[geos-commits] r3812 - in trunk/src: algorithm geom geomgraph/index io operation/buffer operation/linemerge operation/polygonize
svn_geos at osgeo.org
Fri Jun 7 02:13:55 PDT 2013
Author: mloskot
Date: 2013-06-07 02:13:55 -0700 (Fri, 07 Jun 2013)
New Revision: 3812
trunk/src/algorithm/RayCrossingCounter.cpp
trunk/src/geom/LineString.cpp
trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp
trunk/src/io/WKBWriter.cpp
trunk/src/operation/buffer/BufferInputLineSimplifier.cpp
trunk/src/operation/linemerge/LineSequencer.cpp
trunk/src/operation/polygonize/PolygonizeGraph.cpp
Correct int and std::size_t mismatch for 64-bit target.
Modified: trunk/src/algorithm/RayCrossingCounter.cpp
--- trunk/src/algorithm/RayCrossingCounter.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/algorithm/RayCrossingCounter.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -43,7 +43,7 @@
RayCrossingCounter rcc(point);
- for (int i = 1, ni = ring.size(); i < ni; i++)
+ for (std::size_t i = 1, ni = ring.size(); i < ni; i++)
const geom::Coordinate & p1 = ring[ i ];
const geom::Coordinate & p2 = ring[ i - 1 ];
@@ -62,7 +62,7 @@
const geom::Coordinate & p1 = *ring[ i ];
const geom::Coordinate & p2 = *ring[ i - 1 ];
Modified: trunk/src/geom/LineString.cpp
--- trunk/src/geom/LineString.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/geom/LineString.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -236,8 +236,8 @@
LineString::isCoordinate(Coordinate& pt) const
assert(points.get());
- int npts=points->getSize();
- for (int i = 0; i<npts; i++) {
+ std::size_t npts=points->getSize();
+ for (std::size_t i = 0; i<npts; i++) {
if (points->getAt(i)==pt) {
return true;
@@ -263,8 +263,8 @@
double miny = c.y;
double maxx = c.x;
double maxy = c.y;
- for (int i=1; i<npts; i++) {
+ for (std::size_t i=1; i<npts; i++) {
const Coordinate &c=points->getAt(i);
minx = minx < c.x ? minx : c.x;
maxx = maxx > c.x ? maxx : c.x;
@@ -330,10 +330,10 @@
LineString::normalize()
- int n=npts/2;
- for (int i=0; i<n; i++) {
- int j = npts - 1 - i;
+ std::size_t n=npts/2;
+ for (std::size_t i=0; i<n; i++) {
+ std::size_t j = npts - 1 - i;
if (!(points->getAt(i)==points->getAt(j))) {
if (points->getAt(i).compareTo(points->getAt(j)) > 0) {
CoordinateSequence::reverse(points.get());
@@ -349,11 +349,11 @@
const LineString *line=dynamic_cast<const LineString*>(ls);
assert(line);
// MD - optimized implementation
- int mynpts=points->getSize();
- int othnpts=line->points->getSize();
+ std::size_t mynpts=points->getSize();
+ std::size_t othnpts=line->points->getSize();
if ( mynpts > othnpts ) return 1;
if ( mynpts < othnpts ) return -1;
- for (int i=0; i<mynpts; i++)
+ for (std::size_t i=0; i<mynpts; i++)
int cmp=points->getAt(i).compareTo(line->points->getAt(i));
if (cmp) return cmp;
Modified: trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp
--- trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/geomgraph/index/SimpleSweepLineIntersector.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -86,8 +86,8 @@
SimpleSweepLineIntersector::add(Edge *edge, void* edgeSet)
const CoordinateSequence *pts=edge->getCoordinates();
- int n=pts->getSize()-1;
- for(int i=0; i<n; ++i)
+ std::size_t n=pts->getSize()-1;
+ for(std::size_t i=0; i<n; ++i)
SweepLineSegment *ss=new SweepLineSegment(edge, i);
SweepLineEvent *insertEvent=new SweepLineEvent(edgeSet, ss->getMinX(), NULL, ss);
Modified: trunk/src/io/WKBWriter.cpp
--- trunk/src/io/WKBWriter.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/io/WKBWriter.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -164,7 +164,7 @@
writeGeometryType(WKBConstants::wkbPolygon, g.getSRID());
writeSRID(g.getSRID());
- int nholes = g.getNumInteriorRing();
+ std::size_t nholes = g.getNumInteriorRing();
writeInt(nholes+1);
const LineString* ls = g.getExteriorRing();
@@ -174,7 +174,7 @@
assert(cs);
writeCoordinateSequence(*cs, true);
- for (int i=0; i<nholes; i++)
+ for (std::size_t i=0; i<nholes; i++)
ls = g.getInteriorRingN(i);
assert(ls);
@@ -195,11 +195,11 @@
writeGeometryType(wkbtype, g.getSRID());
- int ngeoms = g.getNumGeometries();
+ std::size_t ngeoms = g.getNumGeometries();
writeInt(ngeoms);
assert(outStream);
- for (int i=0; i<ngeoms; i++)
+ for (std::size_t i=0; i<ngeoms; i++)
const Geometry* elem = g.getGeometryN(i);
assert(elem);
@@ -272,12 +272,12 @@
WKBWriter::writeCoordinateSequence(const CoordinateSequence &cs,
bool sized)
- int size = cs.getSize();
+ std::size_t size = cs.getSize();
bool is3d=false;
if ( outputDimension > 2) is3d = true;
if (sized) writeInt(size);
- for (int i=0; i<size; i++) writeCoordinate(cs, i, is3d);
+ for (std::size_t i=0; i<size; i++) writeCoordinate(cs, i, is3d);
void
Modified: trunk/src/operation/buffer/BufferInputLineSimplifier.cpp
--- trunk/src/operation/buffer/BufferInputLineSimplifier.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/operation/buffer/BufferInputLineSimplifier.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -113,11 +113,11 @@
unsigned int
BufferInputLineSimplifier::findNextNonDeletedIndex(unsigned int index) const
- unsigned int next = index + 1;
- const unsigned int len = inputLine.size();
+ std::size_t next = index + 1;
+ const std::size_t len = inputLine.size();
while (next < len && isDeleted[next] == DELETE)
next++;
- return next;
+ return static_cast<unsigned int>(next);
/* private */
Modified: trunk/src/operation/linemerge/LineSequencer.cpp
--- trunk/src/operation/linemerge/LineSequencer.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/operation/linemerge/LineSequencer.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -65,7 +65,7 @@
const Coordinate* lastNode = NULL;
- for (unsigned int i=0, n=mls->getNumGeometries(); i<n; ++i)
+ for (std::size_t i=0, n=mls->getNumGeometries(); i<n; ++i)
const LineString* lineptr = \
dynamic_cast<const LineString*>(mls->getGeometryN(i));
Modified: trunk/src/operation/polygonize/PolygonizeGraph.cpp
--- trunk/src/operation/polygonize/PolygonizeGraph.cpp 2013-06-07 09:10:16 UTC (rev 3811)
+++ trunk/src/operation/polygonize/PolygonizeGraph.cpp 2013-06-07 09:13:55 UTC (rev 3812)
@@ -382,7 +382,7 @@
* Must use a SIGNED int here to allow for beak condition
* to be true.
- for(int i=edges.size()-1; i>=0; --i)
+ for(int i=static_cast<int>(edges.size())-1; i>=0; --i)
PolygonizeDirectedEdge *de=(PolygonizeDirectedEdge*)edges[i];
PolygonizeDirectedEdge *sym=(PolygonizeDirectedEdge*) de->getSym();
More information about the geos-commits
