[geos-commits] r4039 - in branches/3.4: . include/geos/algorithm src/algorithm swig/python tests/xmltester tests/xmltester/tests/ticket
svn_geos at osgeo.org
Mon Jan 19 02:59:18 PST 2015
Author: strk
Date: 2015-01-19 02:59:17 -0800 (Mon, 19 Jan 2015)
New Revision: 4039
Added:
branches/3.4/tests/xmltester/tests/ticket/bug716.xml
branches/3.4/NEWS
branches/3.4/include/geos/algorithm/RayCrossingCounter.h
branches/3.4/src/algorithm/CGAlgorithms.cpp
branches/3.4/src/algorithm/RayCrossingCounter.cpp
branches/3.4/swig/python/geos.py
branches/3.4/swig/python/geos_wrap.cxx
branches/3.4/tests/xmltester/Makefile.am
Improve robustness of intersection testing (#716)
RayCrossingCounter uses orientationIndex to handle floating point
precision errors the same way as LineIntersector.
Includes testcase for ticket #716 with CW and CCW polygons
Patch by Asmund Tokheim <tokheim at outlook.com>
Modified: branches/3.4/NEWS
--- branches/3.4/NEWS 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/NEWS 2015-01-19 10:59:17 UTC (rev 4039)
@@ -2,6 +2,7 @@
YYYY-MM-DD
- Bug fixes / improvements
+ - Improve robustness of intersection testing (#716)
- Fixed compilation against thread-safe PHP (#541)
- Fix Empty to Empty equals (#703)
- Fix build on OpenBSD (#700)
Modified: branches/3.4/include/geos/algorithm/RayCrossingCounter.h
--- branches/3.4/include/geos/algorithm/RayCrossingCounter.h 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/include/geos/algorithm/RayCrossingCounter.h 2015-01-19 10:59:17 UTC (rev 4039)
@@ -93,6 +93,22 @@
static int locatePointInRing(const geom::Coordinate& p,
const std::vector<const geom::Coordinate*>& ring);
+ /** \brief
+ * Returns the index of the direction of the point <code>q</code>
+ * relative to a vector specified by <code>p1-p2</code>.
+ * @param p1 the origin point of the vector
+ * @param p2 the final point of the vector
+ * @param q the point to compute the direction to
+ * @return 1 if q is counter-clockwise (left) from p1-p2
+ * @return -1 if q is clockwise (right) from p1-p2
+ * @return 0 if q is collinear with p1-p2
+ static int orientationIndex(const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ const geom::Coordinate& q);
RayCrossingCounter(const geom::Coordinate& point)
: point( point),
crossingCount( 0),
Modified: branches/3.4/src/algorithm/CGAlgorithms.cpp
--- branches/3.4/src/algorithm/CGAlgorithms.cpp 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/src/algorithm/CGAlgorithms.cpp 2015-01-19 10:59:17 UTC (rev 4039)
@@ -42,14 +42,7 @@
int
CGAlgorithms::orientationIndex(const Coordinate& p1,const Coordinate& p2,const Coordinate& q)
- // travelling along p1->p2, turn counter clockwise to get to q return 1,
- // travelling along p1->p2, turn clockwise to get to q return -1,
- // p1, p2 and q are colinear return 0.
- double dx1=p2.x-p1.x;
- double dy1=p2.y-p1.y;
- double dx2=q.x-p2.x;
- double dy2=q.y-p2.y;
- return RobustDeterminant::signOfDet2x2(dx1,dy1,dx2,dy2);
+ return RayCrossingCounter::orientationIndex(p1, p2, q);
/*public static*/
Modified: branches/3.4/src/algorithm/RayCrossingCounter.cpp
--- branches/3.4/src/algorithm/RayCrossingCounter.cpp 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/src/algorithm/RayCrossingCounter.cpp 2015-01-19 10:59:17 UTC (rev 4039)
@@ -45,8 +45,8 @@
for (std::size_t i = 1, ni = ring.size(); i < ni; i++)
- const geom::Coordinate & p1 = ring[ i ];
- const geom::Coordinate & p2 = ring[ i - 1 ];
+ const geom::Coordinate & p1 = ring[ i - 1 ];
+ const geom::Coordinate & p2 = ring[ i ];
rcc.countSegment(p1, p2);
@@ -64,8 +64,8 @@
- const geom::Coordinate & p1 = *ring[ i ];
- const geom::Coordinate & p2 = *ring[ i - 1 ];
+ const geom::Coordinate & p1 = *ring[ i - 1 ];
+ const geom::Coordinate & p2 = *ring[ i ];
@@ -75,6 +75,20 @@
return rcc.getLocation();
+/*public static*/
+int
+RayCrossingCounter::orientationIndex(const geom::Coordinate& p1,
+ const geom::Coordinate& p2, const geom::Coordinate& q)
+ // travelling along p1->p2, turn counter clockwise to get to q return 1,
+ // travelling along p1->p2, turn clockwise to get to q return -1,
+ // p1, p2 and q are colinear return 0.
+ double dx1=p2.x-p1.x;
+ double dy1=p2.y-p1.y;
+ double dx2=q.x-p2.x;
+ double dy2=q.y-p2.y;
+ return RobustDeterminant::signOfDet2x2(dx1,dy1,dx2,dy2);
void
RayCrossingCounter::countSegment(const geom::Coordinate& p1,
@@ -124,30 +138,20 @@
if (((p1.y > point.y) && (p2.y <= point.y)) ||
((p2.y > point.y) && (p1.y <= point.y)) )
- // translate the segment so that the test point lies
- // on the origin
- double x1 = p1.x - point.x;
- double y1 = p1.y - point.y;
- double x2 = p2.x - point.x;
- double y2 = p2.y - point.y;
- // The translated segment straddles the x-axis.
- // Compute the sign of the ordinate of intersection
- // with the x-axis. (y2 != y1, so denominator
- // will never be 0.0)
- // MD - faster & more robust computation?
- double xIntSign = RobustDeterminant::signOfDet2x2(x1, y1, x2, y2);
- if (xIntSign == 0.0)
+ // For an upward edge, orientationIndex will be positive when p1->p2
+ // crosses ray. Conversely, downward edges should have negative sign.
+ int sign = orientationIndex(p1, p2, point);
+ if (sign == 0)
isPointOnSegment = true;
return;
- if (y2 < y1)
- xIntSign = -xIntSign;
+ if (p2.y < p1.y)
+ sign = -sign;
// The segment crosses the ray if the sign is strictly positive.
- if (xIntSign > 0.0)
+ if (sign > 0)
crossingCount++;
Modified: branches/3.4/swig/python/geos.py
--- branches/3.4/swig/python/geos.py 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/swig/python/geos.py 2015-01-19 10:59:17 UTC (rev 4039)
@@ -1,11 +1,13 @@
# This file was automatically generated by SWIG (http://www.swig.org).
-# Version 2.0.4
+# Version 2.0.11
# Do not make changes to this file unless you know what you are doing--modify
# the SWIG interface file instead.
from sys import version_info
if version_info >= (2,6,0):
def swig_import_helper():
@@ -84,8 +86,8 @@
__swig_destroy__ = _geos.delete_SwigPyIterator
__del__ = lambda self : None;
def value(self): return _geos.SwigPyIterator_value(self)
- def incr(self, n = 1): return _geos.SwigPyIterator_incr(self, n)
- def decr(self, n = 1): return _geos.SwigPyIterator_decr(self, n)
+ def incr(self, n=1): return _geos.SwigPyIterator_incr(self, n)
+ def decr(self, n=1): return _geos.SwigPyIterator_decr(self, n)
def distance(self, *args): return _geos.SwigPyIterator_distance(self, *args)
def equal(self, *args): return _geos.SwigPyIterator_equal(self, *args)
def copy(self): return _geos.SwigPyIterator_copy(self)
Modified: branches/3.4/swig/python/geos_wrap.cxx
--- branches/3.4/swig/python/geos_wrap.cxx 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/swig/python/geos_wrap.cxx 2015-01-19 10:59:17 UTC (rev 4039)
@@ -1,11 +1,11 @@
* This file was automatically generated by SWIG (http://www.swig.org).
- * Version 2.0.4
- * This file is not intended to be easily readable and contains a number of
+ * Version 2.0.11
+ * This file is not intended to be easily readable and contains a number of
* coding conventions designed to improve portability and efficiency. Do not make
- * changes to this file unless you know what you are doing--modify the SWIG
- * interface file instead.
+ * changes to this file unless you know what you are doing--modify the SWIG
+ * interface file instead.
#define SWIGPYTHON
@@ -66,28 +66,28 @@
#ifndef SWIGUNUSED
# if defined(__GNUC__)
# if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
-# define SWIGUNUSED __attribute__ ((__unused__))
+# define SWIGUNUSED __attribute__ ((__unused__))
# else
# define SWIGUNUSED
# endif
# elif defined(__ICC)
# else
# endif
#endif
#ifndef SWIG_MSC_UNSUPPRESS_4505
# if defined(_MSC_VER)
# pragma warning(disable : 4505) /* unreferenced local function has been removed */
-# endif
+# endif
#endif
#ifndef SWIGUNUSEDPARM
# ifdef __cplusplus
# define SWIGUNUSEDPARM(p)
# else
-# define SWIGUNUSEDPARM(p) p SWIGUNUSED
+# define SWIGUNUSEDPARM(p) p SWIGUNUSED
# endif
#endif
@@ -130,7 +130,7 @@
# define SWIGSTDCALL __stdcall
# else
-# endif
+# endif
#endif
/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
@@ -145,8 +145,14 @@
-/* Python.h has to appear first */
-#include <Python.h>
+#if defined(_DEBUG) && defined(SWIG_PYTHON_INTERPRETER_NO_DEBUG)
+/* Use debug wrappers with the Python release dll */
+# undef _DEBUG
+# include <Python.h>
+# define _DEBUG
+#else
+#endif
* swigrun.swg
@@ -172,7 +178,7 @@
You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
creating a static or dynamic library from the SWIG runtime code.
In 99.9% of the cases, SWIG just needs to declare them as 'static'.
But only do this if strictly necessary, ie, if you have problems
with your compiler or suchlike.
@@ -198,16 +204,16 @@
#define SWIG_POINTER_OWN 0x1
Flags/methods for returning states.
- The SWIG conversion methods, as ConvertPtr, return an integer
+ The SWIG conversion methods, as ConvertPtr, return an integer
that tells if the conversion was successful or not. And if not,
an error code can be returned (see swigerrors.swg for the codes).
Use the following macros/flags to set or process the returning
states.
In old versions of SWIG, code such as the following was usually written:
if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
@@ -240,23 +246,23 @@
} else {
// fail code
I.e., now SWIG_ConvertPtr can return new objects and you can
identify the case and take care of the deallocation. Of course that
also requires SWIG_ConvertPtr to return new result values, such as
- int SWIG_ConvertPtr(obj, ptr,...) {
- if (<obj is ok>) {
- if (<need new object>) {
- *ptr = <ptr to new allocated object>;
- return SWIG_NEWOBJ;
- } else {
- *ptr = <ptr to old object>;
- return SWIG_OLDOBJ;
- } else {
- return SWIG_BADOBJ;
+ int SWIG_ConvertPtr(obj, ptr,...) {
+ if (<obj is ok>) {
+ if (<need new object>) {
+ *ptr = <ptr to new allocated object>;
+ return SWIG_NEWOBJ;
+ } else {
+ *ptr = <ptr to old object>;
+ return SWIG_OLDOBJ;
+ } else {
+ return SWIG_BADOBJ;
Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
@@ -270,17 +276,17 @@
int fooi(int);
and you call
food(1) // cast rank '1' (1 -> 1.0)
fooi(1) // cast rank '0'
just use the SWIG_AddCast()/SWIG_CheckState()
-#define SWIG_OK (0)
+#define SWIG_OK (0)
#define SWIG_ERROR (-1)
#define SWIG_IsOK(r) (r >= 0)
-#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
+#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
/* The CastRankLimit says how many bits are used for the cast rank */
#define SWIG_CASTRANKLIMIT (1 << 8)
@@ -311,14 +317,14 @@
# endif
# define SWIG_CASTRANKMASK ((SWIG_CASTRANKLIMIT) -1)
# define SWIG_CastRank(r) (r & SWIG_CASTRANKMASK)
-SWIGINTERNINLINE int SWIG_AddCast(int r) {
+SWIGINTERNINLINE int SWIG_AddCast(int r) {
return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
-SWIGINTERNINLINE int SWIG_CheckState(int r) {
- return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
+SWIGINTERNINLINE int SWIG_CheckState(int r) {
+ return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
#else /* no cast-rank mode */
-# define SWIG_AddCast
+# define SWIG_AddCast(r) (r)
# define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
#endif
@@ -362,7 +368,7 @@
void *clientdata; /* Language specific module data */
} swig_module_info;
Compare two type names skipping the space characters, therefore
"char*" == "char *" and "Class<int>" == "Class<int >", etc.
@@ -382,18 +388,18 @@
Check type equivalence in a name list like <name1>|<name2>|...
- Return 0 if not equal, 1 if equal
+ Return 0 if equal, -1 if nb < tb, 1 if nb > tb
SWIGRUNTIME int
-SWIG_TypeEquiv(const char *nb, const char *tb) {
- int equiv = 0;
+SWIG_TypeCmp(const char *nb, const char *tb) {
+ int equiv = 1;
const char* te = tb + strlen(tb);
const char* ne = nb;
- while (!equiv && *ne) {
+ while (equiv != 0 && *ne) {
for (nb = ne; *ne; ++ne) {
if (*ne == '|') break;
- equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
+ equiv = SWIG_TypeNameComp(nb, ne, tb, te);
if (*ne) ++ne;
return equiv;
@@ -401,24 +407,13 @@
- Return 0 if equal, -1 if nb < tb, 1 if nb > tb
+ Return 0 if not equal, 1 if equal
SWIGRUNTIME int
-SWIG_TypeCompare(const char *nb, const char *tb) {
- int equiv = 0;
- const char* te = tb + strlen(tb);
- const char* ne = nb;
- for (nb = ne; *ne; ++ne) {
- if (*ne == '|') break;
- if (*ne) ++ne;
- return equiv;
+SWIG_TypeEquiv(const char *nb, const char *tb) {
+ return SWIG_TypeCmp(nb, tb) == 0 ? 1 : 0;
Check the typename
@@ -446,7 +441,7 @@
return 0;
Identical to SWIG_TypeCheck, except strcmp is replaced with a pointer comparison
SWIGRUNTIME swig_cast_info *
@@ -481,7 +476,7 @@
return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr, newmemory);
Dynamic pointer casting. Down an inheritance hierarchy
SWIGRUNTIME swig_type_info *
@@ -525,7 +520,7 @@
return type->name;
Set the clientdata field for a type
SWIGRUNTIME void
@@ -533,14 +528,14 @@
swig_cast_info *cast = ti->cast;
/* if (ti->clientdata == clientdata) return; */
ti->clientdata = clientdata;
while (cast) {
if (!cast->converter) {
swig_type_info *tc = cast->type;
if (!tc->clientdata) {
SWIG_TypeClientData(tc, clientdata);
cast = cast->next;
@@ -549,18 +544,18 @@
SWIG_TypeClientData(ti, clientdata);
ti->owndata = 1;
Search for a swig_type_info structure only by mangled name
Search is a O(log #types)
- We start searching at module start, and finish searching when start == end.
+ We start searching at module start, and finish searching when start == end.
Note: if start == end at the beginning of the function, we go all the way around
the circular list.
-SWIG_MangledTypeQueryModule(swig_module_info *start,
- swig_module_info *end,
+SWIG_MangledTypeQueryModule(swig_module_info *start,
+ swig_module_info *end,
const char *name) {
swig_module_info *iter = start;
do {
@@ -569,11 +564,11 @@
register size_t r = iter->size - 1;
do {
/* since l+r >= 0, we can (>> 1) instead (/ 2) */
- register size_t i = (l + r) >> 1;
+ register size_t i = (l + r) >> 1;
const char *iname = iter->types[i]->name;
if (iname) {
register int compare = strcmp(name, iname);
- if (compare == 0) {
+ if (compare == 0) {
return iter->types[i];
} else if (compare < 0) {
if (i) {
@@ -598,14 +593,14 @@
Search for a swig_type_info structure for either a mangled name or a human readable name.
It first searches the mangled names of the types, which is a O(log #types)
If a type is not found it then searches the human readable names, which is O(#types).
the circular list.
-SWIG_TypeQueryModule(swig_module_info *start,
+SWIG_TypeQueryModule(swig_module_info *start,
const char *name) {
/* STEP 1: Search the name field using binary search */
swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
@@ -624,12 +619,12 @@
iter = iter->next;
} while (iter != end);
/* neither found a match */
return 0;
Pack binary data into a string
SWIGRUNTIME char *
@@ -645,7 +640,7 @@
return c;
Unpack binary data from a string
SWIGRUNTIME const char *
@@ -659,21 +654,21 @@
uu = ((d - '0') << 4);
else if ((d >= 'a') && (d <= 'f'))
uu = ((d - ('a'-10)) << 4);
- else
+ else
return (char *) 0;
d = *(c++);
if ((d >= '0') && (d <= '9'))
uu |= (d - '0');
uu |= (d - ('a'-10));
- else
+ else
return (char *) 0;
*u = uu;
return c;
Pack 'void *' into a string buffer.
SWIGRUNTIME char *
@@ -733,18 +728,18 @@
#endif
/* Errors in SWIG */
-#define SWIG_UnknownError -1
-#define SWIG_IOError -2
-#define SWIG_RuntimeError -3
-#define SWIG_IndexError -4
-#define SWIG_TypeError -5
-#define SWIG_DivisionByZero -6
-#define SWIG_OverflowError -7
-#define SWIG_SyntaxError -8
-#define SWIG_ValueError -9
+#define SWIG_UnknownError -1
+#define SWIG_IOError -2
+#define SWIG_RuntimeError -3
+#define SWIG_IndexError -4
+#define SWIG_TypeError -5
+#define SWIG_DivisionByZero -6
+#define SWIG_OverflowError -7
+#define SWIG_SyntaxError -8
+#define SWIG_ValueError -9
#define SWIG_SystemError -10
#define SWIG_AttributeError -11
-#define SWIG_MemoryError -12
+#define SWIG_MemoryError -12
#define SWIG_NullReferenceError -13
@@ -756,6 +751,7 @@
#define PyInt_Check(x) PyLong_Check(x)
#define PyInt_AsLong(x) PyLong_AsLong(x)
#define PyInt_FromLong(x) PyLong_FromLong(x)
+#define PyInt_FromSize_t(x) PyLong_FromSize_t(x)
#define PyString_Check(name) PyBytes_Check(name)
#define PyString_FromString(x) PyUnicode_FromString(x)
#define PyString_Format(fmt, args) PyUnicode_Format(fmt, args)
@@ -925,6 +921,10 @@
#endif
+#if PY_VERSION_HEX < 0x02050000
+#define PyInt_FromSize_t(x) PyInt_FromLong((long)x)
+#endif
#if PY_VERSION_HEX < 0x02040000
#define Py_VISIT(op) \
do { \
@@ -1196,7 +1196,7 @@
/* Runtime API */
-#define SWIG_GetModule(clientdata) SWIG_Python_GetModule()
+#define SWIG_GetModule(clientdata) SWIG_Python_GetModule(clientdata)
#define SWIG_SetModule(clientdata, pointer) SWIG_Python_SetModule(pointer)
#define SWIG_NewClientData(obj) SwigPyClientData_New(obj)
@@ -1222,7 +1222,7 @@
SWIGINTERN void
SWIG_Python_SetErrorMsg(PyObject *errtype, const char *msg) {
SWIG_PYTHON_THREAD_BEGIN_BLOCK;
- PyErr_SetString(errtype, (char *) msg);
+ PyErr_SetString(errtype, msg);
SWIG_PYTHON_THREAD_END_BLOCK;
@@ -1241,7 +1241,11 @@
SWIGINTERN void
SWIG_Python_SetConstant(PyObject *d, PyObject *public_interface, const char *name, PyObject *obj) {
+#if PY_VERSION_HEX < 0x02030000
PyDict_SetItemString(d, (char *)name, obj);
+#else
+ PyDict_SetItemString(d, name, obj);
+#endif
Py_DECREF(obj);
if (public_interface)
SwigPyBuiltin_AddPublicSymbol(public_interface, name);
@@ -1251,7 +1255,11 @@
SWIGINTERN void
SWIG_Python_SetConstant(PyObject *d, const char *name, PyObject *obj) {
+#else
+#endif
Py_DECREF(obj);
@@ -1572,7 +1580,7 @@
#endif
const char *name = SWIG_TypePrettyName(v->ty);
- PyObject *repr = SWIG_Python_str_FromFormat("<Swig Object of type '%s' at %p>", name, (void *)v);
+ PyObject *repr = SWIG_Python_str_FromFormat("<Swig Object of type '%s' at %p>", (name ? name : "unknown"), (void *)v);
if (v->next) {
# ifdef METH_NOARGS
PyObject *nrep = SwigPyObject_repr((SwigPyObject *)v->next);
@@ -1592,34 +1600,6 @@
SWIGRUNTIME int
-SwigPyObject_print(SwigPyObject *v, FILE *fp, int SWIGUNUSEDPARM(flags))
- char *str;
-#ifdef METH_NOARGS
- PyObject *repr = SwigPyObject_repr(v);
-#else
- PyObject *repr = SwigPyObject_repr(v, NULL);
-#endif
- if (repr) {
- str = SWIG_Python_str_AsChar(repr);
- fputs(str, fp);
- SWIG_Python_str_DelForPy3(str);
- Py_DECREF(repr);
- return 0;
- } else {
- return 1;
-SWIGRUNTIME PyObject *
-SwigPyObject_str(SwigPyObject *v)
- char result[SWIG_BUFFER_SIZE];
- return SWIG_PackVoidPtr(result, v->ptr, v->ty->name, sizeof(result)) ?
- SWIG_Python_str_FromChar(result) : 0;
-SWIGRUNTIME int
SwigPyObject_compare(SwigPyObject *v, SwigPyObject *w)
void *i = v->ptr;
@@ -1776,8 +1756,10 @@
PyObject *val = 0;
#if (PY_VERSION_HEX < 0x02020000)
if (!PyArg_ParseTuple(args,(char *)"|O:own",&val))
+#elif (PY_VERSION_HEX < 0x02050000)
+ if (!PyArg_UnpackTuple(args, (char *)"own", 0, 1, &val))
#else
- if (!PyArg_UnpackTuple(args, (char *)"own", 0, 1, &val))
+ if (!PyArg_UnpackTuple(args, "own", 0, 1, &val))
#endif
return NULL;
@@ -1809,7 +1791,7 @@
static PyMethodDef
swigobject_methods[] = {
{(char *)"disown", (PyCFunction)SwigPyObject_disown, METH_NOARGS, (char *)"releases ownership of the pointer"},
- {(char *)"acquire", (PyCFunction)SwigPyObject_acquire, METH_NOARGS, (char *)"aquires ownership of the pointer"},
+ {(char *)"acquire", (PyCFunction)SwigPyObject_acquire, METH_NOARGS, (char *)"acquires ownership of the pointer"},
{(char *)"own", (PyCFunction)SwigPyObject_own, METH_VARARGS, (char *)"returns/sets ownership of the pointer"},
{(char *)"append", (PyCFunction)SwigPyObject_append, METH_O, (char *)"appends another 'this' object"},
{(char *)"next", (PyCFunction)SwigPyObject_next, METH_NOARGS, (char *)"returns the next 'this' object"},
@@ -1902,7 +1884,7 @@
sizeof(SwigPyObject), /* tp_basicsize */
0, /* tp_itemsize */
(destructor)SwigPyObject_dealloc, /* tp_dealloc */
- (printfunc)SwigPyObject_print, /* tp_print */
+ 0, /* tp_print */
#if PY_VERSION_HEX < 0x02020000
(getattrfunc)SwigPyObject_getattr, /* tp_getattr */
#else
@@ -1920,7 +1902,7 @@
0, /* tp_as_mapping */
(hashfunc)0, /* tp_hash */
(ternaryfunc)0, /* tp_call */
- (reprfunc)SwigPyObject_str, /* tp_str */
+ 0, /* tp_str */
PyObject_GenericGetAttr, /* tp_getattro */
0, /* tp_setattro */
0, /* tp_as_buffer */
@@ -2297,10 +2279,11 @@
SWIG_Python_ConvertPtrAndOwn(PyObject *obj, void **ptr, swig_type_info *ty, int flags, int *own) {
int res;
SwigPyObject *sobj;
+ int implicit_conv = (flags & SWIG_POINTER_IMPLICIT_CONV) != 0;
if (!obj)
return SWIG_ERROR;
- if (obj == Py_None) {
+ if (obj == Py_None && !implicit_conv) {
if (ptr)
*ptr = 0;
return SWIG_OK;
@@ -2349,7 +2332,7 @@
res = SWIG_OK;
} else {
- if (flags & SWIG_POINTER_IMPLICIT_CONV) {
+ if (implicit_conv) {
SwigPyClientData *data = ty ? (SwigPyClientData *) ty->clientdata : 0;
if (data && !data->implicitconv) {
PyObject *klass = data->klass;
@@ -2384,6 +2367,13 @@
+ if (!SWIG_IsOK(res) && obj == Py_None) {
+ if (ptr)
+ *ptr = 0;
+ if (PyErr_Occurred())
+ PyErr_Clear();
+ res = SWIG_OK;
return res;
@@ -2472,23 +2462,29 @@
} else {
#if PY_VERSION_HEX >= 0x03000000
inst = PyBaseObject_Type.tp_new((PyTypeObject*) data->newargs, Py_None, Py_None);
- PyObject_SetAttr(inst, SWIG_This(), swig_this);
- Py_TYPE(inst)->tp_flags &= ~Py_TPFLAGS_VALID_VERSION_TAG;
+ if (inst) {
+ PyObject_SetAttr(inst, SWIG_This(), swig_this);
+ Py_TYPE(inst)->tp_flags &= ~Py_TPFLAGS_VALID_VERSION_TAG;
#else
PyObject *dict = PyDict_New();
- PyDict_SetItem(dict, SWIG_This(), swig_this);
- inst = PyInstance_NewRaw(data->newargs, dict);
- Py_DECREF(dict);
+ if (dict) {
+ PyDict_SetItem(dict, SWIG_This(), swig_this);
+ inst = PyInstance_NewRaw(data->newargs, dict);
+ Py_DECREF(dict);
#endif
return inst;
#else
#if (PY_VERSION_HEX >= 0x02010000)
- PyObject *inst;
+ PyObject *inst = 0;
- Py_DECREF(dict);
+ if (dict) {
+ Py_DECREF(dict);
return (PyObject *) inst;
#else
PyInstanceObject *inst = PyObject_NEW(PyInstanceObject, &PyInstance_Type);
@@ -2539,7 +2535,7 @@
SWIGINTERN PyObject *
SWIG_Python_InitShadowInstance(PyObject *args) {
PyObject *obj[2];
- if (!SWIG_Python_UnpackTuple(args,(char*)"swiginit", 2, 2, obj)) {
+ if (!SWIG_Python_UnpackTuple(args, "swiginit", 2, 2, obj)) {
return NULL;
} else {
SwigPyObject *sthis = SWIG_Python_GetSwigThis(obj[0]);
@@ -2595,12 +2591,10 @@
assert(!(flags & SWIG_BUILTIN_TP_INIT));
robj = SwigPyObject_New(ptr, type, own);
- if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
+ if (robj && clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
- if (inst) {
- Py_DECREF(robj);
- robj = inst;
+ Py_DECREF(robj);
+ robj = inst;
return robj;
@@ -2621,7 +2615,7 @@
#endif
SWIGRUNTIME swig_module_info *
-SWIG_Python_GetModule(void) {
+SWIG_Python_GetModule(void *SWIGUNUSEDPARM(clientdata)) {
static void *type_pointer = (void *)0;
/* first check if module already created */
if (!type_pointer) {
@@ -2747,7 +2741,7 @@
descriptor = (swig_type_info *) PyCObject_AsVoidPtr(obj);
#endif
} else {
- swig_module_info *swig_module = SWIG_Python_GetModule();
+ swig_module_info *swig_module = SWIG_GetModule(0);
descriptor = SWIG_TypeQueryModule(swig_module, swig_module, type);
if (descriptor) {
#ifdef SWIGPY_USE_CAPSULE
@@ -2815,7 +2809,7 @@
SwigPyObject *v = (SwigPyObject *)self;
swig_type_info *ty = v ? v->ty : 0;
- return ty ? ty->str : (char*)"";
+ return ty ? ty->str : "";
SWIGRUNTIME void
@@ -2872,23 +2866,24 @@
return result;
+#ifdef SWIGPYTHON_BUILTIN
SWIGRUNTIME int
SWIG_Python_NonDynamicSetAttr(PyObject *obj, PyObject *name, PyObject *value) {
PyTypeObject *tp = obj->ob_type;
PyObject *descr;
PyObject *encoded_name;
descrsetfunc f;
- int res;
+ int res = -1;
-#ifdef Py_USING_UNICODE
+# ifdef Py_USING_UNICODE
if (PyString_Check(name)) {
name = PyUnicode_Decode(PyString_AsString(name), PyString_Size(name), NULL, NULL);
if (!name)
return -1;
} else if (!PyUnicode_Check(name))
-#else
+# else
if (!PyString_Check(name))
-#endif
+# endif
PyErr_Format(PyExc_TypeError, "attribute name must be string, not '%.200s'", name->ob_type->tp_name);
return -1;
@@ -2901,7 +2896,6 @@
goto done;
- res = -1;
descr = _PyType_Lookup(tp, name);
f = NULL;
if (descr != NULL)
@@ -2923,6 +2917,7 @@
Py_DECREF(name);
return res;
+#endif
#ifdef __cplusplus
@@ -2998,7 +2993,7 @@
#endif
#define SWIG_name "_geos"
-#define SWIGVERSION 0x020004
+#define SWIGVERSION 0x020011
#define SWIG_VERSION SWIGVERSION
@@ -3097,7 +3092,10 @@
#include <stdexcept>
#include <stddef.h>
+ #include <stddef.h>
namespace swig {
struct stop_iteration {
@@ -3308,6 +3306,7 @@
SWIGINTERN int
SWIG_AsVal_unsigned_SS_long (PyObject *obj, unsigned long *val)
+#if PY_VERSION_HEX < 0x03000000
if (PyInt_Check(obj)) {
long v = PyInt_AsLong(obj);
if (v >= 0) {
@@ -3316,13 +3315,27 @@
} else {
return SWIG_OverflowError;
- } else if (PyLong_Check(obj)) {
+ } else
+#endif
+ if (PyLong_Check(obj)) {
unsigned long v = PyLong_AsUnsignedLong(obj);
if (!PyErr_Occurred()) {
if (val) *val = v;
return SWIG_OK;
} else {
PyErr_Clear();
+#if PY_VERSION_HEX >= 0x03000000
+ long v = PyLong_AsLong(obj);
+ if (!PyErr_Occurred()) {
+ if (v < 0) {
+ return SWIG_OverflowError;
+ } else {
+ PyErr_Clear();
+#endif
#ifdef SWIG_PYTHON_CAST_MODE
@@ -3359,7 +3372,7 @@
- #define SWIG_From_long PyInt_FromLong
+ #define SWIG_From_long PyLong_FromLong
SWIGINTERNINLINE PyObject *
@@ -3439,10 +3452,10 @@
#include <stdarg.h>
-SWIGINTERNINLINE PyObject *
-SWIG_From_int (int value)
- return SWIG_From_long (value);
+SWIGINTERNINLINE PyObject*
+ SWIG_From_int (int value)
+ return PyInt_FromLong((long) value);
@@ -3592,20 +3605,12 @@
return result;
-SWIGINTERNINLINE PyObject*
-SWIG_From_unsigned_SS_long (unsigned long value)
+ SWIG_From_unsigned_SS_int (unsigned int value)
- return (value > LONG_MAX) ?
- PyLong_FromUnsignedLong(value) : PyInt_FromLong(static_cast< long >(value));
+ return PyInt_FromSize_t((size_t) value);
-SWIG_From_unsigned_SS_int (unsigned int value)
- return SWIG_From_unsigned_SS_long (value);
SWIGINTERN unsigned int GeosCoordinateSequence_getDimensions(GeosCoordinateSequence *self){
unsigned int result;
GEOSCoordSeq coords = (GEOSCoordSeq) self;
@@ -3704,6 +3709,14 @@
return GEOSGeom_getDimensions(geom);
+SWIG_From_unsigned_SS_long (unsigned long value)
+ return (value > LONG_MAX) ?
+ PyLong_FromUnsignedLong(value) : PyLong_FromLong(static_cast< long >(value));
SWIG_From_size_t (size_t value)
@@ -10381,18 +10394,18 @@
#endif
* Type initialization:
- * This problem is tough by the requirement that no dynamic
- * memory is used. Also, since swig_type_info structures store pointers to
+ * This problem is tough by the requirement that no dynamic
+ * memory is used. Also, since swig_type_info structures store pointers to
* swig_cast_info structures and swig_cast_info structures store pointers back
- * to swig_type_info structures, we need some lookup code at initialization.
- * The idea is that swig generates all the structures that are needed.
- * The runtime then collects these partially filled structures.
- * The SWIG_InitializeModule function takes these initial arrays out of
+ * to swig_type_info structures, we need some lookup code at initialization.
+ * The idea is that swig generates all the structures that are needed.
+ * The runtime then collects these partially filled structures.
+ * The SWIG_InitializeModule function takes these initial arrays out of
* swig_module, and does all the lookup, filling in the swig_module.types
* array with the correct data and linking the correct swig_cast_info
* structures together.
- * The generated swig_type_info structures are assigned staticly to an initial
+ * The generated swig_type_info structures are assigned staticly to an initial
* array. We just loop through that array, and handle each type individually.
* First we lookup if this type has been already loaded, and if so, use the
* loaded structure instead of the generated one. Then we have to fill in the
@@ -10402,17 +10415,17 @@
* a column is one of the swig_cast_info structures for that type.
* The cast_initial array is actually an array of arrays, because each row has
* a variable number of columns. So to actually build the cast linked list,
- * we find the array of casts associated with the type, and loop through it
+ * we find the array of casts associated with the type, and loop through it
* adding the casts to the list. The one last trick we need to do is making
* sure the type pointer in the swig_cast_info struct is correct.
- * First off, we lookup the cast->type name to see if it is already loaded.
+ * First off, we lookup the cast->type name to see if it is already loaded.
* There are three cases to handle:
* 1) If the cast->type has already been loaded AND the type we are adding
* casting info to has not been loaded (it is in this module), THEN we
* replace the cast->type pointer with the type pointer that has already
* been loaded.
- * 2) If BOTH types (the one we are adding casting info to, and the
+ * 2) If BOTH types (the one we are adding casting info to, and the
* cast->type) are loaded, THEN the cast info has already been loaded by
* the previous module so we just ignore it.
* 3) Finally, if cast->type has not already been loaded, then we add that
@@ -10438,8 +10451,6 @@
swig_module_info *module_head, *iter;
int found, init;
- clientdata = clientdata;
/* check to see if the circular list has been setup, if not, set it up */
if (swig_module.next==0) {
/* Initialize the swig_module */
@@ -10477,7 +10488,7 @@
module_head->next = &swig_module;
- /* When multiple interpeters are used, a module could have already been initialized in
+ /* When multiple interpreters are used, a module could have already been initialized in
a different interpreter, but not yet have a pointer in this interpreter.
In this case, we do not want to continue adding types... everything should be
set up already */
@@ -11012,6 +11023,7 @@
m = Py_InitModule((char *) SWIG_name, SwigMethods);
#endif
md = d = PyModule_GetDict(m);
+ (void)md;
SWIG_InitializeModule(0);
@@ -11055,14 +11067,14 @@
SWIG_Python_SetConstant(d, "GEOS_VERSION_MAJOR",SWIG_From_int(static_cast< int >(3)));
SWIG_Python_SetConstant(d, "GEOS_VERSION_MINOR",SWIG_From_int(static_cast< int >(4)));
- SWIG_Python_SetConstant(d, "GEOS_VERSION",SWIG_FromCharPtr("3.4.0dev"));
+ SWIG_Python_SetConstant(d, "GEOS_VERSION",SWIG_FromCharPtr("3.4.3dev"));
SWIG_Python_SetConstant(d, "GEOS_JTS_PORT",SWIG_FromCharPtr("1.12.0"));
SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MAJOR",SWIG_From_int(static_cast< int >(1)));
SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_MINOR",SWIG_From_int(static_cast< int >(8)));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_PATCH",SWIG_From_int(static_cast< int >(0)));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION_PATCH",SWIG_From_int(static_cast< int >(3)));
SWIG_Python_SetConstant(d, "GEOS_CAPI_FIRST_INTERFACE",SWIG_From_int(static_cast< int >(1)));
SWIG_Python_SetConstant(d, "GEOS_CAPI_LAST_INTERFACE",SWIG_From_int(static_cast< int >((1+8))));
- SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION",SWIG_FromCharPtr("3.4.0dev-CAPI-1.8.0"));
+ SWIG_Python_SetConstant(d, "GEOS_CAPI_VERSION",SWIG_FromCharPtr("3.4.3dev-CAPI-1.8.3"));
SWIG_Python_SetConstant(d, "GEOS_POINT",SWIG_From_int(static_cast< int >(GEOS_POINT)));
SWIG_Python_SetConstant(d, "GEOS_LINESTRING",SWIG_From_int(static_cast< int >(GEOS_LINESTRING)));
SWIG_Python_SetConstant(d, "GEOS_LINEARRING",SWIG_From_int(static_cast< int >(GEOS_LINEARRING)));
Modified: branches/3.4/tests/xmltester/Makefile.am
--- branches/3.4/tests/xmltester/Makefile.am 2014-12-05 09:37:26 UTC (rev 4038)
+++ branches/3.4/tests/xmltester/Makefile.am 2015-01-19 10:59:17 UTC (rev 4039)
@@ -39,6 +39,7 @@
$(srcdir)/tests/ticket/bug599.xml \
$(srcdir)/tests/ticket/bug605.xml \
$(srcdir)/tests/ticket/bug615.xml \
+ $(srcdir)/tests/ticket/bug716.xml \
$(srcdir)/tests/general/TestBoundary.xml \
$(srcdir)/tests/general/TestBuffer.xml \
$(srcdir)/tests/general/TestBufferMitredJoin.xml \
Added: branches/3.4/tests/xmltester/tests/ticket/bug716.xml
--- branches/3.4/tests/xmltester/tests/ticket/bug716.xml (rev 0)
+++ branches/3.4/tests/xmltester/tests/ticket/bug716.xml 2015-01-19 10:59:17 UTC (rev 4039)
@@ -0,0 +1,75 @@
+<run>
+ <precisionModel type="FLOATING"/>
+ <desc>
+ Intersects operation of polygons with collinear lines.
+ http://trac.osgeo.org/geos/ticket/716
+ </desc>
+<case>
+ <desc>
+ a CW, b CW
+ </desc>
+ <a>
+ POLYGON((0.04745459120333707 7.998990511152711, 10.222919749090828 34.08521670606894, 10 10, 0.04745459120333707 7.998990511152711))
+ </a>
+ <b>
+ POLYGON((15 5, 0.010044793132693013 7.903085268568247, 10.260329547338191 34.181121949106455, 15 5))
+ </b>
+<test>
+ <op name="intersects" arg1="A" arg2="B">
+ true
+ </op>
+</test>
+</case>
+<case>
+ <desc>
+ a CCW, b CW
+ </desc>
+ <a>
+ POLYGON((0.04745459120333707 7.998990511152711, 10 10, 10.222919749090828 34.08521670606894, 0.04745459120333707 7.998990511152711))
+ </a>
+ <b>
+ </b>
+<test>
+ true
+ </op>
+</test>
+</case>
+<case>
+ <desc>
+ a CW, b CCW
+ </desc>
+ <a>
+ </a>
+ <b>
+ POLYGON((15 5, 10.260329547338191 34.181121949106455, 0.010044793132693013 7.903085268568247, 15 5))
+ </b>
+<test>
+ true
+ </op>
+</test>
+</case>
+<case>
+ <desc>
+ a CCW, b CCW
+ </desc>
+ <a>
+ </a>
+ <b>
+ </b>
+<test>
+ true
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits
