[geos-commits] r4115 - in branches/3.5: . include/geos
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Nov 4 12:37:34 PST 2015
Author: mloskot
Date: 2015-11-04 12:37:34 -0800 (Wed, 04 Nov 2015)
New Revision: 4115
   branches/3.5/
   branches/3.5/CMakeLists.txt
   branches/3.5/include/geos/platform.h.cmake
Merged revision(s) 4112,4114 from trunk:
Add #define NOMINMAX for Visual C++
CMake should not try to generate geos_svn_revision.h if GEOS is built from packaged sources.
Fixes #753
Property changes on: branches/3.5
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/3.4:4056
/trunk:4099-4100,4104
   + /branches/3.4:4056
/trunk:4099-4100,4104,4112,4114
Modified: branches/3.5/CMakeLists.txt
--- branches/3.5/CMakeLists.txt	2015-11-04 20:30:49 UTC (rev 4114)
+++ branches/3.5/CMakeLists.txt	2015-11-04 20:37:34 UTC (rev 4115)
@@ -254,29 +254,35 @@
 ENDMACRO(GET_SVN_REVISION)
 # Determine SVN/Git revision
-if(EXISTS "${CMAKE_SOURCE_DIR}/.svn")
+set(GEOS_BUILD_PACKAGED TRUE)
+if(EXISTS "${PROJECT_SOURCE_DIR}/.svn")
+  set(GEOS_BUILD_PACKAGED FALSE)
   GET_SVN_REVISION()
+elseif(EXISTS "${PROJECT_SOURCE_DIR}/.git")
 endif()
-if ( NOT ${Project_WC_REVISION} EQUAL 0 )
-   set( GEOS_SVN_REVISION ${Project_WC_REVISION} )
-   configure_file (
-      "${PROJECT_SOURCE_DIR}/tools/geos_svn_revision_cmake.h.in"
-      "${PROJECT_SOURCE_DIR}/geos_svn_revision.h" )
-      # "${geos_BINARY_DIR}/include/geos_svn_revision.h" )
-else()
-   message(STATUS "Generating revision header ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
-   find_program(SH sh)
-   if(SH)
-      execute_process(COMMAND ${SH} -c
-      "cd ${CMAKE_SOURCE_DIR} && ${CMAKE_SOURCE_DIR}/tools/svn_repo_revision.sh")
-      file(RENAME "${CMAKE_SOURCE_DIR}/geos_svn_revision.h"
-      "${CMAKE_BINARY_DIR}/geos_svn_revision.h")
-   else()
-      message("*** sh-compatible command not found, cannot create geos_svn_revision.h")
-      message("*** Check SVN revision and create revision header manually:")
-      message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
-   endif()
+if (NOT GEOS_BUILD_PACKAGED)
+  message(STATUS "Generating GEOS revision header in ${PROJECT_BINARY_DIR}/geos_svn_revision.h")
+  if ( NOT ${Project_WC_REVISION} EQUAL 0 )
+     set( GEOS_SVN_REVISION ${Project_WC_REVISION} )
+     configure_file (
+        "${PROJECT_SOURCE_DIR}/tools/geos_svn_revision_cmake.h.in"
+        "${PROJECT_BINARY_DIR}/include/geos_svn_revision.h" )
+  else()
+     find_program(SH sh)
+     if(SH)
+        execute_process(COMMAND ${SH} -c
+        "cd ${PROJECT_SOURCE_DIR} && ${PROJECT_SOURCE_DIR}/tools/svn_repo_revision.sh")
+        file(RENAME "${PROJECT_SOURCE_DIR}/geos_svn_revision.h"
+        "${PROJECT_BINARY_DIR}/geos_svn_revision.h")
+     else()
+        message("*** sh-compatible command not found, cannot create geos_svn_revision.h")
+        message("*** Check SVN revision and create revision header manually:")
+        message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${PROJECT_SOURCE_DIR}/geos_svn_revision.h")
+     endif()
+  endif()
 endif()
 # End: Determine SVN/Git revision
Modified: branches/3.5/include/geos/platform.h.cmake
--- branches/3.5/include/geos/platform.h.cmake	2015-11-04 20:30:49 UTC (rev 4114)
+++ branches/3.5/include/geos/platform.h.cmake	2015-11-04 20:37:34 UTC (rev 4115)
@@ -19,6 +19,12 @@
 #ifndef GEOS_PLATFORM_H_INCLUDED
 #define GEOS_PLATFORM_H_INCLUDED
+#ifdef _MSC_VER
+#ifndef NOMINMAX
+#define NOMINMAX 1
+#endif
+#endif
 /* Disable inclusion of platform.h not generated by CMake */
 #define GEOS_PLATFORM_H 1
More information about the geos-commits mailing list
