[geos-commits] r4018 - in trunk: include/geos/operation/overlay src/operation/overlay
svn_geos at osgeo.org
Tue Sep 23 01:17:24 PDT 2014
Author: strk
Date: 2014-09-23 01:17:24 -0700 (Tue, 23 Sep 2014)
New Revision: 4018
trunk/include/geos/operation/overlay/OverlayOp.h
trunk/src/operation/overlay/OverlayOp.cpp
Further speedup difference/intersection at the validating phase
This avoids to insert to the output graph edges which do not intersect
the target envelope.
Modified: trunk/include/geos/operation/overlay/OverlayOp.h
--- trunk/include/geos/operation/overlay/OverlayOp.h 2014-09-23 07:55:54 UTC (rev 4017)
+++ trunk/include/geos/operation/overlay/OverlayOp.h 2014-09-23 08:17:24 UTC (rev 4018)
@@ -201,7 +201,7 @@
void computeOverlay(OpCode opCode); // throw(TopologyException *);
- void insertUniqueEdges(std::vector<geomgraph::Edge*> *edges);
+ void insertUniqueEdges(std::vector<geomgraph::Edge*> *edges, const geom::Envelope *env=0);
* If either of the GeometryLocations for the existing label is
Modified: trunk/src/operation/overlay/OverlayOp.cpp
--- trunk/src/operation/overlay/OverlayOp.cpp 2014-09-23 07:55:54 UTC (rev 4017)
+++ trunk/src/operation/overlay/OverlayOp.cpp 2014-09-23 08:17:24 UTC (rev 4018)
@@ -190,20 +190,20 @@
/*private*/
void
-OverlayOp::insertUniqueEdges(vector<Edge*> *edges)
+OverlayOp::insertUniqueEdges(vector<Edge*> *edges, const Envelope *env)
+ for(size_t i=0, n=edges->size(); i<n; ++i) {
+ Edge *e = (*edges)[i];
+ if ( env && ! env->intersects(e->getEnvelope()) ) continue;
+#if GEOS_DEBUG
+ cerr <<" "<< e->print() << endl;
+#endif
+ insertUniqueEdge(e);
for_each(edges->begin(), edges->end(),
bind1st(mem_fun(&OverlayOp::insertUniqueEdge), this));
-#if GEOS_DEBUG
- cerr<<"OverlayOp::insertUniqueEdges("<<edges->size()<<"): "<<endl;
- for(size_t i=0;i<edges->size();i++) {
- Edge *e=(*edges)[i];
- if ( ! e ) cerr <<" NULL"<<endl;
- cerr <<" "<< e->print() << endl;
-#endif // GEOS_DEBUG
/*private*/
@@ -729,7 +729,7 @@
GEOS_CHECK_FOR_INTERRUPTS();
// add the noded edges to this result graph
- insertUniqueEdges(&baseSplitEdges);
+ insertUniqueEdges(&baseSplitEdges, env);
computeLabelsFromDepths();
replaceCollapsedEdges();
//Debug.println(edgeList);
@@ -750,6 +750,9 @@
try
+#ifdef GEOS_DEBUG_VALIDATION
+ cout << "EdgeNodingValidator about to evaluate " << edgeList.getEdges().size() << " edges" << endl;
+#endif
// Will throw TopologyException if noding is
// found to be invalid
EdgeNodingValidator::checkValid(edgeList.getEdges());
More information about the geos-commits
