[geos-commits] r4006 - in trunk/tests/unit: . geom/Geometry
svn_geos at osgeo.org
Tue Sep 16 02:52:21 PDT 2014
Author: strk
Date: 2014-09-16 02:52:21 -0700 (Tue, 16 Sep 2014)
New Revision: 4006
Added:
trunk/tests/unit/geom/Geometry/normalize.cpp
trunk/tests/unit/Makefile.am
Add tests for Geometry->normalize()
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2014-09-16 08:50:44 UTC (rev 4005)
+++ trunk/tests/unit/Makefile.am 2014-09-16 09:52:21 UTC (rev 4006)
@@ -51,6 +51,7 @@
geom/Geometry/coversTest.cpp \
geom/Geometry/equalsTest.cpp \
geom/Geometry/isRectangleTest.cpp \
+ geom/Geometry/normalize.cpp \
geom/GeometryFactoryTest.cpp \
geom/IntersectionMatrixTest.cpp \
geom/LinearRingTest.cpp \
Added: trunk/tests/unit/geom/Geometry/normalize.cpp
--- trunk/tests/unit/geom/Geometry/normalize.cpp (rev 0)
+++ trunk/tests/unit/geom/Geometry/normalize.cpp 2014-09-16 09:52:21 UTC (rev 4006)
@@ -0,0 +1,215 @@
+// Test Suite for Geometry's normalize()
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+// std
+#include <memory>
+#include <string>
+#include <iostream>
+namespace tut {
+// Test Group
+struct test_geometry_normalize_data
+ typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
+ geos::geom::GeometryFactory factory;
+ geos::io::WKTReader reader;
+ geos::io::WKTWriter writer;
+ test_geometry_normalize_data()
+ : reader(&factory), writer()
+ writer.setTrim(true);
+ void
+ runTest(const char *from, const char *exp)
+ GeomAutoPtr g1(reader.read(from));
+ ensure(g1.get());
+ GeomAutoPtr g2(g1->clone());
+ ensure(g2.get());
+ g2->normalize();
+ GeomAutoPtr ge(reader.read(exp));
+ bool eq = g2->equalsExact(ge.get());
+ if ( ! eq ) {
+ using namespace std;
+ cout << endl;
+ cout << "Expected: " << exp << endl;
+ cout << "Obtained: " << writer.write(g2.get()) << endl;
+ ensure( eq );
+ // Clone and re-normalize, check it doesn't change anymore
+ ge.reset( g2->clone() );
+ g2->normalize();
+ ensure( g2->equalsExact(ge.get()) );
+typedef test_group<test_geometry_normalize_data> group;
+typedef group::object object;
+group test_geometry_normalize_data("geos::geom::Geometry::normalize");
+// Test Cases
+template<>
+template<>
+void object::test<1>()
+ const char *inp = "POINT (0 100)";
+ const char *exp = inp; // point does not normalize to anything else
+ runTest(inp, exp);
+template<>
+template<>
+void object::test<2>()
+ const char *inp =
+ "LINESTRING(100 0,100 100,0 100,0 0)";
+ const char *exp =
+ "LINESTRING (0 0, 0 100, 100 100, 100 0)";
+template<>
+template<>
+void object::test<3>()
+ const char *inp =
+ "POLYGON ("
+ "(0 0,100 0,100 100,0 100,0 0)," // CCW
+ "(10 10,20 10,20 20,10 20,10 10)," // CCW, leftmost
+ "(40 10,40 20,60 20,60 10,40 10)" // CW, rightmost
+ const char *exp =
+ "POLYGON("
+ "(0 0,0 100,100 100,100 0,0 0)," // CW
+ "(40 10,60 10,60 20,40 20,40 10)," // CCW, rightmost
+ "(10 10,20 10,20 20,10 20,10 10)" // CCW, leftmost
+template<>
+template<>
+void object::test<4>()
+ const char *inp =
+ "MULTIPOINT ("
+ "0 100," // leftmost
+ "5 6" // rightmost
+ const char *exp =
+ "MULTIPOINT ("
+ "5 6," // rightmost
+ "0 100" // leftmost
+template<>
+template<>
+void object::test<5>()
+ const char *inp =
+ "MULTILINESTRING("
+ "(15 25, 25 52)," // rightmost vertex @ 25
+ "(0 0, 0 100, 100 100, 100 0)" // rightmost vertex @ 100
+ const char *exp =
+ "(0 0, 0 100, 100 100, 100 0)," // rightmost vertex @ 100
+ "(15 25, 25 52)" // rightmost vertex @ 25
+template<>
+template<>
+void object::test<6>()
+ const char *inp =
+ "MULTIPOLYGON("
+ "((0 0, 0 1, 1 1, 1 0, 0 0))," // leftmost
+ "((2 0, 2 1, 3 1, 3 0, 2 0))" // rightmost
+ const char *exp =
+ "MULTIPOLYGON("
+ "((2 0, 2 1, 3 1, 3 0, 2 0))," // rightmost
+ "((0 0, 0 1, 1 1, 1 0, 0 0))" // leftmost
+template<>
+template<>
+void object::test<7>()
+ const char *inp =
+ "GEOMETRYCOLLECTION("
+ "MULTIPOINT ("
+ "POINT(10 4)," // more on the right than the multipoint
+ "LINESTRING(100 0,100 100,0 100,0 0),"
+ "MULTIPOLYGON("
+ "POLYGON ("
+ const char *exp =
+ "MULTIPOLYGON("
+ "POLYGON("
+ "LINESTRING (0 0, 0 100, 100 100, 100 0),"
+ "MULTIPOINT ("
+ "POINT(10 4)" // more on the right than the multipoint
+} // namespace tut
More information about the geos-commits
