[geos-commits] r3941 - in branches/3.3: . tools tools/ci
svn_geos at osgeo.org
Wed Sep 4 15:04:52 PDT 2013
Author: mloskot
Date: 2013-09-04 15:04:51 -0700 (Wed, 04 Sep 2013)
New Revision: 3941
Added:
branches/3.3/.travis.yml
branches/3.3/tools/ci/
branches/3.3/tools/ci/before_install.sh
branches/3.3/tools/ci/before_install_autotools.sh
branches/3.3/tools/ci/before_install_cmake.sh
branches/3.3/tools/ci/common.sh
branches/3.3/tools/ci/script.sh
branches/3.3/tools/ci/script_autotools.sh
branches/3.3/tools/ci/script_cmake.sh
Add Travis CI service to branches/3.3
Added: branches/3.3/.travis.yml
--- branches/3.3/.travis.yml (rev 0)
+++ branches/3.3/.travis.yml 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,40 @@
+# .travis.yml - Travis CI service confiuration for GEOS
+# Copyright (C) 2013 Mateusz Loskot <mateusz at loskot.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+language: cpp
+compiler:
+ - g++
+ - clang
+env:
+ matrix:
+ - GEOS_BUILD_TOOL=autotools CFLAGS=-m32 CXXFLAGS=-m32
+ - GEOS_BUILD_TOOL=autotools CFLAGS=-m64 CXXFLAGS=-m64
+ - GEOS_BUILD_TOOL=cmake CFLAGS=-m32 CXXFLAGS=-m32
+ - GEOS_BUILD_TOOL=cmake CFLAGS=-m64 CXXFLAGS=-m64
+before_install: ./tools/ci/before_install.sh
+script: ./tools/ci/script.sh
+notifications:
+ irc:
+ channels:
+ - "chat.freenode.net#postgis"
+ on_success: always # [always|never|change] # default: change
+ on_failure: always # [always|never|change] # default: always
+ use_notice: true
+ email:
+ recipients:
+ #- geos-devel at lists.osgeo.org # TODO: whitelist this e-mail
+ - mateusz at loskot.net
+ on_success: change
Added: branches/3.3/tools/ci/before_install.sh
--- branches/3.3/tools/ci/before_install.sh (rev 0)
+++ branches/3.3/tools/ci/before_install.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,19 @@
+#!/bin/bash -e
+# Travis CI before_install runner for GEOS
+# Copyright (c) 2013 Mateusz Loskot <mateusz at loskot.net>
+source ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
+sudo apt-get update -qq
+sudo apt-get install -qq gcc-multilib g++-multilib
+before_install="${TRAVIS_BUILD_DIR}/tools/ci/before_install_${GEOS_BUILD_TOOL}.sh"
+[ -x ${before_install} ] && ${before_install} || echo "nothing to run"
Property changes on: branches/3.3/tools/ci/before_install.sh
___________________________________________________________________
Added: svn:executable
Added: branches/3.3/tools/ci/before_install_autotools.sh
--- branches/3.3/tools/ci/before_install_autotools.sh (rev 0)
+++ branches/3.3/tools/ci/before_install_autotools.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,14 @@
+#!/bin/bash -e
+# Travis CI before_install for GEOS build with GNU Autotools
+sudo apt-get install -qq make
Property changes on: branches/3.3/tools/ci/before_install_autotools.sh
Added: branches/3.3/tools/ci/before_install_cmake.sh
--- branches/3.3/tools/ci/before_install_cmake.sh (rev 0)
+++ branches/3.3/tools/ci/before_install_cmake.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,14 @@
+#!/bin/bash -e
+# Travis CI before_install for GEOS build with CMake
+sudo apt-get install -qq cmake
Property changes on: branches/3.3/tools/ci/before_install_cmake.sh
Added: branches/3.3/tools/ci/common.sh
--- branches/3.3/tools/ci/common.sh (rev 0)
+++ branches/3.3/tools/ci/common.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,42 @@
+#!/bin/bash -e
+# Common utilities for Travis CI setup for GEOS
+if [[ "$TRAVIS" != "true" ]] ; then
+ echo "Running this script makes no sense outside of travis-ci.org"
+ exit 1
+fi
+# Environment
+TCI_NUMTHREADS=2
+if [[ -f /sys/devices/system/cpu/online ]]; then
+ # Calculates 1.5 times physical threads
+ TCI_NUMTHREADS=$(( ( $(cut -f 2 -d '-' /sys/devices/system/cpu/online) + 1 ) * 15 / 10 ))
+fi
+# Functions
+tmstamp()
+ echo -n "[$(date '+%H:%M:%S')]" ;
+run_make()
+ [ $TCI_NUMTHREADS -gt 0 ] && make -j $TCI_NUMTHREADS || make
+run_test()
+ [ -f CMakeCache.txt ] && \
+ ctest -V --output-on-failure . || \
+ make check
Added: branches/3.3/tools/ci/script.sh
--- branches/3.3/tools/ci/script.sh (rev 0)
+++ branches/3.3/tools/ci/script.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,20 @@
+#!/bin/bash -e
+# Travis CI script runner for GEOS
+# prepare build directory
+builddir="${TRAVIS_BUILD_DIR}/_build"
+mkdir -p ${builddir}
+cd ${builddir}
+# build and run tests
+${TRAVIS_BUILD_DIR}/tools/ci/script_${GEOS_BUILD_TOOL}.sh
Property changes on: branches/3.3/tools/ci/script.sh
Added: branches/3.3/tools/ci/script_autotools.sh
--- branches/3.3/tools/ci/script_autotools.sh (rev 0)
+++ branches/3.3/tools/ci/script_autotools.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,19 @@
+#!/bin/bash -e
+# Travis CI script for GEOS build with GNU Autotools
+cd ${TRAVIS_BUILD_DIR}
+./autogen.sh
+cd -
+${TRAVIS_BUILD_DIR}/configure
+run_make
+run_test
Property changes on: branches/3.3/tools/ci/script_autotools.sh
Added: branches/3.3/tools/ci/script_cmake.sh
--- branches/3.3/tools/ci/script_cmake.sh (rev 0)
+++ branches/3.3/tools/ci/script_cmake.sh 2013-09-04 22:04:51 UTC (rev 3941)
@@ -0,0 +1,16 @@
+#!/bin/bash -e
+# Travis CI script for GEOS build with CMake
+cmake ${TRAVIS_BUILD_DIR}
+run_make
+run_test
Property changes on: branches/3.3/tools/ci/script_cmake.sh
More information about the geos-commits
