
+ encoded_name = name;
+ Py_INCREF(name);
+ } else {
+ encoded_name = PyUnicode_AsUTF8String(name);
+ PyErr_Format(PyExc_AttributeError, "'%.100s' object has no attribute '%.200s'", tp->tp_name, PyString_AsString(encoded_name));
+ Py_DECREF(encoded_name);
+ } else {
+ res = f(descr, obj, value);
+ done:
+ Py_DECREF(name);
+ return res;
+#ifdef __cplusplus
#endif
@@ -2741,7 +2998,7 @@
#endif
#define SWIG_name "_geos"
-#define SWIGVERSION 0x010340
+#define SWIGVERSION 0x020004
#define SWIG_VERSION SWIGVERSION
@@ -2819,7 +3076,13 @@
#include <iostream>
+#if PY_VERSION_HEX >= 0x03020000
+# define SWIGPY_SLICE_ARG(obj) ((PyObject*) (obj))
+#else
+# define SWIGPY_SLICE_ARG(obj) ((PySliceObject*) (obj))
+#endif
#include <stdexcept>
@@ -2832,6 +3095,7 @@
#include <string>
+#include <stddef.h>
namespace swig {
@@ -2950,6 +3214,14 @@
return desc;
+ inline PyObject* make_output_iterator_builtin (PyObject *pyself)
+ Py_INCREF(pyself);
+ return pyself;
+#endif
@@ -3194,7 +3466,7 @@
if (size > INT_MAX) {
swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
return pchar_descriptor ?
- SWIG_NewPointerObj(const_cast< char * >(carray), pchar_descriptor, 0) : SWIG_Py_Void();
+ SWIG_InternalNewPointerObj(const_cast< char * >(carray), pchar_descriptor, 0) : SWIG_Py_Void();
} else {
return PyUnicode_FromStringAndSize(carray, static_cast< int >(size));
@@ -4161,8 +4433,8 @@
int ii;
if (!PyTuple_Check(args)) SWIG_fail;
- argc = (int)PyObject_Length(args);
- for (ii = 0; (ii < argc) && (ii < 2); ii++) {
+ argc = args ? (int)PyObject_Length(args) : 0;
+ for (ii = 0; (ii < 2) && (ii < argc); ii++) {
argv[ii] = PyTuple_GET_ITEM(args,ii);
if (argc == 1) {
@@ -4191,11 +4463,11 @@
fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'SwigPyIterator_incr'.\n"
+ SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number or type of arguments for overloaded function 'SwigPyIterator_incr'.\n"
" Possible C/C++ prototypes are:\n"
- " incr(swig::SwigPyIterator *,size_t)\n"
- " incr(swig::SwigPyIterator *)\n");
- return NULL;
+ " swig::SwigPyIterator::incr(size_t)\n"
+ " swig::SwigPyIterator::incr()\n");
+ return 0;
@@ -4278,8 +4550,8 @@
int ii;
if (argc == 1) {
@@ -4308,11 +4580,11 @@
fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'SwigPyIterator_decr'.\n"
+ SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number or type of arguments for overloaded function 'SwigPyIterator_decr'.\n"
- " decr(swig::SwigPyIterator *,size_t)\n"
- " decr(swig::SwigPyIterator *)\n");
- return NULL;
+ " swig::SwigPyIterator::decr(size_t)\n"
+ " swig::SwigPyIterator::decr()\n");
+ return 0;
@@ -4827,8 +5099,8 @@
int ii;
if (argc == 2) {
@@ -4877,7 +5149,6 @@
PyObject *resultobj = 0;
char *result = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"version",0,0)) SWIG_fail;
result = (char *)GEOSversion();
resultobj = SWIG_FromCharPtr((const char *)result);
return resultobj;
@@ -8969,7 +9240,6 @@
GeosWktReader *result = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"new_WktReader",0,0)) SWIG_fail;
try
@@ -9107,7 +9377,6 @@
GeosWktWriter *result = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"new_WktWriter",0,0)) SWIG_fail;
try
@@ -9206,7 +9475,6 @@
GeosWkbReader *result = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"new_WkbReader",0,0)) SWIG_fail;
try
@@ -9421,7 +9689,6 @@
GeosWkbWriter *result = 0 ;
- if(!PyArg_UnpackTuple(args,(char *)"new_WkbWriter",0,0)) SWIG_fail;
try
@@ -10483,24 +10750,23 @@
swig_varlink_type(void) {
static char varlink__doc__[] = "Swig var link object";
static PyTypeObject varlink_type;
if (!type_init) {
#else
- 0, /* Number of items in variable part (ob_size) */
+ 0, /* ob_size */
#endif
- (char *)"swigvarlink", /* Type name (tp_name) */
- sizeof(swig_varlinkobject), /* Basic size (tp_basicsize) */
- 0, /* Itemsize (tp_itemsize) */
- (destructor) swig_varlink_dealloc, /* Deallocator (tp_dealloc) */
- (printfunc) swig_varlink_print, /* Print (tp_print) */
- (getattrfunc) swig_varlink_getattr, /* get attr (tp_getattr) */
- (setattrfunc) swig_varlink_setattr, /* Set attr (tp_setattr) */
+ (char *)"swigvarlink", /* tp_name */
+ sizeof(swig_varlinkobject), /* tp_basicsize */
+ (destructor) swig_varlink_dealloc, /* tp_dealloc */
+ (printfunc) swig_varlink_print, /* tp_print */
+ (getattrfunc) swig_varlink_getattr, /* tp_getattr */
+ (setattrfunc) swig_varlink_setattr, /* tp_setattr */
0, /* tp_compare */
(reprfunc) swig_varlink_repr, /* tp_repr */
@@ -10524,16 +10790,21 @@
0, /* tp_del */
#endif
+#endif
#ifdef COUNT_ALLOCS
#endif
varlink_type = tmp;
+ type_init = 1;
varlink_type.ob_type = &PyType_Type;
+#else
+ if (PyType_Ready(&varlink_type) < 0)
+ return NULL;
#endif
- type_init = 1;
return &varlink_type;
@@ -10584,7 +10855,7 @@
for (i = 0; constants[i].type; ++i) {
switch(constants[i].type) {
case SWIG_PY_POINTER:
- obj = SWIG_NewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
+ obj = SWIG_InternalNewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
break;
case SWIG_PY_BINARY:
obj = SWIG_NewPackedObj(constants[i].pvalue, constants[i].lvalue, *(constants[i].ptype));
@@ -10624,15 +10895,15 @@
if (ci) {
- size_t shift = (ci->ptype) - types;
- swig_type_info *ty = types_initial[shift];
- size_t ldoc = (c - methods[i].ml_doc);
- size_t lptr = strlen(ty->name)+2*sizeof(void*)+2;
- char *ndoc = (char*)malloc(ldoc + lptr + 10);
- if (ndoc) {
- char *buff = ndoc;
- void *ptr = (ci->type == SWIG_PY_POINTER) ? ci->pvalue : 0;
- if (ptr) {
+ void *ptr = (ci->type == SWIG_PY_POINTER) ? ci->pvalue : 0;
+ if (ptr) {
+ size_t shift = (ci->ptype) - types;
+ swig_type_info *ty = types_initial[shift];
+ size_t ldoc = (c - methods[i].ml_doc);
+ size_t lptr = strlen(ty->name)+2*sizeof(void*)+2;
+ char *ndoc = (char*)malloc(ldoc + lptr + 10);
+ if (ndoc) {
+ char *buff = ndoc;
strncpy(buff, methods[i].ml_doc, ldoc);
buff += ldoc;
strncpy(buff, "swig_ptr: ", 10);
@@ -10665,10 +10936,19 @@
void
#endif
SWIG_init(void) {
- PyObject *m, *d;
+ PyObject *m, *d, *md;
static struct PyModuleDef SWIG_module = {
+# if PY_VERSION_HEX >= 0x03020000
PyModuleDef_HEAD_INIT,
+# else
+ NULL, /* m_init */
+ 0, /* m_index */
+ NULL, /* m_copy */
+# endif
(char *) SWIG_name,
NULL,
-1,
@@ -10680,6 +10960,49 @@
#endif
+ static SwigPyClientData SwigPyObject_clientdata = {
+ 0, 0, 0, 0, 0, 0, 0
+ static PyGetSetDef this_getset_def = {
+ (char *)"this", &SwigPyBuiltin_ThisClosure, NULL, NULL, NULL
+ static SwigPyGetSet thisown_getset_closure = {
+ (PyCFunction) SwigPyObject_own,
+ static PyGetSetDef thisown_getset_def = {
+ (char *)"thisown", SwigPyBuiltin_GetterClosure, SwigPyBuiltin_SetterClosure, NULL, &thisown_getset_closure
+ PyObject *metatype_args;
+ PyTypeObject *builtin_pytype;
+ int builtin_base_count;
+ swig_type_info *builtin_basetype;
+ PyObject *tuple;
+ PyGetSetDescrObject *static_getset;
+ PyTypeObject *metatype;
+ PyObject *public_interface, *public_symbol;
+ PyObject *this_descr;
+ PyObject *thisown_descr;
+ int i;
+ (void)builtin_pytype;
+ (void)builtin_base_count;
+ (void)builtin_basetype;
+ (void)tuple;
+ (void)static_getset;
+ /* metatype is used to implement static member variables. */
+ metatype_args = Py_BuildValue("(s(O){})", "SwigPyObjectType", &PyType_Type);
+ assert(metatype_args);
+ metatype = (PyTypeObject *) PyType_Type.tp_call((PyObject *) &PyType_Type, metatype_args, NULL);
+ assert(metatype);
+ Py_DECREF(metatype_args);
+ metatype->tp_setattro = (setattrofunc) &SwigPyObjectType_setattro;
+ assert(PyType_Ready(metatype) >= 0);
+#endif
/* Fix SwigMethods to carry the callback ptrs when needed */
SWIG_Python_FixMethods(SwigMethods, swig_const_table, swig_types, swig_type_initial);
@@ -10688,23 +11011,58 @@
#else
m = Py_InitModule((char *) SWIG_name, SwigMethods);
#endif
- d = PyModule_GetDict(m);
+ md = d = PyModule_GetDict(m);
SWIG_InitializeModule(0);
+ SwigPyObject_stype = SWIG_MangledTypeQuery("_p_SwigPyObject");
+ if (!cd) {
+ SwigPyObject_stype->clientdata = &SwigPyObject_clientdata;
+ SwigPyObject_clientdata.pytype = SwigPyObject_TypeOnce();
+ } else if (SwigPyObject_TypeOnce()->tp_basicsize != cd->pytype->tp_basicsize) {
+ PyErr_SetString(PyExc_RuntimeError, "Import error: attempted to load two incompatible swig-generated modules.");
+ return NULL;
+# else
+ return;
+# endif
+ /* All objects have a 'this' attribute */
+ this_descr = PyDescr_NewGetSet(SwigPyObject_type(), &this_getset_def);
+ (void)this_descr;
+ /* All objects have a 'thisown' attribute */
+ thisown_descr = PyDescr_NewGetSet(SwigPyObject_type(), &thisown_getset_def);
+ (void)thisown_descr;
+ public_interface = PyList_New(0);
+ public_symbol = 0;
+ (void)public_symbol;
+ PyDict_SetItemString(md, "__all__", public_interface);
+ Py_DECREF(public_interface);
+ for (i = 0; SwigMethods[i].ml_name != NULL; ++i)
+ SwigPyBuiltin_AddPublicSymbol(public_interface, SwigMethods[i].ml_name);
+ for (i = 0; swig_const_table[i].name != 0; ++i)
+ SwigPyBuiltin_AddPublicSymbol(public_interface, swig_const_table[i].name);
+#endif
SWIG_InstallConstants(d,swig_const_table);
SWIG_Python_SetConstant(d, "GEOS_VERSION_MAJOR",SWIG_From_int(static_cast< int >(3)));
SWIG_Python_SetConstant(d, "GEOS_VERSION_MINOR",SWIG_From_int(static_cast< int >(3)));
- SWIG_Python_SetConstant(d, "GEOS_VERSION_PATCH",SWIG_From_int(static_cast< int >(4)));
- SWIG_Python_SetConstant(d, "GEOS_VERSION",SWIG_FromCharPtr("3.3.4"));
+ SWIG_Python_SetConstant(d, "GEOS_VERSION",SWIG_FromCharPtr("3.3.6dev"));
SWIG_Python_SetConstant(d, "GEOS_JTS_PORT",SWIG_FromCharPtr("1.12.0"));
SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MAJOR",SWIG_From_int(static_cast< int >(1)));
SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MINOR",SWIG_From_int(static_cast< int >(7)));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_PATCH",SWIG_From_int(static_cast< int >(3)));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_PATCH",SWIG_From_int(static_cast< int >(6)));
SWIG_Python_SetConstant(d, "GEOS_CAPI_FIRST_INTERFACE",SWIG_From_int(static_cast< int >(1)));
SWIG_Python_SetConstant(d, "GEOS_CAPI_LAST_INTERFACE",SWIG_From_int(static_cast< int >((1+7))));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION",SWIG_FromCharPtr("3.3.4-CAPI-1.7.3"));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION",SWIG_FromCharPtr("3.3.6dev-CAPI-1.7.6"));
SWIG_Python_SetConstant(d, "GEOS_POINT",SWIG_From_int(static_cast< int >(GEOS_POINT)));
SWIG_Python_SetConstant(d, "GEOS_LINESTRING",SWIG_From_int(static_cast< int >(GEOS_LINESTRING)));
SWIG_Python_SetConstant(d, "GEOS_LINEARRING",SWIG_From_int(static_cast< int >(GEOS_LINEARRING)));
More information about the geos-commits
