[geos-commits] r3933 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Sat Aug 31 03:38:10 PDT 2013
Author: mloskot
Date: 2013-08-31 03:38:10 -0700 (Sat, 31 Aug 2013)
New Revision: 3933
   trunk/
Ignore geos_svn_revision.h, compile and test-driver files
Property changes on: trunk
___________________________________________________________________
Modified: svn:ignore
   - aclocal.m4
autom4te.cache
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
.gdb*
CMakeFiles
*.cmake
cmake_install.*
CMakeCache.txt
_build
   + aclocal.m4
autom4te.cache
compile
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
.gdb*
CMakeFiles
*.cmake
cmake_install.*
CMakeCache.txt
_build
geos_svn_revision.h
test-driver
More information about the geos-commits mailing list
