[geos-commits] r4096 - trunk
svn_geos at osgeo.org
Sat Oct 3 13:58:35 PDT 2015
Author: mloskot
Date: 2015-10-03 13:58:35 -0700 (Sat, 03 Oct 2015)
New Revision: 4096
trunk/CMakeLists.txt
Clean up CMake variables mismatch
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2015-10-03 20:29:15 UTC (rev 4095)
+++ trunk/CMakeLists.txt 2015-10-03 20:58:35 UTC (rev 4096)
@@ -19,7 +19,7 @@
endif()
# Location of custom CMake modules with macros used by GEOS
-set(CMAKE_MODULE_PATH "${GEOS_SOURCE_DIR}/cmake/modules")
+set(CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
# Setup GEOS version
@@ -225,13 +225,13 @@
# for including GEOS C++ API headers
-include_directories(${GEOS_SOURCE_DIR}/include)
+include_directories(${PROJECT_SOURCE_DIR}/include)
# for including build-specific GEOS C API headers
-include_directories(${GEOS_BINARY_DIR}/capi)
+include_directories(${PROJECT_BINARY_DIR}/capi)
# for including build-specific version.h, platform.h and geos_c.h
-include_directories(${geos_BINARY_DIR}/include)
+include_directories(${PROJECT_BINARY_DIR}/include)
# Setup checks and generate config headers
@@ -254,56 +254,58 @@
ENDMACRO(GET_SVN_REVISION)
# Determine SVN/Git revision
-if(EXISTS "${CMAKE_SOURCE_DIR}/.svn")
+if(EXISTS "${PROJECT_SOURCE_DIR}/.svn")
GET_SVN_REVISION()
endif()
+message(STATUS "Generating GEOS revision header in ${PROJECT_BINARY_DIR}/geos_svn_revision.h")
if ( NOT ${Project_WC_REVISION} EQUAL 0 )
set( GEOS_SVN_REVISION ${Project_WC_REVISION} )
configure_file (
"${PROJECT_SOURCE_DIR}/tools/geos_svn_revision_cmake.h.in"
- "${PROJECT_SOURCE_DIR}/geos_svn_revision.h" )
- # "${geos_BINARY_DIR}/include/geos_svn_revision.h" )
+ "${PROJECT_BINARY_DIR}/include/geos_svn_revision.h" )
else()
- message(STATUS "Generating revision header ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
find_program(SH sh)
if(SH)
execute_process(COMMAND ${SH} -c
- "cd ${CMAKE_SOURCE_DIR} && ${CMAKE_SOURCE_DIR}/tools/svn_repo_revision.sh")
+ "cd ${PROJECT_SOURCE_DIR} && ${PROJECT_SOURCE_DIR}/tools/svn_repo_revision.sh")
- file(RENAME "${CMAKE_SOURCE_DIR}/geos_svn_revision.h"
- "${CMAKE_BINARY_DIR}/geos_svn_revision.h")
+ file(RENAME "${PROJECT_SOURCE_DIR}/geos_svn_revision.h"
+ "${PROJECT_BINARY_DIR}/geos_svn_revision.h")
else()
message("*** sh-compatible command not found, cannot create geos_svn_revision.h")
message("*** Check SVN revision and create revision header manually:")
- message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${CMAKE_SOURCE_DIR}/geos_svn_revision.h")
+ message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${PROJECT_SOURCE_DIR}/geos_svn_revision.h")
endif()
endif()
# End: Determine SVN/Git revision
-if(EXISTS ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h)
- message(STATUS "Disabling existing ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h")
+if(EXISTS ${PROJECT_SOURCE_DIR}/include/geos/platform.h)
+ message(STATUS "Disabling existing ${PROJECT_SOURCE_DIR}/include/geos/platform.h")
if(${CMAKE_MAJOR_VERSION} EQUAL 2 AND ${CMAKE_MINOR_VERSION} EQUAL 6)
- file(REMOVE ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h)
+ file(REMOVE ${PROJECT_SOURCE_DIR}/include/geos/platform.h)
set(PH_RESULT "removed")
else()
file(RENAME
- ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h
- ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h.disabled)
+ ${PROJECT_SOURCE_DIR}/include/geos/platform.h
+ ${PROJECT_SOURCE_DIR}/include/geos/platform.h.disabled)
set(PH_RESULT "renamed")
endif()
- message(STATUS "Disabling existing ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h - ${PH_RESULT}")
+ message(STATUS "Disabling existing ${PROJECT_SOURCE_DIR}/include/geos/platform.h - ${PH_RESULT}")
endif()
-configure_file(${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h.cmake
- ${CMAKE_CURRENT_BINARY_DIR}/include/geos/platform.h)
+message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/include/geos/platform.h")
+configure_file(${PROJECT_SOURCE_DIR}/include/geos/platform.h.cmake
+ ${PROJECT_BINARY_DIR}/include/geos/platform.h)
-configure_file(${CMAKE_CURRENT_SOURCE_DIR}/include/geos/version.h.in
- ${CMAKE_CURRENT_BINARY_DIR}/include/geos/version.h @ONLY)
+message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/include/geos/version.h")
+configure_file(${PROJECT_SOURCE_DIR}/include/geos/version.h.in
+ ${PROJECT_BINARY_DIR}/include/geos/version.h @ONLY)
-configure_file(${CMAKE_CURRENT_SOURCE_DIR}/capi/geos_c.h.in
- ${CMAKE_CURRENT_BINARY_DIR}/capi/geos_c.h @ONLY)
+message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/capi/geos_c.h")
+configure_file(${PROJECT_SOURCE_DIR}/capi/geos_c.h.in
+ ${PROJECT_BINARY_DIR}/capi/geos_c.h @ONLY)
# Configure tests
@@ -330,12 +332,12 @@
# Install/Uninstall
-configure_file("${CMAKE_CURRENT_SOURCE_DIR}/cmake/cmake_uninstall.cmake.in"
- "${CMAKE_CURRENT_BINARY_DIR}/cmake/cmake_uninstall.cmake"
+configure_file("${PROJECT_SOURCE_DIR}/cmake/cmake_uninstall.cmake.in"
+ "${PROJECT_BINARY_DIR}/cmake/cmake_uninstall.cmake"
IMMEDIATE @ONLY)
add_custom_target(uninstall
- "${CMAKE_COMMAND}" -P "${CMAKE_CURRENT_BINARY_DIR}/cmake/cmake_uninstall.cmake")
+ "${CMAKE_COMMAND}" -P "${PROJECT_BINARY_DIR}/cmake/cmake_uninstall.cmake")
# DEBUG settings - TODO: make a summary
More information about the geos-commits
