[geos-commits] r3944 - in trunk: include/geos/triangulate/quadedge src/triangulate/quadedge tests/unit/triangulate/quadedge
svn_geos at osgeo.org
Sat Sep 7 13:11:58 PDT 2013
Author: strk
Date: 2013-09-07 13:11:58 -0700 (Sat, 07 Sep 2013)
New Revision: 3944
trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
Voronoi APIs added to QuadEdgeSubdivision class, with test added
Contributed by Vishal Tiwari
Modified: trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
--- trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h 2013-09-04 23:15:33 UTC (rev 3943)
+++ trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h 2013-09-07 20:11:58 UTC (rev 3944)
@@ -23,8 +23,8 @@
#include <list>
#include <stack>
#include <set>
+#include <vector>
-#include <geos/geom/Envelope.h>
#include <geos/geom/MultiLineString.h>
#include <geos/triangulate/quadedge/QuadEdgeLocator.h>
#include <geos/triangulate/quadedge/Vertex.h>
@@ -37,6 +37,8 @@
class GeometryCollection;
class GeometryFactory;
class Coordinate;
+ class Geometry;
+ class Envelope;
namespace triangulate { //geos.triangulate
@@ -372,7 +374,8 @@
void getTriangleCoordinates(TriList* triList, bool includeFrame);
private:
- class TriangleCoordinatesVisitor;
+ class TriangleCoordinatesVisitor;
+ class TriangleCircumcentreVisitor;
public:
@@ -392,7 +395,61 @@
* @return a GeometryCollection of triangular Polygons. The caller takes ownership of the returned object.
std::auto_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory &geomFact);
+ * Gets the cells in the Voronoi diagram for this triangulation.
+ * The cells are returned as a {@link GeometryCollection} of {@link Polygon}s
+ * The userData of each polygon is set to be the {@link Coordinate}
+ * of the cell site. This allows easily associating external
+ * data associated with the sites to the cells.
+ * @param geomFact a geometry factory
+ * @return a GeometryCollection of Polygons
+ std::auto_ptr<geom::GeometryCollection> getVoronoiDiagram(const geom::GeometryFactory& geomFact);
+ * Gets a List of {@link Polygon}s for the Voronoi cells
+ * of this triangulation.
+ * @return a List of Polygons
+ std::auto_ptr< std::vector<geom::Geometry*> > getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
+ * Gets a collection of {@link QuadEdge}s whose origin
+ * vertices are a unique set which includes
+ * all vertices in the subdivision.
+ * The frame vertices can be included if required.
+ * This is useful for algorithms which require traversing the
+ * subdivision starting at all vertices.
+ * Returning a quadedge for each vertex
+ * is more efficient than
+ * the alternative of finding the actual vertices
+ * using {@link #getVertices} and then locating
+ * quadedges attached to them.
+ * @param includeFrame true if the frame vertices should be included
+ * @return a collection of QuadEdge with the vertices of the subdivision as their origins
+ std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList> getVertexUniqueEdges(bool includeFrame);
+ * Gets the Voronoi cell around a site specified
+ * by the origin of a QuadEdge.
+ * The userData of the polygon is set to be the {@link Coordinate}
+ * of the site. This allows attaching external
+ * data associated with the site to this cell polygon.
+ * @param qe a quadedge originating at the cell site
+ * @param geomFact a factory for building the polygon
+ * @return a polygon indicating the cell extent
+ std::auto_ptr<geom::Geometry> getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
} //namespace geos.triangulate.quadedge
Modified: trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
--- trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2013-09-04 23:15:33 UTC (rev 3943)
+++ trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2013-09-07 20:11:58 UTC (rev 3944)
@@ -18,6 +18,8 @@
#include <geos/triangulate/quadedge/QuadEdgeSubdivision.h>
#include <vector>
+#include <set>
+#include <iostream>
#include <geos/geom/Polygon.h>
#include <geos/geom/LineSegment.h>
@@ -26,6 +28,7 @@
#include <geos/geom/CoordinateArraySequence.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/CoordinateArraySequenceFactory.h>
+#include <geos/geom/CoordinateList.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/util/IllegalArgumentException.h>
@@ -35,9 +38,11 @@
#include <geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h>
#include <geos/triangulate/quadedge/LocateFailureException.h>
#include <geos/triangulate/quadedge/TriangleVisitor.h>
+#include <geos/geom/Triangle.h>
using namespace geos::geom;
+using namespace std;
namespace geos {
namespace quadedge { //geos.triangulate.quadedge
@@ -389,6 +394,27 @@
+class
+QuadEdgeSubdivision::TriangleCircumcentreVisitor : public TriangleVisitor
+public:
+ void visit(QuadEdge* triEdges[3])
+ Triangle triangle(triEdges[0]->orig().getCoordinate(),
+ triEdges[1]->orig().getCoordinate(), triEdges[2]->orig().getCoordinate());
+ Coordinate cc;
+ triangle.circumcentre(cc);
+ Vertex ccVertex(cc);
+ for(int i=0 ; i<3 ; i++){
+ triEdges[i]->rot().setOrig(ccVertex);
void
QuadEdgeSubdivision::getTriangleCoordinates(QuadEdgeSubdivision::TriList* triList, bool includeFrame)
@@ -470,6 +496,102 @@
return std::auto_ptr<GeometryCollection>(ret);
+//Methods for VoronoiDiagram
+std::auto_ptr<geom::GeometryCollection>
+QuadEdgeSubdivision::getVoronoiDiagram(const geom::GeometryFactory& geomFact)
+ std::auto_ptr< std::vector<geom::Geometry*> > vorCells = getVoronoiCellPolygons(geomFact);
+ return std::auto_ptr<GeometryCollection>(geomFact.createGeometryCollection(vorCells.release()));
+std::auto_ptr< std::vector<geom::Geometry*> >
+QuadEdgeSubdivision::getVoronoiCellPolygons(const geom::GeometryFactory& geomFact)
+ std::auto_ptr< std::vector<geom::Geometry*> > cells(new std::vector<geom::Geometry*>);
+ TriangleCircumcentreVisitor* tricircumVisitor = new TriangleCircumcentreVisitor();
+ visitTriangles((TriangleVisitor*)tricircumVisitor, true);
+ std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList> edges = getVertexUniqueEdges(false);
+ for(QuadEdgeSubdivision::QuadEdgeList::iterator it=edges->begin() ; it!=edges->end() ; ++it)
+ QuadEdge *qe = *it;
+ std::auto_ptr<geom::Geometry> poly = getVoronoiCellPolygon(qe,geomFact);
+ cells->push_back(poly.release());
+ delete tricircumVisitor;
+ return cells;
+std::auto_ptr<geom::Geometry>
+QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFactory& geomFact)
+ std::vector<Coordinate> cellPts;
+ QuadEdge *startQE = qe;
+ do{
+ Coordinate cc = qe->rot().orig().getCoordinate();
+ cellPts.push_back(cc);
+ qe = &qe->oPrev();
+ }while ( qe != startQE);
+ //CoordList from a vector of Coordinates.
+ geom::CoordinateList coordList(cellPts);
+ //for checking close ring in CoordList class:
+ coordList.closeRing();
+ if(coordList.size() < 4)
+ cout << coordList << endl;
+ coordList.insert(coordList.end(),*(coordList.end()),true);
+ std::auto_ptr<Coordinate::Vect> pts = coordList.toCoordinateArray();
+ std::auto_ptr<geom::Geometry> cellPoly(
+ geomFact.createPolygon(geomFact.createLinearRing(new geom::CoordinateArraySequence(pts.release())),NULL));
+ Vertex v = startQE->orig();
+ Coordinate c(0,0);
+ c = v.getCoordinate();
+ cellPoly->setUserData(reinterpret_cast<void*>(&c));
+ return cellPoly;
+std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList>
+QuadEdgeSubdivision::getVertexUniqueEdges(bool includeFrame)
+ std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList> edges(new QuadEdgeList());
+ std::set<Vertex> visitedVertices;
+ for(QuadEdgeSubdivision::QuadEdgeList::iterator it=quadEdges.begin() ; it!=quadEdges.end() ; ++it)
+ QuadEdge *qe = (QuadEdge*)(*it);
+ Vertex v = qe->orig();
+ if(visitedVertices.find(v) == visitedVertices.end()) //if v not found
+ visitedVertices.insert(v);
+ if(includeFrame || ! QuadEdgeSubdivision::isFrameVertex(v))
+ edges->push_back(qe);
+ QuadEdge *qd = &(qe->sym());
+ Vertex vd = qd->orig();
+ if(visitedVertices.find(vd) == visitedVertices.end()){
+ visitedVertices.insert(vd);
+ if(includeFrame || ! QuadEdgeSubdivision::isFrameVertex(vd)){
+ edges->push_back(qd);
+ return edges;
} //namespace goes
Modified: trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
--- trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp 2013-09-04 23:15:33 UTC (rev 3943)
+++ trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp 2013-09-07 20:11:58 UTC (rev 3944)
@@ -8,15 +8,19 @@
#include <geos/triangulate/quadedge/QuadEdge.h>
+#include <geos/triangulate/DelaunayTriangulationBuilder.h>
+#include <geos/geom/CoordinateSequence.h>
//#include <geos/io/WKTWriter.h>
+#include <geos/io/WKTReader.h>
#include <geos/geom/Coordinate.h>
// std
#include <stdio.h>
using namespace geos::triangulate::quadedge;
+using namespace geos::triangulate;
using namespace geos::io;
@@ -66,7 +70,43 @@
//WKTWriter wkt;
//printf("%s\n", wkt.writeFormatted(tris).c_str());
+ template<>
+ template<>
+ void object::test<2>()
+ WKTReader reader;
+ Geometry* sites;
+ QuadEdgeSubdivision* subdiv;
+ sites = reader.read("MULTIPOINT ((150 200), (180 270), (275 163))");
+ CoordinateSequence* siteCoords = DelaunayTriangulationBuilder::extractUniqueCoordinates(*sites);
+ Envelope Env = DelaunayTriangulationBuilder::envelope(*siteCoords);
+ double expandBy = fmax(Env.getWidth() , Env.getHeight());
+ Env.expandBy(expandBy);
+ IncrementalDelaunayTriangulator::VertexList* vertices = DelaunayTriangulationBuilder::toVertices(*siteCoords);
+ subdiv = new quadedge::QuadEdgeSubdivision(Env,0);
+ IncrementalDelaunayTriangulator triangulator(subdiv);
+ triangulator.insertSites(*vertices);
+ //Test for getVoronoiDiagram::
+ GeometryFactory geomFact;
+ std::auto_ptr<GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
+ const char *expected_str = "GEOMETRYCOLLECTION (POLYGON ((-5849.974929324658 2268.0517257497568, -4529.9920486948895 2247.139449440667, 221.20588235294116 210.91176470588235, -684.4227119984187 -2848.644297291955, -5849.974929324658 2268.0517257497568)), POLYGON ((212.5 -3774.5, -684.4227119984187 -2848.644297291955, 221.20588235294116 210.91176470588235, 2448.7167655626645 2188.608343256571, 6235.0370264064295 2248.0370264064295, 212.5 -3774.5)), POLYGON ((-4529.9920486948895 2247.139449440667, 2448.7167655626645 2188.608343256571, 221.20588235294116 210.91176470588235, -4529.9920486948895 2247.139449440667)))";
+// std::cout << polys->toString() << std::endl;
+ Geometry *expected = reader.read(expected_str);
+ polys->normalize();
+ expected->normalize();
+ ensure(polys->equalsExact(expected, 1e-7));
+ delete siteCoords;
+ delete sites;
+ delete subdiv;
+ delete vertices;
+ delete expected;
+// ensure(polys->getCoordinateDimension() == expected->getCoordinateDimension());
} // namespace tut
More information about the geos-commits
