[geos-commits] r3792 - in trunk: . capi tests/unit tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Mar 15 11:05:58 PDT 2013
Author: strk
Date: 2013-03-15 11:05:58 -0700 (Fri, 15 Mar 2013)
New Revision: 3792
Added:
   trunk/tests/unit/capi/GEOSNearestPointsTest.cpp
   trunk/NEWS
   trunk/capi/geos_c.cpp
   trunk/capi/geos_c.h.in
   trunk/capi/geos_ts_c.cpp
   trunk/tests/unit/Makefile.am
Add GEOSNearestPoints CAPI function
Contributed by Richard Frith-Macdonald <richard at tiptree.demon.co.uk>
Modified: trunk/NEWS
--- trunk/NEWS	2013-03-15 15:36:19 UTC (rev 3791)
+++ trunk/NEWS	2013-03-15 18:05:58 UTC (rev 3792)
@@ -9,6 +9,7 @@
   - BufferInputLineSimplifier header exposed (#548)
   - New Centroid class supporting mixed geometry components (#612)
   - io::Writer::reserve() method
+  - CAPI: GEOSNearestPoints
 - C++ API changes:
   - New noding::GeometryNoder class
   - Added BufferOp::setSingleSided
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp	2013-03-15 15:36:19 UTC (rev 3791)
+++ trunk/capi/geos_c.cpp	2013-03-15 18:05:58 UTC (rev 3792)
@@ -302,6 +302,12 @@
     return GEOSLength_r( handle, g, length );
+CoordinateSequence *
+GEOSNearestPoints(const Geometry *g1, const Geometry *g2)
+    return GEOSNearestPoints_r( handle, g1, g2 );
 Geometry *
 GEOSGeomFromWKT(const char *wkt)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in	2013-03-15 15:36:19 UTC (rev 3791)
+++ trunk/capi/geos_c.h.in	2013-03-15 18:05:58 UTC (rev 3792)
@@ -1191,6 +1191,15 @@
 extern int GEOS_DLL GEOSGeomGetLength_r(GEOSContextHandle_t handle,
                                    const GEOSGeometry *g1, double *length);
+/* Return 0 on exception, the closest points of the two geometries otherwise.
+ * The first point comes from g1 geometry and the second point comes from g2.
+extern GEOSCoordSequence GEOS_DLL *GEOSNearestPoints(
+  const GEOSGeometry* g1, const GEOSGeometry* g2);
+extern GEOSCoordSequence GEOS_DLL *GEOSNearestPoints_r(
+  GEOSContextHandle_t handle, const GEOSGeometry* g1, const GEOSGeometry* g2);
  * Algorithms
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2013-03-15 15:36:19 UTC (rev 3791)
+++ trunk/capi/geos_ts_c.cpp	2013-03-15 18:05:58 UTC (rev 3792)
@@ -46,17 +46,18 @@
 #include <geos/simplify/DouglasPeuckerSimplifier.h>
 #include <geos/simplify/TopologyPreservingSimplifier.h>
 #include <geos/noding/GeometryNoder.h>
-#include <geos/operation/valid/IsValidOp.h>
-#include <geos/operation/polygonize/Polygonizer.h>
+#include <geos/operation/buffer/BufferBuilder.h>
+#include <geos/operation/buffer/BufferOp.h>
+#include <geos/operation/buffer/BufferParameters.h>
+#include <geos/operation/distance/DistanceOp.h>
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/operation/overlay/OverlayOp.h>
 #include <geos/operation/overlay/snap/GeometrySnapper.h>
-#include <geos/operation/union/CascadedPolygonUnion.h>
-#include <geos/operation/buffer/BufferOp.h>
-#include <geos/operation/buffer/BufferParameters.h>
-#include <geos/operation/buffer/BufferBuilder.h>
+#include <geos/operation/polygonize/Polygonizer.h>
 #include <geos/operation/relate/RelateOp.h>
 #include <geos/operation/sharedpaths/SharedPathsOp.h>
+#include <geos/operation/union/CascadedPolygonUnion.h>
+#include <geos/operation/valid/IsValidOp.h>
 #include <geos/linearref/LengthIndexedLine.h>
 #include <geos/triangulate/DelaunayTriangulationBuilder.h>
 #include <geos/util/IllegalArgumentException.h>
@@ -1150,6 +1151,39 @@
     return 0;
+GEOSNearestPoints_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
+    if ( 0 == extHandle )
+        return NULL;
+    GEOSContextHandleInternal_t *handle = 0;
+    handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+    if ( 0 == handle->initialized )
+        return NULL;
+    try
+        if (g1->isEmpty() || g2->isEmpty()) return 0;
+        return geos::operation::distance::DistanceOp::nearestPoints(g1, g2);
+    catch (const std::exception &e)
+        handle->ERROR_MESSAGE("%s", e.what());
+    catch (...)
+        handle->ERROR_MESSAGE("Unknown exception thrown");
+    return NULL;
 Geometry *
 GEOSGeomFromWKT_r(GEOSContextHandle_t extHandle, const char *wkt)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2013-03-15 15:36:19 UTC (rev 3791)
+++ trunk/tests/unit/Makefile.am	2013-03-15 18:05:58 UTC (rev 3792)
@@ -116,10 +116,11 @@
 	capi/GEOSDistanceTest.cpp \
 	capi/GEOSInterruptTest.cpp \
 	capi/GEOSIntersectsTest.cpp \
+	capi/GEOSNearestPointsTest.cpp \
 	capi/GEOSWithinTest.cpp \
 	capi/GEOSSimplifyTest.cpp \
 	capi/GEOSPreparedGeometryTest.cpp \
-  capi/GEOSPointOnSurfaceTest.cpp \
+	capi/GEOSPointOnSurfaceTest.cpp \
 	capi/GEOSPolygonizer_getCutEdgesTest.cpp \
 	capi/GEOSBufferTest.cpp \
 	capi/GEOSOffsetCurveTest.cpp \
Added: trunk/tests/unit/capi/GEOSNearestPointsTest.cpp
--- trunk/tests/unit/capi/GEOSNearestPointsTest.cpp	                        (rev 0)
+++ trunk/tests/unit/capi/GEOSNearestPointsTest.cpp	2013-03-15 18:05:58 UTC (rev 3792)
@@ -0,0 +1,120 @@
+// $Id: GEOSNearestPointsTest.cpp 2424 2009-04-29 23:52:36Z mloskot $
+// Test Suite for C-API GEOSNearestPoints
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+    // Test Group
+    // Common data used in test cases.
+    struct test_capigeosnearestpoints_data
+        GEOSGeometry *geom1_;
+        GEOSGeometry *geom2_;
+        static void notice(const char *fmt, ...)
+            std::fprintf( stdout, "NOTICE: ");
+            va_list ap;
+            va_start(ap, fmt);
+            std::vfprintf(stdout, fmt, ap);
+            va_end(ap);
+            std::fprintf(stdout, "\n");
+        test_capigeosnearestpoints_data()
+            : geom1_(0), geom2_(0)
+            initGEOS(notice, notice);
+        ~test_capigeosnearestpoints_data()
+            GEOSGeom_destroy(geom1_);
+            GEOSGeom_destroy(geom2_);
+            geom1_ = 0;
+            geom2_ = 0;
+            finishGEOS();
+    typedef test_group<test_capigeosnearestpoints_data> group;
+    typedef group::object object;
+    group test_capigeosnearestpoints_group("capi::GEOSNearestPoints");
+    // Test Cases
+    template<>
+    template<>
+    void object::test<1>()
+        geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+        geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
+        ensure( 0 != geom1_ );
+        ensure( 0 != geom2_ );
+        GEOSCoordSequence *coords_;
+        coords_ = GEOSNearestPoints(geom1_, geom2_);
+        ensure( 0 == coords_ );
+    template<>
+    template<>
+    void object::test<2>()
+        geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
+        // geom2_ = GEOSGeomFromWKT("POINT(8 8)");
+        geom2_ = GEOSGeomFromWKT("POLYGON((8 8, 9 9, 9 10, 8 8))");
+        ensure( 0 != coords_ );
+        unsigned int size;
+        GEOSCoordSeq_getSize(coords_, &size);
+        ensure( 2 == size );
+        double  x1, x2, y1, y2;
+        /* Point in geom1_
+        GEOSCoordSeq_getOrdinate(coords_, 0, 0, &x1);
+        GEOSCoordSeq_getOrdinate(coords_, 0, 1, &y1);
+        /* Point in geom2_
+        GEOSCoordSeq_getOrdinate(coords_, 1, 0, &x2);
+        GEOSCoordSeq_getOrdinate(coords_, 1, 1, &y2);
+        ensure( 5 == x1 );
+        ensure( 5 == y1 );
+        ensure( 8 == x2 );
+        ensure( 8 == y2 );
+        GEOSCoordSeq_destroy(coords_);
+} // namespace tut
More information about the geos-commits mailing list
