[geos-commits] r4119 - in trunk: include/geos/triangulate/quadedge src/triangulate/quadedge
svn_geos at osgeo.org
Sat Nov 21 04:59:28 PST 2015
Author: strk
Date: 2015-11-21 04:59:28 -0800 (Sat, 21 Nov 2015)
New Revision: 4119
trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
use std::vector instead of std::list to avoid size() bottleneck
Patch by Daniel Baston via
https://github.com/libgeos/libgeos/pull/55
Modified: trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
--- trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h 2015-11-16 10:53:09 UTC (rev 4118)
+++ trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h 2015-11-21 12:59:28 UTC (rev 4119)
@@ -78,7 +78,7 @@
class GEOS_DLL QuadEdgeSubdivision {
public:
- typedef std::list<QuadEdge*> QuadEdgeList;
+ typedef std::vector<QuadEdge*> QuadEdgeList;
* Gets the edges for the triangle to the left of the given {@link QuadEdge}.
Modified: trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
--- trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2015-11-16 10:53:09 UTC (rev 4118)
+++ trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2015-11-21 12:59:28 UTC (rev 4119)
@@ -17,6 +17,7 @@
#include <geos/triangulate/quadedge/QuadEdgeSubdivision.h>
+#include <algorithm>
#include <vector>
#include <set>
#include <iostream>
@@ -159,8 +160,8 @@
QuadEdge::splice(e, e.oPrev());
QuadEdge::splice(e.sym(), e.sym().oPrev());
- // this is inefficient on an ArrayList, but this method should be called infrequently
- quadEdges.remove(&e);
+ // this is inefficient on a std::vector, but this method should be called infrequently
+ quadEdges.erase(std::remove(quadEdges.begin(), quadEdges.end(), &e), quadEdges.end());
//mark these edges as removed
e.remove();
More information about the geos-commits
