[geos-commits] r3858 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Aug 1 14:13:33 PDT 2013
Author: robe
Date: 2013-08-01 14:13:33 -0700 (Thu, 01 Aug 2013)
New Revision: 3858
   trunk/NEWS
updates add some missing ticket items  and add ticket numbers where missing
Modified: trunk/NEWS
--- trunk/NEWS	2013-07-31 21:25:54 UTC (rev 3857)
+++ trunk/NEWS	2013-08-01 21:13:33 UTC (rev 3858)
@@ -1,11 +1,11 @@
 Changes in 3.4.0
+2013-08-??
 - New things:
   - Delaunay Triangulation API (#487, #565, #570, #567)
   - Interruptibility API (C and C++)
   - CAPI: GEOSNode (#496) - PHP: Geometry->node
-  - GeometryPrecisionReducer class
+  - GeometryPrecisionReducer class (#496, #526)
   - BufferInputLineSimplifier header exposed (#548)
   - New Centroid class supporting mixed geometry components (#612)
   - io::Writer::reserve() method
@@ -23,11 +23,19 @@
   - GraphComponent::label is now a Label value (from a pointer)
   - NodedSegmentString takes ownership of CoordinateSenuence now
   - io::Writer's toString() returns by const ref, write() takes a const ref
+  - Unify prototypes of WKTReader and WKBReader constructor (#310)
+  - GeometryCollection::computeEnvelopInternal and
+    GeometryCollection::compareToSameClass are marked virtual (#478)
 - Bug fixes / improvements
+  - A point interpolated from a line does not always intersect
+    the same line (#323)
+  - Port ConvexHull robustness fix from JTS-1.13 (#457)
   - Improve Overlay robustness by reducing input precision on topology
     exception and by refusing to accept unnoded output (#459)
   - Improve Buffer robustness by reducing input precision on topology
     exception (#605)
+  - Mismatch segment sides in OffsetCurveBuilder (#633 )
   - Fixed Linear Referencing API to handle MultiLineStrings consistently
     by always using the lowest possible index value, and by trimming
     zero-length components from results (#323)
More information about the geos-commits mailing list
