[geos-commits] r4124 - in trunk: . capi tests/unit tests/unit/capi
svn_geos at osgeo.org
Mon Nov 30 12:30:15 PST 2015
Author: strk
Date: 2015-11-30 12:30:15 -0800 (Mon, 30 Nov 2015)
New Revision: 4124
Added:
trunk/tests/unit/capi/GEOSMinimumWidthTest.cpp
Removed:
trunk/tests/unit/capi/GEOSMinimumDiameterTest.cpp
trunk/NEWS
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/tests/unit/Makefile.am
Rename GEOSMinimumDiameter to GEOSMinimumWidth, add docs
Patch by Nyall Dawson
Modified: trunk/NEWS
--- trunk/NEWS 2015-11-30 12:01:42 UTC (rev 4123)
+++ trunk/NEWS 2015-11-30 20:30:15 UTC (rev 4124)
@@ -4,7 +4,7 @@
- New things:
- CAPI: GEOSGeom_setPrecision (#713) - PHP: Geometry->setPrecision
- CAPI: GEOSGeom_getPrecision - PHP: Geometry->getPrecision
- - CAPI: GEOSMinimumRotatedRectangle and GEOSMinimumDiameter
+ - CAPI: GEOSMinimumRotatedRectangle and GEOSMinimumWidth
(#729, Nyall Dawson)
- Improvements:
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2015-11-30 12:01:42 UTC (rev 4123)
+++ trunk/capi/geos_c.cpp 2015-11-30 20:30:15 UTC (rev 4124)
@@ -443,9 +443,9 @@
Geometry *
-GEOSMinimumDiameter(const Geometry *g)
+GEOSMinimumWidth(const Geometry *g)
- return GEOSMinimumDiameter_r( handle, g );
+ return GEOSMinimumWidth_r( handle, g );
Geometry *
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2015-11-30 12:01:42 UTC (rev 4123)
+++ trunk/capi/geos_c.h.in 2015-11-30 20:30:15 UTC (rev 4124)
@@ -538,10 +538,24 @@
const GEOSGeometry* g2);
extern GEOSGeometry GEOS_DLL *GEOSConvexHull_r(GEOSContextHandle_t handle,
const GEOSGeometry* g);
+/* Returns the minimum rotated rectangular POLYGON which encloses the input geometry. The rectangle
+ * has width equal to the minimum diameter, and a longer length. If the convex hill of the input is
+ * degenerate (a line or point) a LINESTRING or POINT is returned. The minimum rotated rectangle can
+ * be used as an extremely generalized representation for the given geometry.
extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t handle,
-extern GEOSGeometry GEOS_DLL *GEOSMinimumDiameter_r(GEOSContextHandle_t handle,
+/* Returns a LINESTRING geometry which represents the minimum diameter of the geometry.
+ * The minimum diameter is defined to be the width of the smallest band that
+ * contains the geometry, where a band is a strip of the plane defined
+ * by two parallel lines. This can be thought of as the smallest hole that the geometry
+ * can be moved through, with a single rotation.
+extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth_r(GEOSContextHandle_t handle,
extern GEOSGeometry GEOS_DLL *GEOSDifference_r(GEOSContextHandle_t handle,
const GEOSGeometry* g1,
@@ -1452,8 +1466,22 @@
extern GEOSGeometry GEOS_DLL *GEOSEnvelope(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSIntersection(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern GEOSGeometry GEOS_DLL *GEOSConvexHull(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle(const GEOSGeometry* g);
-extern GEOSGeometry GEOS_DLL *GEOSMinimumDiameter(const GEOSGeometry* g);
+extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSDifference(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern GEOSGeometry GEOS_DLL *GEOSSymDifference(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern GEOSGeometry GEOS_DLL *GEOSBoundary(const GEOSGeometry* g);
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2015-11-30 12:01:42 UTC (rev 4123)
+++ trunk/capi/geos_ts_c.cpp 2015-11-30 20:30:15 UTC (rev 4124)
@@ -2044,7 +2044,7 @@
Geometry *
-GEOSMinimumDiameter_r(GEOSContextHandle_t extHandle, const Geometry *g)
+GEOSMinimumWidth_r(GEOSContextHandle_t extHandle, const Geometry *g)
if ( 0 == extHandle )
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2015-11-30 12:01:42 UTC (rev 4123)
+++ trunk/tests/unit/Makefile.am 2015-11-30 20:30:15 UTC (rev 4124)
@@ -132,7 +132,7 @@
capi/GEOSIntersectsTest.cpp \
capi/GEOSIntersectionTest.cpp \
capi/GEOSMinimumRectangleTest.cpp \
- capi/GEOSMinimumDiameterTest.cpp \
+ capi/GEOSMinimumWidthTest.cpp \
capi/GEOSNearestPointsTest.cpp \
capi/GEOSWithinTest.cpp \
capi/GEOSSimplifyTest.cpp \
Deleted: trunk/tests/unit/capi/GEOSMinimumDiameterTest.cpp
--- trunk/tests/unit/capi/GEOSMinimumDiameterTest.cpp 2015-11-30 12:01:42 UTC (rev 4123)
+++ trunk/tests/unit/capi/GEOSMinimumDiameterTest.cpp 2015-11-30 20:30:15 UTC (rev 4124)
@@ -1,83 +0,0 @@
-// Test Suite for C-API GEOSMinimumDiameter
-#include <tut.hpp>
-// geos
-#include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-namespace tut
- // Test Group
- // Common data used in test cases.
- struct test_capigeosminimumdiameter_data
- GEOSGeometry* input_;
- GEOSWKTWriter* wktw_;
- char* wkt_;
- static void notice(const char *fmt, ...)
- std::fprintf( stdout, "NOTICE: ");
- va_list ap;
- va_start(ap, fmt);
- std::vfprintf(stdout, fmt, ap);
- va_end(ap);
- std::fprintf(stdout, "\n");
- test_capigeosminimumdiameter_data()
- : input_(0), wkt_(0)
- initGEOS(notice, notice);
- wktw_ = GEOSWKTWriter_create();
- GEOSWKTWriter_setTrim(wktw_, 1);
- GEOSWKTWriter_setRoundingPrecision(wktw_, 8);
- ~test_capigeosminimumdiameter_data()
- GEOSGeom_destroy(input_);
- input_ = 0;
- GEOSWKTWriter_destroy(wktw_);
- GEOSFree(wkt_);
- wkt_ = 0;
- finishGEOS();
- typedef test_group<test_capigeosminimumdiameter_data> group;
- typedef group::object object;
- group test_capigeosminimumdiameter_group("capi::GEOSMinimumDiameter");
- // Test Cases
- template<>
- template<>
- void object::test<1>()
- input_ = GEOSGeomFromWKT("POLYGON ((0 0, 0 15, 5 10, 5 0, 0 0))");
- ensure( 0 != input_ );
- GEOSGeometry* output = GEOSMinimumDiameter(input_);
- ensure( 0 != output );
- ensure( 0 == GEOSisEmpty(output) );
- wkt_ = GEOSWKTWriter_write(wktw_, output);
- ensure_equals(std::string(wkt_), std::string( "LINESTRING (0 0, 5 0)"));
- GEOSGeom_destroy(output);
-} // namespace tut
Copied: trunk/tests/unit/capi/GEOSMinimumWidthTest.cpp (from rev 4123, trunk/tests/unit/capi/GEOSMinimumDiameterTest.cpp)
--- trunk/tests/unit/capi/GEOSMinimumWidthTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSMinimumWidthTest.cpp 2015-11-30 20:30:15 UTC (rev 4124)
@@ -0,0 +1,83 @@
+// Test Suite for C-API GEOSMinimumWidth
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeosminimumwidth_data
+ GEOSGeometry* input_;
+ GEOSWKTWriter* wktw_;
+ char* wkt_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosminimumwidth_data()
+ : input_(0), wkt_(0)
+ initGEOS(notice, notice);
+ wktw_ = GEOSWKTWriter_create();
+ GEOSWKTWriter_setTrim(wktw_, 1);
+ GEOSWKTWriter_setRoundingPrecision(wktw_, 8);
+ ~test_capigeosminimumwidth_data()
+ GEOSGeom_destroy(input_);
+ input_ = 0;
+ GEOSWKTWriter_destroy(wktw_);
+ GEOSFree(wkt_);
+ wkt_ = 0;
+ finishGEOS();
+ typedef test_group<test_capigeosminimumwidth_data> group;
+ typedef group::object object;
+ group test_capigeosminimumwidth_group("capi::GEOSMinimumWidth");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ input_ = GEOSGeomFromWKT("POLYGON ((0 0, 0 15, 5 10, 5 0, 0 0))");
+ ensure( 0 != input_ );
+ GEOSGeometry* output = GEOSMinimumWidth(input_);
+ ensure( 0 != output );
+ ensure( 0 == GEOSisEmpty(output) );
+ wkt_ = GEOSWKTWriter_write(wktw_, output);
+ ensure_equals(std::string(wkt_), std::string( "LINESTRING (0 0, 5 0)"));
+ GEOSGeom_destroy(output);
+} // namespace tut
More information about the geos-commits
