[geos-commits] r3910 - trunk/tests/unit/capi
svn_geos at osgeo.org
Wed Aug 21 23:19:06 PDT 2013
Author: strk
Date: 2013-08-21 23:19:06 -0700 (Wed, 21 Aug 2013)
New Revision: 3910
trunk/tests/unit/capi/GEOSisValidDetailTest.cpp
Accept multiple NaN representations (#656)
Modified: trunk/tests/unit/capi/GEOSisValidDetailTest.cpp
--- trunk/tests/unit/capi/GEOSisValidDetailTest.cpp 2013-08-21 15:48:21 UTC (rev 3909)
+++ trunk/tests/unit/capi/GEOSisValidDetailTest.cpp 2013-08-22 06:19:06 UTC (rev 3910)
@@ -111,7 +111,6 @@
template<>
void object::test<3>()
-#if defined(__STDC_VERSION__) && __STDC_VERSION__ >= 199901L
geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0, NaN -5)");
ensure(0 != geom_);
int r = GEOSisValidDetail(geom_, 0, &reason_, &loc_);
@@ -119,8 +118,16 @@
strToUpper(wkt);
ensure_equals(r, 0); // invalid
ensure_equals(std::string(reason_), std::string("Invalid Coordinate"));
- ensure_equals(wkt, "POINT (NAN -5)");
-#endif
+ std::string exp1 = "POINT (NAN -5)";
+ std::string exp2 = "POINT (-1#IND -5)";
+ // http://trac.osgeo.org/geos/ticket/656
+ std::string exp3 = "POINT (1.#QNAN -5)";
+ std::stringstream ss;
+ ss << "Expected '" << exp1 << "' or '" << exp2 << "' or '" << exp3 << "', Obtained '" << wkt;
+ ensure(ss.str(),
+ wkt == exp1 ||
+ wkt == exp2 ||
+ wkt == exp3);
// Self intersecting ring forming hole
More information about the geos-commits
