[geos-commits] r4042 - in branches/3.3/tests/xmltester: . tests/ticket
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Jan 23 02:27:05 PST 2015
Author: strk
Date: 2015-01-23 02:27:04 -0800 (Fri, 23 Jan 2015)
New Revision: 4042
Added:
   branches/3.3/tests/xmltester/tests/ticket/bug569.xml
   branches/3.3/tests/xmltester/Makefile.am
Add (succeeding) test for reported bug #569
Modified: branches/3.3/tests/xmltester/Makefile.am
--- branches/3.3/tests/xmltester/Makefile.am	2015-01-23 10:19:12 UTC (rev 4041)
+++ branches/3.3/tests/xmltester/Makefile.am	2015-01-23 10:27:04 UTC (rev 4042)
@@ -34,6 +34,7 @@
 	$(srcdir)/tests/ticket/bug398.xml \
 	$(srcdir)/tests/ticket/bug434.xml \
 	$(srcdir)/tests/ticket/bug527.xml \
+	$(srcdir)/tests/ticket/bug569.xml \
 	$(srcdir)/tests/ticket/bug582.xml \
 	$(srcdir)/tests/ticket/bug586.xml \
 	$(srcdir)/tests/ticket/bug599.xml \
Added: branches/3.3/tests/xmltester/tests/ticket/bug569.xml
--- branches/3.3/tests/xmltester/tests/ticket/bug569.xml	                        (rev 0)
+++ branches/3.3/tests/xmltester/tests/ticket/bug569.xml	2015-01-23 10:27:04 UTC (rev 4042)
@@ -0,0 +1,22 @@
+<run>
+  <desc>
+    http://trac.osgeo.org/geos/ticket/569
+  </desc>
+  <precisionModel type="FLOATING" />
+  <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+  <desc>
+  </desc>
+  <a>
+POLYGON((0 0, 50 100, 30 130, 124 290, 82 144, 129 289, 120 140, 170 135, 0 0))'
+  </a>
+<test>
+  <op name='buffer' arg1='A' arg2='25' arg3='8'>
+POLYGON((15.5470535900397 -19.5777711874573,11.4976107110387 -22.1992105250932,7.0200900440899 -23.9941312777285,2.2811981503014 -24.8957051516735,-2.54262706420865 -24.8703648467881,-7.27178546518863 -23.91905383054,-11.730201542863 -22.0771912109266,-15.7518800361076 -19.4133530161091,-19.1870862499068 -16.026718979212,-21.9079209611867 -12.0433798893166,-23.8130823487386 -7.61164299295461,-24.8316376515772 -2.89651023488152,-24.9256641297612 1.92646507633405,-24.0916609997104 6.67771444994727,-22.3606797749979 11.1803398874989,21.1511170340587 98.2039335056121,9.19874264155391 116.132495094369,6.98783622003994 120.23064392274,5.57528365445842 124.667717989469,5.01009019256528 129.289783261055,5.31186391571979 133.936487861541,6.47013548180344 138.446625110381,8.44472133485679 142.663726215772,102.444721334857 302.663726215772,105.268944378042 306.557401827796,108.786574484237 309.838137112046,112.867392107363 312.384482158602,117.360328999059 314.102173532677,122.09906062
 123 314.927623823346,126.908163332901 314.830275593097,131.223450301601 313.897227411553,131.262110575215 313.897446771617,135.985092572393 313.004342976951,140.449858682776 311.223877612704,144.491361195318 308.621868624476,147.960199061366 305.294503722218,150.728140759799 301.364784637119,152.692864594398 296.977980152364,153.781741190247 292.296255994245,153.954518362728 287.492680098896,146.403677896142 162.484321263188,172.487592975525 159.87592975525,177.321907493882 158.9037585047,181.871362160861 157.001608133172,185.958959796235 154.243482071137,189.425671833216 150.736685604923,192.13662534744 146.617651149311,193.98635030725 142.046630325048,194.902882900269 137.201459346772,194.85056529574 132.270640279816,193.831432917501 127.446007340574,191.885135255529 122.915263559051,189.087393296904 118.854678165818,185.54705359004 115.422228812543,15.5470535900397 -19.5777711874573))
+  </op>
+</test>
+</case>
+</run>
More information about the geos-commits mailing list
