[geos-commits] r3968 - in branches/3.3: src/io tests/unit/io
svn_geos at osgeo.org
Tue Dec 17 10:16:47 PST 2013
Author: strk
Date: 2013-12-17 10:16:47 -0800 (Tue, 17 Dec 2013)
New Revision: 3968
branches/3.3/src/io/WKBReader.cpp
branches/3.3/tests/unit/io/WKBReaderTest.cpp
Throw a ParseException on missing chars from HEXWKB string (#675)
Includes testcase.
Modified: branches/3.3/src/io/WKBReader.cpp
--- branches/3.3/src/io/WKBReader.cpp 2013-12-10 10:03:38 UTC (rev 3967)
+++ branches/3.3/src/io/WKBReader.cpp 2013-12-17 18:16:47 UTC (rev 3968)
@@ -81,14 +81,15 @@
// setup input/output stream
stringstream os(ios_base::binary|ios_base::in|ios_base::out);
- unsigned char high, low, result_high, result_low, value;
+ unsigned char result_high, result_low, value;
+ char high, low;
- while(!is.eof())//readsome(&str[0], 2))
+ while( (high = is.get()) != char_traits<char>::eof() )
- // get the high part of the byte
- is >> high;
// geth the low part of the byte
- is >> low;
+ low = is.get();
+ if ( low == char_traits<char>::eof() )
+ throw ParseException("Premature end of HEX string");
switch (high)
Modified: branches/3.3/tests/unit/io/WKBReaderTest.cpp
--- branches/3.3/tests/unit/io/WKBReaderTest.cpp 2013-12-10 10:03:38 UTC (rev 3967)
+++ branches/3.3/tests/unit/io/WKBReaderTest.cpp 2013-12-17 18:16:47 UTC (rev 3968)
@@ -16,6 +16,7 @@
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
+#include <geos/util/GEOSException.h>
// std
#include <sstream>
#include <string>
@@ -242,6 +243,25 @@
+ // 8 - Invalid HEXWKB for missing HEX char (#675)
+ template<>
+ template<>
+ void object::test<8>()
+ std::stringstream hexwkb;
+ // NOTE: add a 0 to make valid
+ hexwkb << "01010000000000000000000000000000000000000";
+ //hexwkb << "0";
+ std::string err;
+ try {
+ GeomPtr gWKB_ndr(wkbreader.readHEX(hexwkb));
+ } catch (const geos::util::GEOSException& ex) {
+ err = ex.what();
+ ensure("Missing expected error", !err.empty());
+ ensure_equals(err, "ParseException: Premature end of HEX string");
} // namespace tut
More information about the geos-commits
