[geos-commits] r4000 - in branches/3.4: . src/geom tests/unit tests/unit/geom tests/unit/geom/Geometry
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Sep 9 07:36:35 PDT 2014
Author: strk
Date: 2014-09-09 07:36:35 -0700 (Tue, 09 Sep 2014)
New Revision: 4000
Added:
   branches/3.4/tests/unit/geom/Geometry/equalsTest.cpp
   branches/3.4/NEWS
   branches/3.4/src/geom/Envelope.cpp
   branches/3.4/src/geom/Geometry.cpp
   branches/3.4/tests/unit/Makefile.am
   branches/3.4/tests/unit/geom/EnvelopeTest.cpp
   branches/3.4/tests/unit/geom/PointTest.cpp
Fix Empty to Empty equals response (#703)
Modified: branches/3.4/NEWS
--- branches/3.4/NEWS	2014-09-09 14:35:51 UTC (rev 3999)
+++ branches/3.4/NEWS	2014-09-09 14:36:35 UTC (rev 4000)
@@ -2,6 +2,7 @@
 YYYY-MM-DD
 - Bug fixes / improvements
+ - Fix Empty to Empty equals (#703)
  - Fix build on OpenBSD (#700)
  - Fix build on HP-UX 11.23 (#664)
  - Throw a ParseException on missing chars from HEXWKB string (#675)
Modified: branches/3.4/src/geom/Envelope.cpp
--- branches/3.4/src/geom/Envelope.cpp	2014-09-09 14:35:51 UTC (rev 3999)
+++ branches/3.4/src/geom/Envelope.cpp	2014-09-09 14:36:35 UTC (rev 4000)
@@ -325,7 +325,7 @@
 bool
 Envelope::equals(const Envelope* other) const
-	if (isNull() || other->isNull()) { return false; }
+	if (isNull()) return other->isNull();
 	return  other->getMinX() == minx &&
 			other->getMaxX() == maxx &&
 			other->getMinY() == miny &&
Modified: branches/3.4/src/geom/Geometry.cpp
--- branches/3.4/src/geom/Geometry.cpp	2014-09-09 14:35:51 UTC (rev 3999)
+++ branches/3.4/src/geom/Geometry.cpp	2014-09-09 14:36:35 UTC (rev 4000)
@@ -435,6 +435,10 @@
 	if (! getEnvelopeInternal()->equals(g->getEnvelopeInternal()))
 		return false;
 #endif
+	if (isEmpty()) return g->isEmpty();
+	else if (g->isEmpty()) return isEmpty();
 	auto_ptr<IntersectionMatrix> im ( relate(g) );
 	bool res=im->isEquals(getDimension(), g->getDimension());
 	return res;
Modified: branches/3.4/tests/unit/Makefile.am
--- branches/3.4/tests/unit/Makefile.am	2014-09-09 14:35:51 UTC (rev 3999)
+++ branches/3.4/tests/unit/Makefile.am	2014-09-09 14:36:35 UTC (rev 4000)
@@ -49,6 +49,7 @@
 	geom/EnvelopeTest.cpp \
 	geom/Geometry/clone.cpp \
 	geom/Geometry/coversTest.cpp \
+	geom/Geometry/equalsTest.cpp \
 	geom/Geometry/isRectangleTest.cpp \
 	geom/GeometryFactoryTest.cpp \
 	geom/IntersectionMatrixTest.cpp \
Modified: branches/3.4/tests/unit/geom/EnvelopeTest.cpp
--- branches/3.4/tests/unit/geom/EnvelopeTest.cpp	2014-09-09 14:35:51 UTC (rev 3999)
+++ branches/3.4/tests/unit/geom/EnvelopeTest.cpp	2014-09-09 14:36:35 UTC (rev 4000)
@@ -102,6 +102,9 @@
         ensure( !zero2.isNull() );
         ensure( !box.isNull() );
+        /* See http://trac.osgeo.org/geos/ticket/703 */
+        ensure( empty.equals( &empty ) );
         ensure( !empty.equals( &zero ) );
         ensure( !zero.equals( &empty ) );
Added: branches/3.4/tests/unit/geom/Geometry/equalsTest.cpp
--- branches/3.4/tests/unit/geom/Geometry/equalsTest.cpp	                        (rev 0)
+++ branches/3.4/tests/unit/geom/Geometry/equalsTest.cpp	2014-09-09 14:36:35 UTC (rev 4000)
@@ -0,0 +1,68 @@
+// Test Suite for Geometry's equals() function
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <memory>
+#include <string>
+namespace tut {
+// Test Group
+struct test_equals_data
+	typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
+	geos::geom::GeometryFactory factory;
+	geos::io::WKTReader reader;
+	test_equals_data()
+	    : reader(&factory)
+typedef test_group<test_equals_data> group;
+typedef group::object object;
+group test_equals_data("geos::geom::Geometry::equals");
+// Test Cases
+// Empty equals empty
+// See http://trac.osgeo.org/geos/ticket/703
+template<> template<> void object::test<1>() {
+	GeomAutoPtr g1(reader.read("POINT EMPTY"));
+	ensure( g1->equals(g1.get()) );
+	GeomAutoPtr g2(reader.read("LINESTRING EMPTY"));
+	ensure( g2->equals(g2.get()) );
+	ensure( g2->equals(g1.get()) );
+	GeomAutoPtr g3(reader.read("POLYGON EMPTY"));
+	ensure( g3->equals(g3.get()) );
+	ensure( g3->equals(g2.get()) );
+	ensure( g3->equals(g1.get()) );
+	GeomAutoPtr g4(reader.read("GEOMETRYCOLLECTION EMPTY"));
+	ensure( g4->equals(g4.get()) );
+	ensure( g4->equals(g3.get()) );
+	ensure( g4->equals(g2.get()) );
+	ensure( g4->equals(g1.get()) );
+} // namespace tut
Modified: branches/3.4/tests/unit/geom/PointTest.cpp
--- branches/3.4/tests/unit/geom/PointTest.cpp	2014-09-09 14:35:51 UTC (rev 3999)
+++ branches/3.4/tests/unit/geom/PointTest.cpp	2014-09-09 14:36:35 UTC (rev 4000)
@@ -371,7 +371,7 @@
 		GeometryAutoPtr geo(empty_point_->clone());
-		ensure( !empty_point_->equals(geo.get()) );
+		ensure( empty_point_->equals(geo.get()) );
 	// Test of equals() for non-empty Point (1.234,5.678)
More information about the geos-commits mailing list
