[geos-commits] r4098 - in trunk/src: algorithm algorithm/locate geom io noding/snapround operation/buffer operation/overlay/snap operation/overlay/validate
svn_geos at osgeo.org
Sat Oct 3 14:37:16 PDT 2015
Author: mloskot
Date: 2015-10-03 14:37:16 -0700 (Sat, 03 Oct 2015)
New Revision: 4098
trunk/src/algorithm/CGAlgorithms.cpp
trunk/src/algorithm/LineIntersector.cpp
trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp
trunk/src/geom/LineSegment.cpp
trunk/src/io/WKTWriter.cpp
trunk/src/noding/snapround/HotPixel.cpp
trunk/src/operation/buffer/BufferBuilder.cpp
trunk/src/operation/buffer/BufferOp.cpp
trunk/src/operation/overlay/snap/GeometrySnapper.cpp
trunk/src/operation/overlay/validate/OverlayResultValidator.cpp
Clean up Windows-specific extra parenthesis around std::min/std::max which worked around min/max macros causing syntax error. The workaround is no loner necessary since NOMINMAX placement has been corrected.
Modified: trunk/src/algorithm/CGAlgorithms.cpp
--- trunk/src/algorithm/CGAlgorithms.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/algorithm/CGAlgorithms.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -277,17 +277,17 @@
double s_top=(A.y-C.y)*(B.x-A.x)-(A.x-C.x)*(B.y-A.y);
double s_bot=(B.x-A.x)*(D.y-C.y)-(B.y-A.y)*(D.x-C.x);
if ((r_bot==0)||(s_bot==0)) {
- return (std::min)(distancePointLine(A,C,D),
- (std::min)(distancePointLine(B,C,D),
- (std::min)(distancePointLine(C,A,B), distancePointLine(D,A,B))));
+ return std::min(distancePointLine(A,C,D),
+ std::min(distancePointLine(B,C,D),
+ std::min(distancePointLine(C,A,B), distancePointLine(D,A,B))));
double s=s_top/s_bot;
double r=r_top/r_bot;
if ((r<0)||( r>1)||(s<0)||(s>1)) {
//no intersection
return 0.0; //intersection exists
Modified: trunk/src/algorithm/LineIntersector.cpp
--- trunk/src/algorithm/LineIntersector.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/algorithm/LineIntersector.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -127,7 +127,7 @@
// <FIX>
// hack to ensure that non-endpoints always have a non-zero distance
if (dist == 0.0 && !(p==p0)) {
- dist=(std::max)(pdx,pdy);
+ dist=std::max(pdx,pdy);
assert(!(dist == 0.0 && !(p==p0))); // Bad distance calculation
Modified: trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp
--- trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -74,8 +74,8 @@
for ( size_t i = 1, ni = pts->size(); i < ni; i++ )
geom::LineSegment * seg = new geom::LineSegment( (*pts)[ i - 1 ], (*pts)[ i ]);
- double const min = (std::min)( seg->p0.y, seg->p1.y);
- double const max = (std::max)( seg->p0.y, seg->p1.y);
+ double const min = std::min( seg->p0.y, seg->p1.y);
+ double const max = std::max( seg->p0.y, seg->p1.y);
// NOTE: seg ownership still ours
allocatedSegments.push_back(seg);
Modified: trunk/src/geom/LineSegment.cpp
--- trunk/src/geom/LineSegment.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/geom/LineSegment.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -169,10 +169,10 @@
int orient1 = algorithm::CGAlgorithms::orientationIndex(p0, p1, seg.p1);
// this handles the case where the points are L or collinear
if (orient0 >= 0 && orient1 >= 0)
- return (std::max)(orient0, orient1);
+ return std::max(orient0, orient1);
// this handles the case where the points are R or collinear
if (orient0 <= 0 && orient1 <= 0)
// points lie on opposite sides ==> indeterminate orientation
return 0;
Modified: trunk/src/io/WKTWriter.cpp
--- trunk/src/io/WKTWriter.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/io/WKTWriter.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -181,7 +181,7 @@
WKTWriter::appendGeometryTaggedText(const Geometry *geometry, int level,
Writer *writer)
- outputDimension = (std::min)( defaultOutputDimension,
+ outputDimension = std::min( defaultOutputDimension,
geometry->getCoordinateDimension() );
indent(level, writer);
Modified: trunk/src/noding/snapround/HotPixel.cpp
--- trunk/src/noding/snapround/HotPixel.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/noding/snapround/HotPixel.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -104,10 +104,10 @@
const Coordinate& p1) const
- double const segMinx = (std::min)(p0.x, p1.x);
- double const segMaxx = (std::max)(p0.x, p1.x);
- double const segMiny = (std::min)(p0.y, p1.y);
- double const segMaxy = (std::max)(p0.y, p1.y);
+ double const segMinx = std::min(p0.x, p1.x);
+ double const segMaxx = std::max(p0.x, p1.x);
+ double const segMiny = std::min(p0.y, p1.y);
+ double const segMaxy = std::max(p0.y, p1.y);
bool isOutsidePixelEnv = maxx < segMinx
|| minx > segMaxx
Modified: trunk/src/operation/buffer/BufferBuilder.cpp
--- trunk/src/operation/buffer/BufferBuilder.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/operation/buffer/BufferBuilder.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -266,7 +266,7 @@
// Let the length of the line play a factor in the distance, which is still
// going to be bounded by 98%. Take 10% of the length of the line from the buffer distance
// to try and minimize any artifacts.
- const double ptDistAllowance = (std::max)(distance - l->getLength()*0.1, distance * 0.98);
+ const double ptDistAllowance = std::max(distance - l->getLength()*0.1, distance * 0.98);
// Use 102% of the buffer width as the line-length requirement - this
// is to ensure that line segments that is length "distance" +/-
// epsilon is removed.
Modified: trunk/src/operation/buffer/BufferOp.cpp
--- trunk/src/operation/buffer/BufferOp.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/operation/buffer/BufferOp.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -66,7 +66,7 @@
double distance, int maxPrecisionDigits)
const Envelope *env=g->getEnvelopeInternal();
- double envSize=(std::max)(env->getHeight(), env->getWidth());
+ double envSize=std::max(env->getHeight(), env->getWidth());
double expandByDistance=distance > 0.0 ? distance : 0.0;
double bufEnvSize=envSize + 2 * expandByDistance;
// the smallest power of 10 greater than the buffer envelope
Modified: trunk/src/operation/overlay/snap/GeometrySnapper.cpp
--- trunk/src/operation/overlay/snap/GeometrySnapper.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/operation/overlay/snap/GeometrySnapper.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -148,7 +148,7 @@
GeometrySnapper::computeSizeBasedSnapTolerance(const geom::Geometry& g)
const Envelope* env = g.getEnvelopeInternal();
- double minDimension = (std::min)(env->getHeight(), env->getWidth());
+ double minDimension = std::min(env->getHeight(), env->getWidth());
double snapTol = minDimension * snapPrecisionFactor;
return snapTol;
@@ -184,7 +184,7 @@
GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g1,
const geom::Geometry& g2)
- return (std::min)(computeOverlaySnapTolerance(g1), computeOverlaySnapTolerance(g2));
+ return std::min(computeOverlaySnapTolerance(g1), computeOverlaySnapTolerance(g2));
/* public static */
Modified: trunk/src/operation/overlay/validate/OverlayResultValidator.cpp
--- trunk/src/operation/overlay/validate/OverlayResultValidator.cpp 2015-10-03 21:21:11 UTC (rev 4097)
+++ trunk/src/operation/overlay/validate/OverlayResultValidator.cpp 2015-10-03 21:37:16 UTC (rev 4098)
@@ -238,7 +238,7 @@
using geos::operation::overlay::snap::GeometrySnapper;
- return (std::min)(GeometrySnapper::computeSizeBasedSnapTolerance(g0),
+ return std::min(GeometrySnapper::computeSizeBasedSnapTolerance(g0),
GeometrySnapper::computeSizeBasedSnapTolerance(g1));
More information about the geos-commits
