[geos-commits] r4091 - in trunk: . doc include/geos/geom include/geos/operation/valid include/geos/precision src/geom src/operation/valid src/precision tests/bigtest tests/perf/operation/buffer tests/perf/operation/predicate tests/unit/algorithm tests/unit/algorithm/distance tests/unit/capi tests/unit/geom tests/unit/geom/Geometry tests/unit/geom/prep tests/unit/geom/util tests/unit/io tests/unit/linearref tests/unit/noding tests/unit/noding/snapround tests/unit/operation tests/unit/operation/buffer tests/unit/operation/distance tests/unit/operation/intersection tests/unit/operation/linemerge tests/unit/operation/overlay/snap tests/unit/operation/overlay/validate tests/unit/operation/polygonize tests/unit/operation/sharedpaths tests/unit/operation/union tests/unit/operation/valid tests/unit/precision tests/unit/simplify tests/unit/triangulate tests/unit/triangulate/quadedge tests/unit/util tests/xmltester
svn_geos at osgeo.org
Fri Oct 2 02:59:33 PDT 2015
Author: strk
Date: 2015-10-02 02:59:33 -0700 (Fri, 02 Oct 2015)
New Revision: 4091
trunk/NEWS
trunk/doc/example.cpp
trunk/include/geos/geom/BinaryOp.h
trunk/include/geos/geom/GeometryFactory.h
trunk/include/geos/operation/valid/ConnectedInteriorTester.h
trunk/include/geos/precision/GeometryPrecisionReducer.h
trunk/src/geom/Geometry.cpp
trunk/src/geom/GeometryFactory.cpp
trunk/src/operation/valid/ConnectedInteriorTester.cpp
trunk/src/precision/GeometryPrecisionReducer.cpp
trunk/tests/bigtest/TestSweepLineSpeed.cpp
trunk/tests/bigtest/bug234.cpp
trunk/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
trunk/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
trunk/tests/unit/algorithm/ConvexHullTest.cpp
trunk/tests/unit/algorithm/PointLocatorTest.cpp
trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp
trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp
trunk/tests/unit/geom/Geometry/clone.cpp
trunk/tests/unit/geom/Geometry/coversTest.cpp
trunk/tests/unit/geom/Geometry/equalsTest.cpp
trunk/tests/unit/geom/Geometry/isRectangleTest.cpp
trunk/tests/unit/geom/Geometry/normalize.cpp
trunk/tests/unit/geom/GeometryFactoryTest.cpp
trunk/tests/unit/geom/LineStringTest.cpp
trunk/tests/unit/geom/LinearRingTest.cpp
trunk/tests/unit/geom/MultiPointTest.cpp
trunk/tests/unit/geom/PointTest.cpp
trunk/tests/unit/geom/PolygonTest.cpp
trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
trunk/tests/unit/geom/util/GeometryExtracterTest.cpp
trunk/tests/unit/io/WKBReaderTest.cpp
trunk/tests/unit/io/WKBWriterTest.cpp
trunk/tests/unit/io/WKTReaderTest.cpp
trunk/tests/unit/io/WKTWriterTest.cpp
trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
trunk/tests/unit/noding/OrientedCoordinateArray.cpp
trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
trunk/tests/unit/operation/IsSimpleOpTest.cpp
trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
trunk/tests/unit/operation/buffer/BufferOpTest.cpp
trunk/tests/unit/operation/distance/DistanceOpTest.cpp
trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
trunk/tests/unit/operation/linemerge/LineMergerTest.cpp
trunk/tests/unit/operation/linemerge/LineSequencerTest.cpp
trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
trunk/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
trunk/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
trunk/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp
trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp
trunk/tests/unit/operation/valid/IsValidTest.cpp
trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp
trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp
trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
trunk/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
trunk/tests/unit/triangulate/DelaunayTest.cpp
trunk/tests/unit/triangulate/VoronoiTest.cpp
trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
trunk/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp
trunk/tests/xmltester/SimpleWKTTester.cpp
trunk/tests/xmltester/XMLTester.cpp
trunk/tests/xmltester/XMLTester.h
Prevent stack allocation of GeometryFactory
Geometry factory objects can be created by static methods
returning a smart pointer with automatic ownership transfer
semantic. The so-created GeometryFactory will be kept alive
as long as Geometry objects referencing it will be alive.
Modified: trunk/NEWS
--- trunk/NEWS 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/NEWS 2015-10-02 09:59:33 UTC (rev 4091)
@@ -4,6 +4,7 @@
- New things:
- Improvements:
- C++ API changes:
+ - Automatic memory management for GeometryFactory objects
Changes in 3.5.0
Modified: trunk/doc/example.cpp
--- trunk/doc/example.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/doc/example.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -84,7 +84,7 @@
// but that would be boring because you'd need to specify
// a PrecisionModel and a SRID everytime: those infos are
// cached inside a GeometryFactory object.
-GeometryFactory *global_factory;
+GeometryFactory::unique_ptr global_factory;
//#define DEBUG_STREAM_STATE 1
@@ -335,7 +335,7 @@
Polygon *
create_circle(double centerX, double centerY, double radius)
- geos::util::GeometricShapeFactory shapefactory(global_factory);
+ geos::util::GeometricShapeFactory shapefactory(global_factory.get());
shapefactory.setCentre(Coordinate(centerX, centerY));
shapefactory.setSize(radius);
// same as:
@@ -351,7 +351,7 @@
Polygon *
create_ellipse(double centerX, double centerY, double width, double height)
shapefactory.setHeight(height);
shapefactory.setWidth(width);
@@ -366,7 +366,7 @@
Polygon *
create_rectangle(double llX, double llY, double width, double height)
shapefactory.setBase(Coordinate(llX, llY));
@@ -383,7 +383,7 @@
LineString *
create_arc(double llX, double llY, double width, double height, double startang, double endang)
@@ -395,7 +395,7 @@
auto_ptr<Polygon>
create_sinestar(double cx, double cy, double size, int nArms, double armLenRat)
- geos::geom::util::SineStarFactory fact(global_factory);
+ geos::geom::util::SineStarFactory fact(global_factory.get());
fact.setCentre(Coordinate(cx, cy));
fact.setSize(size);
fact.setNumPoints(nArms*5);
@@ -416,7 +416,7 @@
// Initialize global factory with defined PrecisionModel
// and a SRID of -1 (undefined).
- global_factory = new GeometryFactory(pm, -1);
+ global_factory = GeometryFactory::create(pm, -1);
// We do not need PrecisionMode object anymore, it has
// been copied to global_factory private storage
@@ -1080,8 +1080,6 @@
delete (*geoms)[i];
delete geoms;
- delete global_factory;
int
Modified: trunk/include/geos/geom/BinaryOp.h
--- trunk/include/geos/geom/BinaryOp.h 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/include/geos/geom/BinaryOp.h 2015-10-02 09:59:33 UTC (rev 4091)
@@ -469,12 +469,12 @@
for (double scale=maxScale; scale >= 1; scale /= 10)
PrecisionModel pm(scale);
- GeometryFactory gf(&pm);
+ GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm);
#if GEOS_DEBUG_BINARYOP
std::cerr << "Trying with scale " << scale << std::endl;
#endif
- precision::GeometryPrecisionReducer reducer( gf );
+ precision::GeometryPrecisionReducer reducer( *gf );
GeomPtr rG0( reducer.reduce(*g0) );
GeomPtr rG1( reducer.reduce(*g1) );
Modified: trunk/include/geos/geom/GeometryFactory.h
--- trunk/include/geos/geom/GeometryFactory.h 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/include/geos/geom/GeometryFactory.h 2015-10-02 09:59:33 UTC (rev 4091)
@@ -66,12 +66,34 @@
class GEOS_DLL GeometryFactory {
public:
+ // TODO: typedef std::unique_ptr<GeometryFactory,destroy>
+ class unique_ptr {
+ mutable GeometryFactory *_f;
+ public:
+ // Copying an auto_unique_ptr transfers ownership
+ unique_ptr(const unique_ptr& o): _f(o.release()) {};
+ GeometryFactory* release() const { GeometryFactory *f = _f; _f=0; return f; }
+ void reset(GeometryFactory* f) { if ( _f ) _f->destroy(); _f = f; }
+ // assigning an auto_unique_ptr transfers ownership
+ unique_ptr& operator=(const unique_ptr& o) {
+ reset( o.release() );
+ return *this;
+ GeometryFactory* get() const { return _f; }
+ GeometryFactory* operator->() const { return _f; }
+ GeometryFactory& operator*() { return *_f; };
+ unique_ptr(): _f(0) {}
+ unique_ptr(GeometryFactory* f): _f(f) {}
+ ~unique_ptr() { reset(0); }
* \brief
* Constructs a GeometryFactory that generates Geometries having a
* floating PrecisionModel and a spatial-reference ID of 0.
- GeometryFactory();
+ static GeometryFactory::unique_ptr create();
* \brief
@@ -85,7 +107,7 @@
* and must be available for the whole lifetime
* of the GeometryFactory
- GeometryFactory(const PrecisionModel *pm, int newSRID,
+ static GeometryFactory::unique_ptr create(const PrecisionModel *pm, int newSRID,
CoordinateSequenceFactory *nCoordinateSequenceFactory);
@@ -94,7 +116,7 @@
* given CoordinateSequence implementation, a double-precision floating
* PrecisionModel and a spatial-reference ID of 0.
- GeometryFactory(CoordinateSequenceFactory *nCoordinateSequenceFactory);
+ static GeometryFactory::unique_ptr create(CoordinateSequenceFactory *nCoordinateSequenceFactory);
* \brief
@@ -104,7 +126,7 @@
* @param pm the PrecisionModel to use
- GeometryFactory(const PrecisionModel *pm);
+ static GeometryFactory::unique_ptr create(const PrecisionModel *pm);
* \brief
@@ -112,17 +134,17 @@
* the given {@link PrecisionModel} and spatial-reference ID,
* and the default CoordinateSequence implementation.
- * @param pm the PrecisionModel to use
+ * @param pm the PrecisionModel to use, will be copied internally
* @param newSRID the SRID to use
- GeometryFactory(const PrecisionModel* pm, int newSRID);
+ static GeometryFactory::unique_ptr create(const PrecisionModel* pm, int newSRID);
* \brief Copy constructor
* @param gf the GeometryFactory to clone from
- GeometryFactory(const GeometryFactory &gf);
+ static GeometryFactory::unique_ptr create(const GeometryFactory &gf);
* \brief
@@ -133,9 +155,6 @@
static const GeometryFactory*
getDefaultInstance();
- /// Destructor
- virtual ~GeometryFactory();
//Skipped a lot of list to array convertors
Point* createPointFromInternalCoord(const Coordinate* coord,
@@ -383,10 +402,91 @@
/// Destroy a Geometry, or release it
void destroyGeometry(Geometry *g) const;
+ /// Request that the instance is deleted.
+ /// It will really be deleted only after last child Geometry is
+ /// deleted. Do not use the instance anymore after calling this function
+ /// (unless you're a live child!).
+ void destroy();
+protected:
+ * \brief
+ * Constructs a GeometryFactory that generates Geometries having a
+ * floating PrecisionModel and a spatial-reference ID of 0.
+ GeometryFactory();
+ * \brief
+ * the given PrecisionModel, spatial-reference ID, and
+ * CoordinateSequence implementation.
+ * NOTES:
+ * (1) the given PrecisionModel is COPIED
+ * (2) the CoordinateSequenceFactory is NOT COPIED
+ * and must be available for the whole lifetime
+ * of the GeometryFactory
+ GeometryFactory(const PrecisionModel *pm, int newSRID,
+ CoordinateSequenceFactory *nCoordinateSequenceFactory);
+ * \brief
+ * Constructs a GeometryFactory that generates Geometries having the
+ * given CoordinateSequence implementation, a double-precision floating
+ * PrecisionModel and a spatial-reference ID of 0.
+ GeometryFactory(CoordinateSequenceFactory *nCoordinateSequenceFactory);
+ * \brief
+ * the given PrecisionModel and the default CoordinateSequence
+ * implementation.
+ GeometryFactory(const PrecisionModel *pm);
+ * \brief
+ * the given {@link PrecisionModel} and spatial-reference ID,
+ * and the default CoordinateSequence implementation.
+ * @param newSRID the SRID to use
+ GeometryFactory(const PrecisionModel* pm, int newSRID);
+ * \brief Copy constructor
+ * @param gf the GeometryFactory to clone from
+ GeometryFactory(const GeometryFactory &gf);
+ /// Destructor
+ virtual ~GeometryFactory();
private:
const PrecisionModel* precisionModel;
int SRID;
const CoordinateSequenceFactory *coordinateListFactory;
+ mutable int _geometryCount;
+ bool _autoDestroy;
+friend class Geometry;
+ void addChild(const Geometry *g) const;
+ void delChild(const Geometry *g) const;
} // namespace geos::geom
Modified: trunk/include/geos/operation/valid/ConnectedInteriorTester.h
--- trunk/include/geos/operation/valid/ConnectedInteriorTester.h 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/include/geos/operation/valid/ConnectedInteriorTester.h 2015-10-02 09:59:33 UTC (rev 4091)
@@ -23,6 +23,7 @@
#include <geos/export.h>
#include <geos/geom/Coordinate.h> // for composition
+#include <geos/geom/GeometryFactory.h> // for GeometryFactory::unique_ptr
#include <vector>
@@ -83,7 +84,7 @@
private:
- geom::GeometryFactory *geometryFactory;
+ geom::GeometryFactory::unique_ptr geometryFactory;
geomgraph::GeometryGraph &geomGraph;
Modified: trunk/include/geos/precision/GeometryPrecisionReducer.h
--- trunk/include/geos/precision/GeometryPrecisionReducer.h 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/include/geos/precision/GeometryPrecisionReducer.h 2015-10-02 09:59:33 UTC (rev 4091)
@@ -20,6 +20,7 @@
#define GEOS_PRECISION_GEOMETRYPRECISIONREDUCER_H
#include <memory> // for auto_ptr
// Forward declarations
@@ -57,7 +58,7 @@
std::auto_ptr<geom::Geometry> fixPolygonalTopology(
const geom::Geometry& geom );
- std::auto_ptr<geom::GeometryFactory> createFactory(
+ geom::GeometryFactory::unique_ptr createFactory(
const geom::GeometryFactory& oldGF,
const geom::PrecisionModel& newPM );
Modified: trunk/src/geom/Geometry.cpp
--- trunk/src/geom/Geometry.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/src/geom/Geometry.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -116,6 +116,7 @@
factory = GeometryFactory::getDefaultInstance();
SRID=factory->getSRID();
+ factory->addChild(this);
Geometry::Geometry(const Geometry &geom)
@@ -132,6 +133,7 @@
//envelope(new Envelope(*(geom.envelope.get())));
//SRID=geom.getSRID();
//userData=NULL;
bool
@@ -808,7 +810,7 @@
Geometry::~Geometry()
- //delete envelope;
+ factory->delChild(this);
bool
Modified: trunk/src/geom/GeometryFactory.cpp
--- trunk/src/geom/GeometryFactory.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/src/geom/GeometryFactory.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -78,12 +78,13 @@
-/*public*/
+/*protected*/
GeometryFactory::GeometryFactory()
precisionModel(new PrecisionModel()),
SRID(0),
coordinateListFactory(CoordinateArraySequenceFactory::instance())
+ ,_geometryCount(0),_autoDestroy(false)
#if GEOS_DEBUG
std::cerr << "GEOS_DEBUG: GeometryFactory["<<this<<"]::GeometryFactory()" << std::endl;
@@ -91,11 +92,16 @@
#endif
-/*public*/
+/*public static*/
+GeometryFactory::create() { return GeometryFactory::unique_ptr(new GeometryFactory()); }
+/*protected*/
GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID,
CoordinateSequenceFactory* nCoordinateSequenceFactory)
SRID(newSRID)
#if GEOS_DEBUG
std::cerr << "GEOS_DEBUG: GeometryFactory["<<this<<"]::GeometryFactory(PrecisionModel["<<pm<<"], SRID)" << std::endl;
@@ -113,12 +119,23 @@
-/*public*/
+/*public static*/
+GeometryFactory::create(const PrecisionModel* pm, int newSRID,
+ CoordinateSequenceFactory* nCoordinateSequenceFactory)
+ return GeometryFactory::unique_ptr(
+ new GeometryFactory(pm, newSRID, nCoordinateSequenceFactory)
+/*protected*/
SRID(0)
#if GEOS_DEBUG
std::cerr << "GEOS_DEBUG: GeometryFactory["<<this<<"]::GeometryFactory(CoordinateSequenceFactory["<<nCoordinateSequenceFactory<<"])" << std::endl;
@@ -130,11 +147,22 @@
-/*public*/
+/*public static*/
+ new GeometryFactory(nCoordinateSequenceFactory)
+/*protected*/
GeometryFactory::GeometryFactory(const PrecisionModel *pm)
SRID(0),
#if GEOS_DEBUG
std::cerr << "GEOS_DEBUG: GeometryFactory["<<this<<"]::GeometryFactory(PrecisionModel["<<pm<<"])" << std::endl;
@@ -146,11 +174,21 @@
-/*public*/
+/*public static*/
+GeometryFactory::create(const PrecisionModel *pm)
+ new GeometryFactory(pm)
+/*protected*/
GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID)
SRID(newSRID),
#if GEOS_DEBUG
@@ -162,16 +200,36 @@
-/*public*/
+/*public static*/
+GeometryFactory::create(const PrecisionModel* pm, int newSRID)
+ new GeometryFactory(pm, newSRID)
+/*protected*/
GeometryFactory::GeometryFactory(const GeometryFactory &gf)
assert(gf.precisionModel);
precisionModel=new PrecisionModel(*(gf.precisionModel));
SRID=gf.SRID;
coordinateListFactory=gf.coordinateListFactory;
+ _autoDestroy=false;
+ _geometryCount=0;
-/*public*/
+/*public static*/
+GeometryFactory::create(const GeometryFactory &gf)
+ new GeometryFactory(gf)
+/*public virtual*/
GeometryFactory::~GeometryFactory(){
#if GEOS_DEBUG
std::cerr << "GEOS_DEBUG: GeometryFactory["<<this<<"]::~GeometryFactory()" << std::endl;
@@ -729,5 +787,30 @@
return defInstance;
+/*private*/
+void
+GeometryFactory::addChild(const Geometry *) const
+ ++_geometryCount;
+/*private*/
+void
+GeometryFactory::delChild(const Geometry *) const
+ if ( ! --_geometryCount )
+ if ( _autoDestroy ) delete this;
+void
+GeometryFactory::destroy()
+ assert(!_autoDestroy); // don't call me twice !
+ _autoDestroy = true;
+ if ( ! _geometryCount ) delete this;
} // namespace geos
Modified: trunk/src/operation/valid/ConnectedInteriorTester.cpp
--- trunk/src/operation/valid/ConnectedInteriorTester.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/src/operation/valid/ConnectedInteriorTester.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -69,7 +69,7 @@
namespace valid { // geos.operation.valid
ConnectedInteriorTester::ConnectedInteriorTester(GeometryGraph &newGeomGraph):
- geometryFactory(new GeometryFactory()),
+ geometryFactory(GeometryFactory::create()),
geomGraph(newGeomGraph),
disconnectedRingcoord()
@@ -77,7 +77,6 @@
ConnectedInteriorTester::~ConnectedInteriorTester()
- delete geometryFactory;
Coordinate&
@@ -219,7 +218,7 @@
if(de->isInResult() && de->getEdgeRing()==NULL)
MaximalEdgeRing* er = new MaximalEdgeRing(de,
- geometryFactory);
+ geometryFactory.get());
// We track MaximalEdgeRings allocations
// using the private maximalEdgeRings vector
maximalEdgeRings.push_back(er);
Modified: trunk/src/precision/GeometryPrecisionReducer.cpp
--- trunk/src/precision/GeometryPrecisionReducer.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/src/precision/GeometryPrecisionReducer.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -107,7 +107,7 @@
* geometry to targetPM, buffer in that model, then flip back
auto_ptr<Geometry> tmp;
- auto_ptr<GeometryFactory> tmpFactory;
+ GeometryFactory::unique_ptr tmpFactory;
const Geometry* geomToBuffer = &geom;
@@ -128,12 +128,12 @@
/* private */
-auto_ptr<GeometryFactory>
GeometryPrecisionReducer::createFactory( const GeometryFactory& oldGF,
const PrecisionModel& newPM )
- auto_ptr<GeometryFactory> newFactory(
- new GeometryFactory(&newPM,
+ GeometryFactory::unique_ptr newFactory(
+ GeometryFactory::create(&newPM,
oldGF.getSRID(),
const_cast<CoordinateSequenceFactory*>(oldGF.getCoordinateSequenceFactory()))
Modified: trunk/tests/bigtest/TestSweepLineSpeed.cpp
--- trunk/tests/bigtest/TestSweepLineSpeed.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/bigtest/TestSweepLineSpeed.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -53,7 +53,8 @@
int main(int /* argc */, char** /* argv[] */) {
- GeometryFactory *fact=new GeometryFactory();
+ GeometryFactory::unique_ptr factptr = GeometryFactory::create();
+ GeometryFactory* fact = factptr.get();
run(1000,fact);
run(2000,fact);
@@ -71,7 +72,5 @@
cout << "Done" << endl;
- // FIXME - mloskot: Who's gonna to eat the 'fact'? Mr. Leak!
return 0;
Modified: trunk/tests/bigtest/bug234.cpp
--- trunk/tests/bigtest/bug234.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/bigtest/bug234.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -12,7 +12,7 @@
using namespace std;
int main() {
- GeometryFactory factory;
+ GeometryFactory::unique_ptr factory = GeometryFactory::create();
vector< Geometry * > *polys1 = new vector<Geometry*>();
vector< Geometry * > *polys2 = new vector<Geometry*>();
@@ -24,8 +24,8 @@
coords1.add(Coordinate(5, 5));
coords1.add(Coordinate(5, 1));
coords1.add(Coordinate(1, 1));
- holes1->push_back( factory.createLinearRing() );
- polys1->push_back( factory.createPolygon(factory.createLinearRing(coords1), holes1) );
+ holes1->push_back( factory->createLinearRing() );
+ polys1->push_back( factory->createPolygon(factory->createLinearRing(coords1), holes1) );
CoordinateArraySequence coords2;
coords2.add(Coordinate(3, 3));
@@ -33,10 +33,10 @@
coords2.add(Coordinate(4, 4));
coords2.add(Coordinate(4, 3));
- polys2->push_back( factory.createPolygon(factory.createLinearRing(coords2), new vector<Geometry*>) );
+ polys2->push_back( factory->createPolygon(factory->createLinearRing(coords2), new vector<Geometry*>) );
- MultiPolygon *mpoly1 = factory.createMultiPolygon(polys1);
- MultiPolygon *mpoly2 = factory.createMultiPolygon(polys2);
+ MultiPolygon *mpoly1 = factory->createMultiPolygon(polys1);
+ MultiPolygon *mpoly2 = factory->createMultiPolygon(polys2);
cout << " Mpoly1: " << mpoly1->toString() << endl;
cout << " Mpoly2: " << mpoly2->toString() << endl;
Modified: trunk/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
--- trunk/tests/perf/operation/buffer/IteratedBufferStressTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/perf/operation/buffer/IteratedBufferStressTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -73,8 +73,8 @@
main()
PrecisionModel pm;
- WKTReader rdr(&gf);
+ WKTReader rdr(gf.get());
string inputWKT =
"POLYGON ((110 320, 190 220, 60 200, 180 120, 120 40, 290 150, 410 40, 410 230, 500 340, 320 310, 260 370, 220 310, 110 320), (220 260, 250 180, 290 220, 360 150, 350 250, 260 280, 220 260))";
Modified: trunk/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
--- trunk/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -41,7 +41,7 @@
RectangleIntersectsPerfTest()
pm(),
- fact(&pm, 0)
+ fact(GeometryFactory::create(&pm, 0))
void test(int nPts)
@@ -78,7 +78,7 @@
static const int NUM_LINE_PTS = 1000;
PrecisionModel pm;
- GeometryFactory fact;
+ GeometryFactory::unique_ptr fact;
void testRectangles(const Geometry& target, int nRect, double rectSize)
@@ -122,7 +122,7 @@
Envelope envRect(
baseX, baseX + dx,
baseY, baseY + dy);
- Geometry* rect = fact.toGeometry(&envRect);
+ Geometry* rect = fact->toGeometry(&envRect);
rectList.push_back(rect);
@@ -133,7 +133,7 @@
using geos::geom::util::SineStarFactory;
- SineStarFactory gsf(&fact);
+ SineStarFactory gsf(fact.get());
gsf.setCentre(origin);
gsf.setSize(size);
gsf.setNumPoints(nPts);
Modified: trunk/tests/unit/algorithm/ConvexHullTest.cpp
--- trunk/tests/unit/algorithm/ConvexHullTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/algorithm/ConvexHullTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -39,21 +39,22 @@
// Typedefs used as short names by test cases
typedef std::auto_ptr<geos::geom::Geometry> GeometryAPtr;
typedef std::auto_ptr<geos::geom::LineString> LineStringAPtr;
+ typedef geos::geom::GeometryFactory GeometryFactory;
GeometryPtr geom_;
geos::geom::PrecisionModel pm_;
- geos::geom::GeometryFactory factory_;
+ geos::geom::GeometryFactory::unique_ptr factory_;
geos::io::WKTReader reader_;
test_convexhull_data()
- : geom_(0), pm_(1), factory_(&pm_, 0), reader_(&factory_)
+ : geom_(0), pm_(1), factory_(GeometryFactory::create(&pm_, 0)), reader_(factory_.get())
assert(0 == geom_);
~test_convexhull_data()
- factory_.destroyGeometry(geom_);
+ factory_->destroyGeometry(geom_);
geom_ = 0;
Modified: trunk/tests/unit/algorithm/PointLocatorTest.cpp
--- trunk/tests/unit/algorithm/PointLocatorTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/algorithm/PointLocatorTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -42,8 +42,8 @@
// for the same reason...
static PrecisionModel pm;
- static GeometryFactory gf(&pm);
- static geos::io::WKTReader reader(&gf);
+ static GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm);
+ static geos::io::WKTReader reader(gf.get());
typedef std::auto_ptr<Geometry> GeomPtr;
Modified: trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
--- trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -244,14 +244,14 @@
test_robustlineintersection_data()
pm(),
- gf(&pm),
- reader(&gf)
+ gf(GeometryFactory::create(&pm)),
+ reader(gf.get())
PrecisionModel pm;
- GeometryFactory gf;
- geos::io::WKTReader reader;
+ GeometryFactory::unique_ptr gf;
+ geos::io::WKTReader reader;
Modified: trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp
--- trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/algorithm/RobustLineIntersectorTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -238,13 +238,13 @@
using geos::geom::GeometryFactory;
using geos::geom::LineString;
CoordinateSequence* cs = new CoordinateArraySequence();
cs->add(p1);
cs->add(p2);
- GeomPtr l ( factory.createLineString(cs) );
- GeomPtr p ( factory.createPoint(q) );
+ GeomPtr l ( factory->createLineString(cs) );
+ GeomPtr p ( factory->createPoint(q) );
ensure(!l->intersects(p.get()));
ensure(!CGAlgorithms::isOnLine(q, cs));
@@ -298,9 +298,10 @@
template<>
void object::test<15>()
+ using geos::geom::GeometryFactory;
geos::geom::PrecisionModel pm(1e+13);
- geos::geom::GeometryFactory factory(&pm);
- geos::io::WKBReader reader(factory);
+ GeometryFactory::unique_ptr factory = GeometryFactory::create(&pm);
+ geos::io::WKBReader reader(*factory);
// POINT located between 3rd and 4th vertex of LINESTRING
// POINT(-23.1094689600055080 50.5195368635957180)
Modified: trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
--- trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -41,8 +41,8 @@
test_DiscreteHausdorffDistance_data()
pm(),
- gf(&pm),
- reader(&gf)
+ reader(gf.get())
static const double TOLERANCE;
@@ -73,8 +73,8 @@
PrecisionModel pm;
const double test_DiscreteHausdorffDistance_data::TOLERANCE = 0.00001;
Modified: trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp
--- trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -219,8 +219,8 @@
void object::test<8>()
+ geos::geom::GeometryFactory::unique_ptr factory = geos::geom::GeometryFactory::create(&pm);
Modified: trunk/tests/unit/geom/Geometry/clone.cpp
--- trunk/tests/unit/geom/Geometry/clone.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/Geometry/clone.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -21,11 +21,13 @@
struct test_geometry_clone_data
typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
- geos::geom::GeometryFactory factory;
+ GeometryFactory::unique_ptr factory;
test_geometry_clone_data()
- : reader(&factory)
+ : factory(GeometryFactory::create())
+ , reader(factory.get())
Modified: trunk/tests/unit/geom/Geometry/coversTest.cpp
--- trunk/tests/unit/geom/Geometry/coversTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/Geometry/coversTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -21,11 +21,14 @@
struct test_contains_data
+ geos::geom::GeometryFactory::unique_ptr factory;
test_contains_data()
Modified: trunk/tests/unit/geom/Geometry/equalsTest.cpp
--- trunk/tests/unit/geom/Geometry/equalsTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/Geometry/equalsTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -21,11 +21,10 @@
struct test_equals_data
test_equals_data()
+ : reader()
Modified: trunk/tests/unit/geom/Geometry/isRectangleTest.cpp
--- trunk/tests/unit/geom/Geometry/isRectangleTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/Geometry/isRectangleTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -4,7 +4,6 @@
// tut
#include <tut.hpp>
// geos
-#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/Polygon.h>
#include <geos/io/WKTReader.h>
@@ -19,11 +18,9 @@
struct test_isrectangle_data
test_isrectangle_data()
Modified: trunk/tests/unit/geom/Geometry/normalize.cpp
--- trunk/tests/unit/geom/Geometry/normalize.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/Geometry/normalize.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -4,7 +4,6 @@
// tut
#include <tut.hpp>
// geos
@@ -23,12 +22,11 @@
struct test_geometry_normalize_data
geos::io::WKTWriter writer;
test_geometry_normalize_data()
- : reader(&factory), writer()
+ : reader(), writer()
writer.setTrim(true);
Modified: trunk/tests/unit/geom/GeometryFactoryTest.cpp
--- trunk/tests/unit/geom/GeometryFactoryTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/GeometryFactoryTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -54,11 +54,13 @@
const int srid_;
test_geometryfactory_data()
- : x_(5), y_(10), z_(15), srid_(666), pm_(1.0), factory_(&pm_, srid_), reader_(&factory_)
+ : x_(5), y_(10), z_(15), srid_(666), pm_(1.0),
+factory_(geos::geom::GeometryFactory::create(&pm_, srid_)),
+reader_(factory_.get())
private:
// Declare type as noncopyable
@@ -80,18 +82,19 @@
template<>
void object::test<1>()
- geos::geom::GeometryFactory gf;
+ GeometryFactory::unique_ptr gf = GeometryFactory::create();
- ensure_equals( gf.getSRID(), 0 );
- ensure_equals( gf.getPrecisionModel()->getType(), geos::geom::PrecisionModel::FLOATING );
+ ensure_equals( gf->getSRID(), 0 );
+ ensure_equals( gf->getPrecisionModel()->getType(), geos::geom::PrecisionModel::FLOATING );
- geos::geom::Geometry* geo = gf.createEmptyGeometry();
+ geos::geom::Geometry* geo = gf->createEmptyGeometry();
ensure( "createEmptyGeometry() returned null pointer.", geo != 0 );
- ensure_equals( geo->getSRID() , gf.getSRID() );
+ ensure_equals( geo->getSRID() , gf->getSRID() );
ensure_equals( geo->getPrecisionModel()->getType(), geos::geom::PrecisionModel::FLOATING );
// FREE MEMORY
- gf.destroyGeometry(geo);
+ gf->destroyGeometry(geo);
// Test of user's constructor
@@ -107,20 +110,20 @@
PrecisionModel pm(1.0);
- GeometryFactory gf(&pm, srid_, &csf);
+ GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm, srid_, &csf);
- ensure_equals( gf.getSRID(), srid_ );
- ensure_equals( gf.getPrecisionModel()->getType(), geos::geom::PrecisionModel::FIXED );
+ ensure_equals( gf->getSRID(), srid_ );
+ ensure_equals( gf->getPrecisionModel()->getType(), geos::geom::PrecisionModel::FIXED );
- ensure_equals( &csf, gf.getCoordinateSequenceFactory() );
+ ensure_equals( &csf, gf->getCoordinateSequenceFactory() );
- GeometryPtr geo = gf.createEmptyGeometry();
+ GeometryPtr geo = gf->createEmptyGeometry();
ensure_equals( geo->getPrecisionModel()->getType(), geos::geom::PrecisionModel::FIXED );
// FREE MEMORY
// csf lifetime must exceed lifetime of the GeometryFactory instance
@@ -137,18 +140,18 @@
CoordinateArraySequenceFactory csf;
- GeometryFactory gf(&csf);
+ GeometryFactory::unique_ptr gf = GeometryFactory::create(&csf);
// FREE MEMORY
@@ -159,20 +162,21 @@
void object::test<4>()
using geos::geom::PrecisionModel;
PrecisionModel pm(PrecisionModel::FIXED);
- geos::geom::GeometryFactory gf(&pm);
+ GeometryFactory::unique_ptr gf(GeometryFactory::create(&pm));
- ensure_equals( gf.getPrecisionModel()->getType(), PrecisionModel::FIXED );
+ ensure_equals( gf->getPrecisionModel()->getType(), PrecisionModel::FIXED );
ensure_equals( geo->getPrecisionModel()->getType(), PrecisionModel::FIXED );
// FREE MEMORY
@@ -181,20 +185,21 @@
void object::test<5>()
- geos::geom::GeometryFactory gf(&pm, srid_);
+ GeometryFactory::unique_ptr gf(GeometryFactory::create(&pm, srid_));
// FREE MEMORY
// Test of copy constructor
@@ -202,10 +207,11 @@
template<>
void object::test<6>()
- geos::geom::GeometryFactory gf(factory_);
+ GeometryFactory::unique_ptr gf(GeometryFactory::create(*factory_));
- ensure_equals( factory_.getSRID(), gf.getSRID() );
- ensure_equals( factory_.getPrecisionModel()->getType(), gf.getPrecisionModel()->getType() );
+ ensure_equals( factory_->getSRID(), gf->getSRID() );
+ ensure_equals( factory_->getPrecisionModel()->getType(), gf->getPrecisionModel()->getType() );
// Test of createEmptyGeometry() const
@@ -213,7 +219,7 @@
template<>
void object::test<7>()
- GeometryPtr geo = factory_.createEmptyGeometry();
+ GeometryPtr geo = factory_->createEmptyGeometry();
ensure( "createEmptyGeometry() returned non-empty geometry.", geo->isEmpty() );
@@ -229,7 +235,7 @@
// FREE MEMORY
- factory_.destroyGeometry(geo);
+ factory_->destroyGeometry(geo);
// Test of createPoint() const
@@ -237,7 +243,7 @@
template<>
- PointPtr pt = factory_.createPoint();
+ PointPtr pt = factory_->createPoint();
ensure( "createPoint() returned null pointer.", pt != 0 );
ensure( "createPoint() returned non-empty point.", pt->isEmpty() );
@@ -250,17 +256,17 @@
geo = pt->getEnvelope();
ensure( geo != 0 );
ensure( geo->isEmpty() );
geo = pt->getBoundary();
ensure( geo != 0 );
geo = pt->convexHull();
ensure( geo != 0 );
ensure_equals( pt->getGeometryTypeId(), geos::geom::GEOS_POINT );
ensure_equals( pt->getDimension(), geos::geom::Dimension::P );
@@ -270,7 +276,7 @@
ensure_equals( pt->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(pt);
+ factory_->destroyGeometry(pt);
// Test of createPoint(const Coordinate &coordinate) const
@@ -280,7 +286,7 @@
geos::geom::Coordinate coord(x_, y_, z_);
- PointPtr pt = factory_.createPoint(coord);
+ PointPtr pt = factory_->createPoint(coord);
ensure( "createPoint() returned empty point.", !pt->isEmpty() );
@@ -298,22 +304,22 @@
ensure( geo != 0 );
ensure( !geo->isEmpty() );
geo = pt->getCentroid();
ensure( geo != 0 );
ensure( geo != 0 );
ensure( geo != 0 );
@@ -323,7 +329,7 @@
// FREE MEMORY
// Test of createPoint(CoordinateSequence *coordinates) const
@@ -338,7 +344,7 @@
ensure( "sequence is null pointer.", sequence != 0 );
sequence->add(coord);
- PointPtr pt = factory_.createPoint(sequence);
+ PointPtr pt = factory_->createPoint(sequence);
@@ -356,22 +362,22 @@
ensure( geo != 0 );
ensure( geo != 0 );
ensure( geo != 0 );
ensure( geo != 0 );
@@ -381,7 +387,7 @@
// FREE MEMORY
// Test of createPoint(const CoordinateSequence &coordinates) const
@@ -394,7 +400,7 @@
geos::geom::CoordinateArraySequence sequence;
sequence.add(coord);
@@ -412,22 +418,22 @@
ensure( geo != 0 );
ensure( geo != 0 );
ensure( geo != 0 );
ensure( geo != 0 );
@@ -437,7 +443,7 @@
// FREE MEMORY
// Test of createLinearRing() const
@@ -445,7 +451,7 @@
template<>
void object::test<12>()
- LinearRingPtr lr = factory_.createLinearRing();
+ LinearRingPtr lr = factory_->createLinearRing();
ensure( "createLinearRing() returned null pointer.", lr != 0 );
ensure( "createLinearRing() returned non-empty point.", lr->isEmpty() );
@@ -470,7 +476,7 @@
ensure_equals( lr->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(lr);
+ factory_->destroyGeometry(lr);
// Test of createLinearRing(CoordinateSequence* newCoords) const
@@ -483,7 +489,7 @@
ensure( coords != 0 );
ensure_equals( coords->getSize(), size );
- LinearRingPtr lr = factory_.createLinearRing(coords);
+ LinearRingPtr lr = factory_->createLinearRing(coords);
ensure( "createLinearRing() returned empty point.", !lr->isEmpty() );
ensure( lr->isSimple() );
@@ -500,7 +506,7 @@
// FREE MEMORY
// Test of createLinearRing(const CoordinateSequence& coordinates) const
@@ -512,7 +518,7 @@
geos::geom::CoordinateArraySequence coords(size);
ensure_equals( coords.getSize(), size );
ensure_equals( lr->getNumPoints(), size );
@@ -526,7 +532,7 @@
// FREE MEMORY
// Test of createLineString() const
@@ -534,7 +540,7 @@
template<>
- LineStringPtr line = factory_.createLineString();
+ LineStringPtr line = factory_->createLineString();
ensure( "createLineString() returned null pointer.", line != 0 );
ensure( "createLineString() returned non-empty point.", line->isEmpty() );
@@ -550,17 +556,17 @@
geo = line->getEnvelope();
ensure( geo != 0 );
geo = line->getBoundary();
ensure( geo != 0 );
geo = line->convexHull();
ensure( geo != 0 );
ensure_equals( line->getGeometryTypeId(), geos::geom::GEOS_LINESTRING );
ensure_equals( line->getDimension(), geos::geom::Dimension::L );
@@ -570,7 +576,7 @@
ensure_equals( line->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(line);
+ factory_->destroyGeometry(line);
// Test of createLineString(CoordinateSequence* coordinates) const
@@ -583,7 +589,7 @@
- LineStringPtr line = factory_.createLineString(coords);
+ LineStringPtr line = factory_->createLineString(coords);
ensure( "createLineString() returned empty point.", !line->isEmpty() );
ensure( line->isSimple() );
@@ -600,7 +606,7 @@
// FREE MEMORY
// Test of createLineString(const CoordinateSequence& coordinates) const
@@ -612,7 +618,7 @@
ensure_equals( line->getNumPoints(), size );
@@ -626,14 +632,14 @@
// FREE MEMORY
// Test of createPolygon() const
template<>
template<>
void object::test<18>()
- PolygonPtr poly = factory_.createPolygon();
+ PolygonPtr poly = factory_->createPolygon();
ensure( "createPolygon() returned null pointer.", poly != 0 );
ensure( "createPolygon() returned non-empty point.", poly->isEmpty() );
@@ -651,17 +657,17 @@
//geo = poly->getEnvelope();
//ensure( geo != 0 );
//ensure( geo->isEmpty() );
- //factory_.destroyGeometry(geo);
+ //factory_->destroyGeometry(geo);
geo = poly->getBoundary();
ensure( geo != 0 );
geo = poly->convexHull();
ensure( geo != 0 );
ensure_equals( poly->getGeometryTypeId(), geos::geom::GEOS_POLYGON );
ensure_equals( poly->getDimension(), geos::geom::Dimension::A );
@@ -671,7 +677,7 @@
ensure_equals( poly->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(poly);
+ factory_->destroyGeometry(poly);
// Test of createPolygon(LinearRing* shell, std::vector<Geometry*>* holes) const
@@ -695,7 +701,7 @@
// Create exterior ring
- LinearRingPtr exterior = factory_.createLinearRing(coords);
+ LinearRingPtr exterior = factory_->createLinearRing(coords);
ensure( "createLinearRing returned null pointer.", exterior != 0 );
ensure( "createLinearRing() returned empty point.", !exterior->isEmpty() );
ensure( exterior->isSimple() );
@@ -707,7 +713,7 @@
ensure( exterior->getLength() != 0.0 );
// Create polygon
- PolygonPtr poly = factory_.createPolygon(exterior, 0);
+ PolygonPtr poly = factory_->createPolygon(exterior, 0);
ensure( "createPolygon returned null pointer.", poly != 0 );
ensure( "createPolygon() returned empty point.", !poly->isEmpty() );
ensure( poly->isSimple() );
@@ -719,7 +725,7 @@
ensure( poly->getLength() != 0.0 );
// FREE MEMORY
// Test of createPolygon(const LinearRing& shell, const std::vector<Geometry*>& holes) const
@@ -744,7 +750,7 @@
ensure_equals( coords->getSize(), exteriorSize );
@@ -769,7 +775,7 @@
holes.push_back(hole);
// Create polygon using copy ctor
- PolygonPtr poly = factory_.createPolygon((*exterior), holes);
+ PolygonPtr poly = factory_->createPolygon((*exterior), holes);
@@ -791,8 +797,8 @@
holes.clear();
- factory_.destroyGeometry(exterior);
+ factory_->destroyGeometry(exterior);
// Test of createGeometryCollection() const
@@ -800,7 +806,7 @@
template<>
void object::test<21>()
- GeometryColPtr col = factory_.createGeometryCollection();
+ GeometryColPtr col = factory_->createGeometryCollection();
ensure( "createGeometryCollection() returned null pointer.", col != 0 );
ensure( col->isEmpty() );
@@ -826,7 +832,7 @@
ensure_equals( col->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(col);
+ factory_->destroyGeometry(col);
// Test of createGeometryCollection(std::vector<Geometry*>* newGeoms) const
@@ -841,7 +847,7 @@
// Add single point
- GeometryPtr point = factory_.createPoint(coord);
+ GeometryPtr point = factory_->createPoint(coord);
ensure( point != 0 );
vec->push_back(point);
@@ -852,17 +858,17 @@
coords->setAt(Coordinate(5, 5), 1);
coords->setAt(Coordinate(10, 5), 2);
ensure_equals( coords->getSize(), 3u );
- GeometryPtr line = factory_.createLineString(coords);
+ GeometryPtr line = factory_->createLineString(coords);
vec->push_back(line);
// Create geometry collection
- GeometryColPtr col = factory_.createGeometryCollection(vec);
+ GeometryColPtr col = factory_->createGeometryCollection(vec);
ensure_equals( col->getGeometryTypeId(), geos::geom::GEOS_GEOMETRYCOLLECTION );
ensure_equals( col->getNumGeometries(), 2u );
// FREE MEMORY
// Test of createGeometryCollection(const std::vector<Geometry*>& newGeoms) const
@@ -876,29 +882,29 @@
std::vector<GeometryPtr> vec;
GeometryPtr geo = 0;
- geo = factory_.createPoint(coord);
+ geo = factory_->createPoint(coord);
vec.push_back(geo);
coord.x *= 2;
coord.y *= 2;
coord.z *= 2;
vec.push_back(geo);
coord.x *= 3;
coord.y *= 3;
coord.z *= 3;
vec.push_back(geo);
// Factory creates copy of the vec collection
ensure( col != 0 );
ensure_equals( col->getGeometryTypeId() , geos::geom::GEOS_GEOMETRYCOLLECTION );
ensure_equals( col->getNumGeometries() , size );
// FREE MEMORY
std::vector<GeometryPtr>::const_iterator it;
for (it = vec.begin(); it != vec.end(); ++it)
@@ -911,7 +917,7 @@
template<>
void object::test<24>()
- MultiPointPtr mp = factory_.createMultiPoint();
+ MultiPointPtr mp = factory_->createMultiPoint();
ensure( "createMultiPoint() returned null pointer.", mp != 0 );
ensure( "createMultiPoint() returned non-empty point.", mp->isEmpty() );
@@ -926,17 +932,17 @@
geo = mp->getBoundary();
ensure( geo != 0 );
geo = mp->convexHull();
ensure( geo != 0 );
ensure_equals( mp->getGeometryTypeId(), geos::geom::GEOS_MULTIPOINT );
ensure_equals( mp->getDimension(), geos::geom::Dimension::P );
@@ -946,7 +952,7 @@
ensure_equals( mp->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(mp);
+ factory_->destroyGeometry(mp);
// Test of createMultiPoint(std::vector<Geometry*>* newPoints) const
@@ -960,26 +966,26 @@
std::vector<GeometryPtr>* vec = new std::vector<GeometryPtr>();
ensure( geo != 0 );
vec->push_back(geo);
coord.x *= 2;
coord.y *= 2;
coord.z *= 2;
ensure( geo != 0 );
coord.x *= 3;
coord.y *= 3;
coord.z *= 3;
ensure( geo != 0 );
- MultiPointPtr mp = factory_.createMultiPoint(vec);
+ MultiPointPtr mp = factory_->createMultiPoint(vec);
ensure( mp != 0 );
ensure( mp->isValid() );
ensure( mp->isSimple() );
@@ -987,7 +993,7 @@
// FREE MEMORY
// Test of createMultiPoint(const std::vector<Geometry*>& fromPoints) const
@@ -1001,23 +1007,23 @@
vec.push_back(geo);
coord.x *= 2;
coord.y *= 2;
coord.z *= 2;
vec.push_back(geo);
coord.x *= 3;
coord.y *= 3;
coord.z *= 3;
vec.push_back(geo);
ensure( mp != 0 );
@@ -1025,7 +1031,7 @@
// FREE MEMORY
@@ -1048,7 +1054,7 @@
coords.setAt(Coordinate(10, 5), 2);
- MultiPointPtr mp = factory_.createMultiPoint(coords);
+ MultiPointPtr mp = factory_->createMultiPoint(coords);
ensure( mp != 0 );
@@ -1056,7 +1062,7 @@
// FREE MEMORY
// Test of createMultiLineString() const
@@ -1064,7 +1070,7 @@
template<>
void object::test<28>()
- MultiLineStringPtr mls = factory_.createMultiLineString();
+ MultiLineStringPtr mls = factory_->createMultiLineString();
ensure( "createMultiLineString() returned null pointer.", mls != 0 );
ensure( "createMultiLineString() returned non-empty point.", mls->isEmpty() );
@@ -1079,17 +1085,17 @@
geo = mls->getBoundary();
ensure( geo != 0 );
geo = mls->convexHull();
ensure( geo != 0 );
ensure_equals( mls->getGeometryTypeId(), geos::geom::GEOS_MULTILINESTRING );
ensure_equals( mls->getDimension(), geos::geom::Dimension::L );
@@ -1099,7 +1105,7 @@
ensure_equals( mls->getArea(), 0.0 );
// FREE MEMORY
- factory_.destroyGeometry(mls);
+ factory_->destroyGeometry(mls);
// Test of createMultiLineString(std::vector<Geometry*>* newLines) const
@@ -1123,7 +1129,7 @@
coords->setAt(Coordinate(5 + factor, 5 + factor), 1);
ensure_equals( coords->getSize(), lineSize );
ensure_equals( line->getNumPoints(), lineSize );
@@ -1133,7 +1139,7 @@
lines->push_back(line);
- MultiLineStringPtr mls = factory_.createMultiLineString(lines);
+ MultiLineStringPtr mls = factory_->createMultiLineString(lines);
ensure( mls != 0 );
// TODO - mloskot - why isValid() returns false?
//ensure( mls->isValid() );
@@ -1141,7 +1147,7 @@
// FREE MEMORY
// Test of createMultiLineString(const std::vector<Geometry*>& fromLines) const
@@ -1165,7 +1171,7 @@
@@ -1175,7 +1181,7 @@
lines.push_back(line);
ensure( mls != 0 );
@@ -1183,7 +1189,7 @@
// FREE MEMORY
for (it = lines.begin(); it != lines.end(); ++it)
@@ -1251,23 +1257,23 @@
PointVect vec;
PointPtr geo = 0;
vec.push_back(geo);
coord.x *= 2;
coord.y *= 2;
coord.z *= 2;
vec.push_back(geo);
coord.x *= 3;
coord.y *= 3;
coord.z *= 3;
vec.push_back(geo);
- GeometryAutoPtr g = factory_.buildGeometry(vec.begin(), vec.end());
+ GeometryAutoPtr g = factory_->buildGeometry(vec.begin(), vec.end());
ensure( g.get() != 0 );
ensure_equals( g->getGeometryTypeId(), geos::geom::GEOS_MULTIPOINT );
ensure_equals( g->getNumGeometries(), size );
Modified: trunk/tests/unit/geom/LineStringTest.cpp
--- trunk/tests/unit/geom/LineStringTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/LineStringTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -33,21 +33,23 @@
typedef std::auto_ptr<geos::geom::LineString> LineStringAutoPtr;
LineStringPtr empty_line_;
test_linestring_data()
- : pm_(1000), factory_(&pm_, 0), reader_(&factory_),
- empty_line_(factory_.createLineString(new geos::geom::CoordinateArraySequence()))
+ : pm_(1000)
+ , factory_(geos::geom::GeometryFactory::create(&pm_, 0))
+ , reader_(factory_.get())
+ , empty_line_(factory_->createLineString(new geos::geom::CoordinateArraySequence()))
assert(0 != empty_line_);
~test_linestring_data()
- factory_.destroyGeometry(empty_line_);
+ factory_->destroyGeometry(empty_line_);
empty_line_ = 0;
@@ -73,7 +75,7 @@
ensure( "sequence is null pointer.", pseq != 0 );
// Create empty linstring instance
- LineStringAutoPtr ls(factory_.createLineString(pseq));
+ LineStringAutoPtr ls(factory_->createLineString(pseq));
ensure( ls->isEmpty() );
ensure( ls->isSimple() );
@@ -100,7 +102,7 @@
ensure_equals( pseq->size(), size3 );
// Create non-empty linstring instance
ensure( !ls->isEmpty() );
@@ -113,17 +115,17 @@
geo = ls->getEnvelope();
ensure( geo != 0 );
geo = ls->getBoundary();
ensure( geo != 0 );
geo = ls->convexHull();
ensure( geo != 0 );
ensure_equals( ls->getGeometryTypeId(), geos::geom::GEOS_LINESTRING );
ensure_equals( ls->getDimension(), geos::geom::Dimension::L );
@@ -149,7 +151,7 @@
ensure_equals( pseq->size(), 1u );
// Create incomplete linstring
fail("IllegalArgumentException expected.");
catch (geos::util::IllegalArgumentException const& e)
@@ -183,7 +185,7 @@
ensure_equals( pseq->size(), size );
// Create examplar of linstring instance
- LineStringAutoPtr examplar(factory_.createLineString(pseq));
+ LineStringAutoPtr examplar(factory_->createLineString(pseq));
// Create copy
LineStringAutoPtr copy(dynamic_cast<geos::geom::LineString*>(examplar->clone()));
@@ -201,17 +203,17 @@
geo = copy->getEnvelope();
ensure( geo != 0 );
geo = copy->getBoundary();
ensure( geo != 0 );
geo = copy->convexHull();
ensure( geo != 0 );
ensure_equals( copy->getGeometryTypeId(), geos::geom::GEOS_LINESTRING );
ensure_equals( copy->getDimension(), geos::geom::Dimension::L );
@@ -239,7 +241,7 @@
geo = empty_line_->getEnvelope();
ensure( geo != 0 );
// Test of getBoundary() for empty linestring
@@ -251,7 +253,7 @@
geo = empty_line_->getBoundary();
ensure( geo != 0 );
// Test of convexHull() for empty linestring
@@ -263,7 +265,7 @@
geo = empty_line_->convexHull();
ensure( geo != 0 );
// Test of getGeometryTypeId() for empty linestring
@@ -331,7 +333,7 @@
ensure( line->getCoordinateDimension() == 2 );
// FREE TESTED LINESTRING
// Test of getEnvelope() for non-empty linestring
@@ -350,10 +352,10 @@
ensure( !envelope->isEmpty() );
ensure_equals( envelope->getDimension(), geos::geom::Dimension::A );
- factory_.destroyGeometry(envelope);
+ factory_->destroyGeometry(envelope);
// Test of getBoundary() for non-empty linestring
@@ -372,10 +374,10 @@
ensure( !boundary->isEmpty() );
ensure_equals( boundary->getGeometryTypeId(), geos::geom::GEOS_MULTIPOINT );
ensure_equals( boundary->getDimension(), geos::geom::Dimension::P );
- factory_.destroyGeometry(boundary);
+ factory_->destroyGeometry(boundary);
// Test of convexHull() for non-empty linestring
@@ -394,10 +396,10 @@
ensure( !hull->isEmpty() );
ensure_equals( hull->getGeometryTypeId(), geos::geom::GEOS_POLYGON );
ensure_equals( hull->getDimension(), geos::geom::Dimension::A );
- factory_.destroyGeometry(hull);
+ factory_->destroyGeometry(hull);
// Test of getGeometryTypeId() for non-empty linestring
@@ -411,7 +413,7 @@
ensure_equals( geo->getGeometryTypeId(), geos::geom::GEOS_LINESTRING );
// Test of getDimension() for non-empty linestring
@@ -425,7 +427,7 @@
ensure_equals( geo->getDimension(), geos::geom::Dimension::L );
// Test of getBoundaryDimension() for non-empty linestring
@@ -439,7 +441,7 @@
ensure_equals( geo->getBoundaryDimension(), geos::geom::Dimension::P );
// Test of getNumPoints() for non-empty linestring
@@ -454,7 +456,7 @@
ensure_equals( geo->getNumPoints(), size );
// Test of getLength() for non-empty linestring
@@ -473,7 +475,7 @@
ensure( diff <= tolerance );
// Test of getArea() for non-empty linestring
@@ -487,7 +489,7 @@
ensure_equals( geo->getArea(), 0.0 );
// Test of getGeometryType() for non-empty Polygon
@@ -502,7 +504,7 @@
ensure_equals( geo->getGeometryType(), type );
// FREE MEMORY
} // namespace tut
Modified: trunk/tests/unit/geom/LinearRingTest.cpp
--- trunk/tests/unit/geom/LinearRingTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/LinearRingTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -40,7 +40,7 @@
typedef geos::geom::LinearRing const* LinearRingCPtr;
geos::geom::LinearRing empty_ring_;
@@ -48,8 +48,9 @@
const size_t ring_size_;
test_linearring_data()
- empty_ring_(new geos::geom::CoordinateArraySequence(), &factory_),
+ : pm_(1000), factory_(geos::geom::GeometryFactory::create(&pm_, 0))
+ , empty_ring_(new geos::geom::CoordinateArraySequence(), factory_.get()),
ring_size_(7)
// Create non-empty LinearRing
@@ -60,7 +61,7 @@
~test_linearring_data()
- factory_.destroyGeometry(ring_);
+ factory_->destroyGeometry(ring_);
private:
@@ -103,7 +104,7 @@
try
// Create non-empty linearring instance
- geos::geom::LinearRing ring(coords, &factory_);
+ geos::geom::LinearRing ring(coords, factory_.get());
ensure( !ring.isEmpty() );
ensure( ring.isClosed() );
ensure( ring.isRing() );
@@ -176,7 +177,7 @@
GeometryPtr envelope = empty_ring_.getEnvelope();
ensure( envelope != 0 );
ensure( envelope->isEmpty() );
// Test of getBoundary() for empty LinearRing
@@ -187,7 +188,7 @@
GeometryPtr boundary = empty_ring_.getBoundary();
ensure( boundary != 0 );
ensure( boundary->isEmpty() );
// Test of convexHull() for empty LinearRing
@@ -198,7 +199,7 @@
GeometryPtr hull = empty_ring_.convexHull();
ensure( hull != 0 );
ensure( hull->isEmpty() );
// Test of getGeometryTypeId() for empty LinearRing
@@ -281,7 +282,7 @@
// FREE MEMORY
// Test of getBoundary() for non-empty LinearRing
@@ -298,7 +299,7 @@
ensure( "[OGC] The boundary of a closed Curve must be empty.", boundary->isEmpty() );
// FREE MEMORY
// Test of convexHull() for non-empty LinearRing
@@ -315,7 +316,7 @@
// FREE MEMORY
// Test of getGeometryTypeId() for non-empty LinearRing
@@ -388,7 +389,7 @@
ensure(geo != 0);
// FREE TESTED LINEARRING
@@ -416,7 +417,7 @@
ensure( !ring->isValid() );
Modified: trunk/tests/unit/geom/MultiPointTest.cpp
--- trunk/tests/unit/geom/MultiPointTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/MultiPointTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -25,9 +25,10 @@
struct test_multipoint_data
typedef std::auto_ptr<geos::geom::MultiPoint> MultiPointAutoPtr;
MultiPointAutoPtr empty_mp_;
@@ -36,8 +37,9 @@
test_multipoint_data()
- pm_(1.0), factory_(&pm_, 0), reader_(&factory_),
- empty_mp_(factory_.createMultiPoint()), mp_size_(5)
+ pm_(1.0), factory_(GeometryFactory::create(&pm_, 0))
+ , empty_mp_(factory_->createMultiPoint()), mp_size_(5)
// Create non-empty MultiPoint
@@ -47,7 +49,7 @@
~test_multipoint_data()
- factory_.destroyGeometry(mp_);
+ factory_->destroyGeometry(mp_);
private:
@@ -71,7 +73,7 @@
const size_t size0 = 0;
- MultiPointAutoPtr mp(factory_.createMultiPoint());
+ MultiPointAutoPtr mp(factory_->createMultiPoint());
ensure( mp->isEmpty() );
@@ -115,7 +117,7 @@
ensure_equals( mp->getNumGeometries(), size0 );
// FREE MEMORY
// Test of isEmpty() for empty MultiPoint
@@ -150,7 +152,7 @@
GeometryPtr envelope = empty_mp_->getEnvelope();
// Test of getBoundary() for empty MultiPoint
@@ -161,7 +163,7 @@
GeometryPtr boundary = empty_mp_->getBoundary();
// Test of convexHull() for empty MultiPoint
@@ -172,7 +174,7 @@
GeometryPtr hull = empty_mp_->convexHull();
// Test of getGeometryTypeId() for empty MultiPoint
@@ -254,7 +256,7 @@
// FREE MEMORY
@@ -271,7 +273,7 @@
ensure( "[OGC] The boundary of a MultiPoint is the empty set.", boundary->isEmpty() );
// FREE MEMORY
@@ -288,7 +290,7 @@
ensure_equals( hull->getDimension(), geos::geom::Dimension::L );
// FREE MEMORY
@@ -367,7 +369,7 @@
ensure(geo != 0);
fail("ParseException expected.");
Modified: trunk/tests/unit/geom/PointTest.cpp
--- trunk/tests/unit/geom/PointTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/PointTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -36,15 +36,17 @@
typedef geos::geom::Point* PointPtr;
typedef std::auto_ptr<geos::geom::Point> PointAutoPtr;
typedef geos::geom::Point const* PointCPtr;
+ GeometryFactory::unique_ptr factory_;
PointAutoPtr empty_point_;
PointPtr point_;
test_point_data()
- : pm_(1000), factory_(&pm_, 0), reader_(&factory_), empty_point_(factory_.createPoint())
+ : pm_(1000), factory_(GeometryFactory::create(&pm_, 0))
+ , reader_(factory_.get()), empty_point_(factory_->createPoint())
// Create non-empty Point
@@ -54,7 +56,7 @@
~test_point_data()
- factory_.destroyGeometry(point_);
+ factory_->destroyGeometry(point_);
@@ -72,7 +74,7 @@
template<>
- PointAutoPtr point(factory_.createPoint());
+ PointAutoPtr point(factory_->createPoint());
ensure( point->isEmpty() );
@@ -88,7 +90,7 @@
coords->add(Coordinate(1.234, 5.678));
- PointAutoPtr point(factory_.createPoint(coords));
+ PointAutoPtr point(factory_->createPoint(coords));
ensure( !point->isEmpty() );
// currently the empty CoordinateArraySequence constructor
@@ -113,7 +115,7 @@
coords->add(Coordinate(4.321, 8.765));
@@ -168,7 +170,7 @@
GeometryPtr envelope = empty_point_->getEnvelope();
// Test of getBoundary() for empty Point
@@ -179,7 +181,7 @@
GeometryPtr boundary = empty_point_->getBoundary();
// Test of convexHull() for empty Point
@@ -190,7 +192,7 @@
GeometryPtr hull = empty_point_->convexHull();
// Test of getGeometryTypeId() for empty Point
@@ -282,7 +284,7 @@
GeometryPtr envelope = point_->getEnvelope();
// Test of getBoundary() for non-empty Point
@@ -293,7 +295,7 @@
GeometryPtr boundary = point_->getBoundary();
// Test of convexHull() for non-empty Point
@@ -304,7 +306,7 @@
GeometryPtr hull = point_->convexHull();
// Test of getGeometryTypeId() for non-empty Point
@@ -386,8 +388,8 @@
ensure( p1->equals(p2) );
// FREE MEMORY
- factory_.destroyGeometry(p1);
- factory_.destroyGeometry(p2);
+ factory_->destroyGeometry(p1);
+ factory_->destroyGeometry(p2);
// Test of equals() for non-empty Point (1.23 5.67)
@@ -402,8 +404,8 @@
// FREE MEMORY
// Test of equals() for non-empty Points (1.235 5.678) and (1.234 5.678)
@@ -418,8 +420,8 @@
ensure( !p1->equals(p2) );
// FREE MEMORY
// Test of equals() for non-empty Points (1.2334 5.678) and (1.2333 5.678)
@@ -434,8 +436,8 @@
// FREE MEMORY
// Test of equals() for non-empty Points (1.2334 5.678) and (1.2335 5.678)
@@ -450,8 +452,8 @@
// FREE MEMORY
// Test of equals() for non-empty Points (1.2324 5.678) and (1.2325 5.678)
@@ -466,8 +468,8 @@
// FREE MEMORY
// Test of equals() for non-empty Points (1.2324 5.678) and (EMPTY)
@@ -482,8 +484,8 @@
// FREE MEMORY
// Test of equals() for non-empty Points with negative coordiantes
@@ -506,11 +508,11 @@
ensure( p3->equals(pHi) );
// FREE MEMORY
- factory_.destroyGeometry(pLo);
- factory_.destroyGeometry(pHi);
- factory_.destroyGeometry(p3);
+ factory_->destroyGeometry(pLo);
+ factory_->destroyGeometry(pHi);
+ factory_->destroyGeometry(p3);
// Test of getCoordinateDimension() for 2d/3d.
Modified: trunk/tests/unit/geom/PolygonTest.cpp
--- trunk/tests/unit/geom/PolygonTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/PolygonTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -33,9 +33,10 @@
typedef std::auto_ptr<geos::geom::Geometry> GeometryAutoPtr;
typedef std::auto_ptr<geos::geom::Polygon> PolygonAutoPtr;
PolygonAutoPtr empty_poly_;
@@ -43,8 +44,10 @@
const size_t poly_size_;
test_polygon_data()
- : pm_(1), factory_(&pm_, 0), reader_(&factory_),
- empty_poly_(factory_.createPolygon()), poly_size_(7)
+ : pm_(1)
+ , factory_(GeometryFactory::create(&pm_, 0))
+ , empty_poly_(factory_->createPolygon()), poly_size_(7)
@@ -55,7 +58,7 @@
~test_polygon_data()
// FREE MEMORY
- factory_.destroyGeometry(poly_);
+ factory_->destroyGeometry(poly_);
private:
@@ -98,7 +101,7 @@
try
// Create non-empty LinearRing instance
@@ -110,7 +113,7 @@
// Create non-empty Polygon
//geos::geom::Polygon poly(exterior, 0, &factory_);
- PolygonAutoPtr poly(factory_.createPolygon(exterior, 0));
+ PolygonAutoPtr poly(factory_->createPolygon(exterior, 0));
ensure( !poly->isEmpty() );
@@ -186,7 +189,7 @@
GeometryPtr boundary = empty_poly_->getBoundary();
// Test of convexHull() for empty Polygon
@@ -197,7 +200,7 @@
GeometryPtr hull = empty_poly_->convexHull();
// Test of getGeometryTypeId() for empty Polygon
@@ -270,7 +273,7 @@
// FREE MEMORY
// Test of getBoundary() for non-empty Polygon
@@ -287,7 +290,7 @@
ensure( "[OGC] The boundary of Polygin is the set of closed Curves.", !boundary->isEmpty() );
// FREE MEMORY
// Test of convexHull() for non-empty Polygon
@@ -304,7 +307,7 @@
// FREE MEMORY
// Test of getGeometryTypeId() for non-empty Polygon
@@ -394,7 +397,7 @@
ensure( geo != 0 );
ensure( geo->equals(poly_) );
// Test of getExteriorRing() for non-empty Polygon
@@ -441,7 +444,7 @@
ensure_equals( interior->getGeometryTypeId(), geos::geom::GEOS_LINEARRING );
// Test of getCoordiante() for non-empty Polygon
@@ -524,7 +527,7 @@
ensure_equals( point->getGeometryTypeId(), geos::geom::GEOS_POINT );
// FREE MEMORY
- factory_.destroyGeometry(point);
+ factory_->destroyGeometry(point);
// Test of Geometry::getCentroid(Coordinate& ret) const for non-empty Polygon
@@ -552,7 +555,7 @@
ensure( pointCoord != 0 );
geos::geom::Coordinate pointCentr(*pointCoord);
// FREE MEMORY
// Second centroid
geos::geom::Coordinate coordCentr;
Modified: trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
--- trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -27,14 +27,17 @@
// Common data used by tests
struct test_preparedgeometryfactory_data
GeometryPtr g_;
PreparedGeometryPtr pg_;
test_preparedgeometryfactory_data()
- : g_(0), pg_(0), pm_(1.0), factory_(&pm_), reader_(&factory_)
+ : g_(0), pg_(0), pm_(1.0)
+ , factory_(GeometryFactory::create(&pm_))
assert(0 == g_);
assert(0 == pg_);
@@ -44,7 +47,7 @@
// FREE MEMORY per test case
prep::PreparedGeometryFactory::destroy(pg_);
- factory_.destroyGeometry(g_);
+ factory_->destroyGeometry(g_);
pg_ = 0;
g_ = 0;
@@ -115,7 +118,7 @@
template<>
- g_ = factory_.createEmptyGeometry();
+ g_ = factory_->createEmptyGeometry();
ensure( 0 != g_ );
pg_ = prep::PreparedGeometryFactory::prepare(g_);
@@ -129,7 +132,7 @@
template<>
ensure( 0 != g_ );
prep::PreparedGeometryFactory pgf;
@@ -144,7 +147,7 @@
template<>
- g_ = factory_.createPoint();
+ g_ = factory_->createPoint();
ensure( 0 != g_ );
@@ -158,7 +161,7 @@
template<>
ensure( 0 != g_ );
@@ -173,7 +176,7 @@
template<>
- g_ = factory_.createLineString();
+ g_ = factory_->createLineString();
ensure( 0 != g_ );
@@ -187,7 +190,7 @@
template<>
void object::test<9>()
ensure( 0 != g_ );
@@ -201,7 +204,7 @@
template<>
void object::test<10>()
- g_ = factory_.createPolygon();
+ g_ = factory_->createPolygon();
ensure( 0 != g_ );
@@ -215,7 +218,7 @@
template<>
void object::test<11>()
ensure( 0 != g_ );
@@ -230,7 +233,7 @@
template<>
- g_ = factory_.createMultiPoint();
+ g_ = factory_->createMultiPoint();
ensure( 0 != g_ );
@@ -244,7 +247,7 @@
template<>
void object::test<13>()
ensure( 0 != g_ );
@@ -259,7 +262,7 @@
template<>
void object::test<14>()
- g_ = factory_.createMultiLineString();
+ g_ = factory_->createMultiLineString();
ensure( 0 != g_ );
@@ -273,7 +276,7 @@
template<>
ensure( 0 != g_ );
@@ -288,7 +291,7 @@
template<>
void object::test<16>()
- g_ = factory_.createMultiPolygon();
+ g_ = factory_->createMultiPolygon();
ensure( 0 != g_ );
@@ -302,7 +305,7 @@
template<>
void object::test<17>()
ensure( 0 != g_ );
Modified: trunk/tests/unit/geom/util/GeometryExtracterTest.cpp
--- trunk/tests/unit/geom/util/GeometryExtracterTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/geom/util/GeometryExtracterTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -26,7 +26,7 @@
struct test_geometryextracter_data
geos::geom::PrecisionModel pm;
+ geos::geom::GeometryFactory::unique_ptr gf;
geos::io::WKTReader wktreader;
geos::io::WKTWriter wktwriter;
@@ -38,8 +38,8 @@
test_geometryextracter_data()
pm(1.0),
- gf(&pm),
- wktreader(&gf)
+ gf(geos::geom::GeometryFactory::create(&pm)),
+ wktreader(gf.get())
Modified: trunk/tests/unit/io/WKBReaderTest.cpp
--- trunk/tests/unit/io/WKBReaderTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/io/WKBReaderTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -31,7 +31,7 @@
struct test_wkbreader_data
geos::io::WKBReader wkbreader;
geos::io::WKBWriter xdrwkbwriter;
geos::io::WKBWriter ndrwkbwriter;
@@ -42,13 +42,13 @@
test_wkbreader_data()
pm(1.0),
- gf(&pm),
- wkbreader(gf),
+ wkbreader(*gf),
// 2D only, XDR (big endian)
xdrwkbwriter(2, geos::io::WKBConstants::wkbXDR),
// 2D only, NDR (little endian)
ndrwkbwriter(2, geos::io::WKBConstants::wkbNDR),
- wktreader(&gf)
void testInputOutput(const std::string& WKT,
Modified: trunk/tests/unit/io/WKBWriterTest.cpp
--- trunk/tests/unit/io/WKBWriterTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/io/WKBWriterTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -27,7 +27,7 @@
struct test_wkbwriter_data
@@ -36,9 +36,9 @@
test_wkbwriter_data()
pm(1000.0),
- gf(&pm),
- wktreader(&gf),
- wkbreader(gf)
+ wktreader(gf.get()),
+ wkbreader(*gf)
@@ -144,7 +144,7 @@
GeomVect *geoms = new GeomVect;
geoms->push_back( wktreader.read("POLYGON((0 0,1 0,1 1,0 1,0 0))") );
geoms->back()->setSRID(4326);
- Geom *geom = gf.createGeometryCollection(geoms);
+ Geom *geom = gf->createGeometryCollection(geoms);
std::stringstream result_stream;
wkbwriter.setOutputDimension( 2 );
Modified: trunk/tests/unit/io/WKTReaderTest.cpp
--- trunk/tests/unit/io/WKTReaderTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/io/WKTReaderTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -26,7 +26,7 @@
struct test_wktreader_data
@@ -35,8 +35,8 @@
test_wktreader_data()
pm(1.0),
- gf(&pm),
- wktreader(&gf)
wktwriter.setOutputDimension( 3 );
@@ -150,8 +150,8 @@
namespace ggm = geos::geom;
namespace gio = geos::io;
ggm::PrecisionModel pm(ggm::PrecisionModel::FLOATING);
- ggm::GeometryFactory gf(&pm);
- gio::WKTReader wktReader(&gf);
+ ggm::GeometryFactory::unique_ptr gf = ggm::GeometryFactory::create(&pm);
+ gio::WKTReader wktReader(gf.get());
const std::string str = " POINT (0 0) ";
geom.reset(wktReader.read(str)); //HERE IT FAILS
Modified: trunk/tests/unit/io/WKTWriterTest.cpp
--- trunk/tests/unit/io/WKTWriterTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/io/WKTWriterTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -30,15 +30,15 @@
typedef std::auto_ptr<geos::geom::Geometry> GeomPtr;
PrecisionModel pm;
test_wktwriter_data()
pm(1000.0),
- gf(&pm),
- wktreader(&gf)
@@ -138,8 +138,8 @@
PrecisionModel pm3(0.001);
- GeometryFactory gf3(&pm3);
- WKTReader wktreader3(&gf3);
+ GeometryFactory::unique_ptr gf3(GeometryFactory::create(&pm3));
+ WKTReader wktreader3(gf3.get());
GeomPtr geom ( wktreader3.read("POINT(123456 654321)") );
std::string result = wktwriter.write( geom.get() );
Modified: trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
--- trunk/tests/unit/linearref/LengthIndexedLineTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/linearref/LengthIndexedLineTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -36,13 +36,11 @@
struct test_lengthindexedline_data
test_lengthindexedline_data()
- : pm(), gf(&pm), reader(&gf), writer()
- PrecisionModel pm;
Modified: trunk/tests/unit/noding/OrientedCoordinateArray.cpp
--- trunk/tests/unit/noding/OrientedCoordinateArray.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/noding/OrientedCoordinateArray.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -26,15 +26,19 @@
// Common data used by all tests
struct test_orientedcoordinatearray_data
typedef std::auto_ptr<CoordinateSequence> CoordSeqPtr;
test_orientedcoordinatearray_data()
- : pm_(), factory_(&pm_), reader_(&factory_) {}
+ : pm_()
+ , reader_(factory_.get()) {}
CoordSeqPtr coords_from_wkt(const char *wkt) {
GeomPtr g ( reader_.read(wkt) );
Modified: trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
--- trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -55,10 +55,10 @@
typedef std::vector<SegmentString*> SegStrVct;
typedef std::vector<Geometry*> GeomVct;
- const geos::geom::GeometryFactory gf_;
+ const geos::geom::GeometryFactory *gf_;
test_mcidxsnprndr_data()
- : gf_()
+ : gf_(geos::geom::GeometryFactory::getDefaultInstance())
GeomPtr getGeometry(SegStrVct& vct)
@@ -67,9 +67,9 @@
for (SegStrVct::size_type i=0, n=vct.size(); i<n; ++i)
SegmentString* ss = vct[i];
- lines->push_back( gf_.createLineString(*(ss->getCoordinates())) );
+ lines->push_back( gf_->createLineString(*(ss->getCoordinates())) );
- return GeomPtr(gf_.createMultiLineString(lines));
+ return GeomPtr(gf_->createMultiLineString(lines));
void getSegmentStrings(const Geometry& g, SegStrVct& vct)
Modified: trunk/tests/unit/operation/IsSimpleOpTest.cpp
--- trunk/tests/unit/operation/IsSimpleOpTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/IsSimpleOpTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -26,13 +26,17 @@
struct test_issimpleop_data
double tolerance_;
test_issimpleop_data()
- : pm_(1), factory_(&pm_, 0), reader_(&factory_), tolerance_(0.00005)
+ : pm_(1)
+ , tolerance_(0.00005)
Modified: trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
--- trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -29,7 +29,7 @@
struct test_bufferbuilder_data
+ const geos::geom::GeometryFactory &gf;
int const default_quadrant_segments;
@@ -37,7 +37,9 @@
typedef std::auto_ptr<geos::geom::CoordinateSequence> CSPtr;
test_bufferbuilder_data()
- : gf(), wktreader(&gf), default_quadrant_segments(geos::operation::buffer::BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
+ : gf(*geos::geom::GeometryFactory::getDefaultInstance())
+ , wktreader(&gf)
+ , default_quadrant_segments(geos::operation::buffer::BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
ensure_equals(default_quadrant_segments, int(8));
Modified: trunk/tests/unit/operation/buffer/BufferOpTest.cpp
--- trunk/tests/unit/operation/buffer/BufferOpTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/buffer/BufferOpTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -27,7 +27,7 @@
struct test_bufferop_data
@@ -35,7 +35,9 @@
test_bufferop_data()
+ , wktreader(&gf)
Modified: trunk/tests/unit/operation/distance/DistanceOpTest.cpp
--- trunk/tests/unit/operation/distance/DistanceOpTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/distance/DistanceOpTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -28,14 +28,13 @@
struct test_distanceop_data
typedef geos::geom::Geometry::AutoPtr GeomPtr;
test_distanceop_data()
+ : wktreader()
@@ -462,14 +461,15 @@
template<>
void object::test<19>()
const char* wkb_geom1 = "01060000000100000001030000000100000000000000";
const char* wkb_geom2 = "010100000000000000000000000000000000000000";
geos::geom::PrecisionModel precision(geos::geom::PrecisionModel::FLOATING);
- geos::geom::GeometryFactory f(&precision);
+ GeometryFactory::unique_ptr f(GeometryFactory::create(&precision));
std::istringstream istr1(wkb_geom1);
std::istringstream istr2(wkb_geom2);
- geos::io::WKBReader wkb(f);
+ geos::io::WKBReader wkb(*f);
GeomPtr g1(wkb.readHEX(istr1));
GeomPtr g2(wkb.readHEX(istr2));
ensure(g1->isValid());
Modified: trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
--- trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -6,7 +6,6 @@
// geos
#include <geos/operation/intersection/Rectangle.h>
#include <geos/operation/intersection/RectangleIntersection.h>
#include <geos/geom/Point.h>
@@ -27,7 +26,6 @@
struct test_rectangleintersectiontest_data
@@ -37,8 +35,7 @@
typedef geos::operation::intersection::RectangleIntersection RectangleIntersection;
test_rectangleintersectiontest_data()
- : gf(),
- wktreader(&gf)
+ : wktreader()
wktwriter.setTrim(true);
Modified: trunk/tests/unit/operation/linemerge/LineMergerTest.cpp
--- trunk/tests/unit/operation/linemerge/LineMergerTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/linemerge/LineMergerTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -30,7 +30,6 @@
typedef std::vector<geos::geom::Geometry*> GeomVect;
typedef std::vector<geos::geom::LineString*> LineVect;
@@ -42,7 +41,7 @@
LineVect* mrgGeoms;
test_linemerger_data()
- : gf(), wktreader(&gf), wktwriter(), mrgGeoms(0)
+ : wktreader(), wktwriter(), mrgGeoms(0)
Modified: trunk/tests/unit/operation/linemerge/LineSequencerTest.cpp
--- trunk/tests/unit/operation/linemerge/LineSequencerTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/linemerge/LineSequencerTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -30,7 +30,6 @@
@@ -40,7 +39,7 @@
GeomVect inpGeoms;
test_linesequencer_data()
Modified: trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
--- trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -24,16 +24,13 @@
typedef geos::operation::overlay::snap::GeometrySnapper GeometrySnapper;
test_geometrysnapper_data()
- factory(), // initialize before use!
- reader(&factory)
+ reader()
Modified: trunk/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
--- trunk/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -25,7 +25,6 @@
struct test_fuzzypointlocator_data
@@ -35,9 +34,8 @@
test_fuzzypointlocator_data()
- gf(),
- wktreader(&gf),
- wkbreader(gf)
+ wktreader(),
+ wkbreader()
std::string wkt("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))");
g.reset(wktreader.read(wkt));
Modified: trunk/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
--- trunk/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -27,7 +27,7 @@
struct test_offsetpointgenerator_data
+ const geos::geom::GeometryFactory& gf;
geos::algorithm::PointLocator locator;
@@ -37,7 +37,7 @@
test_offsetpointgenerator_data()
- gf(),
+ gf(*GeometryFactory::getDefaultInstance()),
wktreader(&gf)
Modified: trunk/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
--- trunk/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -27,7 +27,6 @@
struct test_overlayresultvalidator_data
@@ -37,8 +36,7 @@
test_overlayresultvalidator_data()
- gf(),
- wktreader(&gf)
+ wktreader()
Modified: trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp
--- trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/polygonize/PolygonizeTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -29,7 +29,6 @@
struct test_polygonizetest_data
@@ -39,8 +38,7 @@
typedef geos::operation::polygonize::Polygonizer Polygonizer;
test_polygonizetest_data()
- : gf(),
- wktreader(&gf)
+ : wktreader()
Modified: trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
--- trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -28,7 +28,6 @@
typedef geos::operation::sharedpaths::SharedPathsOp SharedPathsOp;
@@ -38,7 +37,7 @@
SharedPathsOp::PathList backDir;
test_shpathop_data()
Modified: trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
--- trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -25,15 +25,15 @@
struct test_cascadedpolygonuniontest_data
test_cascadedpolygonuniontest_data()
- : gf(),
- wktreader(&gf)
+ , wktreader(&gf)
Modified: trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp
--- trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -26,7 +26,8 @@
struct test_unaryuniontest_data
@@ -35,8 +36,8 @@
typedef geos::operation::geounion::UnaryUnionOp UnaryUnionOp;
test_unaryuniontest_data()
- : gf(),
- wktreader(&gf)
+ : gf(GeometryFactory::create()),
@@ -85,7 +86,7 @@
GeomPtr result;
if ( geoms.empty() )
- result = UnaryUnionOp::Union(geoms, gf);
+ result = UnaryUnionOp::Union(geoms, *gf);
else
result = UnaryUnionOp::Union(geoms);
Modified: trunk/tests/unit/operation/valid/IsValidTest.cpp
--- trunk/tests/unit/operation/valid/IsValidTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/valid/IsValidTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -33,12 +33,13 @@
struct test_isvalidop_data
test_isvalidop_data()
+ : pm_(1), factory_(GeometryFactory::create(&pm_, 0))
@@ -59,7 +60,7 @@
cs->add(Coordinate(0.0, 0.0));
cs->add(Coordinate(1.0, DoubleNotANumber));
- GeomPtr line ( factory_.createLineString(cs) );
+ GeomPtr line ( factory_->createLineString(cs) );
IsValidOp isValidOp(line.get());
Modified: trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp
--- trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -38,13 +38,16 @@
struct test_validclosedring_data
geos::io::WKTReader rdr;
test_validclosedring_data()
- : pm_(1), factory_(&pm_, 0), rdr(&factory_)
+ : pm_(1)
+ , rdr(factory_.get())
GeomPtr fromWKT(const std::string& wkt)
Modified: trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
--- trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -40,11 +40,14 @@
test_ValidSelfTouchingRingFormingHole_data()
+ : pm_(1)
Modified: trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp
--- trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -25,11 +25,12 @@
struct test_gpr_data
typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
geos::geom::PrecisionModel pm_float_;
geos::geom::PrecisionModel pm_fixed_;
- geos::geom::GeometryFactory factory_fixed_;
+ GeometryFactory::unique_ptr factory_fixed_;
geos::precision::GeometryPrecisionReducer reducer_;
geos::precision::GeometryPrecisionReducer reducerKeepCollapse_; // keep collapse
@@ -38,12 +39,12 @@
test_gpr_data() :
pm_float_(),
pm_fixed_(1),
- factory_(&pm_float_, 0),
- factory_fixed_(&pm_fixed_, 0),
- reader_(&factory_),
+ factory_(GeometryFactory::create(&pm_float_, 0)),
+ factory_fixed_(GeometryFactory::create(&pm_fixed_, 0)),
+ reader_(factory_.get()),
reducer_(pm_fixed_),
reducerKeepCollapse_(pm_fixed_),
- reducerChangePM_(factory_fixed_)
+ reducerChangePM_(*factory_fixed_)
reducerKeepCollapse_.setRemoveCollapsedComponents(false);
@@ -171,7 +172,7 @@
GeometryPtr result(reducerChangePM_.reduce(*g1));
ensure( result->equalsExact(g2.get()) );
- ensure( result->getFactory() == &factory_fixed_ );
+ ensure( result->getFactory() == factory_fixed_.get() );
// Test points with changed PM
@@ -185,7 +186,7 @@
Modified: trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
--- trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -23,10 +23,11 @@
struct test_sgpr_data
geos::precision::SimpleGeometryPrecisionReducer reducer_;
geos::precision::SimpleGeometryPrecisionReducer reducer2_; // keep collapse
@@ -34,8 +35,8 @@
test_sgpr_data() :
pm_float_(),
pm_fixed_(1),
reducer_(&pm_fixed_),
reducer2_(&pm_fixed_)
Modified: trunk/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
--- trunk/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -27,8 +27,6 @@
struct test_dpsimp_data
- geos::geom::PrecisionModel pm;
@@ -36,9 +34,7 @@
test_dpsimp_data()
- pm(geos::geom::PrecisionModel::FLOATING),
- gf(&pm),
- wktreader(&gf)
+ wktreader()
Modified: trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
--- trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -28,14 +28,18 @@
struct test_tpsimp_data
test_tpsimp_data()
- : pm(1.0), gf(&pm), wktreader(&gf), wktwriter()
+ : pm(1.0)
+ , gf(GeometryFactory::create(&pm))
+ , wktreader(gf.get())
+ , wktwriter()
//wktwriter.setTrim(1);
Modified: trunk/tests/unit/triangulate/DelaunayTest.cpp
--- trunk/tests/unit/triangulate/DelaunayTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/triangulate/DelaunayTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -49,7 +49,7 @@
Geometry *expected = reader.read(expectedWkt);
DelaunayTriangulationBuilder builder;
builder.setTolerance(tolerance);
- GeometryFactory geomFact;
+ const GeometryFactory& geomFact(*GeometryFactory::getDefaultInstance());
builder.setSites(*sites);
if(computeTriangles)
@@ -84,7 +84,7 @@
triangulator.insertSite(Vertex(0, 0));
//extract the triangles from the subdivision
std::auto_ptr<GeometryCollection> tris = sub.getTriangles(geomFact);
Modified: trunk/tests/unit/triangulate/VoronoiTest.cpp
--- trunk/tests/unit/triangulate/VoronoiTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/triangulate/VoronoiTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -52,7 +52,7 @@
std::auto_ptr<Geometry> sites ( reader.read(sitesWkt) );
std::auto_ptr<Geometry> expected ( reader.read(expectedWkt) );
std::auto_ptr<GeometryCollection> results;
//set Tolerance:
Modified: trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
--- trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -37,15 +37,11 @@
// dummy data, not used
struct test_quadedgesub_data
test_quadedgesub_data()
- pm(),
- gf(&pm),
- reader(gf),
+ reader(),
writer()
@@ -78,8 +74,8 @@
ensure(!sub.isOnEdge(e, Coordinate(10, 10)));
ensure(!sub.isVertexOfEdge(e, Vertex(10, 10)));
- std::auto_ptr<GeometryCollection> tris = sub.getTriangles(geomFact);
+ GeometryFactory::unique_ptr geomFact(GeometryFactory::create());
+ std::auto_ptr<GeometryCollection> tris = sub.getTriangles(*geomFact);
tris.reset();
//WKTWriter wkt;
//printf("%s\n", wkt.writeFormatted(tris).c_str());
@@ -103,7 +99,7 @@
triangulator.insertSites(*vertices);
//Test for getVoronoiDiagram::
std::auto_ptr<GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
const char *expected_str = "GEOMETRYCOLLECTION (POLYGON ((-5849.974929324658 2268.0517257497568, -4529.9920486948895 2247.139449440667, 221.20588235294116 210.91176470588235, -684.4227119984187 -2848.644297291955, -5849.974929324658 2268.0517257497568)), POLYGON ((212.5 -3774.5, -684.4227119984187 -2848.644297291955, 221.20588235294116 210.91176470588235, 2448.7167655626645 2188.608343256571, 6235.0370264064295 2248.0370264064295, 212.5 -3774.5)), POLYGON ((-4529.9920486948895 2247.139449440667, 2448.7167655626645 2188.608343256571, 221.20588235294116 210.91176470588235, -4529.9920486948895 2247.139449440667)))";
// std::cout << polys->toString() << std::endl;
@@ -151,7 +147,7 @@
for (std::size_t i=0; i<polys->getNumGeometries(); ++i) {
const Polygon* p = dynamic_cast<const Polygon*>(polys->getGeometryN(i));
Modified: trunk/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp
--- trunk/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -25,13 +25,16 @@
struct test_uniquecoordinatearrayfilter_data
test_uniquecoordinatearrayfilter_data()
+ : pm_(1)
Modified: trunk/tests/xmltester/SimpleWKTTester.cpp
--- trunk/tests/xmltester/SimpleWKTTester.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/xmltester/SimpleWKTTester.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -39,7 +39,9 @@
ifstream in("WKTIn");
string instr;
string outstr;
- WKTReader *r = new WKTReader(new GeometryFactory(new PrecisionModel(),10));
+ PrecisionModel pm;
+ GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm, 10);
+ WKTReader *r = new WKTReader(gf.get());
WKTWriter *w = new WKTWriter();
Geometry *g;
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/xmltester/XMLTester.cpp 2015-10-02 09:59:33 UTC (rev 4091)
@@ -435,7 +435,7 @@
std::cerr << *curr_file <<": run: Precision Model: " << pm->toString() <<std::endl;
- factory.reset(new geom::GeometryFactory(pm.get()));
+ factory = geom::GeometryFactory::create(pm.get());
wktreader.reset(new io::WKTReader(factory.get()));
wktwriter.reset(new io::WKTWriter());
wkbreader.reset(new io::WKBReader(*factory));
Modified: trunk/tests/xmltester/XMLTester.h
--- trunk/tests/xmltester/XMLTester.h 2015-10-01 15:22:06 UTC (rev 4090)
+++ trunk/tests/xmltester/XMLTester.h 2015-10-02 09:59:33 UTC (rev 4091)
@@ -51,7 +51,7 @@
geom::Geometry *gT;
std::auto_ptr<geom::PrecisionModel> pm;
- std::auto_ptr<geom::GeometryFactory> factory;
+ geom::GeometryFactory::unique_ptr factory;
std::auto_ptr<io::WKTReader> wktreader;
std::auto_ptr<io::WKTWriter> wktwriter;
std::auto_ptr<io::WKBReader> wkbreader;
More information about the geos-commits
