[geos-commits] r4085 - in trunk: . capi include/geos
svn_geos at osgeo.org
Sun Aug 16 15:19:47 PDT 2015
Author: pramsey
Date: 2015-08-16 15:19:47 -0700 (Sun, 16 Aug 2015)
New Revision: 4085
trunk/CMakeLists.txt
trunk/HOWTO_RELEASE
trunk/NEWS
trunk/capi/geos_c.h.in
trunk/configure.ac
trunk/include/geos/version.h.vc
Bump trunk versions to 3.6
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2015-08-14 18:34:11 UTC (rev 4084)
+++ trunk/CMakeLists.txt 2015-08-16 22:19:47 UTC (rev 4085)
@@ -28,7 +28,7 @@
# GEOS release version
# GEOS C++ library SONAME will use these encoding ABI break at every release
set(VERSION_MAJOR 3)
-set(VERSION_MINOR 5)
+set(VERSION_MINOR 6)
set(VERSION_PATCH 0dev)
set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_PATCH}")
@@ -37,7 +37,7 @@
message(STATUS "Setting GEOS version ${VERSION} as port of JTS ${JTS_PORT}")
# GEOS C API version
-set(CAPI_INTERFACE_CURRENT 10)
+set(CAPI_INTERFACE_CURRENT 11)
set(CAPI_INTERFACE_REVISION 0)
set(CAPI_INTERFACE_AGE 9)
Modified: trunk/HOWTO_RELEASE
--- trunk/HOWTO_RELEASE 2015-08-14 18:34:11 UTC (rev 4084)
+++ trunk/HOWTO_RELEASE 2015-08-16 22:19:47 UTC (rev 4085)
@@ -33,7 +33,7 @@
[ THIS MUST BE CAREFULLY AVOIDED ]
12: Increment release version:
- - In configure.in
+ - In configure.ac
- In include/geos/version.h.vc
- In capi/geos_c.h.in
- VERSION_PATCH for bugfixes/improvements (even breaking C++ API)
Modified: trunk/NEWS
--- trunk/NEWS 2015-08-14 18:34:11 UTC (rev 4084)
+++ trunk/NEWS 2015-08-16 22:19:47 UTC (rev 4085)
@@ -1,5 +1,13 @@
+Changes in 3.6.0
+2015-MM-DD
+- New things:
+- Improvements:
+- C++ API changes:
Changes in 3.5.0
-2013-MM-DD
+2015-08-16
- New things:
- Voronoi API (#627)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2015-08-14 18:34:11 UTC (rev 4084)
+++ trunk/capi/geos_c.h.in 2015-08-16 22:19:47 UTC (rev 4085)
@@ -59,9 +59,9 @@
#if defined(_MSC_VER)
#include <geos/version.h>
#define GEOS_CAPI_VERSION_MAJOR 1
-#define GEOS_CAPI_VERSION_MINOR 9
+#define GEOS_CAPI_VERSION_MINOR 11
#define GEOS_CAPI_VERSION_PATCH 0
-#define GEOS_CAPI_VERSION "3.5.0-CAPI-1.9.0"
+#define GEOS_CAPI_VERSION "3.6.0-CAPI-1.11.0"
#else
#ifndef GEOS_VERSION_MAJOR
#define GEOS_VERSION_MAJOR @VERSION_MAJOR@
Modified: trunk/configure.ac
--- trunk/configure.ac 2015-08-14 18:34:11 UTC (rev 4084)
+++ trunk/configure.ac 2015-08-16 22:19:47 UTC (rev 4085)
@@ -14,7 +14,7 @@
JTS_PORT=1.13.0
dnl -- Version info for the CAPI
-CAPI_INTERFACE_CURRENT=10
+CAPI_INTERFACE_CURRENT=11
CAPI_INTERFACE_REVISION=0
CAPI_INTERFACE_AGE=9
@@ -23,7 +23,7 @@
dnl -- encoding ABI break at every release
dnl
VERSION_MAJOR=3
-VERSION_MINOR=5
+VERSION_MINOR=6
VERSION_PATCH=0dev
VERSION="$VERSION_MAJOR.$VERSION_MINOR.$VERSION_PATCH"
Modified: trunk/include/geos/version.h.vc
--- trunk/include/geos/version.h.vc 2015-08-14 18:34:11 UTC (rev 4084)
+++ trunk/include/geos/version.h.vc 2015-08-16 22:19:47 UTC (rev 4085)
@@ -30,7 +30,7 @@
#endif
#ifndef GEOS_VERSION_MINOR
-#define GEOS_VERSION_MINOR 5
+#define GEOS_VERSION_MINOR 6
#endif
#ifndef GEOS_VERSION_PATCH
@@ -38,7 +38,7 @@
#endif
-#define GEOS_VERSION "3.5.0"
+#define GEOS_VERSION "3.6.0"
#endif
#ifndef GEOS_JTS_PORT
More information about the geos-commits
