[geos-commits] r4015 - in trunk: . php php/test
svn_geos at osgeo.org
Mon Sep 22 00:42:03 PDT 2014
Author: strk
Date: 2014-09-22 00:42:02 -0700 (Mon, 22 Sep 2014)
New Revision: 4015
trunk/NEWS
trunk/php/geos.c
trunk/php/test/test.php
Add WKBReader::read() & WKBWriter::write() PHP bindings
Includes tests.
Patch by Benjamin Morel <benjamin.morel at gmail.com>
Signed-off-by: Sandro Santilli <strk at keybit.net>
Modified: trunk/NEWS
--- trunk/NEWS 2014-09-19 13:50:40 UTC (rev 4014)
+++ trunk/NEWS 2014-09-22 07:42:02 UTC (rev 4015)
@@ -5,6 +5,7 @@
- Voronoi API (#627)
- PHP: Geometry->normalize method
- GEOS_USE_ONLY_R_API macro support (#695)
+ - PHP: WKBReader->read() & WKBWriter::write() methods (Benjamin Morel)
Changes in 3.4.2
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2014-09-19 13:50:40 UTC (rev 4014)
+++ trunk/php/geos.c 2014-09-22 07:42:02 UTC (rev 4015)
@@ -2205,6 +2205,7 @@
PHP_METHOD(WKBWriter, setByteOrder);
PHP_METHOD(WKBWriter, setIncludeSRID);
PHP_METHOD(WKBWriter, getIncludeSRID);
+PHP_METHOD(WKBWriter, write);
PHP_METHOD(WKBWriter, writeHEX);
static zend_function_entry WKBWriter_methods[] = {
@@ -2215,6 +2216,7 @@
PHP_ME(WKBWriter, setByteOrder, NULL, 0)
PHP_ME(WKBWriter, getIncludeSRID, NULL, 0)
PHP_ME(WKBWriter, setIncludeSRID, NULL, 0)
+ PHP_ME(WKBWriter, write, NULL, 0)
PHP_ME(WKBWriter, writeHEX, NULL, 0)
{NULL, NULL, NULL}
@@ -2294,6 +2296,38 @@
+ * string GEOSWKBWriter::write(GEOSGeometry)
+ GEOSWKBWriter *writer;
+ zval *zobj;
+ GEOSGeometry *geom;
+ char *ret;
+ size_t retsize;
+ char* retstr;
+ writer = (GEOSWKBWriter*)getRelay(getThis(), WKBWriter_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
+ == FAILURE)
+ RETURN_NULL();
+ geom = getRelay(zobj, Geometry_ce_ptr);
+ ret = (char*)GEOSWKBWriter_write(writer, geom, &retsize);
+ /* we'll probably get an exception if ret is null */
+ if ( ! ret ) RETURN_NULL();
+ retstr = estrndup(ret, retsize);
+ GEOSFree(ret);
+ RETURN_STRINGL(retstr, retsize, 0);
* string GEOSWKBWriter::writeHEX(GEOSGeometry)
@@ -2401,10 +2435,12 @@
/* -- class GEOSWKBReader -------------------- */
PHP_METHOD(WKBReader, __construct);
+PHP_METHOD(WKBReader, read);
PHP_METHOD(WKBReader, readHEX);
static zend_function_entry WKBReader_methods[] = {
PHP_ME(WKBReader, __construct, NULL, 0)
+ PHP_ME(WKBReader, read, NULL, 0)
PHP_ME(WKBReader, readHEX, NULL, 0)
{NULL, NULL, NULL}
@@ -2446,6 +2482,31 @@
setRelay(object, obj);
+ GEOSWKBReader *reader;
+ unsigned char* wkb;
+ int wkblen;
+ reader = (GEOSWKBReader*)getRelay(getThis(), WKBReader_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s",
+ &wkb, &wkblen) == FAILURE)
+ RETURN_NULL();
+ geom = GEOSWKBReader_read(reader, wkb, wkblen);
+ /* we'll probably get an exception if geom is null */
+ if ( ! geom ) RETURN_NULL();
+ /* return_value is a zval */
+ object_init_ex(return_value, Geometry_ce_ptr);
+ setRelay(return_value, geom);
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2014-09-19 13:50:40 UTC (rev 4014)
+++ trunk/php/test/test.php 2014-09-22 07:42:02 UTC (rev 4015)
@@ -2165,6 +2165,119 @@
$this->assertEquals(FALSE, $writer->getIncludeSRID());
+ public function testWKBWriter_write()
+ $writer = new GEOSWKBWriter();
+ $reader = new GEOSWKTReader();
+ try {
+ $writer->write(1);
+ $this->assertTrue(FALSE); # this is just to fail if we get here
+ } catch (Exception $e) {
+ $this->assertContains('expects parameter 1', $e->getMessage());
+ $g = $reader->read('POINT(6 7)');
+ $g->setSRID(43);
+ $writer->setOutputDimension(2); // 2D
+ // 2D LITTLE endian
+ $writer->setByteOrder(1);
+ $this->assertEquals(
+ hex2bin('010100000000000000000018400000000000001C40'),
+ $writer->write($g));
+ // 2D LITTLE endian + SRID
+ $writer->setIncludeSRID(TRUE);
+ hex2bin('01010000202B00000000000000000018400000000000001C40'),
+ $writer->setIncludeSRID(FALSE);
+ // 2D BIG endian
+ $writer->setByteOrder(0);
+ $this->assertEquals(hex2bin('00000000014018000000000000401C000000000000'),
+ // 2D BIG endian + SRID
+ hex2bin('00200000010000002B4018000000000000401C000000000000'),
+ $writer->setOutputDimension(3); // 3D
+ // 3D LITTLE endian (2D input)
+ // 3D LITTLE endian + SRID (2D input)
+ // 3D BIG endian (2D input)
+ // 3D BIG endian + SRID (2D input)
+ $g = $reader->read('POINT(6 7 8)');
+ $g->setSRID(53);
+ // 2D LITTLE endian (3D input)
+ $this->assertEquals(hex2bin('010100000000000000000018400000000000001C40'),
+ // 2D LITTLE endian + SRID (3D input)
+ hex2bin('01010000203500000000000000000018400000000000001C40'),
+ // 2D BIG endian (3D input)
+ // 2D BIG endian + SRID (3D input)
+ hex2bin('0020000001000000354018000000000000401C000000000000'),
+ // 3D LITTLE endian (3D input)
+ hex2bin('010100008000000000000018400000000000001C400000000000002040'),
+ // 3D BIG endian (3D input)
+ hex2bin('00800000014018000000000000401C0000000000004020000000000000'),
+ // 3D BIG endian + SRID (3D input)
+ hex2bin('00A0000001000000354018000000000000401C0000000000004020000000000000'),
public function testWKBWriter_writeHEX()
@@ -2284,6 +2397,64 @@
$this->assertNotNull($reader);
+ public function testWKBReader_read()
+ $reader = new GEOSWKBReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setTrim(TRUE);
+ $g = $reader->read(hex2bin(
+ '010100000000000000000018400000000000001C40'
+ $this->assertEquals('POINT (6 7)', $writer->write($g));
+ $this->assertEquals(0, $g->getSRID());
+ // 2D BIG endian
+ '00000000014018000000000000401C000000000000'
+ '01010000202B00000000000000000018400000000000001C40'
+ $this->assertEquals(43, $g->getSRID());
+ '00200000010000002B4018000000000000401C000000000000'
+ '010100008000000000000018400000000000001C400000000000002040'
+ $this->assertEquals('POINT Z (6 7 8)', $writer->write($g));
+ // 3D BIG endian
+ '00800000014018000000000000401C0000000000004020000000000000'
+ '00A0000001000000354018000000000000401C0000000000004020000000000000'
+ $this->assertEquals(53, $g->getSRID());
public function testWKBReader_readHEX()
More information about the geos-commits
