[geos-commits] r4074 - branches/3.3
svn_geos at osgeo.org
Thu Aug 6 08:40:35 PDT 2015
Author: mloskot
Date: 2015-08-06 08:40:35 -0700 (Thu, 06 Aug 2015)
New Revision: 4074
branches/3.3/
branches/3.3/.travis.yml
Merged revision(s) 4072 from trunk:
Allow failure for CMake x64 build on Travis CI.
This should eliminate unimportant signal and keep the core GEOS builds green.
Property changes on: branches/3.3
___________________________________________________________________
Modified: svn:mergeinfo
- /trunk:4068-4069
+ /trunk:4068-4069,4072
Modified: branches/3.3/.travis.yml
--- branches/3.3/.travis.yml 2015-08-06 15:39:37 UTC (rev 4073)
+++ branches/3.3/.travis.yml 2015-08-06 15:40:35 UTC (rev 4074)
@@ -16,12 +16,16 @@
- clang
env:
- matrix:
- - GEOS_BUILD_TOOL=autotools CFLAGS=-m32 CXXFLAGS=-m32
- - GEOS_BUILD_TOOL=autotools CFLAGS=-m64 CXXFLAGS=-m64
- - GEOS_BUILD_TOOL=cmake CFLAGS=-m32 CXXFLAGS=-m32
- - GEOS_BUILD_TOOL=cmake CFLAGS=-m64 CXXFLAGS=-m64
+ - GEOS_BUILD_TOOL=autotools CFLAGS=-m32 CXXFLAGS=-m32
+ - GEOS_BUILD_TOOL=autotools CFLAGS=-m64 CXXFLAGS=-m64
+ - GEOS_BUILD_TOOL=cmake CFLAGS=-m32 CXXFLAGS=-m32
+ - GEOS_BUILD_TOOL=cmake CFLAGS=-m64 CXXFLAGS=-m64
+matrix:
+ fast_finish: true
+ allow_failures:
+ - env: GEOS_BUILD_TOOL=cmake CFLAGS=-m64 CXXFLAGS=-m64
addons:
apt:
packages:
More information about the geos-commits
