[geos-commits] r3849 - in trunk: include/geos/geom tests/unit/geom
svn_geos at osgeo.org
Thu Jul 25 13:51:22 PDT 2013
Author: strk
Date: 2013-07-25 13:51:22 -0700 (Thu, 25 Jul 2013)
New Revision: 3849
trunk/include/geos/geom/CoordinateList.h
trunk/tests/unit/geom/CoordinateListTest.cpp
closeRing() method added in CoordinateList class
Patch by Vishal Tiwari <hi.vishal123 at gmail.com>
Modified: trunk/include/geos/geom/CoordinateList.h
--- trunk/include/geos/geom/CoordinateList.h 2013-07-23 11:01:38 UTC (rev 3848)
+++ trunk/include/geos/geom/CoordinateList.h 2013-07-25 20:51:22 UTC (rev 3849)
@@ -157,7 +157,16 @@
ret->assign(coords.begin(), coords.end());
return ret;
+ void closeRing()
+ if(!coords.empty() && ! (*(coords.begin())).equals(*(coords.end())))
+ Coordinate c= *(coords.begin());
+ coords.insert(coords.end(),c);
private:
std::list<Coordinate> coords;
Modified: trunk/tests/unit/geom/CoordinateListTest.cpp
--- trunk/tests/unit/geom/CoordinateListTest.cpp 2013-07-23 11:01:38 UTC (rev 3848)
+++ trunk/tests/unit/geom/CoordinateListTest.cpp 2013-07-25 20:51:22 UTC (rev 3849)
@@ -129,6 +129,42 @@
clist.insert(it, Coordinate(0, 0), false);
ensure_equals( clist.size(), 3u );
+ //Test to check the functioning of closeRing() method.
+ template<>
+ template<>
+ void object::test<3>()
+ using geos::geom::Coordinate;
+ const Coordinate a(0,0);
+ const Coordinate b(10,10);
+ const Coordinate c(45,60);
+ const Coordinate d(100,0);
+ std::auto_ptr< std::vector<Coordinate> > v( new std::vector<Coordinate>() );
+ v->push_back(a);
+ v->push_back(b);
+ v->push_back(c);
+ v->push_back(d);
+ geos::geom::CoordinateList coordlist(*v);
+ coordlist.closeRing();
+ geos::geom::CoordinateList::iterator it1,it2;
+ it1 = coordlist.begin();
+ it2 = --coordlist.end();
+ ensure_equals(*it1,*it2);
+ /* for(CoordinateList::iterator it=coordlist.begin() ; it!=coordlist.end() ; ++it)
+ cout << (*it).x << " " << (*it).y << endl;
+ //If the list is empty::
+ coordlist.erase(coordlist.begin(),coordlist.end());
+ ensure_equals(coordlist.empty(), true);
} // namespace tut
More information about the geos-commits
