[geos-commits] r3961 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Nov 19 00:58:04 PST 2013
Author: strk
Date: 2013-11-19 00:58:04 -0800 (Tue, 19 Nov 2013)
New Revision: 3961
   trunk/configure.in
Do not try to build python and ruby bindings without swig (#673)
Modified: trunk/configure.in
--- trunk/configure.in	2013-11-19 08:26:42 UTC (rev 3960)
+++ trunk/configure.in	2013-11-19 08:58:04 UTC (rev 3961)
@@ -276,13 +276,15 @@
 use_swig=false
 if test x"$use_python" = xtrue ||
    test x"$use_ruby" = xtrue; then
-	AC_PROG_SWIG(1.3.28)
-	if test x"$SWIG" != "x"; then
-	    SWIG_ENABLE_CXX
-            AC_SUBST(SWIG)
-            use_swig=true
-	fi
+  AC_PROG_SWIG(1.3.28)
+  if test x"$SWIG" != "x"; then
+    SWIG_ENABLE_CXX
+    AC_SUBST(SWIG)
+    use_swig=true
+  else
+    use_python=false
+    use_ruby=false
+  fi
 fi
 AM_CONDITIONAL(ENABLE_SWIG, [ test x"$use_swig" = xtrue ])
@@ -293,8 +295,8 @@
 if test x"$use_python" = xtrue; then
 	dnl Check for Python
-        AM_PATH_PYTHON
-        SWIG_PYTHON
+  AM_PATH_PYTHON
+  SWIG_PYTHON
 	if test x"$PYTHON" = "x"; then
 		use_python=false
More information about the geos-commits mailing list
