[geos-commits] r3946 - trunk
svn_geos at osgeo.org
Tue Sep 10 00:06:18 PDT 2013
Author: strk
Date: 2013-09-10 00:06:18 -0700 (Tue, 10 Sep 2013)
New Revision: 3946
trunk/COPYING
Fix FSF address in license file (#662)
Modified: trunk/COPYING
--- trunk/COPYING 2013-09-07 21:41:24 UTC (rev 3945)
+++ trunk/COPYING 2013-09-10 07:06:18 UTC (rev 3946)
@@ -1,8 +1,8 @@
- GNU LESSER GENERAL PUBLIC LICENSE
- Version 2.1, February 1999
+ GNU LESSER GENERAL PUBLIC LICENSE
+ Version 2.1, February 1999
Copyright (C) 1991, 1999 Free Software Foundation, Inc.
- 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+ 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
Everyone is permitted to copy and distribute verbatim copies
of this license document, but changing it is not allowed.
@@ -10,7 +10,7 @@
as the successor of the GNU Library Public License, version 2, hence
the version number 2.1.]
- Preamble
+ Preamble
The licenses for most software are designed to take away your
freedom to share and change it. By contrast, the GNU General Public
@@ -112,7 +112,7 @@
former contains code derived from the library, whereas the latter must
be combined with the library in order to run.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
0. This License Agreement applies to any software library or other
@@ -146,7 +146,7 @@
on the Library (independent of the use of the Library in a tool for
writing it). Whether that is true depends on what the Library does
and what the program that uses the Library does.
1. You may copy and distribute verbatim copies of the Library's
complete source code as you receive it, in any medium, provided that
you conspicuously and appropriately publish on each copy an
@@ -432,7 +432,7 @@
of all derivatives of our free software and of promoting the sharing
and reuse of software generally.
- NO WARRANTY
+ NO WARRANTY
15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
@@ -455,7 +455,7 @@
SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
DAMAGES.
- END OF TERMS AND CONDITIONS
+ END OF TERMS AND CONDITIONS
How to Apply These Terms to Your New Libraries
@@ -485,7 +485,7 @@
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+ Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
Also add information on how to contact you by electronic and paper mail.
@@ -500,5 +500,3 @@
Ty Coon, President of Vice
That's all there is to it!
More information about the geos-commits
