[geos-commits] r3741 - in trunk: src/algorithm tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Jan 11 06:58:04 PST 2013
Author: strk
Date: 2013-01-11 06:58:04 -0800 (Fri, 11 Jan 2013)
New Revision: 3741
   trunk/src/algorithm/InteriorPointLine.cpp
   trunk/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
Fix GEOSPointOnSurface with zero-length linestring (#609)
Modified: trunk/src/algorithm/InteriorPointLine.cpp
--- trunk/src/algorithm/InteriorPointLine.cpp	2013-01-11 14:35:38 UTC (rev 3740)
+++ trunk/src/algorithm/InteriorPointLine.cpp	2013-01-11 14:58:04 UTC (rev 3741)
@@ -47,8 +47,8 @@
 		std::cerr << "Centroid: " << centroid << std::endl;
 #endif
 		addInterior(g);
-		if (!hasInterior) addEndpoints(g);
+	if (!hasInterior) addEndpoints(g);
 InteriorPointLine::~InteriorPointLine()
@@ -118,8 +118,11 @@
 void
 InteriorPointLine::addEndpoints(const CoordinateSequence *pts)
-	add(pts->getAt(0));
-	add(pts->getAt(pts->getSize()-1));
+  size_t npts = pts->size();
+  if ( npts ) {
+    add(pts->getAt(0));
+    if ( npts > 1 ) add(pts->getAt(npts-1));
 /*private*/
Modified: trunk/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
--- trunk/tests/unit/capi/GEOSPointOnSurfaceTest.cpp	2013-01-11 14:35:38 UTC (rev 3740)
+++ trunk/tests/unit/capi/GEOSPointOnSurfaceTest.cpp	2013-01-11 14:58:04 UTC (rev 3741)
@@ -167,7 +167,25 @@
         wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
         ensure_equals(std::string(wkt_), std::string( "POINT EMPTY"));
+    // Single point linestring -- see http://trac.osgeo.org/geos/ticket/609
+    template<>
+    template<>
+    void object::test<6>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 0 0)");
+        ensure( 0 != geom1_ );
+        geom2_ = GEOSPointOnSurface(geom1_);
+        ensure( 0 != geom2_ );
+        wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+        ensure_equals(std::string(wkt_), std::string( "POINT (0 0)"));
 } // namespace tut
More information about the geos-commits mailing list
