[geos-commits] r4113 - in trunk/tests/unit: . capi
svn_geos at osgeo.org
Tue Nov 3 01:17:42 PST 2015
Author: strk
Date: 2015-11-03 01:17:42 -0800 (Tue, 03 Nov 2015)
New Revision: 4113
Added:
trunk/tests/unit/capi/GEOSEqualsTest.cpp
trunk/tests/unit/Makefile.am
Add test for GEOSEquals
Includes disabled test for #752
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2015-11-02 12:52:12 UTC (rev 4112)
+++ trunk/tests/unit/Makefile.am 2015-11-03 09:17:42 UTC (rev 4113)
@@ -126,6 +126,7 @@
capi/GEOSContainsTest.cpp \
capi/GEOSConvexHullTest.cpp \
capi/GEOSDistanceTest.cpp \
+ capi/GEOSEqualsTest.cpp \
capi/GEOSInterruptTest.cpp \
capi/GEOSIntersectsTest.cpp \
capi/GEOSIntersectionTest.cpp \
Added: trunk/tests/unit/capi/GEOSEqualsTest.cpp
--- trunk/tests/unit/capi/GEOSEqualsTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSEqualsTest.cpp 2015-11-03 09:17:42 UTC (rev 4113)
@@ -0,0 +1,186 @@
+// Test Suite for C-API GEOSEquals
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeosequals_data
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosequals_data()
+ : geom1_(0), geom2_(0)
+ initGEOS(notice, notice);
+ ~test_capigeosequals_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ geom1_ = 0;
+ geom2_ = 0;
+ finishGEOS();
+ typedef test_group<test_capigeosequals_data> group;
+ typedef group::object object;
+ group test_capigeosequals_group("capi::GEOSEquals");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ ensure( 0 != geom1_ );
+ ensure( 0 != geom2_ );
+ char const r1 = GEOSEquals(geom1_, geom2_);
+ ensure_equals(r1, 1);
+ char const r2 = GEOSEquals(geom2_, geom1_);
+ ensure_equals(r2, 1);
+ template<>
+ template<>
+ void object::test<2>()
+ geom1_ = GEOSGeomFromWKT("POINT(2 3)");
+ geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+ ensure_equals(int(r1), 0);
+ ensure_equals(int(r2), 0);
+ template<>
+ template<>
+ void object::test<3>()
+ geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
+ geom2_ = GEOSGeomFromWKT("POLYGON((0 0,0 10,10 10,10 0,0 0))");
+ ensure_equals(int(r1), 1);
+ ensure_equals(int(r2), 1);
+ // This is a test for bug #357 (GEOSEquals with nan coords)
+ template<>
+ template<>
+ void object::test<4>()
+ GEOSCoordSequence* cs = GEOSCoordSeq_create(5, 2);
+ double nan = std::numeric_limits<double>::quiet_NaN();
+ GEOSCoordSeq_setX(cs, 0, 1); GEOSCoordSeq_setY(cs, 0, 1);
+ for (unsigned int i=1; i<4; ++i) {
+ GEOSCoordSeq_setX(cs, i, nan);
+ GEOSCoordSeq_setY(cs, i, nan);
+ GEOSCoordSeq_setX(cs, 4, 1); GEOSCoordSeq_setY(cs, 4, 1);
+ geom1_ = GEOSGeom_createPolygon(GEOSGeom_createLinearRing(cs),
+ NULL, 0);
+ char const r1 = GEOSEquals(geom1_, geom1_);
+ ensure_equals(int(r1), 2);
+ // This is a test for bug #357 (GEOSEquals with inf coords)
+ template<>
+ template<>
+ void object::test<5>()
+ const char *hex = "0103000020E61000000100000005000000737979F3DDCC2CC0F92154F9E7534540000000000000F07F000000000000F07F8F806E993F7E55C0304B29FFEA8554400634E8D1DD424540B5FEE6A37FCD4540737979F3DDCC2CC0F92154F9E7534540";
+ geom1_ = GEOSGeomFromHEX_buf((unsigned char*)hex, std::strlen(hex));
+#if 0 // fails
+ // This is a test for bug #752 (GEOSEquals with collection)
+ template<>
+ template<>
+ void object::test<6>()
+ const char *wkt1 = "GEOMETRYCOLLECTION(POLYGON ("
+ "(0 0, 0 4, 4 4, 4 0, 0 0)"
+ "POLYGON ("
+ "(3 3, 3 4, 4 4, 4 3, 3 3)"
+ geom1_ = GEOSGeomFromWKT(wkt1);
+#endif
+} // namespace tut
More information about the geos-commits
