[geos-commits] r4037 - trunk/src/io
svn_geos at osgeo.org
Wed Nov 26 07:33:49 PST 2014
Author: mloskot
Date: 2014-11-26 07:33:49 -0800 (Wed, 26 Nov 2014)
New Revision: 4037
trunk/src/io/StringTokenizer.cpp
Fix MSVC handling of strtod (Thanks to Paul Kohut for the patch submitted as part of https://github.com/libgeos/libgeos/pull/31/)
Apparently, it solves the long running INF/NAN parsing issues on Windows and enables GEOSisValidDetail test pass again.
It should also solve problems reported as part of ticket #509.
Modified: trunk/src/io/StringTokenizer.cpp
--- trunk/src/io/StringTokenizer.cpp 2014-11-26 14:58:35 UTC (rev 4036)
+++ trunk/src/io/StringTokenizer.cpp 2014-11-26 15:33:49 UTC (rev 4037)
@@ -37,6 +37,41 @@
iter=str.begin();
+double strtod_with_vc_fix(const char * str, char ** str_end)
+ double dbl = strtod(str, str_end);
+#if _MSC_VER && !__INTEL_COMPILER
+ // Special handling of NAN and INF in MSVC, where strtod returns 0.0
+ // for NAN and INF.
+ // This fixes failing test GEOSisValidDetail::test<3>, maybe others
+ // as well.
+ // Note: this hack is not robust, Boost lexical_cast or
+ // std::stod (C++11) would be better.
+ if (*str_end[0] != '\0')
+ char sign = 0;
+ const char *pos = str;
+ if (*pos == '+' || *pos == '-')
+ sign = *pos++;
+ if (stricmp(pos, "inf") == 0)
+ if (!sign || sign == '+')
+ dbl = std::numeric_limits<double>::infinity();
+ else
+ dbl = -(std::numeric_limits<double>::infinity)();
+ *str_end[0] = '\0';
+ else if (stricmp(pos, "nan") == 0)
+ dbl = std::numeric_limits<double>::quiet_NaN();
+#endif
+ return dbl;
/*public*/
int
StringTokenizer::nextToken()
@@ -76,7 +111,7 @@
iter=str.begin()+pos;
char *stopstring;
- double dbl=strtod(tok.c_str(),&stopstring);
+ double dbl=strtod_with_vc_fix(tok.c_str(),&stopstring);
if (*stopstring=='\0') {
ntok=dbl;
stok="";
@@ -124,7 +159,7 @@
char *stopstring;
+ double dbl = strtod_with_vc_fix(tok.c_str(), &stopstring);
ntok=dbl;
stok="";
More information about the geos-commits
